8
7
4
5
6
1
2
3
REV.
ECO. NO
L
3809
M
N
REVISIONS
DESCRIPTION
ADD KEY SLOT IN POSITION, KEY SLOT BETWEEN
POSITIONS OPTION, OBSOLETE DWG 12896 (REPLACE
WITH DWG 11051)
DATE
BY
2/13/2018
JH
4133
ADD PIN A1, A2, B1, B2 NOTE, REMOVE KEY LOCATION
TABLE (REPLACE WITH C13556, CHANGE S1013 TO S2425) 10/25/2019
JH
4340
ADD NOTE TO P/N CODING S81 FOR GREEN PBT W/O KEY &
C14008 FOR BROWN PPS/BLACK PBT WITH MOLDED KEY, 3/31/2023
OBSOLETE DWG 13027, E_C_ _MMSD-S2167
JH
F
F
D
C
2X
A
.125 3.18
E
.370
PIN A2
(PIN B2 ON OPPOSITE SIDE)
PIN A1
(PIN B1 ON OPPOSITE SIDE)
(.025 0.64 ) DEPTH
FROM TOP OF INSULATOR
TO TOP OF PIN
E
+0.13
+.005
9.40
- .015
- 0.38
B
A
FITS EDGECARDS THAT
ACCEPT .062 1.57 PCB's
D
D
.540±.010 13.72±0.25
.250 6.35
.030 0.76
.100 2.54
.200 5.08
ROW SPACING
_ _C_ _M_ _D
E_C_ _M_ _D-S81
G_C_ _M_ _D-S2196
SECTION A-A
C
MW = .125±.025 3.18±0.64
MS = .190 .025[4.83 0.64]
MM = .560 .025[14.22 0.64]
.025 0.64
A
C
C
A
2X
PIN B1
PIN B2
.125 3.18
.200 5.08
B
B
PIN A1
PIN A2
.043 1.09 MIN
NOTES:
RECOMMENDED PCB LAYOUT
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
(COMPONENT SIDE)
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
UNLESS OTHERWISE SPECIFIED: DRAWN
DIMENSIONS ARE IN INCHES [MM]
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 700 VAC
TOLERANCES:
8. CURRENT RATING: 3 AMP
ANGULAR: 1
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
DECIMALS
10. INSULATION RESISTANCE: 5000 MEGA OHMS
.XX= .02 [.5]
.XXX= .005 [.13]
11. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
.XXXX= .0005 [.013]
12. MODIFICATION: SEE PART NUMBER CODING
RoHS COMPLIANT
CUSTOMER COPY
A
Pb
DATE
NAME
02/05/08 MNH
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
_ _C_ _M(MW,MS,MM)_-(S81, S2196)
SIZE
C
CAGE CODE
54453
SCALE: 3:1
8
7
6
5
4
3
A
MALE, EDGECARD, .100 CC
2
DWG. NO.
C11051
REV
N
SHEET 1 OF 4
1
FILE NAME: C11051, _ _C_ _M(MW,MS,MM)_-OMIT, S81, S2196, S_ _ _ _ MOLDED KEY
8
7
4
5
6
1
2
3
F
F
2X #4-40
THREADED
INSERTS
E
C
E
E
D
_ _C_ _M_ _T
E_C_ _M_ _T-S81
G_C_ _M_ _T-S2196
_ _C_ _M_ _N
E_C_ _M_ _N-S81
G_C_ _M_ _N-S2196
2X
D
.125 3.18
C
C
C
C
2X
.125 3.18
.125 3.18
B
.125 3.18
B
2X #4-40
THREADED
INSERTS
_ _C_ _M_ _Z
E_C_ _M_ _Z-S81
G_C_ _M_ _Z-S2196
_ _C_ _M_ _V
E_C_ _M_ _V-S81
G_C_ _M_ _V-S2196
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 3:1
8
7
6
5
4
3
A
2
DWG. NO.
C11051
REV
N
SHEET 2 OF 4
1
8
PART NUMBER
F
E
D
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
C04M_
C05M_
C06M_
C07M_
C08M_
C09M_
C10M_
C11M_
C12M_
C13M_
C14M_
C15M_
C16M_
C17M_
C18M_
C19M_
C20M_
C21M_
C22M_
C23M_
C24M_
C25M_
C26M_
C27M_
C28M_
C29M_
C30M_
C31M_
C32M_
C33M_
C34M_
C35M_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
7
N0. OF
POS.
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
A±.008[0.20]
4
5
6
B±.008[0.20]
C±.010[0.25]
D±.020[0.51]
*E±.020[0.51]
IN
MM
IN
MM
IN
MM
IN
MM
IN
MM
0.300
0.400
0.500
0.600
0.700
0.800
0.900
1.000
1.100
1.200
1.300
1.400
1.500
1.600
1.700
1.800
1.900
2.000
2.100
2.200
2.300
2.400
2.500
2.600
2.700
2.800
2.900
3.000
3.100
3.200
3.300
3.400
7.62
10.16
12.70
15.24
17.78
20.32
22.86
25.40
27.94
30.48
33.02
35.56
38.10
40.64
43.18
45.72
48.26
50.80
53.34
55.88
58.42
60.96
63.50
66.04
68.58
71.12
73.66
76.20
78.74
81.28
83.82
86.36
0.486
0.586
0.686
0.786
0.886
0.986
1.086
1.186
1.286
1.386
1.486
1.586
1.686
1.786
1.886
1.986
2.086
2.186
2.286
2.386
2.486
2.586
2.686
2.786
2.886
2.986
3.086
3.186
3.286
3.386
3.486
3.586
12.34
14.88
17.42
19.96
22.50
25.04
27.58
30.12
32.66
35.20
37.74
40.28
42.82
45.36
47.90
50.44
52.98
55.52
58.06
60.60
63.14
65.68
68.22
70.76
73.30
75.84
78.38
80.92
83.46
86.00
88.54
91.08
0.975
1.075
1.175
1.275
1.375
1.475
1.575
1.675
1.775
1.875
1.975
2.075
2.175
2.275
2.375
2.475
2.575
2.675
2.775
2.875
2.975
3.075
3.175
3.275
3.375
3.475
3.575
3.675
3.775
3.875
3.975
4.075
24.77
27.31
29.85
32.39
34.93
37.47
40.01
42.55
45.09
47.63
50.17
52.71
55.25
57.79
60.33
62.87
65.41
67.95
70.49
73.03
75.57
78.11
80.65
83.19
85.73
88.27
90.81
93.35
95.89
98.43
100.97
103.51
1.236
1.336
1.436
1.536
1.636
1.736
1.836
1.936
2.036
2.136
2.236
2.336
2.436
2.536
2.636
2.736
2.836
2.936
3.036
3.136
3.236
3.336
3.436
3.536
3.636
3.736
3.836
3.936
4.036
4.136
4.236
4.336
31.39
33.93
36.47
39.01
41.55
44.09
46.63
49.17
51.71
54.25
56.79
59.33
61.87
64.41
66.95
69.49
72.03
74.57
77.11
79.65
82.19
84.73
87.27
89.81
92.35
94.89
97.43
99.97
102.51
105.05
107.59
110.13
0.656
0.756
0.856
0.956
1.056
1.156
1.256
1.356
1.456
1.556
1.656
1.756
1.856
1.956
2.056
2.156
2.256
2.356
2.456
2.556
2.656
2.756
2.856
2.956
3.056
3.156
3.256
3.356
3.456
3.556
3.656
3.756
16.66
19.20
21.74
24.28
26.82
29.36
31.90
34.44
36.98
39.52
42.06
44.60
47.14
49.68
52.22
54.76
57.30
59.84
62.38
64.92
67.46
70.00
72.54
75.08
77.62
80.16
82.70
85.24
87.78
90.32
92.86
95.40
PART NUMBER
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
C36M_
C37M_
C38M_
C39M_
C40M_
C41M_
C42M_
C43M_
C44M_
C45M_
C46M_
C47M_
C48M_
C49M_
C50M_
C51M_
C52M_
C53M_
C54M_
C55M_
C56M_
C57M_
C58M_
C59M_
C60M_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_*
_*
_*
_*
_*
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
1
2
3
N0. OF
POS.
A±.008[0.20]
B±.008[0.20]
C±.010[0.25]
D±.020[0.51]
*E±.020[0.51]
IN
MM
IN
MM
IN
MM
IN
MM
IN
MM
3.500
3.600
3.700
3.800
3.900
4.000
4.100
4.200
4.300
4.400
4.500
4.600
4.700
4.800
4.900
5.000
5.100
5.200
5.300
5.400
5.500
5.600
5.700
5.800
5.900
88.90
91.44
93.98
96.52
99.06
101.60
104.14
106.68
109.22
111.76
114.30
116.84
119.38
121.92
124.46
127.00
129.54
132.08
134.62
137.16
139.70
142.24
144.78
147.32
149.86
3.686
3.786
3.886
3.986
4.086
4.186
4.286
4.386
4.486
4.586
4.686
4.786
4.886
4.986
5.086
5.186
5.286
5.386
5.486
5.586
5.686
5.786
5.886
5.986
6.086
93.62
96.16
98.70
101.24
103.78
106.32
108.86
111.40
113.94
116.48
119.02
121.56
124.10
126.64
129.18
131.72
134.26
136.80
139.34
141.88
144.42
146.96
149.50
152.04
154.58
4.175
4.275
4.375
4.475
4.575
4.675
4.775
4.875
4.975
5.075
5.175
5.275
5.375
5.475
5.575
5.675
5.775
5.875
5.975
6.075
106.05
108.59
111.13
113.67
116.21
118.75
121.29
123.83
126.37
128.91
131.45
133.99
136.53
139.07
141.61
144.15
146.69
149.23
151.77
154.31
4.436
4.536
4.636
4.736
4.836
4.936
5.036
5.136
5.236
5.336
5.436
5.536
5.636
5.736
5.836
5.936
6.036
6.136
6.236
6.336
112.67
115.21
117.75
120.29
122.83
125.37
127.91
130.45
132.99
135.53
138.07
140.61
143.15
145.69
148.23
150.77
153.31
155.85
158.39
160.93
3.856
3.956
4.056
4.156
4.256
4.356
4.456
4.556
4.656
4.756
4.856
4.956
5.056
5.156
5.256
5.356
5.456
5.556
5.656
5.756
5.856
5.956
6.056
6.156
6.256
97.94
100.48
103.02
105.56
108.10
110.64
113.18
115.72
118.26
120.80
123.34
125.88
128.42
130.96
133.50
136.04
138.58
141.12
143.66
146.20
148.74
151.28
153.82
156.36
158.90
F
E
D
*'N' MTG ONLY
PART NUMBER CODING
_ _ C _ _ M _ _ _ -S_ _ _ _
C
B
C
MATERIAL (INSULATOR/CONTACT)
MODIFICATION
E = BLUE PBT/PHOSPHOR BRONZE
OPERATING TEMP: -65°C TO +125°C
PROCESSING TEMP: WAVE/MANUAL SOLDERING ONLY
G = BLACK PA9T/PHOSPHOR BRONZE**
OPERATING TEMP: -65°C TO +150°C
PROCESSING TEMP: 260°C MAX FOR 20 SECONDS
R = BLACK PPS/PHOSPHOR BRONZE**
OPERATING TEMP:
-65°C TO +150°C ('B' OR 'C' PLATING)
-65°C TO +200°C ('M' PLATING ONLY)
Q = TAN PEEK/PHOSPHOR BRONZE**
OPERATING TEMP: -65°C TO +250°C
AVAILABLE IN OVERALL GOLD ('M' PLATING ONLY)
OMIT FOR STANDARD COLOR INSULATOR WITHOUT MOLDED KEY, EX: 'EBC22MMWD'
S81 = GREEN PBT WITHOUT MOLDED KEY (FOR MATERIAL CODE 'E' ONLY)
S2196 = WHITE PA9T WITHOUT MOLDED KEY (FOR MATERIAL CODE 'G' ONLY)
SEE DRAWING C13556 FOR S#, 'G' & 'H' DIMENSIONS FOR STANDARD COLOR WITH MOLDED KEY
SEE DRAWING C14008 FOR S#, 'G' & 'H' DIMENSIONS FOR BROWN PPS OR BLACK PBT WITH MOLDED KEY
MOUNTING STYLE
D=
N=
Z=
T=
V=
B
TERMINATION
MW = DIP SOLDER, .125[3.18] TAIL LENGTH
MS = DIP SOLDER, .190[4.93] TAIL LENGTH
MM = WIRE WRAP, .560[14.22] TAIL LENGTH
PLATING
A
FLUSH .125" DIA. CLEARANCE HOLES
NO MOUNTING EARS
FLUSH, .125" DIA. SIDE MOUNTING
FLUSH, #4-40 THREADED INSERT
FLUSH, SIDE MOUNT #4-40 THREADED INSERT
ALL PLATINGS HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
M = .000030" GOLD
.000010" GOLD OVERALL
**OR EQUIVALENT
CUSTOMER COPY
NUMBER OF POSITIONS
(CONTACTS PER ROW)
Pb
RoHS COMPLIANT
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 3:1
8
7
6
5
4
3
A
2
DWG. NO.
C11051
REV
N
SHEET 3 OF 4
1
8
7
5
6
4
1
2
3
F
F
E
E
H
G
.074±.002 1.88±0.05
MOLDED KEY IN POSITION
.036±.002 0.91±0.05
MOLDED KEY BETWEEN POSITION
D
D
('D' MOUNTING AS SHOWN FOR EXAMPLE)
C
MATING SULLINS PRODUCT SERIES:
1. STD LOW PROFILE FEMALE CONNECTORS WITH MOLDED KEY IN POSTION
2. STD HIGH PROFILE FEMALE CONNECTORS WITH MOLDED KEY IN POSITION
C
1. STD LOW PROFILE FEMALE CONNECTORS WITH MOLDED KEY BETWEEN POSTIONS, OR WITH INBETWEEN CONTACT KEY (SULLINS P/N: PLA-K1)
2. HIGH PROFILE FEMALE CONNECTORS WITH MOLDED KEY .030" WIDE BETWEEN POSITIONS
(CONSULT FACTORY FOR PART NUMBER)
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 3:1
8
7
6
5
4
3
A
2
DWG. NO.
C11051
REV
N
SHEET 4 OF 4
1
