Dual Card Edge
.100” [2.54 mm] Contact Centers, Dual Edge
SPECIFICATIONS
Sullins Dual Edge
Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board, both sides
PBT or PPS
3 Amps current rating for one contact energized
30 milli Ohms maximum at rated current
READOUT
UL Flammability Rating: 94V-0
.370” [9.40]
.415” [10.54]
.265” [6.73]
.265” [6.73]
.415” [10.54]
CROSS SECTION
MOUNTING STYLE
D
C
2X Ø .125” [3.18] THRU.
NO MOUNTING EARS (N)
FLUSH MOUNTING (D)
D
2X #4-40 THREADED INSERT
4X Ø .125” [3.18] THRU.
STRADDLE MOUNT (Q)
38
THREADED INSERT (I)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Dual Card Edge
PART NUMBER OPTIONS
E
A C 50 F SL Q - Sxxx
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
H = PBT/Beryllium Copper
A = PPS/Beryllium Copper
Refer to Page 7 for Operating/Processing Temperatures
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
A = .000030” Gold, both ends
Sullins Dual Edge
MOUNTING STYLE (Opposite Page)
Q = Straddle Mount
D = Flush Mounting
I = Threaded Insert
N = No Mounting
TERMINATION TYPE (Opposite Page)
SL = Single Level
CONTACT CENTERS
C = .100” [2.54 mm]
NUMBER OF CONTACT POSITIONS
See Chart Below (Contacts per Row)
READOUT (Opposite Page)
F = Dual Edge
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
E
D
C
.150 [3.81]
B
A
.425 [10.80]
1.220 ±.010
[30.99 ±0.25]
.068 [1.72]
.100 [2.54]
.075 [1.91]
BOTH SIDES
4X Ø.125 [3.18]
_ AC _ _ FSLQ
POSITIONS/
CONTACTS
05/10
06/12
07/14
10/20
12/24
13/26
15/30
16/32
17/34
18/36
20/40
22/44
23/46
24/48
25/50
26/52
28/56
30/60
31/62
34/68
35/70
36/72
40/80
43/86
44/88
50/100
60/120
A±.008[0.20]
in
0.400
0.500
0.600
0.900
1.100
1.200
1.400
1.500
1.600
1.700
1.900
2.100
2.200
2.300
2.400
2.500
2.700
2.900
3.000
3.300
3.400
3.500
3.900
4.200
4.300
4.900
5.900
mm
10.16
12.70
15.24
22.86
27.94
30.48
35.56
38.10
40.64
43.18
48.26
53.34
55.88
58.42
60.96
63.50
68.58
73.66
76.20
83.82
86.36
88.90
99.06
106.68
109.22
124.46
149.86
VIEW BOTH TOP AND BOTTOM SIDE
B±.008[0.20]
in
0.600
0.700
0.800
1.100
1.300
1.400
1.600
1.700
1.800
1.900
2.100
2.300
2.400
2.500
2.600
2.700
2.900
3.100
3.200
3.500
3.600
3.700
4.100
4.400
4.500
5.100
6.100
mm
15.24
17.78
20.32
27.94
33.02
35.56
40.64
43.18
45.72
48.26
53.34
58.42
60.96
63.50
66.04
68.58
73.66
78.74
81.28
88.90
91.44
93.98
104.14
111.76
114.30
129.54
154.94
C±.015[0.38]
in
0.756
0.856
0.956
1.256
1.456
1.556
1.756
1.856
1.956
2.056
2.256
2.456
2.556
2.656
2.756
2.856
3.056
3.256
3.356
3.656
3.756
3.856
4.256
4.556
4.656
5.256
6.256
mm
19.20
21.74
24.28
31.90
36.98
39.52
44.60
47.14
49.68
52.22
57.30
62.38
64.92
67.46
70.00
72.54
77.62
82.70
85.24
92.86
95.40
97.94
108.10
115.72
118.26
133.50
158.90
D±.010[0.25]
in
1.075
1.175
1.275
1.575
1.775
1.875
2.075
2.175
2.275
2.375
2.575
2.775
2.875
2.975
3.075
3.175
3.375
3.575
3.675
3.975
4.075
4.175
4.575
4.875
4.975
5.575
E±.020[0.25]
mm
in
27.31
1.335
29.85
1.435
32.39
1.535
40.01
1.835
45.09
2.035
47.63
2.135
52.71
2.335
55.25
2.435
57.79
2.535
60.33
2.635
65.41
2.835
70.49
3.035
73.03
3.135
75.57
3.235
78.11
3.335
80.65
3.435
85.73
3.635
90.81
3.835
93.35
3.935
100.97
4.235
103.51
4.335
106.05
4.435
116.21
4.835
123.83
5.135
126.37
5.235
141.61
5.835
‘N’ MOUNTING ONLY
mm
33.91
36.45
38.99
46.61
51.69
54.23
59.31
61.85
64.39
66.93
72.01
77.09
79.63
82.17
84.71
87.25
92.33
97.41
99.95
107.57
110.11
112.65
122.81
130.43
132.97
148.21
39
很抱歉,暂时无法提供与“EAC15FSLN”相匹配的价格&库存,您可以联系我们找货
