8
7
5
6
4
1
2
3
REVISIONS
F
E
D
B
A
ECO. NO
DESCRIPTION
DATE
BY
J
4408
ADD POSITIONS 02, 03, 14
7/29/2021
PL
K
4550
ADD POSITION 64, X' MATERIAL
8/22/2022
JH
L
4762
ADD C14008 TO P/N CODING & 24 POSITION
1/23/2024
JH
.075[1.90]
SEE NOTE 13
E
2X
REV.
.125 3.18
THRU
F
E
F
C
.030 0.76
A
.265 6.73
INSERTION
DEPTH
.431 10.95
.245 6.22
D
D
.025 0.64
FITS
.043[1.09] MIN HOLE
A
C
.100 2.54
D
A
.200±.025 5.08±0.64
TAIL LENGTH
.140 3.56
ROW SPACING
.100 2.54
_ _ C _ _ DRTH
_ _ C _ _ DRTH-S38, S81, S328
SECTION A - A
2X .125 3.18
OPTIONAL FOR
H, I, OR F MOUNTING
C
CONTACT MARKING:
B 1 2 3 ... 60 B
A 1 2 3 ... 60 A
.140 3.56
.043 1.09 MIN
PCB LAYOUT RECOMMENDED
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 700 VAC
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE
16. MODIFICATION: SEE PART NUMBER CODING
8
7
6
5
CONTACT ID
SCALE 4 : 1
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
01/25/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
_ _C_ _DRT_ (-S38, S81, S328)
SIZE
C
CAGE CODE
54453
SCALE: 3:1
4
3
A
EDGECARD, .100 CC LP
2
DWG. NO.
C10878
REV
L
SHEET 1 OF 3
1
FILE NAME: C10878, _ _C_ _DRT_ -OMIT, S38, S81, S328, S_ _ _ _ MOLDED KEY
8
7
4
5
6
1
2
3
F
F
C
2X
D
.125 3.18
THRU
.135 3.43
E
E
_ _ C _ _ DRTS
_ _ C _ _ DRTS-S38, S81, S328
_ _ C _ _ DRTN
_ _ C _ _ DRTN-S38, S81, S328
D
2X #4-40
THREADED
INSERTS
D
D
2X FLOATING BOBBIN
.116 2.95 CLEARANCE
FOR #4 SCREW
D
.280 7.11
_ _ C _ _ DRTF
_ _ C _ _ DRTF-S38, S81, S328
_ _ C _ _ DRTI
_ _ C _ _ DRTI-S38, S81, S328
C
C
A
2X .065 1.65
B
B
L .015[0.38]
(L = DIM 'A' + .130[3.30])
CUSTOMER COPY
Pb
A
_ _ C _ _ DRTB
_ _ C _ _ DRTB-S38, S81, S328
RoHS COMPLIANT
01/25/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
8
7
6
5
4
3
A
2
DWG. NO.
C10878
REV
L
SHEET 2 OF 3
1
8
F
E
D
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
PART
NUMBER
_ C02DRT
_ C03DRT
_ C04DRT
_ C05DRT
_ C06DRT
_ C07DRT
_ C08DRT
_ C10DRT
_ C12DRT
_ C13DRT
_ C14DRT
_ C15DRT
_ C17DRT
_ C18DRT
_ C19DRT
_ C20DRT
_ C22DRT
_ C23DRT
_ C24DRT
_ C25DRT
_ C26DRT
_ C28DRT
_ C30DRT
_ C31DRT
_ C32DRT
_ C35DRT
_ C36DRT
_ C40DRT
_ C43DRT
_ C44DRT
_ C49DRT
_ C50DRT
_ C52DRT
_ C60DRT
_ C64DRT
_ C65DRT
7
NO. OF
POS.
2
3
4
5
6
7
8
10
12
13
14
15
17
18
19
23
24
25
26
28
30
31
32
35
36
40
43
44
49
50
52
60
64
65
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
A±.008[0.20]
IN
MM
0.100
2.54
0.200
5.08
0.300
7.62
0.400 10.16
0.500 12.70
0.600 15.24
0.700 17.78
0.900 22.86
1.100 27.94
1.200 30.48
1.300 33.02
1.400 35.56
1.600 40.64
1.700 43.18
1.800 45.72
1.900 48.26
2.100 53.34
2.200 55.88
2.300 58.42
2.400 60.96
2.500 63.50
2.700 68.58
2.900 73.66
3.000 76.20
3.100 78.74
3.400 86.36
3.500 88.90
3.900 99.06
4.200 106.68
4.300 109.22
4.800 121.92
4.900 124.46
5.100 129.54
5.900 149.86
6.300 160.02
6.400 162.56
C±.015[0.38]
IN
MM
0.475
12.07
0.575
14.61
0.675
17.15
0.775
19.69
0.875
22.23
0.975
24.77
1.075
27.31
1.275
32.39
1.475
37.47
1.575
40.01
1.675
42.55
1.775
45.09
1.975
50.17
2.075
52.71
2.175
55.25
2.275
57.79
2.475
62.87
2.575
65.41
2.675
67.95
2.775
70.49
2.875
73.03
3.075
78.11
3.275
83.19
3.375
85.73
3.475
88.27
3.775
95.89
3.875
98.43
4.275 108.59
4.575 116.21
4.675 118.75
5.175 131.45
5.275 133.99
5.475 139.07
6.275 159.39
6.675 169.55
6.775 172.09
4
5
6
B±.008[0.20]
IN
MM
0.300
7.62
0.400
10.16
0.500
12.70
0.600
15.24
0.700
17.78
0.800
20.32
0.900
22.86
1.100
27.94
1.300
33.02
1.400
35.56
1.500
38.10
1.600
40.64
1.800
45.72
1.900
48.26
2.000
50.80
2.100
53.34
2.300
58.42
2.400
60.96
2.500
63.50
2.600
66.04
2.700
68.58
2.900
73.66
3.100
78.74
3.200
81.28
3.300
83.82
3.600
91.44
3.700
93.98
4.100 104.14
4.400 111.76
4.500 114.30
5.000 127.00
5.100 129.54
5.300 134.62
6.100 154.94
6.500 165.10
6.600 167.64
D±.010[0.25]
IN
MM
0.775
19.69
0.875
22.23
0.975
24.77
1.075
27.31
1.175
29.85
1.275
32.39
1.375
34.93
1.575
40.01
1.775
45.09
1.875
47.63
1.975
50.17
2.075
52.71
2.275
57.79
2.375
60.33
2.475
62.87
2.575
65.41
2.775
70.49
2.875
73.03
2.975
75.57
3.075
78.11
3.175
80.65
3.375
85.73
3.575
90.81
3.675
93.35
3.775
95.89
4.075
103.51
4.175
106.05
4.575
116.21
4.875
123.83
4.975
126.37
5.475
139.07
5.575
141.61
5.775
146.69
6.575
167.01
6.975
177.17
7.075
179.71
E±.020[0.51]
IN
MM
1.075
27.31
1.175
29.85
1.275
32.39
1.375
34.93
1.475
37.47
1.575
40.01
1.675
42.55
1.875
47.63
2.075
52.71
2.175
55.25
2.275
57.79
2.375
60.33
2.575
65.41
2.675
67.95
2.775
70.49
2.875
73.03
3.075
78.11
3.175
80.65
3.275
83.19
3.375
85.73
3.475
88.27
3.675
93.35
3.875
98.43
3.975 100.97
4.075 103.51
4.375 111.13
4.475 113.67
4.875 123.83
5.175 131.45
5.275 133.99
5.775 146.69
5.875 149.23
6.075 154.31
6.875 174.63
7.275 184.79
7.375 187.33
KEY IN POSITION
B
A
MATERIAL (INSULATOR/CONTACT)
E = BLUE PBT/PHOSPHOR BRONZE
OPERATING TEMP: -65°C TO +125°C
PROCESSING TEMP: WAVE/MANUAL SOLDERING ONLY
R = GREEN PPS/PHOSPHOR BRONZE
PROCESSING TEMP: 260°C MAX FOR 20 SECONDS
G = BLACK PA9T/PHOSPHOR BRONZE
H = BLUE PBT/BERYLLIUM COPPER
A = GREEN PPS/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +150°C
J = BLACK PA9T/BERYLLIUM COPPER
F = GREEN PPS/SPINODAL (CONSULT FACTORY)
OPERATING TEMP: -65°C TO +200°C
AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE)
(CONSULT FACTORY FOR SPECIAL SOLDERING REQUIREMENTS)
C = GREEN PPS/BERYLLIUM NICKEL (CONSULT FACTORY)
W = TAN PEEK/BERYLLIUM NICKEL (CONSULT FACTORY)
AVAILABLE IN OVERALL GOLD ONLY (M PLATING CODE)
OPERATING TEMP: -65°C TO +250°C
0.330
8.38
G
E
('H' MOUNTING AS SHOWN FOR EXAMPLE)
D
0.400
10.16
KEY BETWEEN POSITIONS
.030±.002 0.76±0.05
MODIFICATION
OMIT = STANDARD WITHOUT MOLDED KEY, EX: 'EBC22DRTH'
S38 = BLACK PBT WITHOUT MOLDED KEY (MATERIAL CODES E & H ONLY)
S81 = GREEN PBT WITHOUT MOLDED KEY (MATERIAL CODES E & H ONLY)
S328 = BROWN PPS WITHOUT MOLDED KEY (MATERIAL CODES R, A, F, AND C ONLY)
SEE KEY LOCATION DRAWINGS FOR MODIFICATION NUMBER (S#), 'G' AND 'H' DIMENSION:
DRAWING C13556 FOR STANDARD COLOR
DRAWING C14008 FOR NON-STANDARD COLOR
C
H
MOUNTING STYLE
H = .125" DIA. CLEARANCE HOLES
I = #4-40 THREADED INSERT
S = .125" DIA. SIDE MOUNTING
N = NO MOUNTING EARS
F = FLOATING BOBBIN
B = OPEN CARDSLOT
B
NUMBER OF POSITIONS
(CONTACTS PER ROW)
PLATING
ALL PLATINGS HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
G = .000010" GOLD
.000005" GOLD
Y = .000030" GOLD
.000005" GOLD
*E = .000100" PURE TIN, MATTE OVERALL
S = .000010" GOLD OVERALL
M = .000030" GOLD
*OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES E, R, AND G
CUSTOMER COPY
Pb
RoHS COMPLIANT
01/25/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
7
6
5
4
3
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2.5:1
8
F
.070±.002 1.78±0.05
PART NUMBER CODING
_ _ C _ _ DRT _ -S_ _ _ _
C
1
2
3
F+.005/-.015[+0.13/-0.38]
IN
MM
2
DWG. NO.
C10878
REV
L
SHEET 3 OF 3
1
