8
7
4
5
6
REVISIONS
MATERIAL (INSULATOR/CONTACT)
F
E
MOUNTING STYLE
R = BLACK, PPS/PHOSPHOR BRONZE
OPERATING TEMP: -65°C TO +125°C
PROCESSING TEMP: 260°C MAX FOR 20 SECONDS
G = BLACK, PA9T/PHOSPHOR BRONZE
A = BLACK, PPS/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +150°C
J = BLACK, PA9T/BERYLLIUM COPPER
*F = BLACK, PPS/SPINODAL
OPERATING TEMP: -65°C TO +200°C
(CONSULT FACTORY FOR SPECIAL SOLDERING GUIDELINES)
*AVAILABLE IN 'M' PLATING ONLY
NUMBER OF POSITIONS
(CONTACTS PER ROW)
D=
N=
T=
Q=
FLUSH MOUNTING (PAGE 1)
NO MOUNTING EARS (PAGE 2)
FLUSH MOUNTING, WITH THREADED INSERTS (PAGE 2)
STRADDLE MOUNT (PAGE 2)
REV.
ECO. NO
DESCRIPTION
DATE
BY
F
4614
ADD 'X' MATERIAL, INCREASE CONTACT SURFACE
RADIUS BIGGER
1/5/2023
JH
H
4626
UPDATE NOTE 11 (WAS '500 CYCLES'), UPDATE
NOTE 8 (REMOVE 'PER CONTACT')
2/9/2023
MM
J
4668
REMOVE 'X' MATERIAL
5/11/2023
JH
F
PLATING
ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
M = .000030" GOLD
.000010" GOLD OVERALL
E
E
D
B
A
1ST
POSITION
INDICATOR
D
2X
1
2
3
PART NUMBER CODING
_ _ B _ _ DYR _
.125 3.18 THRU
.075 1.91
SEE NOTE 13
D
.050 1.27
C
.370
.029 0.74
A
+.005
+0.13
9.40
- .015
- 0.38
.300 7.62
INSERTION
DEPTH
C
.610 15.49
C
.144 3.66
.250 6.35
.060 1.52
.016 0.41
_ _B_ _DYRD
B
A
.050 1.28
ACCEPTS .062" PCB
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 300 VAC
8. CURRENT RATING: 1 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 5000 CYCLES MINIMUM
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03
15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE
8
7
6
5
.175±.020 4.45±0.51
SECTION A-A
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
01/06/10 TT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
4
3
2
A
EDGECARD, .050" CC, HP
_ _B_ _DYR_
DWG. NO.
C11421
REV
J
SHEET 1 OF 3
1
FILE NAME: C11421, _ _B_ _DYR_, CARD EXT. STD ASSY
8
7
4
5
6
1
2
3
2X #4-40
THREADED
INSERTS
D
F
F
C
E
E
_ _B_ _DYRT
_ _B_ _DYRN
D
D
2X
+.010
+0.25
.078 - .000 1.98 0
.128 3.25
C
2X .188 4.78
2X.126 3.20
F
A
2X .062 1.57
.230 5.84
2X .128 3.25
.800±.010 20.32±0.25
.050 1.27
C
C
.250 6.35
PCB LAYOUT RECOMMENDED
(FOR _ _B_ _DYRQ)
F
2X
.081 2.06
.070 1.78
_ _B_ _DYRQ
(C-.020[0.51]) MAX
NOT REQ'D FOR 'N' MOUNTING
B
B
(FOR _ _B-DYRN, _ _B_ _DYRD OR _ _B_ _DYRT)
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
01/06/10 TT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
8
7
6
5
4
3
2
A
_ _B_ _DYR_
DWG. NO.
C11421
REV
J
SHEET 2 OF 3
1
8
PART NUMBER
F
E
D
C
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_B05DYR_
_B06DYR_
_B07DYR_
_B08DYR_
_B09DYR_
_B10DYR_
_B11DYR_
_B12DYR_
_B13DYR_
_B14DYR_
_B15DYR_
_B16DYR_
_B17DYR_
_B18DYR_
_B19DYR_
_B20DYR_
_B21DYR_
_B22DYR_
_B23DYR_
_B24DYR_
_B25DYR_
_B26DYR_
_B27DYR_
_B28DYR_
_B29DYR_
_B30DYR_
_B31DYR_
_B32DYR_
_B33DYR_
_B34DYR_
_B35DYR_
_B36DYR_
_B37DYR_
_B38DYR_
_B39DYR_
_B40DYR_
_B41DYR_
_B42DYR_
_B43DYR_
_B44DYR_
_B45DYR_
_B46DYR_
_B47DYR_
_B48DYR_
_B49DYR_
_B50DYR_
_B51DYR_
_B52DYR_
_B53DYR_
_B54DYR_
_B55DYR_
_B56DYR_
_B57DYR_
_B58DYR_
_B59DYR_
_B60DYR_
_B61DYR_
_B62DYR_
NO OF
POS.
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
7
A±.005[0.13]
IN
MM
0.200
5.08
0.250
6.35
0.300
7.62
0.350
8.89
0.400
10.16
0.450
11.43
0.500
12.7
0.550
13.97
0.600
15.24
0.650
16.51
0.700
17.78
0.750
19.05
0.800
20.32
0.850
21.59
0.900
22.86
0.950
24.13
1.000
25.4
1.050
26.67
1.100
27.94
1.150
29.21
1.200
30.48
1.250
31.75
1.300
33.02
1.350
34.29
1.400
35.56
1.450
36.83
1.500
38.1
1.550
39.37
1.600
40.64
1.650
41.91
1.700
43.18
1.750
44.45
1.800
45.72
1.850
46.99
1.900
48.26
1.950
49.53
2.000
50.8
2.050
52.07
2.100
53.34
2.150
54.61
2.200
55.88
2.250
57.15
2.300
58.42
2.350
59.69
2.400
60.96
2.450
62.23
2.500
63.5
2.550
64.77
2.600
66.04
2.650
67.31
2.700
68.58
2.750
69.85
2.800
71.12
2.850
72.39
2.900
73.66
2.950
74.93
3.000
76.2
3.050
77.47
B±.005[0.13]
IN
MM
0.300
7.62
0.350
8.89
0.400
10.16
0.450
11.43
0.500
12.70
0.550
13.97
0.600
15.24
0.650
16.51
0.700
17.78
0.750
19.05
0.800
20.32
0.850
21.59
0.900
22.86
0.950
24.13
1.000
25.40
1.050
26.67
1.100
27.94
1.150
29.21
1.200
30.48
1.250
31.75
1.300
33.02
1.350
34.29
1.400
35.56
1.450
36.83
1.500
38.10
1.550
39.37
1.600
40.64
1.650
41.91
1.700
43.18
1.750
44.45
1.800
45.72
1.850
46.99
1.900
48.26
1.950
49.53
2.000
50.80
2.050
52.07
2.100
53.34
2.150
54.61
2.200
55.88
2.250
57.15
2.300
58.42
2.350
59.69
2.400
60.96
2.450
62.23
2.500
63.50
2.550
64.77
2.600
66.04
2.650
67.31
2.700
68.58
2.750
69.85
2.800
71.12
2.850
72.39
2.900
73.66
2.950
74.93
3.000
76.20
3.050
77.47
3.100
78.74
3.150
80.01
4
5
6
C±.015[0.38]
IN
MM
0.490
12.45
0.540
13.72
0.590
14.99
0.640
16.26
0.690
17.53
0.740
18.80
0.790
20.07
0.840
21.34
0.890
22.61
0.940
23.88
0.990
25.15
1.040
26.42
1.090
27.69
1.140
28.96
1.190
30.23
1.240
31.50
1.290
32.77
1.340
34.04
1.390
35.31
1.440
36.58
1.490
37.85
1.540
39.12
1.590
40.39
1.640
41.66
1.690
42.93
1.740
44.20
1.790
45.47
1.840
46.74
1.890
48.01
1.940
49.28
1.990
50.55
2.040
51.82
2.090
53.09
2.140
54.36
2.190
55.63
2.240
56.90
2.290
58.17
2.340
59.44
2.390
60.71
2.440
61.98
2.490
63.25
2.540
64.52
2.590
65.79
2.640
67.06
2.690
68.33
2.740
69.60
2.790
70.87
2.840
72.14
2.890
73.41
2.940
74.68
2.990
75.95
3.040
77.22
3.090
78.49
3.140
79.76
3.190
81.03
3.240
82.30
3.290
83.57
3.340
84.84
D±.010[0.25]
IN
MM
0.776
19.71
0.826
20.98
0.876
22.25
0.926
23.52
0.976
24.79
1.026
26.06
1.076
27.33
1.126
28.60
1.176
29.87
1.226
31.14
1.276
32.41
1.326
33.68
1.376
34.95
1.426
36.22
1.476
37.49
1.526
38.76
1.576
40.03
1.626
41.30
1.676
42.57
1.726
43.84
1.776
45.11
1.826
46.38
1.876
47.65
1.926
48.92
1.976
50.19
2.026
51.46
2.076
52.73
2.126
54.00
2.176
55.27
2.226
56.54
2.276
57.81
2.326
59.08
2.376
60.35
2.426
61.62
2.476
62.89
2.526
64.16
2.576
65.43
2.626
66.70
2.676
67.97
2.726
69.24
2.776
70.51
2.826
71.78
2.876
73.05
2.926
74.32
2.976
75.59
3.026
76.86
3.076
78.13
3.126
79.40
3.176
80.67
3.226
81.94
3.276
83.21
3.326
84.48
3.376
85.75
3.426
87.02
3.476
88.29
3.526
89.56
3.576
90.83
3.626
92.10
E±.020[0.51]
IN
MM
1.090
27.69
1.140
28.96
1.190
30.23
1.240
31.50
1.290
32.77
1.340
34.04
1.390
35.31
1.440
36.58
1.490
37.85
1.540
39.12
1.590
40.39
1.640
41.66
1.690
42.93
1.740
44.20
1.790
45.47
1.840
46.74
1.890
48.01
1.940
49.28
1.990
50.55
2.040
51.82
2.090
53.09
2.140
54.36
2.190
55.63
2.240
56.90
2.290
58.17
2.340
59.44
2.390
60.71
2.440
61.98
2.490
63.25
2.540
64.52
2.590
65.79
2.640
67.06
2.690
68.33
2.740
69.60
2.790
70.87
2.840
72.14
2.890
73.41
2.940
74.68
2.990
75.95
3.040
77.22
3.090
78.49
3.140
79.76
3.190
81.03
3.240
82.30
3.290
83.57
3.340
84.84
3.390
86.11
3.440
87.38
3.490
88.65
3.540
89.92
3.590
91.19
3.640
92.46
3.690
93.73
3.740
95.00
3.790
96.27
3.840
97.54
3.890
98.81
3.940
100.08
F±.010[0.25]
IN
MM
0.614
15.60
0.664
16.87
0.714
18.14
0.764
19.41
0.814
20.68
0.864
21.95
0.914
23.22
0.964
24.49
1.014
25.76
1.064
27.03
1.114
28.30
1.164
29.57
1.214
30.84
1.264
32.11
1.314
33.38
1.364
34.65
1.414
35.92
1.464
37.19
1.514
38.46
1.564
39.73
1.614
41.00
1.664
42.27
1.714
43.54
1.764
44.81
1.814
46.08
1.864
47.35
1.914
48.62
1.964
49.89
2.014
51.16
2.064
52.43
2.114
53.70
2.164
54.97
2.214
56.24
2.264
57.51
2.314
58.78
2.364
60.05
2.414
61.32
2.464
62.59
2.514
63.86
2.564
65.13
2.614
66.40
2.664
67.67
2.714
68.94
2.764
70.21
2.814
71.48
2.864
72.75
2.914
74.02
2.964
75.29
3.014
76.56
3.064
77.83
3.114
79.10
3.164
80.37
3.214
81.64
3.264
82.91
3.314
84.18
3.364
85.45
3.414
86.72
3.464
87.99
PART NUMBER
_ _B63DYR_
_ _B64DYR_
_ _B65DYR_
_ _B66DYR_
_ _B67DYR_
_ _B68DYR_
_ _B69DYR_
_ _B70DYR_
_ _B71DYR_
_ _B72DYR_
_ _B73DYR_
_ _B74DYR_
_ _B75DYR_
_ _B76DYR_
_ _B77DYR_
_ _B78DYR_
_ _B79DYR_
_ _B80DYR_
_ _B81DYR_
_ _B82DYR_
_ _B83DYR_
_ _B84DYR_
_ _B85DYR_
_ _B86DYR_
_ _B87DYR_
_ _B88DYR_
_ _B89DYR_
_ _B90DYR_
_ _B91DYR_
_ _B92DYR_
_ _B93DYR_
_ _B94DYR_
_ _B95DYR_
_ _B96DYR_
_ _B97DYR_
_ _B98DYR_
_ _B99DYR_
_ _B100DYR_
_ _B101DYR_
_ _B102DYR_
_ _B103DYR_
_ _B104DYR_
_ _B105DYR_
_ _B106DYR_
_ _B107DYR_
_ _B108DYR_
_ _B109DYR_
_ _B110DYR_
_ _B111DYR_
_ _B112DYR_
_ _B113DYR_
_ _B114DYR_
_ _B115DYR_
_ _B116DYR_
_ _B117DYR_
_ _B118DYR_
_ _B119DYR_
_ _B120DYR_
A±.005[0.13]
IN
MM
3.100
78.74
3.150
80.01
3.200
81.28
3.250
82.55
3.300
83.82
3.350
85.09
3.400
86.36
3.450
87.63
3.500
88.90
3.550
90.17
3.600
91.44
3.650
92.71
3.700
93.98
3.750
95.25
3.800
96.52
3.850
97.79
3.900
99.06
3.950
100.33
4.000
101.60
4.050
102.87
4.100
104.14
4.150
105.41
4.200
106.68
4.250
107.95
4.300
109.22
4.350
110.49
4.400
111.76
4.450
113.03
4.500
114.30
4.550
115.57
4.600
116.84
4.650
118.11
4.700
119.38
4.750
120.65
4.800
121.92
4.850
123.19
4.900
124.46
4.950
125.73
5.000
127.00
5.050
128.27
5.100
129.54
5.150
130.81
5.200
132.08
5.250
133.35
5.300
134.62
5.350
135.89
5.400
137.16
5.450
138.43
5.500
139.70
5.550
140.97
5.600
142.24
5.650
143.51
5.700
144.78
5.750
146.05
5.800
147.32
5.850
148.59
5.900
149.86
5.950
151.13
1
2
3
NO OF
POS.
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
B±.005[0.13]
IN
MM
3.200
81.28
3.250
82.55
3.300
83.82
3.350
85.09
3.400
86.36
3.450
87.63
3.500
88.90
3.550
90.17
3.600
91.44
3.650
92.71
3.700
93.98
3.750
95.25
3.800
96.52
3.850
97.79
3.900
99.06
3.950
100.33
4.000
101.60
4.050
102.87
4.100
104.14
4.150
105.41
4.200
106.68
4.250
107.95
4.300
109.22
4.350
110.49
4.400
111.76
4.450
113.03
4.500
114.30
4.550
115.57
4.600
116.84
4.650
118.11
4.700
119.38
4.750
120.65
4.800
121.92
4.850
123.19
4.900
124.46
4.950
125.73
5.000
127.00
5.050
128.27
5.100
129.54
5.150
130.81
5.200
132.08
5.250
133.35
5.300
134.62
5.350
135.89
5.400
137.16
5.450
138.43
5.500
139.70
5.550
140.97
5.600
142.24
5.650
143.51
5.700
144.78
5.750
146.05
5.800
147.32
5.850
148.59
5.900
149.86
5.950
151.13
6.000
152.40
6.050
153.67
C±.015[0.38]
IN
MM
3.390
86.11
3.440
87.38
3.490
88.65
3.540
89.92
3.590
91.19
3.640
92.46
3.690
93.73
3.740
95.00
3.790
96.27
3.840
97.54
3.890
98.81
3.940
100.08
3.990
101.35
4.040
102.62
4.090
103.89
4.140
105.16
4.190
106.43
4.240
107.70
4.290
108.97
4.340
110.24
4.390
111.51
4.440
112.78
4.490
114.05
4.540
115.32
4.590
116.59
4.640
117.86
4.690
119.13
4.740
120.40
4.790
121.67
4.840
122.94
4.890
124.21
4.940
125.48
4.990
126.75
5.040
128.02
5.090
129.29
5.140
130.56
5.190
131.83
5.240
133.10
5.290
134.37
5.340
135.64
5.390
136.91
5.440
138.18
5.490
139.45
5.540
140.72
5.590
141.99
5.640
143.26
5.690
144.53
5.740
145.80
5.790
147.07
5.840
148.34
5.890
149.61
5.940
150.88
5.990
152.15
6.040
153.42
6.090
154.69
6.140
155.96
6.190
157.23
6.240
158.50
D±.010[0.25]
IN
MM
3.676
93.37
3.726
94.64
3.776
95.91
3.826
97.18
3.876
98.45
3.926
99.72
3.976
100.99
4.026
102.26
4.076
103.53
4.126
104.80
4.176
106.07
4.226
107.34
4.276
108.61
4.326
109.88
4.376
111.15
4.426
112.42
4.476
113.69
4.526
114.96
4.576
116.23
4.626
117.50
4.676
118.77
4.726
120.04
4.776
121.31
4.826
122.58
4.876
123.85
4.926
125.12
4.976
126.39
5.026
127.66
5.076
128.93
5.126
130.20
5.176
131.47
5.226
132.74
5.276
134.01
5.326
135.28
5.376
136.55
5.426
137.82
5.476
139.09
5.526
140.36
5.576
141.63
5.626
142.90
5.676
144.17
5.726
145.44
5.776
146.71
5.826
147.98
5.876
149.25
5.926
150.52
5.976
151.79
6.026
153.06
E±.020[0.51]
IN
MM
3.990
101.35
4.040
102.62
4.090
103.89
4.140
105.16
4.190
106.43
4.240
107.70
4.290
108.97
4.340
110.24
4.390
111.51
4.440
112.78
4.490
114.05
4.540
115.32
4.590
116.59
4.640
117.86
4.690
119.13
4.740
120.40
4.790
121.67
4.840
122.94
4.890
124.21
4.940
125.48
4.990
126.75
5.040
128.02
5.090
129.29
5.140
130.56
5.190
131.83
5.240
133.10
5.290
134.37
5.340
135.64
5.390
136.91
5.440
138.18
5.490
139.45
5.540
140.72
5.590
141.99
5.640
143.26
5.690
144.53
5.740
145.80
5.790
147.07
5.840
148.34
5.890
149.61
5.940
150.88
5.990
152.15
6.040
153.42
6.090
154.69
6.140
155.96
6.190
157.23
6.240
158.50
6.290
159.77
6.340
161.04
N OR R MOUNTING ONLY
F±.010[0.25]
IN
MM
3.514
89.26
3.564
90.53
3.614
91.80
3.664
93.07
3.714
94.34
3.764
95.61
3.814
96.88
3.864
98.15
3.914
99.42
3.964
100.69
4.014
101.96
4.064
103.23
4.114
104.50
4.164
105.77
4.214
107.04
4.264
108.31
4.314
109.58
4.364
110.85
4.414
112.12
4.464
113.39
4.514
114.66
4.564
115.93
4.614
117.20
4.664
118.47
4.714
119.74
4.764
121.01
4.814
122.28
4.864
123.55
4.914
124.82
4.964
126.09
5.014
127.36
5.064
128.63
5.114
129.90
5.164
131.17
5.214
132.44
5.264
133.71
5.314
134.98
5.364
136.25
5.414
137.52
5.464
138.79
5.514
140.06
5.564
141.33
5.614
142.60
5.664
143.87
5.714
145.14
5.764
146.41
5.814
147.68
5.864
148.95
5.914
150.22
5.964
151.49
6.014
152.76
6.064
154.03
6.114
155.30
6.164
156.57
6.214
157.84
6.264
159.11
6.314
160.38
6.364
161.65
F
E
D
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
01/06/10 TT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
8
7
6
5
4
3
2
A
_ _B_ _DYR_
DWG. NO.
C11421
REV
J
SHEET 3 OF 3
1
很抱歉,暂时无法提供与“GBB35DYRQ”相匹配的价格&库存,您可以联系我们找货
