8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
855
8/7/2007
VJ
B
2503
INITIAL RELEASE
UPDATE BOARD LOCK DIM 5.600 (WAS 5.626), PCB
LAYOUT, DAUGHTER CARD LAYOUT, STANDOFFS
ON BOTH ENDS, PROCESSING TIME TO 20 SEC
FOR PA9T, NOTES & DWG FORMAT
12/09/2011
JH
E
E
.625 15.88
4.925 125.10
.575 14.61
2.350 59.69
.500 12.70
(11 POSITIONS)
D
.150 3.81
FIRST
POSITION
INDICATOR
2.200 55.88
(45 POSITIONS)
.150 3.81
2.450 62.23
(50 POSITIONS)
.075 1.91
SEE NOTE 13
D
.070 1.78
2X .125 3.18
THRU
.050 1.27
.050 1.27 TYP
.288 7.32
5.450
5.550
6.026±.010
6.340±.020
138.43
140.97
153.06±0.25
161.04±0.51
+.005
+0.13
.370
9.40
- .015
- 0.38
.030±.010 0.77±0.25
A
5.740±.015 145.80±0.38
C
.300 7.62
INSERTION
DEPTH
.610 15.49
.250 6.35
.060 1.52
B
A
F
2.350 59.69
.018 0.46 X .012 [0.30]
_ _ B106DHFD - S621
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: SEE PART NUMBER CODING.
3. PLATING: SEE PART NUMBER CODING.
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING.
5. PROCESSING TEMP: SEE PART NUMBER CODING.
6. UL FLAMMABILITY RATING: 94V-0
7. DIELECTRIC WITHSTANDING VOLTAGE: 300 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 1 AMP PER CONTACT
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01
15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
16. MODIFICATION: CARD SLOT BARRIERS WITHOUT GUIDE POSTS, 11/45/50 POSITIONS (MCA).
8
A
7
6
5
SECTION A-A
C
.100±.025 2.54±0.64
TAIL LENGTH
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
12/09/2011 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
2
_ _B106DHF_-S621
CAGE CODE
54453
SCALE: 2:1
3
A
EDGECARD, .050 CC, HP
DWG. NO.
C10636
SHEET 1 OF 2
1
REV
B
FILE NAME: C10636, _ _B106DHF_-S621
8
7
4
5
6
1
2
3
F
F
5.740 145.80
5.740 145.80
5.600 142.24
_ _ B106DHFN - S621
E
2X #4-40
THREADED
INSERTS
6.026 153.06
.134 3.40
_ _ B106DHFR - S621
E
D
D
_ _ B106DHFT - S621
.150 3.81
.500 12.70
.050 1.27 TYP
.150 3.81
2.200 55.88
2.450 62.23
.040 1.02
.300 7.62 MIN
C
.084 2.13
.310 7.87
2.350 59.69
.575 14.61
.613 15.57
.200 5.08 MIN
.064 1.63
C
4.913 124.79
.500 12.70
2X .075 1.91
2X .288 7.32
2.200 55.88
2.450 62.23
.150 3.81
.185 4.70
MAX
.150 3.81
B
2X .125 3.18
FOR (D) AND (T) MTG'S
2X
.315 8.00
MIN
.040 1.02 TYP
.050 1.27
5.450 138.43
5.600 142.24
6.026 153.06
PCB LAYOUT RECOMMENDED
.096 2.44
FOR (R) MTG
A
Pb
RoHS COMPLIANT
8
7
6
5
B
4
CUSTOMER COPY
12/09/2011 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
2
_ _B106DHF_-S621
CAGE CODE
54453
SCALE: 1.5:1
3
A
DWG. NO.
C10636
SHEET 2 OF 2
1
REV
B
很抱歉,暂时无法提供与“GCB106DHRN-S621”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+188.1469010+24.37161
