8
7
4
5
6
REVISIONS
_ _ B _ _ DHF _ -S_ _ _ _
MATERIALS (INSULATOR / CONTACT)
MODIFICATION
R = BLACK PPS/PHOSPHOR BRONZE
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
D
2919
ADD CONTACT GAP DIM, TOL TO
INSULATOR WIDTH, UPDATE DWG FORMAT
2/13/2014
NC
E
4412
ADD MOLDED KEY OPTIONS
8/6/2021
PL
F
4780
ADD SMT ANGLE & REF CONTACT POINT DISTANCE
3/12/2024
JH
OMIT = WITHOUT MOLDED KEY, EX: 'RBB15DHFD'
OPERATING TEMP: -65°C TO +125°C
PROCESSING TEMP: 260°C MAX FOR 20 SECS
S# FOR MOLDED KEY
MOUNTING STYLE
D = FLUSH MOUNTING (PAGE 1)
NUMBER OF POSITIONS
(CONTACTS PER ROW)
A = BLACK PPS/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +150°C
(CONSULT FACTORY FOR OTHER MATERIALS)
F
(SEE DWG C13556 FOR S#, 'G' & 'H' DIMENSIONS)
G = BLACK PA9T/PHOSPHOR BRONZE
J = BLACK PA9T/BERYLLIUM COPPER
1
2
3
PART NUMBER CODING
N = NO MOUNTING EARS
T = FLUSH MOUNTING WITH #4-40 THREADED INSERT
R = BOARD LOCK
PLATING
ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
E
D
E
B
A
FIRST
POSITION
INDICATOR
2X
E
.075 1.91
SEE NOTE 13
.125 3.18
.050 1.27
D
.370
.030 0.76
C
.250 6.35
.610 15.49
D
.300 7.62
INSERTION
DEPTH
.134 3.40
A
+0.13
+.005
9.40
- 0.38
- .015
90°±3°
.018 0.46 X 0.12[0.30]
.010[0.25]
A
.060 1.52
C
_ _B_ _DHFD
SECTION A-A
.040 1.02
.050 1.27
.100±.025 2.54±0.64
TAIL LENGTH
C
.185 4.70 MAX
2X .125 3.18
FOR (D) AND (T) MTG'S
B
A
2X .096 2.44
NOTES:
A
FOR (R) MTG
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
F
2. CONTACT MATERIAL: SEE PART NUMBER CODING
D
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
RECOMMENDED PCB LAYOUT
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 300 VAC
8. CURRENT RATING: 1 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03
15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
RoHS COMPLIANT
16. MODIFICATION: SEE PART NUMBER CODING
Pb
8
7
6
5
4
B
.315 8.00 MIN
CUSTOMER COPY
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
4/28/2006 HT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
2
_ _B_ _DHF_-S_ _ _ _
CAGE CODE
54453
SCALE: 2:1
3
A
EDGECARD, .050 CC, HP
DWG. NO.
C10708
REV
F
SHEET 1 OF 3
1
FILE NAME: C10708, _ _B_ _DHF_-OMIT, S_ _ _ _ MOLDED KEY
8
7
4
5
6
D
1
2
3
2X #4-40
THREADED
INSERTS
F
F
.134±.015 3.40±0.38
.110 2.79
C
E
E
F (BOARD LOCK)
_ _B_ _DHFT
_ _B_ _DHFN
.026±.002 0.66±0.05
MOLDED KEY IN POSITION
D
.024±.002 0.61±0.05
MOLDED KEY BETWEEN POSITIONS
G
C
.025 0.64
_ _B_ _DHFR
D
H
C
B
B
SCALE 4:1
('D' MOUNTING AS SHOWN FOR EXAMPLE)
SCALE 4:1
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
4/28/2006 HT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
7
6
5
4
3
2
CAGE CODE
54453
SCALE: 2:1
8
A
DWG. NO.
C10708
REV
F
SHEET 2 OF 3
1
8
PART NUMBER
F
E
D
C
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_B05DHF_
_B06DHF_
_B07DHF_
_B08DHF_
_B09DHF_
_B10DHF_
_B11DHF_
_B12DHF_
_B13DHF_
_B14DHF_
_B15DHF_
_B16DHF_
_B17DHF_
_B18DHF_
_B19DHF_
_B20DHF_
_B21DHF_
_B22DHF_
_B23DHF_
_B24DHF_
_B25DHF_
_B26DHF_
_B27DHF_
_B28DHF_
_B29DHF_
_B30DHF_
_B31DHF_
_B32DHF_
_B33DHF_
_B34DHF_
_B35DHF_
_B36DHF_
_B37DHF_
_B38DHF_
_B39DHF_
_B40DHF_
_B41DHF_
_B42DHF_
_B43DHF_
_B44DHF_
_B45DHF_
_B46DHF_
_B47DHF_
_B48DHF_
_B49DHF_
_B50DHF_
_B51DHF_
_B52DHF_
_B53DHF_
_B54DHF_
_B55DHF_
_B56DHF_
_B57DHF_
_B58DHF_
_B59DHF_
_B60DHF_
_B61DHF_
_B62DHF_
_B63DHF_
7
NO OF
POS.
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
B±.005[0.13]
C±.015[0.38]
D±.010[0.25]
E±.020[0.51]
F±.010[0.25]
IN
0.200
0.250
0.300
0.350
0.400
0.450
0.500
0.550
0.600
0.650
0.700
0.750
0.800
0.850
0.900
0.950
1.000
1.050
1.100
1.150
1.200
1.250
1.300
1.350
1.400
1.450
1.500
1.550
1.600
1.650
1.700
1.750
1.800
1.850
1.900
1.950
2.000
2.050
2.100
2.150
2.200
2.250
2.300
2.350
2.400
2.450
2.500
2.550
2.600
2.650
2.700
2.750
2.800
2.850
2.900
2.950
3.000
3.050
3.100
IN
0.300
0.350
0.400
0.450
0.500
0.550
0.600
0.650
0.700
0.750
0.800
0.850
0.900
0.950
1.000
1.050
1.100
1.150
1.200
1.250
1.300
1.350
1.400
1.450
1.500
1.550
1.600
1.650
1.700
1.750
1.800
1.850
1.900
1.950
2.000
2.050
2.100
2.150
2.200
2.250
2.300
2.350
2.400
2.450
2.500
2.550
2.600
2.650
2.700
2.750
2.800
2.850
2.900
2.950
3.000
3.050
3.100
3.150
3.200
IN
0.490
0.540
0.590
0.640
0.690
0.740
0.790
0.840
0.890
0.940
0.990
1.040
1.090
1.140
1.190
1.240
1.290
1.340
1.390
1.440
1.490
1.540
1.590
1.640
1.690
1.740
1.790
1.840
1.890
1.940
1.990
2.040
2.090
2.140
2.190
2.240
2.290
2.340
2.390
2.440
2.490
2.540
2.590
2.640
2.690
2.740
2.790
2.840
2.890
2.940
2.990
3.040
3.090
3.140
3.190
3.240
3.290
3.340
3.390
IN
0.776
0.826
0.876
0.926
0.976
1.026
1.076
1.126
1.176
1.226
1.276
1.326
1.376
1.426
1.476
1.526
1.576
1.626
1.676
1.726
1.776
1.826
1.876
1.926
1.976
2.026
2.076
2.126
2.176
2.226
2.276
2.326
2.376
2.426
2.476
2.526
2.576
2.626
2.676
2.726
2.776
2.826
2.876
2.926
2.976
3.026
3.076
3.126
3.176
3.226
3.276
3.326
3.376
3.426
3.476
3.526
3.576
3.626
3.676
IN
1.090
1.140
1.190
1.240
1.290
1.340
1.390
1.440
1.490
1.540
1.590
1.640
1.690
1.740
1.790
1.840
1.890
1.940
1.990
2.040
2.090
2.140
2.190
2.240
2.290
2.340
2.390
2.440
2.490
2.540
2.590
2.640
2.690
2.740
2.790
2.840
2.890
2.940
2.990
3.040
3.090
3.140
3.190
3.240
3.290
3.340
3.390
3.440
3.490
3.540
3.590
3.640
3.690
3.740
3.790
3.840
3.890
3.940
3.990
IN
0.350
0.400
0.450
0.500
0.550
0.600
0.650
0.700
0.750
0.800
0.850
0.900
0.950
1.000
1.050
1.100
1.150
1.200
1.250
1.300
1.350
1.400
1.450
1.500
1.550
1.600
1.650
1.700
1.750
1.800
1.850
1.900
1.950
2.000
2.050
2.100
2.150
2.200
2.250
2.300
2.350
2.400
2.450
2.500
2.550
2.600
2.650
2.700
2.750
2.800
2.850
2.900
2.950
3.000
3.050
3.100
3.150
3.200
3.250
MM
5.08
6.35
7.62
8.89
10.16
11.43
12.70
13.97
15.24
16.51
17.78
19.05
20.32
21.59
22.86
24.13
25.40
26.67
27.94
29.21
30.48
31.75
33.02
34.29
35.56
36.83
38.10
39.37
40.64
41.91
43.18
44.45
45.72
46.99
48.26
49.53
50.80
52.07
53.34
54.61
55.88
57.15
58.42
59.69
60.96
62.23
63.50
64.77
66.04
67.31
68.58
69.85
71.12
72.39
73.66
74.93
76.20
77.47
78.74
WITHOUT
MOLDED KEY
B
4
5
6
A±.005[0.13]
MM
7.62
8.89
10.16
11.43
12.70
13.97
15.24
16.51
17.78
19.05
20.32
21.59
22.86
24.13
25.40
26.67
27.94
29.21
30.48
31.75
33.02
34.29
35.56
36.83
38.10
39.37
40.64
41.91
43.18
44.45
45.72
46.99
48.26
49.53
50.80
52.07
53.34
54.61
55.88
57.15
58.42
59.69
60.96
62.23
63.50
64.77
66.04
67.31
68.58
69.85
71.12
72.39
73.66
74.93
76.20
77.47
78.74
80.01
81.28
MM
12.45
13.72
14.99
16.26
17.53
18.80
20.07
21.34
22.61
23.88
25.15
26.42
27.69
28.96
30.23
31.50
32.77
34.04
35.31
36.58
37.85
39.12
40.39
41.66
42.93
44.20
45.47
46.74
48.01
49.28
50.55
51.82
53.09
54.36
55.63
56.90
58.17
59.44
60.71
61.98
63.25
64.52
65.79
67.06
68.33
69.60
70.87
72.14
73.41
74.68
75.95
77.22
78.49
79.76
81.03
82.30
83.57
84.84
86.11
MM
19.71
20.98
22.25
23.52
24.79
26.06
27.33
28.60
29.87
31.14
32.41
33.68
34.95
36.22
37.49
38.76
40.03
41.30
42.57
43.84
45.11
46.38
47.65
48.92
50.19
51.46
52.73
54.00
55.27
56.54
57.81
59.08
60.35
61.62
62.89
64.16
65.43
66.70
67.97
69.24
70.51
71.78
73.05
74.32
75.59
76.86
78.13
79.40
80.67
81.94
83.21
84.48
85.75
87.02
88.29
89.56
90.83
92.10
93.37
MM
27.69
28.96
30.23
31.50
32.77
34.04
35.31
36.58
37.85
39.12
40.39
41.66
42.93
44.20
45.47
46.74
48.01
49.28
50.55
51.82
53.09
54.36
55.63
56.90
58.17
59.44
60.71
61.98
63.25
64.52
65.79
67.06
68.33
69.60
70.87
72.14
73.41
74.68
75.95
77.22
78.49
79.76
81.03
82.30
83.57
84.84
86.11
87.38
88.65
89.92
91.19
92.46
93.73
95.00
96.27
97.54
98.81
100.08
101.35
MM
8.89
10.16
11.43
12.70
13.97
15.24
16.51
17.78
19.05
20.32
21.59
22.86
24.13
25.40
26.67
27.94
29.21
30.48
31.75
33.02
34.29
35.56
36.83
38.10
39.37
40.64
41.91
43.18
44.45
45.72
46.99
48.26
49.53
50.80
52.07
53.34
54.61
55.88
57.15
58.42
59.69
60.96
62.23
63.50
64.77
66.04
67.31
68.58
69.85
71.12
72.39
73.66
74.93
76.20
77.47
78.74
80.01
81.28
82.55
PART NUMBER
_ _B64DHF_
_ _B65DHF_
_ _B66DHF_
_ _B67DHF_
_ _B68DHF_
_ _B69DHF_
_ _B70DHF_
_ _B71DHF_
_ _B72DHF_
_ _B73DHF_
_ _B74DHF_
_ _B75DHF_
_ _B76DHF_
_ _B77DHF_
_ _B78DHF_
_ _B79DHF_
_ _B80DHF_
_ _B81DHF_
_ _B82DHF_
_ _B83DHF_
_ _B84DHF_
_ _B85DHF_
_ _B86DHF_
_ _B87DHF_
_ _B88DHF_
_ _B89DHF_
_ _B90DHF_
_ _B91DHF_
_ _B92DHF_
_ _B93DHF_
_ _B94DHF_
_ _B95DHF_
_ _B96DHF_
_ _B97DHF_
_ _B98DHF_
_ _B99DHF_
_ _B100DHF_
_ _B101DHF_
_ _B102DHF_
_ _B103DHF_
_ _B104DHF_
_ _B105DHF_
_ _B106DHF_
_ _B107DHF_
_ _B108DHF_
_ _B109DHF_
_ _B110DHF_
_ _B111DHF_
_ _B112DHF_
_ _B113DHF_
_ _B114DHF_
_ _B115DHF_
_ _B116DHF_
_ _B117DHF_
_ _B118DHF_
_ _B119DHF_
_ _B120DHF_
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
1
2
3
NO OF
POS.
A±.005[0.13]
B±.005[0.13]
C±.015[0.38]
D±.010[0.25]
IN
3.150
3.200
3.250
3.300
3.350
3.400
3.450
3.500
3.550
3.600
3.650
3.700
3.750
3.800
3.850
3.900
3.950
4.000
4.050
4.100
4.150
4.200
4.250
4.300
4.350
4.400
4.450
4.500
4.550
4.600
4.650
4.700
4.750
4.800
4.850
4.900
4.950
5.000
5.050
5.100
5.150
5.200
5.250
5.300
5.350
5.400
5.450
5.500
5.550
5.600
5.650
5.700
5.750
5.800
5.850
5.900
5.950
IN
3.250
3.300
3.350
3.400
3.450
3.500
3.550
3.600
3.650
3.700
3.750
3.800
3.850
3.900
3.950
4.000
4.050
4.100
4.150
4.200
4.250
4.300
4.350
4.400
4.450
4.500
4.550
4.600
4.650
4.700
4.750
4.800
4.850
4.900
4.950
5.000
5.050
5.100
5.150
5.200
5.250
5.300
5.350
5.400
5.450
5.500
5.550
5.600
5.650
5.700
5.750
5.800
5.850
5.900
5.950
6.000
6.050
IN
3.440
3.490
3.540
3.590
3.640
3.690
3.740
3.790
3.840
3.890
3.940
3.990
4.040
4.090
4.140
4.190
4.240
4.290
4.340
4.390
4.440
4.490
4.540
4.590
4.640
4.690
4.740
4.790
4.840
4.890
4.940
4.990
5.040
5.090
5.140
5.190
5.240
5.290
5.340
5.390
5.440
5.490
5.540
5.590
5.640
5.690
5.740
5.790
5.840
5.890
5.940
5.990
6.040
6.090
6.140
6.190
6.240
IN
MM
IN
3.726
94.64
4.040
3.776
95.91
4.090
3.826
97.18
4.140
3.876
98.45
4.190
3.926
99.72
4.240
3.976 100.99 4.290
4.026 102.26 4.340
4.076 103.53 4.390
4.126 104.80 4.440
4.176 106.07 4.490
4.226 107.34 4.540
4.276 108.61 4.590
4.326 109.88 4.640
4.376 111.15 4.690
4.426 112.42 4.740
4.476 113.69 4.790
4.526 114.96 4.840
4.576 116.23 4.890
4.626 117.50 4.940
4.676 118.77 4.990
4.726 120.04 5.040
4.776 121.31 5.090
4.826 122.58 5.140
4.876 123.85 5.190
4.926 125.12 5.240
4.976 126.39 5.290
5.026 127.66 5.340
5.076 128.93 5.390
5.126 130.20 5.440
5.176 131.47 5.490
5.226 132.74 5.540
5.276 134.01 5.590
5.326 135.28 5.640
5.376 136.55 5.690
5.426 137.82 5.740
5.476 139.09 5.790
5.526 140.36 5.840
5.576 141.63 5.890
5.626 142.90 5.940
5.676 144.17 5.990
5.726 145.44 6.040
5.776 146.71 6.090
5.826 147.98 6.140
5.876 149.25 6.190
5.926 150.52 6.240
5.976 151.79 6.290
6.026 153.06 6.340
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
'N' OR 'R' MOUNTING
MM
80.01
81.28
82.55
83.82
85.09
86.36
87.63
88.90
90.17
91.44
92.71
93.98
95.25
96.52
97.79
99.06
100.33
101.60
102.87
104.14
105.41
106.68
107.95
109.22
110.49
111.76
113.03
114.30
115.57
116.84
118.11
119.38
120.65
121.92
123.19
124.46
125.73
127.00
128.27
129.54
130.81
132.08
133.35
134.62
135.89
137.16
138.43
139.70
140.97
142.24
143.51
144.78
146.05
147.32
148.59
149.86
151.13
MM
82.55
83.82
85.09
86.36
87.63
88.90
90.17
91.44
92.71
93.98
95.25
96.52
97.79
99.06
100.33
101.60
102.87
104.14
105.41
106.68
107.95
109.22
110.49
111.76
113.03
114.30
115.57
116.84
118.11
119.38
120.65
121.92
123.19
124.46
125.73
127.00
128.27
129.54
130.81
132.08
133.35
134.62
135.89
137.16
138.43
139.70
140.97
142.24
143.51
144.78
146.05
147.32
148.59
149.86
151.13
152.40
153.67
MM
87.38
88.65
89.92
91.19
92.46
93.73
95.00
96.27
97.54
98.81
100.08
101.35
102.62
103.89
105.16
106.43
107.70
108.97
110.24
111.51
112.78
114.05
115.32
116.59
117.86
119.13
120.40
121.67
122.94
124.21
125.48
126.75
128.02
129.29
130.56
131.83
133.10
134.37
135.64
136.91
138.18
139.45
140.72
141.99
143.26
144.53
145.80
147.07
148.34
149.61
150.88
152.15
153.42
154.69
155.96
157.23
158.50
E±.020[0.51]
MM
102.62
103.89
105.16
106.43
107.70
108.97
110.24
111.51
112.78
114.05
115.32
116.59
117.86
119.13
120.40
121.67
122.94
124.21
125.48
126.75
128.02
129.29
130.56
131.83
133.10
134.37
135.64
136.91
138.18
139.45
140.72
141.99
143.26
144.53
145.80
147.07
148.34
149.61
150.88
152.15
153.42
154.69
155.96
157.23
158.50
159.77
161.04
ONLY
ONLY
ONLY
ONLY
ONLY
ONLY
ONLY
ONLY
ONLY
ONLY
F±.010[0.25]
IN
3.300
3.350
3.400
3.450
3.500
3.550
3.600
3.650
3.700
3.750
3.800
3.850
3.900
3.950
4.000
4.050
4.100
4.150
4.200
4.250
4.300
4.350
4.400
4.450
4.500
4.550
4.600
4.650
4.700
4.750
4.800
4.850
4.900
4.950
5.000
5.050
5.100
5.150
5.200
5.250
5.300
5.350
5.400
5.450
5.500
5.550
5.600
5.650
5.700
5.750
5.800
5.850
5.900
5.950
6.000
6.050
6.100
MM
83.82
85.09
86.36
87.63
88.90
90.17
91.44
92.71
93.98
95.25
96.52
97.79
99.06
100.33
101.60
102.87
104.14
105.41
106.68
107.95
109.22
110.49
111.76
113.03
114.30
115.57
116.84
118.11
119.38
120.65
121.92
123.19
124.46
125.73
127.00
128.27
129.54
130.81
132.08
133.35
134.62
135.89
137.16
138.43
139.70
140.97
142.24
143.51
144.78
146.05
147.32
148.59
149.86
151.13
152.40
153.67
154.94
WITH MOLDED
KEY BETWEEN
POSITIONS
WITH MOLDED
KEY IN
POSITION
F
E
D
C
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
4/28/2006 HT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
7
6
5
4
3
2
CAGE CODE
54453
SCALE: 3:1
8
A
DWG. NO.
C10708
REV
F
SHEET 3 OF 3
1
很抱歉,暂时无法提供与“GCB80DHFN”相匹配的价格&库存,您可以联系我们找货
