EAC43FSLN
EAC43FSLN
    SULLINS
    CONN EDGE ADAPT CARD-CARD 86POS
EAC43FSLN 数据手册
Dual Card Edge .100” [2.54 mm] Contact Centers, Dual Edge SPECIFICATIONS Sullins Dual Edge • • • • • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board, both sides PBT or PPS 3 Amps current rating for one contact energized 30 milli Ohms maximum at rated current READOUT UL Flammability Rating: 94V-0 .370” [9.40] .415” [10.54] .265” [6.73] .265” [6.73] .415” [10.54] CROSS SECTION MOUNTING STYLE D C 2X Ø .125” [3.18] THRU. NO MOUNTING EARS (N) FLUSH MOUNTING (D) D 2X #4-40 THREADED INSERT 4X Ø .125” [3.18] THRU. STRADDLE MOUNT (Q) 38 THREADED INSERT (I) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Dual Card Edge .100” [2.54 mm] Contact Centers, Dual Edge PART NUMBER OPTIONS E A C 50 F SL Q - Sxxx MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper Refer to Page 7 for Operating/Processing Temperatures MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface A = .000030” Gold, both ends Sullins Dual Edge MOUNTING STYLE (Opposite Page) Q = Straddle Mount D = Flush Mounting I = Threaded Insert N = No Mounting TERMINATION TYPE (Opposite Page) SL = Single Level CONTACT CENTERS C = .100” [2.54 mm] NUMBER OF CONTACT POSITIONS See Chart Below (Contacts per Row) READOUT (Opposite Page) F = Dual Edge DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. E D C .150 [3.81] B A .425 [10.80] 1.220 ±.010 [30.99 ±0.25] .068 [1.72] .100 [2.54] .075 [1.91] BOTH SIDES 4X Ø.125 [3.18] _ AC _ _ FSLQ POSITIONS/ CONTACTS 05/10 06/12 07/14 10/20 12/24 13/26 15/30 16/32 17/34 18/36 20/40 22/44 23/46 24/48 25/50 26/52 28/56 30/60 31/62 34/68 35/70 36/72 40/80 43/86 44/88 50/100 60/120 A±.008[0.20] in 0.400 0.500 0.600 0.900 1.100 1.200 1.400 1.500 1.600 1.700 1.900 2.100 2.200 2.300 2.400 2.500 2.700 2.900 3.000 3.300 3.400 3.500 3.900 4.200 4.300 4.900 5.900 mm 10.16 12.70 15.24 22.86 27.94 30.48 35.56 38.10 40.64 43.18 48.26 53.34 55.88 58.42 60.96 63.50 68.58 73.66 76.20 83.82 86.36 88.90 99.06 106.68 109.22 124.46 149.86 VIEW BOTH TOP AND BOTTOM SIDE B±.008[0.20] in 0.600 0.700 0.800 1.100 1.300 1.400 1.600 1.700 1.800 1.900 2.100 2.300 2.400 2.500 2.600 2.700 2.900 3.100 3.200 3.500 3.600 3.700 4.100 4.400 4.500 5.100 6.100 mm 15.24 17.78 20.32 27.94 33.02 35.56 40.64 43.18 45.72 48.26 53.34 58.42 60.96 63.50 66.04 68.58 73.66 78.74 81.28 88.90 91.44 93.98 104.14 111.76 114.30 129.54 154.94 C±.015[0.38] in 0.756 0.856 0.956 1.256 1.456 1.556 1.756 1.856 1.956 2.056 2.256 2.456 2.556 2.656 2.756 2.856 3.056 3.256 3.356 3.656 3.756 3.856 4.256 4.556 4.656 5.256 6.256 mm 19.20 21.74 24.28 31.90 36.98 39.52 44.60 47.14 49.68 52.22 57.30 62.38 64.92 67.46 70.00 72.54 77.62 82.70 85.24 92.86 95.40 97.94 108.10 115.72 118.26 133.50 158.90 D±.010[0.25] in 1.075 1.175 1.275 1.575 1.775 1.875 2.075 2.175 2.275 2.375 2.575 2.775 2.875 2.975 3.075 3.175 3.375 3.575 3.675 3.975 4.075 4.175 4.575 4.875 4.975 5.575 E±.020[0.25] mm in 27.31 1.335 29.85 1.435 32.39 1.535 40.01 1.835 45.09 2.035 47.63 2.135 52.71 2.335 55.25 2.435 57.79 2.535 60.33 2.635 65.41 2.835 70.49 3.035 73.03 3.135 75.57 3.235 78.11 3.335 80.65 3.435 85.73 3.635 90.81 3.835 93.35 3.935 100.97 4.235 103.51 4.335 106.05 4.435 116.21 4.835 123.83 5.135 126.37 5.235 141.61 5.835 ‘N’ MOUNTING ONLY mm 33.91 36.45 38.99 46.61 51.69 54.23 59.31 61.85 64.39 66.93 72.01 77.09 79.63 82.17 84.71 87.25 92.33 97.41 99.95 107.57 110.11 112.65 122.81 130.43 132.97 148.21 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 39
EAC43FSLN 价格&库存
很抱歉,暂时无法提供与“EAC43FSLN”相匹配的价格&库存,您可以联系我们找货
