8
7
4
5
6
REVISIONS
PART NUMBER CODING
_ _B_ _ DYH_-S_ _ _
MATERIAL (INSULATOR/CONTACT)
F
E
MODIFICATION
R = BLACK, PPS/PHOSPHOR BRONZE
OPERATING TEMP: -65°C TO +125°C
PROCESSING TEMP: 260°C MAX FOR 20 SECONDS
G = BLACK, PA9T/PHOSPHOR BRONZE
A = BLACK, PPS/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +150°C
J = BLACK, PA9T/BERYLLIUM COPPER
*F = BLACK, PPS/SPINODAL
OPERATING TEMP: -65°C TO +200°C
(CONSULT FACTORY FOR SPECIAL SOLDERING GUIDELINES)
*AVAILABLE IN 'M' PLATING ONLY
OMIT FOR STANDARD, EX: 'RBB15DYHD'
S# FOR MOLDED KEY
(SEE DRAWING C13556 FOR S#, 'G', & 'H' DIMENSIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
F
4614
ADD 'X' MATERIAL, INCREASE CONTACT
SURFACE RADIUS BIGGER
1/5/2023
JH
H
4626
UPDATE NOTE 11 (WAS '500 CYCLES'), UPDATE
NOTE 8 (REMOVE 'PER CONTACT')
2/8/2023
MM
J
4668
REMOVE 'X' MATERIAL
5/11/2023
JH
F
MOUNTING STYLE
NUMBER OF POSITIONS
(CONTACTS PER ROW)
PLATING
D=
N=
T=
R=
B=
FLUSH MOUNTING (PAGE 1)
NO MOUNTING EARS (PAGE 2)
FLUSH MOUNTING, WITH THREADED INSERTS (PAGE 2)
METAL BOARD LOCKS (PAGE 2)
OPEN CARD SLOT
ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
**N = .000050" GOLD
M = .000030" GOLD
.000010" GOLD OVERALL
** AVAILABLE WITH MATERIAL CODE A OR J ONLY
PIN A2
PIN A1
1ST
POSITION
INDICATOR
D
2X
1
2
3
E
E
D
B
A
D
.075 1.91
SEE NOTE 13
.125 3.18 THRU
PIN B1
PIN B2
C
.370
C
+0.13
+.005
9.40
- .015
- 0.38
.300 7.62
INSERTION
DEPTH
.029 0.74
A
.610 15.49
C
.144 3.66
.250 6.35
.060 1.52
B
A
A
.016 0.41
.050 1.27 TYP
NOTES:
_ _B_ _DYHD
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 300 VAC
8. CURRENT RATING: 1 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHM
11. DURABILITY: 5000 CYCLES MINIMUM
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03
15. WITHDRAWAL FORCE: 1/2 OZ MINIMUM PER CONTACT PAIR USING .062[1.57] TEST BLADE
16. MODIFICATION: SEE PART NUMBER CODING
3X .100 2.54
.125±.025 3.18±0.64
SECTION A-A
CUSTOMER COPY
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
06/18/10 TT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
7
6
5
4
3
A
EDGECARD, .050" CC, CANTILEVER
PART NUMBER
SIZE
C
2
_ _B_ _DYH_-S_ _ _
CAGE CODE
54453
SCALE: 2:1
8
B
DWG. NO.
C11419
REV
J
SHEET 1 OF 3
1
FILE NAME: C11419, _ _B_ _DYH_-OMIT, S_ _ _ _ MOLDED KEY
8
7
4
5
6
1
2
3
2X .037 0.94
A
F
F
L±.015[0.38]
(L = DIM 'A' + .074[.188])
C
C
2X BOARD LOCK
.134±.015 3.40±0.38
E
E
_ _B_ _DYHN
F
_ _B_ _DYHB
_ _B_ _DYHR
2X #4-40
THREADED INSERTS
D
D
D
.024±.002 0.61±0.05
MOLDED KEY BETWEEN POSITIONS
.026±.002 0.66±0.05
MOLDED KEY IN POSITION
_ _B_ _DYHT
C
.040 1.02 MIN TYP
.100 2.54 TYP
.050 1.27
PIN A1
PIN A2
H
G
C
PIN B1
PIN B2
B
3X .100 2.54
2X .125 3.18
FOR 'D' OR 'T' MOUNTING
A
F
D
B
2X .096 2.44
FOR 'R' MOUNTING
RECOMMENDED PCB LAYOUT
CUSTOMER COPY
A
Pb
S# MODIFICATION
('D' MOUNT AS SHOWN FOR EXAMPLE, SCALE 4:1)
RoHS COMPLIANT
06/18/10 TT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
7
6
5
4
3
2
_ _B_ _DYH_-S_ _ _
CAGE CODE
54453
SCALE: 2:1
8
A
DWG. NO.
C11419
REV
J
SHEET 2 OF 3
1
8
NO OF
POS.
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
PART NUMBER
F
E
D
C
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_
_B05DYH_
_B06DYH_
_B07DYH_
_B08DYH_
_B09DYH_
_B10DYH_
_B11DYH_
_B12DYH_
_B13DYH_
_B14DYH_
_B15DYH_
_B16DYH_
_B17DYH_
_B18DYH_
_B19DYH_
_B20DYH_
_B21DYH_
_B22DYH_
_B23DYH_
_B24DYH_
_B25DYH_
_B26DYH_
_B27DYH_
_B28DYH_
_B29DYH_
_B30DYH_
_B31DYH_
_B32DYH_
_B33DYH_
_B34DYH_
_B35DYH_
_B36DYH_
_B37DYH_
_B38DYH_
_B39DYH_
_B40DYH_
_B41DYH_
_B42DYH_
_B43DYH_
_B44DYH_
_B45DYH_
_B46DYH_
_B47DYH_
_B48DYH_
_B49DYH_
_B50DYH_
_B51DYH_
_B52DYH_
_B53DYH_
_B54DYH_
_B55DYH_
_B56DYH_
_B57DYH_
_B58DYH_
_B59DYH_
_B60DYH_
_B61DYH_
_B62DYH_
7
A ±.005[0.13]
IN
MM
0.200
5.08
0.250
6.35
0.300
7.62
0.350
8.89
0.400
10.16
0.450
11.43
0.500
12.7
0.550
13.97
0.600
15.24
0.650
16.51
0.700
17.78
0.750
19.05
0.800
20.32
0.850
21.59
0.900
22.86
0.950
24.13
1.000
25.4
1.050
26.67
1.100
27.94
1.150
29.21
1.200
30.48
1.250
31.75
1.300
33.02
1.350
34.29
1.400
35.56
1.450
36.83
1.500
38.1
1.550
39.37
1.600
40.64
1.650
41.91
1.700
43.18
1.750
44.45
1.800
45.72
1.850
46.99
1.900
48.26
1.950
49.53
2.000
50.8
2.050
52.07
2.100
53.34
2.150
54.61
2.200
55.88
2.250
57.15
2.300
58.42
2.350
59.69
2.400
60.96
2.450
62.23
2.500
63.5
2.550
64.77
2.600
66.04
2.650
67.31
2.700
68.58
2.750
69.85
2.800
71.12
2.850
72.39
2.900
73.66
2.950
74.93
3.000
76.2
3.050
77.47
C±.015[0.38]
IN
MM
0.490
12.45
0.540
13.72
0.590
14.99
0.640
16.26
0.690
17.53
0.740
18.80
0.790
20.07
0.840
21.34
0.890
22.61
0.940
23.88
0.990
25.15
1.040
26.42
1.090
27.69
1.140
28.96
1.190
30.23
1.240
31.50
1.290
32.77
1.340
34.04
1.390
35.31
1.440
36.58
1.490
37.85
1.540
39.12
1.590
40.39
1.640
41.66
1.690
42.93
1.740
44.20
1.790
45.47
1.840
46.74
1.890
48.01
1.940
49.28
1.990
50.55
2.040
51.82
2.090
53.09
2.140
54.36
2.190
55.63
2.240
56.90
2.290
58.17
2.340
59.44
2.390
60.71
2.440
61.98
2.490
63.25
2.540
64.52
2.590
65.79
2.640
67.06
2.690
68.33
2.740
69.60
2.790
70.87
2.840
72.14
2.890
73.41
2.940
74.68
2.990
75.95
3.040
77.22
3.090
78.49
3.140
79.76
3.190
81.03
3.240
82.30
3.290
83.57
3.340
84.84
4
5
6
B±.005[0.13]
IN
MM
0.300
7.62
0.350
8.89
0.400
10.16
0.450
11.43
0.500
12.70
0.550
13.97
0.600
15.24
0.650
16.51
0.700
17.78
0.750
19.05
0.800
20.32
0.850
21.59
0.900
22.86
0.950
24.13
1.000
25.40
1.050
26.67
1.100
27.94
1.150
29.21
1.200
30.48
1.250
31.75
1.300
33.02
1.350
34.29
1.400
35.56
1.450
36.83
1.500
38.10
1.550
39.37
1.600
40.64
1.650
41.91
1.700
43.18
1.750
44.45
1.800
45.72
1.850
46.99
1.900
48.26
1.950
49.53
2.000
50.80
2.050
52.07
2.100
53.34
2.150
54.61
2.200
55.88
2.250
57.15
2.300
58.42
2.350
59.69
2.400
60.96
2.450
62.23
2.500
63.50
2.550
64.77
2.600
66.04
2.650
67.31
2.700
68.58
2.750
69.85
2.800
71.12
2.850
72.39
2.900
73.66
2.950
74.93
3.000
76.20
3.050
77.47
3.100
78.74
3.150
80.01
D±.010[0.25]
IN
MM
0.776
19.71
0.826
20.98
0.876
22.25
0.926
23.52
0.976
24.79
1.026
26.06
1.076
27.33
1.126
28.60
1.176
29.87
1.226
31.14
1.276
32.41
1.326
33.68
1.376
34.95
1.426
36.22
1.476
37.49
1.526
38.76
1.576
40.03
1.626
41.30
1.676
42.57
1.726
43.84
1.776
45.11
1.826
46.38
1.876
47.65
1.926
48.92
1.976
50.19
2.026
51.46
2.076
52.73
2.126
54.00
2.176
55.27
2.226
56.54
2.276
57.81
2.326
59.08
2.376
60.35
2.426
61.62
2.476
62.89
2.526
64.16
2.576
65.43
2.626
66.70
2.676
67.97
2.726
69.24
2.776
70.51
2.826
71.78
2.876
73.05
2.926
74.32
2.976
75.59
3.026
76.86
3.076
78.13
3.126
79.40
3.176
80.67
3.226
81.94
3.276
83.21
3.326
84.48
3.376
85.75
3.426
87.02
3.476
88.29
3.526
89.56
3.576
90.83
3.626
92.10
E±.020[0.51]
IN
MM
1.090
27.69
1.140
28.96
1.190
30.23
1.240
31.50
1.290
32.77
1.340
34.04
1.390
35.31
1.440
36.58
1.490
37.85
1.540
39.12
1.590
40.39
1.640
41.66
1.690
42.93
1.740
44.20
1.790
45.47
1.840
46.74
1.890
48.01
1.940
49.28
1.990
50.55
2.040
51.82
2.090
53.09
2.140
54.36
2.190
55.63
2.240
56.90
2.290
58.17
2.340
59.44
2.390
60.71
2.440
61.98
2.490
63.25
2.540
64.52
2.590
65.79
2.640
67.06
2.690
68.33
2.740
69.60
2.790
70.87
2.840
72.14
2.890
73.41
2.940
74.68
2.990
75.95
3.040
77.22
3.090
78.49
3.140
79.76
3.190
81.03
3.240
82.30
3.290
83.57
3.340
84.84
3.390
86.11
3.440
87.38
3.490
88.65
3.540
89.92
3.590
91.19
3.640
92.46
3.690
93.73
3.740
95.00
3.790
96.27
3.840
97.54
3.890
98.81
3.940
100.08
F±.010[0.25]
IN
MM
0.350
8.89
0.400
10.16
0.450
11.43
0.500
12.70
0.550
13.97
0.600
15.24
0.650
16.51
0.700
17.78
0.750
19.05
0.800
20.32
0.850
21.59
0.900
22.86
0.950
24.13
1.000
25.40
1.050
26.67
1.100
27.94
1.150
29.21
1.200
30.48
1.250
31.75
1.300
33.02
1.350
34.29
1.400
35.56
1.450
36.83
1.500
38.10
1.550
39.37
1.600
40.64
1.650
41.91
1.700
43.18
1.750
44.45
1.800
45.72
1.850
46.99
1.900
48.26
1.950
49.53
2.000
50.80
2.050
52.07
2.100
53.34
2.150
54.61
2.200
55.88
2.250
57.15
2.300
58.42
2.350
59.69
2.400
60.96
2.450
62.23
2.500
63.50
2.550
64.77
2.600
66.04
2.650
67.31
2.700
68.58
2.750
69.85
2.800
71.12
2.850
72.39
2.900
73.66
2.950
74.93
3.000
76.20
3.050
77.47
3.100
78.74
3.150
80.01
3.200
81.28
PART NUMBER
_ _B63DYH_
_ _B64DYH_
_ _B65DYH_
_ _B66DYH_
_ _B67DYH_
_ _B68DYH_
_ _B69DYH_
_ _B70DYH_
_ _B71DYH_
_ _B72DYH_
_ _B73DYH_
_ _B74DYH_
_ _B75DYH_
_ _B76DYH_
_ _B77DYH_
_ _B78DYH_
_ _B79DYH_
_ _B80DYH_
_ _B81DYH_
_ _B82DYH_
_ _B83DYH_
_ _B84DYH_
_ _B85DYH_
_ _B86DYH_
_ _B87DYH_
_ _B88DYH_
_ _B89DYH_
_ _B90DYH_
_ _B91DYH_
_ _B92DYH_
_ _B93DYH_
_ _B94DYH_
_ _B95DYH_
_ _B96DYH_
_ _B97DYH_
_ _B98DYH_
_ _B99DYH_
_ _B100DYH_
_ _B101DYH_
_ _B102DYH_
_ _B103DYH_
_ _B104DYH_
_ _B105DYH_
_ _B106DYH_
_ _B107DYH_
_ _B108DYH_
_ _B109DYH_
_ _B110DYH_
_ _B111DYH_
_ _B112DYH_
_ _B113DYH_
_ _B114DYH_
_ _B115DYH_
_ _B116DYH_
_ _B117DYH_
_ _B118DYH_
_ _B119DYH_
_ _B120DYH_
A±.005[0.13]
IN
MM
3.100
78.74
3.150
80.01
3.200
81.28
3.250
82.55
3.300
83.82
3.350
85.09
3.400
86.36
3.450
87.63
3.500
88.90
3.550
90.17
3.600
91.44
3.650
92.71
3.700
93.98
3.750
95.25
3.800
96.52
3.850
97.79
3.900
99.06
3.950
100.33
4.000
101.60
4.050
102.87
4.100
104.14
4.150
105.41
4.200
106.68
4.250
107.95
4.300
109.22
4.350
110.49
4.400
111.76
4.450
113.03
4.500
114.30
4.550
115.57
4.600
116.84
4.650
118.11
4.700
119.38
4.750
120.65
4.800
121.92
4.850
123.19
4.900
124.46
4.950
125.73
5.000
127.00
5.050
128.27
5.100
129.54
5.150
130.81
5.200
132.08
5.250
133.35
5.300
134.62
5.350
135.89
5.400
137.16
5.450
138.43
5.500
139.70
5.550
140.97
5.600
142.24
5.650
143.51
5.700
144.78
5.750
146.05
5.800
147.32
5.850
148.59
5.900
149.86
5.950
151.13
B±.005[0.13]
IN
MM
3.200
81.28
3.250
82.55
3.300
83.82
3.350
85.09
3.400
86.36
3.450
87.63
3.500
88.90
3.550
90.17
3.600
91.44
3.650
92.71
3.700
93.98
3.750
95.25
3.800
96.52
3.850
97.79
3.900
99.06
3.950
100.33
4.000
101.60
4.050
102.87
4.100
104.14
4.150
105.41
4.200
106.68
4.250
107.95
4.300
109.22
4.350
110.49
4.400
111.76
4.450
113.03
4.500
114.30
4.550
115.57
4.600
116.84
4.650
118.11
4.700
119.38
4.750
120.65
4.800
121.92
4.850
123.19
4.900
124.46
4.950
125.73
5.000
127.00
5.050
128.27
5.100
129.54
5.150
130.81
5.200
132.08
5.250
133.35
5.300
134.62
5.350
135.89
5.400
137.16
5.450
138.43
5.500
139.70
5.550
140.97
5.600
142.24
5.650
143.51
5.700
144.78
5.750
146.05
5.800
147.32
5.850
148.59
5.900
149.86
5.950
151.13
6.000
152.40
6.050
153.67
C±.015[0.38]
IN
MM
3.390
86.11
3.440
87.38
3.490
88.65
3.540
89.92
3.590
91.19
3.640
92.46
3.690
93.73
3.740
95.00
3.790
96.27
3.840
97.54
3.890
98.81
3.940
100.08
3.990
101.35
4.040
102.62
4.090
103.89
4.140
105.16
4.190
106.43
4.240
107.70
4.290
108.97
4.340
110.24
4.390
111.51
4.440
112.78
4.490
114.05
4.540
115.32
4.590
116.59
4.640
117.86
4.690
119.13
4.740
120.40
4.790
121.67
4.840
122.94
4.890
124.21
4.940
125.48
4.990
126.75
5.040
128.02
5.090
129.29
5.140
130.56
5.190
131.83
5.240
133.10
5.290
134.37
5.340
135.64
5.390
136.91
5.440
138.18
5.490
139.45
5.540
140.72
5.590
141.99
5.640
143.26
5.690
144.53
5.740
145.80
5.790
147.07
5.840
148.34
5.890
149.61
5.940
150.88
5.990
152.15
6.040
153.42
6.090
154.69
6.140
155.96
6.190
157.23
6.240
158.50
D±.010[0.25]
IN
MM
3.676
93.37
3.726
94.64
3.776
95.91
3.826
97.18
3.876
98.45
3.926
99.72
3.976
100.99
4.026
102.26
4.076
103.53
4.126
104.80
4.176
106.07
4.226
107.34
4.276
108.61
4.326
109.88
4.376
111.15
4.426
112.42
4.476
113.69
4.526
114.96
4.576
116.23
4.626
117.50
4.676
118.77
4.726
120.04
4.776
121.31
4.826
122.58
4.876
123.85
4.926
125.12
4.976
126.39
5.026
127.66
5.076
128.93
5.126
130.20
5.176
131.47
5.226
132.74
5.276
134.01
5.326
135.28
5.376
136.55
5.426
137.82
5.476
139.09
5.526
140.36
5.576
141.63
5.626
142.90
5.676
144.17
5.726
145.44
5.776
146.71
5.826
147.98
5.876
149.25
5.926
150.52
5.976
151.79
6.026
153.06
E±.020[0.51]
IN
MM
3.990
101.35
4.040
102.62
4.090
103.89
4.140
105.16
4.190
106.43
4.240
107.70
4.290
108.97
4.340
110.24
4.390
111.51
4.440
112.78
4.490
114.05
4.540
115.32
4.590
116.59
4.640
117.86
4.690
119.13
4.740
120.40
4.790
121.67
4.840
122.94
4.890
124.21
4.940
125.48
4.990
126.75
5.040
128.02
5.090
129.29
5.140
130.56
5.190
131.83
5.240
133.10
5.290
134.37
5.340
135.64
5.390
136.91
5.440
138.18
5.490
139.45
5.540
140.72
5.590
141.99
5.640
143.26
5.690
144.53
5.740
145.80
5.790
147.07
5.840
148.34
5.890
149.61
5.940
150.88
5.990
152.15
6.040
153.42
6.090
154.69
6.140
155.96
6.190
157.23
6.240
158.50
6.290
159.77
6.340
161.04
F±.010[0.25]
IN
MM
3.250
82.55
3.300
83.82
3.350
85.09
3.400
86.36
3.450
87.63
3.500
88.90
3.550
90.17
3.600
91.44
3.650
92.71
3.700
93.98
3.750
95.25
3.800
96.52
3.850
97.79
3.900
99.06
3.950
100.33
4.000
101.60
4.050
102.87
4.100
104.14
4.150
105.41
4.200
106.68
4.250
107.95
4.300
109.22
4.350
110.49
4.400
111.76
4.450
113.03
4.500
114.30
4.550
115.57
4.600
116.84
4.650
118.11
4.700
119.38
4.750
120.65
4.800
121.92
4.850
123.19
4.900
124.46
4.950
125.73
5.000
127.00
5.050
128.27
5.100
129.54
5.150
130.81
5.200
132.08
5.250
133.35
5.300
134.62
5.350
135.89
5.400
137.16
5.450
138.43
5.500
139.70
5.550
140.97
5.600
142.24
5.650
143.51
5.700
144.78
5.750
146.05
5.800
147.32
5.850
148.59
5.900
149.86
5.950
151.13
6.000
152.40
6.050
153.67
6.100
154.94
N OR R MOUNTING ONLY
F
E
D
C
WITH MOLDED KEY
BETWEEN
POSITIONS
WITH MOLDED
KEY IN POSITION
WITHOUT MOLDED KEY
1
2
3
NO OF
POS.
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
06/18/10 TT
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
7
6
5
4
3
2
_ _B_ _DYH_-S_ _ _
CAGE CODE
54453
SCALE: 3:1
8
A
DWG. NO.
C11419
REV
J
SHEET 3 OF 3
1
很抱歉,暂时无法提供与“GBB25DYHR”相匹配的价格&库存,您可以联系我们找货
