ECC30DREN
ECC30DREN
    SULLINS
    CONN EDGECARD 60POS .100 EYELET
ECC30DREN 数据手册
8 7 4 5 6 1 2 3 REVISIONS DESCRIPTION REV. ECO. NO DATE BY ADD KEY IN & BETWEEN POSITION OPTION, OBSOLETE DWG 13337(S1632) & DWG 12606(S688) REPLACE WITH 7/17/2018 DWG 10870 JH D 3880 E 4221 ADD REF ROW SPACING DIMENSION 5/29/2020 JH F 4762 ADD C14008 TO P/N CODING 1/23/2024 JH F F ADDED DWG C14008 TO P/N CODING E D CONTACT MARKINGS B 1 2 3 ... 60 B A 1 2 3 ... 60 A B E A 2X .125 3.18 THRU .075[1.90] CARD SLOT SEE NOTE 13 CONTACT ID SCALE 4:1 .100 2.54 TYP D .030 0.76 A D .265 6.73 INSERTION DEPTH F C E .431 10.95 +.025 +0.64 .225 5.71 - .035 - 0.89 .245 6.22 C C .025 0.64 EYELET ACCEPTS 3-#26 AWG .065 1.65 X .007[0.18] A .140 3.56 SECTION A - A _ _C_ _DREH B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 700 VAC 8. CURRENT RATING: 3 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MINIMUM 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE 16. MODIFICATION: SEE PART NUMBER CODING 8 7 6 5 B CUSTOMER COPY Pb RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 10/4/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _C_ _DRE_(-S38,-S81,-S328) SIZE C CAGE CODE 54453 SCALE: 2:1 4 3 A EDGECARD, .100 CC LP 2 DWG. NO. C10870 REV F SHEET 1 OF 3 1 FILE NAME: C10870, _ _C_ _DRE_-OMIT, S38, S81, S328, S_ _ _ _ MOLDED KEY 8 7 2X #4-40 THREADED INSERTS F 5 6 4 1 2 3 F D D E E .135 3.43 _ _C_ _DREI 2X .125 3.18 THRU _ _C_ _DRES 2X FLOATING BOBBIN .116[2.95] CLEARANCE FOR # 4 SCREW D D D C .280 7.11 C C _ _C_ _DREN _ _C_ _DREF A 2X .065 1.65 B B L .015[0.38] (L = DIM 'A' +.130[3.30]) CUSTOMER COPY Pb A _ _C_ _DREB RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 10/4/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _C_ _DRE_(-S38,-S81,-S328) SIZE C CAGE CODE 54453 SCALE: 2:1 8 7 6 5 4 3 A EDGECARD, .100 CC LP 2 DWG. NO. C10870 REV F SHEET 2 OF 3 1 FILE NAME: C10870, _ _C_ _DRE_-OMIT, S38, S81, S328, S_ _ _ _ MOLDED KEY 8 F E D _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ PART NUMBER _C04DRE_-S_ _C05DRE_-S_ _C06DRE_-S_ _C07DRE_-S_ _C08DRE_-S_ _C10DRE_-S_ _C12DRE_-S_ _C13DRE_-S_ _C15DRE_-S_ _C17DRE_-S_ _C18DRE_-S_ _C19DRE_-S_ _C20DRE_-S_ _C22DRE_-S_ _C23DRE_-S_ _C25DRE_-S_ _C26DRE_-S_ _C28DRE_-S_ _C30DRE_-S_ _C31DRE_-S_ _C32DRE_-S_ _C35DRE_-S_ _C36DRE_-S_ _C38DRE_-S_ _C40DRE_-S_ _C43DRE_-S_ _C44DRE_-S_ _C49DRE_-S_ _C50DRE_-S_ _C52DRE_-S_ _C60DRE_-S_ _C65DRE_-S_ 7 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ NO. OF POS. 4 5 6 7 8 10 12 13 15 17 18 19 20 22 23 25 26 28 30 31 32 35 36 38 40 43 44 49 50 52 60 65 A±.008[0.20] IN MM 0.300 7.62 0.400 10.16 0.500 12.70 0.600 15.24 0.700 17.78 0.900 22.86 1.100 27.94 1.200 30.48 1.400 35.56 1.600 40.64 1.700 43.18 1.800 45.72 1.900 48.26 2.100 53.34 2.200 55.88 2.400 60.96 2.500 63.50 2.700 68.58 2.900 73.66 3.000 76.20 3.100 78.74 3.400 86.36 3.500 88.90 3.700 93.98 3.900 99.06 4.200 106.68 4.300 109.22 4.800 121.92 4.900 124.46 5.100 129.54 5.900 149.86 6.400 162.56 B±.008[0.20] IN MM 0.500 12.70 0.600 15.24 0.700 17.78 0.800 20.32 0.900 22.86 1.100 27.94 1.300 33.02 1.400 35.56 1.600 40.64 1.800 45.72 1.900 48.26 2.000 50.80 2.100 53.34 2.300 58.42 2.400 60.96 2.600 66.04 2.700 68.58 2.900 73.66 3.100 78.74 3.200 81.28 3.300 83.82 3.600 91.44 3.700 93.98 4.100 4.400 4.500 5.000 5.100 5.300 6.100 6.600 104.14 111.76 114.30 127.00 129.54 134.62 154.94 167.64 4 5 6 D±..010[0.25] C±.015[0.38] IN MM IN MM 0.675 17.15 0.975 24.77 0.775 19.69 1.075 27.31 0.875 22.23 1.175 29.85 0.975 24.77 1.275 32.39 1.075 27.31 1.375 34.93 1.275 32.39 1.575 40.01 1.475 37.47 1.775 45.09 1.575 40.01 1.875 47.63 1.775 45.09 2.075 52.71 1.975 50.17 2.275 57.79 2.075 52.71 2.375 60.33 2.175 55.25 2.475 62.87 2.275 57.79 2.575 65.41 2.475 62.87 2.775 70.49 2.575 65.41 2.875 73.03 2.775 70.49 3.075 78.11 2.875 73.03 3.175 80.65 3.075 78.11 3.375 85.73 3.275 83.19 3.575 90.81 3.375 85.73 3.675 93.35 3.475 88.27 3.775 95.89 3.775 95.89 4.075 103.51 3.875 98.43 4.175 106.05 "B" MOUNTING ONLY 4.275 108.59 4.575 116.21 4.575 116.21 4.875 123.83 4.675 118.75 4.975 126.37 5.175 131.45 5.475 139.07 5.275 133.99 5.575 141.61 5.475 139.07 5.775 146.69 6.275 159.39 6.575 167.01 6.775 172.09 7.075 179.71 E±.020[0.51] IN MM 1.275 32.39 1.375 34.93 1.475 37.47 1.575 40.01 1.675 42.55 1.875 47.63 2.075 52.71 2.175 55.25 2.375 60.33 2.575 65.41 2.675 67.95 2.775 70.49 2.875 73.03 3.075 78.11 3.175 80.65 3.375 85.73 3.475 88.27 3.675 93.35 3.875 98.43 3.975 100.97 4.075 103.51 4.375 111.13 4.475 113.67 4.875 5.175 5.275 5.775 5.875 6.075 6.875 7.375 123.83 131.45 133.99 146.69 149.23 154.31 174.63 187.33 1 2 3 F+.005[0.13] -.015[0.38] IN MM KEY IN POSITION .070±.002 1.78±0.05 F G 0.330 8.38 E ('H' MOUNTING AS SHOWN FOR EXAMPLE) KEY BETWEEN POSITIONS 0.400 10.16 .030±.002 0.76±0.05 D H PART NUMBER CODING _ _ C _ _ DRE _ -S_ _ _ _ C B A MATERIAL (INSULATOR/CONTACT) E = BLUE PBT/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: WAVE/MANUAL SOLDERING ONLY R = GREEN PPS/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS G = BLACK PA9T/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS H = BLUE PBT/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: WAVE/MANUAL SOLDERING ONLY A = GREEN PPS/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS J = BLACK PA9T/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS F = GREEN PPS/SPINODAL (CONSULT FACTORY) OPERATING TEMP: -65°C TO +200°C AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE) PROCESSING TEMP: 260°C MAX FOR 20 SECONDS (CONSULT FACTORY FOR SPECIAL SOLDERING REQUIREMENTS) C = GREEN PPS/BERYLLIUM NICKEL (CONSULT FACTORY) AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE) OPERATING TEMP: -65°C TO +200°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS W = TAN PEEK/BERYLLIUM NICKEL (CONSULT FACTORY) AVAILABLE IN OVERALL GOLD ONLY (M PLATING CODE) OPERATING TEMP: -65°C TO +250°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS MODIFICATION OMIT = STANDARD WITHOUT MOLDED KEY, EX: 'EBC22DREH' S38 = BLACK PBT WITHOUT MOLDED KEY (MATERIAL CODES E & H ONLY) S81 = GREEN PBT WITHOUT MOLDED KEY (MATERIAL CODES E & H ONLY) S328 = BROWN PPS WITHOUT MOLDED KEY (MATERIAL CODES R, A, F, AND C ONLY) SEE KEY LOCATION DRAWINGS FOR MODIFICATION NUMBER (S#), 'G' AND 'H' DIMENSION: DRAWING C13556 FOR STANDARD COLOR DRAWING C14008 FOR NON-STANDARD COLOR C ('H' MOUNTING AS SHOWN FOR EXAMPLE) MOUNTING STYLE H = .125" DIA. CLEARANCE HOLES I = #4-40 THREADED INSERT S = .125" DIA. SIDE MOUNTING N = NO MOUNTING EARS F = FLOATING BOBBIN B = OPEN CARDSLOT B NUMBER OF POSITIONS (CONTACTS PER ROW) PLATING ALL PLATINGS HAVE .000050" NICKEL UNDERPLATE CONTACT SURFACE TERMINATION B = .000010" GOLD .000100" PURE TIN, MATTE C = .000030" GOLD .000100" PURE TIN, MATTE G = .000010" GOLD .000005" GOLD Y = .000030" GOLD .000005" GOLD *E = .000100" PURE TIN, MATTE OVERALL S = .000010" GOLD OVERALL M = .000030" GOLD .000010" GOLD OVERALL *OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES E, R, AND G CUSTOMER COPY Pb RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 10/4/2011 JH TOLERANCES: ANGULAR: THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE EDGECARD, .100 CC LP, KEY IN POSITION 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] PART NUMBER SIZE C 54453 SCALE: 2.5:1 8 7 6 5 4 3 2 _ _C_ _DRE_-S_ _ _ _ CAGE CODE DWG. NO. C10870 REV F SHEET 3 OF 3 1 FILE NAME: C10870, _ _C_ _DRE_-OMIT, S38, S81, S328, S_ _ _ _ MOLDED KEY A
ECC30DREN 价格&库存
很抱歉,暂时无法提供与“ECC30DREN”相匹配的价格&库存,您可以联系我们找货
