8
7
4
5
6
1
2
3
REVISIONS
REV.
E
D
B
F
2X
.125 3.18
DESCRIPTION
DATE
BY
3951
ADD KEY IN POSITION & KEY BETWEEN
POSITIONS OPTION
11/13/2018
JH
J
A
E
ECO. NO
K
4391
L
4762
F
ADD S# TABLE FOR BROWN PPS AND BLACK PBT
WITH MOLDED KEY (S2853), ADD MTG ON DIM 7/7/2021
TABLE FOR 02, 03 POSI, ADD 32 POSITION
ADD C14008 TO P/N & 09 POSITION, REMOVE
KEY TABLE FROM PAGE 4
1/23/2024
JH
JH
.075 1.91
CARD SLOT
SEE NOTE 13
.100 2.54 TYP.
E
F
C
A
.125±.025 3.18±0.64
.030 0.76
.431 10.95
.050±.010 1.26±0.25
D
D
.265 6.73
INSERTION DEPTH
.245 6.22
_ _ C _ _ DRAH
2X .125 3.18
FOR 'S' OR 'A' MOUNTING
.025 0.64
LETTER B SIDE
.156 3.96
A
SECTION A - A
D
CONTACT IDs:
B 1 2 3 ... 60 B
A 1 2 3 ... 60 A
A
C
C
.185 4.70
.156 3.96
.100 2.54
.043 1.09 MIN
PCB LAYOUT RECOMMENDED
(COMPONENT SIDE)
B
A
CONTACT ID
SCALE 4:1
(PINS OMITTED FOR CLARITY)
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 700 VAC
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI-8.6-03
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE
16. MODIFICATION: SEE PART NUMBER CODING
8
7
6
5
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
01/19/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
_ _C_ _DRA_(-S38,S81,S328)
SIZE
C
CAGE CODE
54453
SCALE: 3:1
4
3
A
EDGECARD, .100 CC LP
2
DWG. NO.
C10876
REV
L
SHEET 1 OF 3
1
FILE NAME: C10876, _ _C_ _DRA_-OMIT, S38, S81, S328, S_ _ _ _ MOLDED KEY
8
7
4
5
6
1
2
3
2X #4-40
THREADED
INSERTS
F
F
D
2X
.125 3.18
.185 4.69
E
.135 3.43
_ _ C _ _ DRAI
_ _ C _ _ DRAS
E
2X FLOATING BOBBIN
.116[2.95] CLEARANCE
FOR # 4 SCREW
C
D
D
.280 7.11
_ _ C _ _ DRAF
_ _ C _ _ DRAN
2X .065 1.65
A
C
C
2X #4-40
THREADED
INSERT
D
L .015[0.38]
(L= DIM 'A' + .130[3.30])
B
B
.185 4.69
_ _C_ _DRAA
CUSTOMER COPY
_ _ C_ _DRAB
Pb
A
RoHS COMPLIANT
01/19/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
8
7
6
5
4
3
A
2
DWG. NO.
C10876
REV
L
SHEET 2 OF 3
1
8
F
E
D
PART
NUMBER
_ _C02DRA_-S_ _ _
_ _C03DRA_-S_ _ _
_ _C04DRA_-S_ _ _
_ _C05DRA_-S_ _ _
_ _C06DRA_-S_ _ _
_ _C07DRA_-S_ _ _
_ _C08DRA_-S_ _ _
_ _C09DRA_-S_ _ _
_ _C10DRA_-S_ _ _
_ _C12DRA_-S_ _ _
_ _C13DRA_-S_ _ _
_ _C14DRA_-S_ _ _
_ _C15DRA_-S_ _ _
_ _C17DRA_-S_ _ _
_ _C18DRA_-S_ _ _
_ _C19DRA_-S_ _ _
_ _C20DRA_-S_ _ _
_ _C22DRA_-S_ _ _
_ _C23DRA_-S_ _ _
_ _C25DRA_-S_ _ _
_ _C26DRA_-S_ _ _
_ _C28DRA_-S_ _ _
_ _C30DRA_-S_ _ _
_ _C31DRA_-S_ _ _
_ _C32DRA_-S_ _ _
_ _C35DRA_-S_ _ _
_ _C36DRA_-S_ _ _
_ _C40DRA_-S_ _ _
_ _C43DRA_-S_ _ _
_ _C44DRA_-S_ _ _
_ _C45DRA_-S_ _ _
_ _C49DRA_-S_ _ _
_ _C50DRA_-S_ _ _
_ _C52DRA_-S_ _ _
_ _C60DRA_-S_ _ _
_ _C65DRA_-S_ _ _
7
NO. OF
POS.
2
3
4
5
6
7
8
9
10
12
13
14
15
17
18
19
23
25
26
28
30
31
32
35
36
40
43
44
45
49
50
52
60
65
A±.008[0.20]
IN
MM
0.100
2.54
0.200
5.08
0.300
7.62
0.400 10.16
0.500 12.70
0.600 15.24
0.700 17.78
0.800 20.32
0.900 22.86
1.100 27.94
1.200 30.48
1.300 33.02
1.400 35.56
1.600 40.64
1.700 43.18
1.800 45.72
1.900 48.26
2.100 53.34
2.200 55.88
2.400 60.96
2.500 63.50
2.700 68.58
2.900 73.66
3.000 76.20
3.100 78.74
3.400 86.36
3.500 88.90
3.900 99.06
4.200 106.68
4.300 109.22
4.400 111.76
4.800 121.92
4.900 124.46
5.100 129.54
5.900 149.86
6.400 162.56
C±.015[0.38]
IN
MM
0.475
12.07
0.575
14.61
0.675
17.15
0.775
19.69
0.875
22.23
0.975
24.77
1.075
27.31
1.175
29.85
1.275
32.39
1.475
37.47
1.575
40.01
1.675
42.55
1.775
45.09
1.975
50.17
2.075
52.71
2.175
55.25
2.275
57.79
2.475
62.87
2.575
65.41
2.775
70.49
2.875
73.03
3.075
78.11
3.275
83.19
3.375
85.73
3.475
88.27
3.775
95.89
3.875
98.43
4.275
108.59
4.575
116.21
4.675
118.75
4.775
121.29
5.175
131.45
5.275
133.99
5.475
139.07
6.275
159.39
6.775
172.09
MATERIAL (INSULATOR/CONTACT)
A
D±.010[0.25]
IN
MM
0.775
19.69
0.875
22.23
0.975
24.77
1.075
27.31
1.175
29.85
1.275
32.39
1.375
34.93
1.475
37.47
1.575
40.01
1.775
45.09
1.875
47.63
1.975
50.17
2.075
52.71
2.275
57.79
2.375
60.33
2.475
62.87
2.575
65.41
2.775
70.49
2.875
73.03
3.075
78.11
3.175
80.65
3.375
85.73
3.575
90.81
3.675
93.35
3.775
95.89
4.075
103.51
4.175
106.05
4.575
116.21
4.875
123.83
4.975
126.37
5.075
128.91
5.475
139.07
5.575
141.61
5.775
146.69
6.575
167.01
7.075
179.71
E±.020[0.51]
IN
MM
1.075
27.31
1.175
29.85
1.275
32.39
1.375
34.93
1.475
37.47
1.575
40.01
1.675
42.55
1.775
45.09
1.875
47.63
2.075
52.71
2.175
55.25
2.275
57.79
2.375
60.33
2.575
65.41
2.675
67.95
2.775
70.49
2.875
73.03
3.075
78.11
3.175
80.65
3.375
85.73
3.475
88.27
3.675
93.35
3.875
98.43
3.975 100.97
4.075 103.51
4.375 111.13
4.475 113.67
4.875 123.83
5.175 131.45
5.275 133.99
5.375 136.53
5.775 146.69
5.875 149.23
6.075 154.31
6.875 174.63
7.375 187.33
F
KEY IN POSITION
0.330
8.38
E
.070±.002 1.78±0.05
G
D
('H' MOUNTING AS SHOWN FOR EXAMPLE)
0.400
10.16
KEY BETWEEN POSITIONS
C
MODIFICATION
E = BLUE PBT/PHOSPHOR BRONZE
OPERATING TEMP: -65°C TO +125°C
PROCESSING TEMP: WAVE/MANUAL SOLDERING ONLY
R = GREEN PPS/PHOSPHOR BRONZE
PROCESSING TEMP: 260°C MAX FOR 20 SECS
G = BLACK PA9T/PHOSPHOR BRONZE
H = BLUE PBT/BERYLLIUM COPPER
A = GREEN PPS/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +150°C
J = BLACK PA9T/BERYLLIUM COPPER
F = GREEN PPS/SPINODAL (CONSULT FACTORY)
OPERATING TEMP: -65°C TO +200°C
(CONSULT FACTORY FOR SPECIAL SOLDERING GUIDELINES)
AVAILABLE IN OVERALL GOLD ONLY (S OR M PLATING CODE)
C = GREEN PPS/BERYLLIUM NICKEL (CONSULT FACTORY)
W = TAN PEEK/BERYLLIUM NICKEL (CONSULT FACTORY)
OPERATING TEMP: -65°C TO +250°C
AVAILABLE IN OVERALL GOLD ONLY (M PLATING CODE)
8
1
2
3
F+.005/-.015[+0.13/-0.38]
IN
MM
PART NUMBER CODING
_ _ C _ _ DRA _ -S_ _ _
C
B
4
5
6
B±.008[0.20]
IN
MM
0.300
7.62
0.400
10.16
0.500
12.70
0.600
15.24
0.700
17.78
0.800
20.32
0.900
22.86
1.000
25.40
1.100
27.94
1.300
33.02
1.400
35.56
1.500
38.10
1.600
40.64
1.800
45.72
1.900
48.26
2.000
50.80
2.100
53.34
2.300
58.42
2.400
60.96
2.600
66.04
2.700
68.58
2.900
73.66
3.100
78.74
3.200
81.28
3.300
83.82
3.600
91.44
3.700
93.98
4.100
104.14
4.400
111.76
4.500
114.30
4.600
116.84
5.000
127.00
5.100
129.54
5.300
134.62
6.100
154.94
6.600
167.64
7
OMIT = STANDARD WITHOUT MOLDED KEY, EX: 'EBC15DRAH'
S38 = BLACK PBT WITHOUT MOLDED KEY (MATERIAL CODES E & H ONLY)
S81 = GREEN PBT WITHOUT MOLDED KEY (MATERIAL CODES E & H ONLY)
S328 = BROWN PPS WITHOUT MOLDED KEY (MATERIAL CODES R, A, F, AND C ONLY)
SEE KEY LOCATION DRAWINGS FOR MODIFICATION NUMBER (S#), 'G' AND 'H' DIMENSION:
DRAWING C13556 FOR STANDARD COLOR
DRAWING C14008 FOR NON-STANDARD COLOR
.030±.002 0.76±0.05
H
MOUNTING STYLE
NUMBER OF POSITIONS
(CONTACTS PER ROW)
PLATING
H=
I=
S=
N=
F=
B=
A=
.125" DIA. CLEARANCE HOLES
#4-40 THREADED INSERT
.125" DIA. SIDE MOUNTING
NO MOUNTING EARS
FLOATING BOBBIN
OPEN CARD SLOT
#4-40 THREADED INSERT IN SIDE HOLES
ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
G = .000010" GOLD
.000005" GOLD
Y = .000030" GOLD
.000005" GOLD
**E = .000100" PURE TIN, MATTE
.000100" PURE TIN, MATTE, OVERALL
S = .000010" GOLD
.000010" GOLD OVERALL
M = .000030" GOLD
** OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES E, R AND G
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
01/19/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
_ _C_ _DRA_(-S38,-S81,-S328)
SIZE
C
CAGE CODE
54453
SCALE: 2:1
6
5
4
3
A
2
DWG. NO.
C10876
REV
L
SHEET 3 OF 3
1
很抱歉,暂时无法提供与“EBC12DRAS”相匹配的价格&库存,您可以联系我们找货
