ESM-240S150MT
ESM-240S150MT
    INVENTRONICS(英飞特)
ESM-240S150MT 数据手册
ESM-240SxxxMx 240W Programmable Driver with INV Digital Dimming Rev.B Features  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Programmability  Isolated 0-10V/PWM/3-Timer-Modes Dimmable  INV Digital Dimming, UART Based Communication Protocol  Dim-to-Off with Low Standby Power  Always-on Auxiliary Power: 12Vdc, 250mA, 3W (Transient Peak Power up to 10W)  Low Inrush Current  Output Lumen Compensation  End-of-Life Indicator  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: IUVP, IOVP, OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location  5 Years Warranty Description The ESM-240SxxxMx series is a 240W, constant-current, programmable and IP66/IP67 rated LED driver that operates from 249-528Vac input with excellent power factor. Created for smart lighting application, this family provides an auxiliary voltage and dim-to-off functionality for powering low voltage, wireless controls. The dimming control supports 0-10V dimming as well as two-way communication via Digital Dimming, a UART based communication protocol. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Output Current Current Range(1) Range Default Output Current Input Voltage Range(2) Output Voltage Range 249~528 Vac/ 115~343Vdc 352~500 Vdc 249~528 Vac/ 105-1500mA1050-1500mA 1050 mA 80~229 Vdc 352~500 Vdc 249~528 Vac/ 215-3500mA2150-3500mA 2150 mA 35~111 Vdc 352~500 Vdc 249~528 Vac/ 420-6700mA4200-6700mA 4900 mA 18 ~ 57 Vdc 352~500 Vdc 70-1050mA 700-1050mA 700 mA Typical Max. Typical Power Factor Output Efficiency Power (3) 277Vac 480Vac Model Number (5) 240 W 94.0% 0.99 0.95 ESM-240S105Mx 240 W 93.5% 0.99 0.95 ESM-240S150Mx 240 W 93.0% 0.99 0.95 ESM-240S350Mx(4) 240 W 92.5% 0.99 0.95 ESM-240S670Mx(4) Notes: (1) Output current range with constant power at 240W (2) Certified input voltage range: 277-480Vac. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV output. (5) x = G are UL Recognized and ENEC, etc. models; x = T are UL Class P models. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx 240W Programmable Driver with INV Digital Dimming Rev.B I-V Operation Area ESM-240S105Mx ESM-240S150Mx ESM-240S350Mx ESM-240S670Mx Input Specifications Parameter Min. Typ. Max. Input AC Voltage 249 Vac - 528 Vac Input DC Voltage 352 Vdc - 500 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 480Vac/ 60Hz - - 0.70 mA IEC60598-1; 480Vac/ 60Hz, - - 1.08 A Measured at full load and 277 Vac input. - - 0.64 A Measured at full load and 480 Vac input. - - 2.10 A2s At 480Vac input, 25C cold start, duration=520 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. Leakage Current Input AC Current Inrush Current(I2t) 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx 240W Programmable Driver with INV Digital Dimming Rev.B Input Specifications (Continued) Parameter Min. Typ. Max. 0.9 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 215 mA 420 mA - 1050 mA 1500 mA 3500 mA 6700 mA 700 mA 1050 mA 2150 mA 4200 mA - 1050 mA 1500 mA 3500 mA 6700 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESM-240S105Mx ESM-240S150Mx ESM-240S350Mx ESM-240S670Mx - - 400 V 290 V 120 V 75 V Line Regulation - - ±0.5% Load Regulation - - ±3.0% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 250 mA 12V Auxiliary Output Transient Peak Current@6W - - 500 mA 12V Auxiliary Output Transient Peak Current@10W - - 850 mA PF THD Notes At 277-480Vac, 50-60Hz, 60%-100% Load (144-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESM-240S105Mx ESM-240S150Mx ESM-240S350Mx ESM-240S670Mx Output Current Setting Range with Constant Power ESM-240S105Mx ESM-240S150Mx ESM-240S350Mx ESM-240S670Mx Total Output Current Ripple (pk-pk) 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 277-480Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ 500mA peak for a maximum duration of 2.2 ms in a 6.0ms period during which time the average should not exceed 250mA. 850mA peak for a maximum duration of 1.3 ms in a 5.2ms period during which time the average should not exceed 250mA. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx 240W Programmable Driver with INV Digital Dimming Rev.B General Specifications Parameter Min. Typ. Max. 90.5% 91.0% 92.5% 93.0% - 90.0% 90.0% 92.0% 92.0% - 90.0% 88.5% 92.0% 90.5% - 89.5% 87.5% 91.5% 89.5% - 91.5% 91.5% 93.5% 93.5% - 91.5% 91.0% 93.5% 93.0% - 91.0% 89.5% 93.0% 91.5% - 90.5% 88.5% 92.5% 90.5% - 91.5% 92.0% 93.5% 94.0% - 91.5% 91.0% 93.5% 93.0% - 91.0% 89.5% 93.0% 91.5% - 90.5% 89.0% 92.5% 91.0% - Standby Power - 1.5 W - MTBF - 203,000 Hours - Lifetime - 106,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +80°C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; Storage Temperature -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 277 Vac input: ESM-240S105Mx Io= 700 mA Io=1050 mA ESM-240S150Mx Io=1050 mA Io=1500 mA ESM-240S350Mx Io=2150 mA Io=3500 mA ESM-240S670Mx Io=4200 mA Io=6700 mA Efficiency at 400 Vac input: ESM-240S105Mx Io= 700 mA Io=1050 mA ESM-240S150Mx Io=1050 mA Io=1500 mA ESM-240S350Mx Io=2150 mA Io=3500 mA ESM-240S670Mx Io=4200 mA Io=6700 mA Efficiency at 480 Vac input: ESM-240S105Mx Io= 700 mA Io=1050 mA ESM-240S150Mx Io=1050 mA Io=1500 mA ESM-240S350Mx Io=2150 mA Io=3500 mA ESM-240S670Mx Io=4200 mA Io=6700 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 1200 g www.inventronics-co.com Tel: 86-571-56565800 Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details 4 / 15 Specifications are subject to changes without notice. Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) With mounting ear 8.58 × 3.01 × 1.52 218 × 76.5 × 38.5 7.91 × 3.01 × 1.52 201 × 76.5 × 38.5 - Notes All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx 240W Programmable Driver with INV Digital Dimming Rev.B Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 μA 300 μA 450 μA ESM-240S105Mx ESM-240S150Mx ESM-240S350Mx ESM-240S670Mx 10%Ioset - Ioset ESM-240S105Mx ESM-240S150Mx ESM-240S350Mx ESM-240S670Mx Recommended Dimming Input Range 70 mA 105 mA 215 mA 420 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 2150 mA ≤ Ioset ≤ 3500 mA 4200 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 215 mA ≤ Ioset < 2150 mA 420 mA ≤ Ioset < 4200 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx Rev.B 240W Programmable Driver with INV Digital Dimming Safety & EMC Compliance (Continued) EMI Standards EN 55015(1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx Rev.B 240W Programmable Driver with INV Digital Dimming Inrush Current Waveform Efficiency vs. Load ESM-240S105Mx(lo=700mA) ESM-240S105Mx(lo=1050mA) ESM-240S150Mx(lo=1050mA) ESM-240S150Mx(lo=1500mA) 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx Rev.B 240W Programmable Driver with INV Digital Dimming ESM-240S350Mx(lo=2150mA) ESM-240S350Mx(lo=3500mA) ESM-240S670Mx(lo=4200mA) ESM-240S670Mx(lo=6700mA) Power Factor 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx 240W Programmable Driver with INV Digital Dimming Rev.B Total Harmonic Distortion Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Under Voltage Protection (IUVP) Input Over Voltage Protection (IOVP) Input Under Voltage Protection Input Under Voltage Recovery Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 220 Vac 230 Vac 240 Vac Turn off the output when the input voltage falls below protection voltage. 230 Vac 240 Vac 250 Vac Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. 550 Vac 570 Vac 590 Vac Turn off the output when the input voltage exceeds protection voltage. 530 Vac 550 Vac 570 Vac - - 590 Vac 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive for 8 hours with input voltage stress of 590Vac. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx Rev.B  Input Under Voltage Protection Diagram  Input Over Voltage Protection Diagram 240W Programmable Driver with INV Digital Dimming Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx 240W Programmable Driver with INV Digital Dimming Rev.B V+ L V- Vac N Inventronics LED Driver G OTP+ OTPVaux Dim+ Dim- Dimmer Implementation 1: Positive logic Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxMx Rev.B 240W Programmable Driver with INV Digital Dimming Implementation 4: Negative logic Note: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESM-240S150MT 价格&库存
很抱歉,暂时无法提供与“ESM-240S150MT”相匹配的价格&库存,您可以联系我们找货
ESM-240S150MT
