EUC-035S070SVM
EUC-035S070SVM
    INVENTRONICS(英飞特)
EUC-035S070SVM 数据手册
EUC-035SxxxSVM000x 35W Constant Current IP67 Driver Rev. C Features  Low THD, 10% Max up to 240Vac  Compact Metal Case with Excellent Thermal Performance  Input Surge Protection: 4kV line-line, 6kV line-earth  High Reliability & Long Lifetime: 80,000 hrs. at 70C  Suitable for Independent Use and Class I Luminaires  Input UVP and Input OVP  Waterproof (IP67)  SELV Output Description The EUC-035SxxxSVM000x series is a 35W, constant-current IP67 LED driver that operates from 90-305 Vac input with excellent power factor and THD feature. It is created for low bay, tunnel and street lights. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Output Current Input Voltage Range(1) Output Voltage Range Max. Output Power Typical Efficiency (2) 120 Vac 220 Vac 500 mA 90 ~ 305 Vac 32~64 Vdc 32 W 87.0% 0.99 0.96 EUC-035S070SVM0004 700 mA 90 ~ 305 Vac 25~50 Vdc 35 W 87.0% 0.99 0.96 EUC-035S070SVM 860 mA 90 ~ 305 Vac 20~41 Vdc 35 W 86.0% 0.99 0.96 EUC-035S105SVM0004 1050 mA 90 ~ 305 Vac 18~33 Vdc 35 W 86.0% 0.99 0.96 EUC-035S105SVM Power Factor Model Number(3) Notes: (1) Certified input voltage range: 120-240Vac. (2) Measured at full load and 220 Vac input. (3) SELV output. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 0.42 A Measured at full load and 120 Vac input. - - 0.2 A Measured at full load and 220 Vac input. - - 0.002 A s Input AC Current 2 Inrush Current(I t) Notes 2 IEC60598-1; 240Vac/ 60Hz At 220Vac input, 25℃ cold start, duration=40 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSVM000x 35W Constant Current IP67 Driver Rev. C Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - - - 10% Min. Typ. Max. -8%Io - 8%Io At full load condition Total Output Current Ripple (pk-avg) - 50%Io 75%Io At full load condition Startup Overshoot Current - - 10%Io At full load condition No Load Output Voltage EUC-035S070SVM0004 EUC-035S070SVM EUC-035S105SVM0004 EUC-035S105SVM - - 82 V 82 V 60 V 60 V Line Regulation - - ±5.0% Load Regulation - - ±5.0% - 1.5 s 2.0 s - 1.0 s 1.5 s - 0.06%/C - PF Notes 120-240Vac, 75%-100%Load(26~35W) THD Output Specifications Parameter Output Current Tolerance Turn-on Delay Time Temperature Coefficient of Iomax Notes Measured at full load Measured at 120Vac input, 75%-100%Load. Measured at 220Vac input, 75%-100%Load. Case temperature = 0C ~Tc max Note: All specifications are tested by Cree XLamp XP-G and typical measured at 220Vac and 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUC-035S070SVM0004 EUC-035S070SVM EUC-035S105SVM0004 EUC-035S105SVM Efficiency at 220 Vac input: EUC-035S070SVM0004 EUC-035S070SVM EUC-035S105SVM0004 EUC-035S105SVM Efficiency at 277 Vac input: EUC-035S070SVM0004 EUC-035S070SVM EUC-035S105SVM0004 EUC-035S105SVM Min. Typ. Max. Notes 85.0% 85.0% 84.0% 83.5% 86.0% 86.0% 85.0% 84.5% - Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) 86.0% 86.0% 85.0% 85.0% 87.0% 87.0% 86.0% 86.0% - Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) 86.0% 86.0% 85.0% 85.0% 87.0% 87.0% 86.0% 86.0% - Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSVM000x 35W Constant Current IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Typ. MTBF - 1172,000 Hours Lifetime - 80,000 Hours - -40 ℃ - +90 ℃ -40 ℃ - +75 ℃ Humidity: 10% RH to 100% RH. -40 ℃ - +85 ℃ Humidity: 5% RH to 100% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Max. Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details - With mounting ear 3.82 x 2.52 x 1.26 97 x 64 x 32 3.15 x 2.52 x 1.26 80 x 64 x 32 Net Weight - 330 g Notes - Note: All specifications are tested by Cree XLamp XP-G and typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT: level 3, criteria A EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSVM000x 35W Constant Current IP67 Driver Rev. C Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating Lifetime vs. Case Temperature 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSVM000x 35W Constant Current IP67 Driver Rev. C Inrush Current Waveform Efficiency vs. Load EUC-035S070SVM(Io=700mA) EUC-035S070SVM0004(Io=500mA) EUC-035S105SVM(Io=1050mA) EUC-035S105SVM0004(Io=860mA) 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSVM000x 35W Constant Current IP67 Driver Rev. C Power Factor Total Harmonic Distortion Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Input Under Voltage Protection Auto Recovery. Turn off the output when the input voltage falls below 80±10V. And the driver will restart when the input voltage exceeds 85±10V. Input Over Voltage Protection Input Protection Voltage 305 Vac 315 Vac 325 Vac Turn off the output when the input voltage exceeds protection voltage. Recovery Voltage 290 Vac 310 Vac 330 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSVM000x 35W Constant Current IP67 Driver Rev. C Protection Functions (Continued) Parameter Input Over Voltage Protection  Max. of Input Over Voltage Min. Typ. Max. - - 380 Vac Notes Input Over Voltage Protection Diagram Vo Recovery Protection Vin 315 Vac 310 Vac Mechanical Outline INPUT (VDE H05RN-F 3*1.0mm 2 7.2 ) OUTPUT (VDE H05RN-F 2*1.0mm 2 6.8) Tc AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) V+ (BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSVM000x 35W Constant Current IP67 Driver Rev. C Revision History Description of Change Change Date Rev. 2016-07-04 A Item From Datasheet Release / / Input Voltage Range(Vac) 108 ~ 305 Vac 90 ~ 305 Vac Input Voltage Range(Vdc) 127 ~ 300 Vdc Deleted EUC035S070SVM0000 EUCModel Number - EUC-035S105SVM(Io=1050mA) 035S105SVM0000 Total Output Current Total Output Current Ripple Ripple (pk-pk) Max.= 150%lo Model Number - EUC-036S070SVM(Io=700mA) 2016-12-26 2017-03-20 B C To EUC-035S070SVM EUC-035S105SVM Total Output Current Ripple (pk-avg) Max.= 75%Io Derating Curve / Added Features / Updated Description / Updated MTBF Min.=600,000Hours Typ.=1172,000 Hours Protection Functions / Updated Input Over Voltage Protection Diagram / Added 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-035S070SVM 价格&库存
很抱歉,暂时无法提供与“EUC-035S070SVM”相匹配的价格&库存,您可以联系我们找货
EUC-035S070SVM
