EUM-075S105DT
EUM-075S105DT
    INVENTRONICS(英飞特)
EUM-075S105DT 数据手册
EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A Features  Compact Metal Case with Excellent Thermal Performance  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Programmability  Isolated 1-5V/1-10V/10V PWM/3-Timer-Modes Dimmable  Output Lumen Compensation  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  Class 2 & SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  UL Class P Type  5 Years Warranty Description The EUM-075SxxxDT series is a 75W, constant-current, programmable IP67 LED driver that operates from 90305Vac input with excellent power factor. It is created for many lighting applications including high bay, tunnel and roadway lights, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Power Factor Max. Typical Output Efficiency Power (3) 120Vac 220Vac Output Voltage Range 90~305 Vac/ 36~107 Vdc 127~300 Vdc 90~305 Vac/ 105-1500mA 1050-1500mA 1050 mA 25~72 Vdc 127~300 Vdc 90~305 Vac/ 140-2100mA 1400-2100mA 2100 mA 18~54 Vdc 127~300 Vdc 70-1050mA 700-1050mA 700 mA Model Number 75W 90.5% 0.99 0.96 EUM-075S105DT (4) 75W 90.5% 0.99 0.96 EUM-075S150DT (4) 75W 89.5% 0.99 0.96 EUM-075S210DT (5) Notes: (1) Output current range with constant power at 75W (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac. (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) Class 2 & SELV output. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A I-V Operation Area EUM-075S105DT 120 (70,107) (455,107) EUM-075S150DT (700,107) 100 (10%Ioset,75/Ioset) (Ioset,75/Ioset) 10 0% Lo ad ad Lo % 65 80 60 (1050,72) (1050,47) 40 20 Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 (1050,36) (Ioset,36) (105,36) 200 400 600 800 1000 1200 Output Current (mA) Note: 700mA Ioset 1050mA 65 Output Voltage(V) EUM-075S210DT % Lo ad Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, - - 0.79 A Measured at 100% load and 120 Vac input. - - 0.43 A Measured at 100% load and 220 Vac input. - - 0.90 A s Leakage Current Input AC Current 2 Inrush Current(I t) 2 Notes 127~300 Vdc At 220Vac input, 25°C cold start, duration=284 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A Input Specifications (Continued) Parameter Min. Typ. Max. 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 140 mA - 1050 mA 1500 mA 2100 mA 700 mA 1050 mA 1400 mA - 1050 mA 1500 mA 2100 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUM-075S105DT EUM-075S150DT EUM-075S210DT - - 120 V 90 V 60 V Line Regulation - - ±1% Load Regulation - - ±5% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.06%/°C - PF Notes At 100-277Vac, 50-60Hz, 65%-100% Load (49-75W) At 220-240Vac, 50-60Hz, 75%-100% Load (56-75W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUM-075S105DT EUM-075S150DT EUM-075S210DT Output Current Setting Range with Constant Power EUM-075S105DT EUM-075S150DT EUM-075S210DT Total Output Current Ripple (pk-pk) Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 120-277Vac input, 65%-100% Load Case temperature = 0°C ~Tc max Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUM-075S105DT Io= 700 mA Io=1050 mA EUM-075S150DT Io=1050 mA Io=1500 mA EUM-075S210DT Io=1400 mA Io=2100 mA Min. Typ. Max. 86.00% 86.50% 88.00% 88.50% - 85.50% 86.00% 87.50% 88.00% - 85.00% 85.00% 87.00% 87.00% - Notes Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A General Specifications (Continued) Parameter Min. Typ. Max. 88.50% 88.50% 90.50% 90.50% - 88.00% 88.50% 90.00% 90.50% - 87.50% 87.50% 89.50% 89.50% - 88.50% 89.00% 90.50% 91.00% - 88.50% 88.50% 90.50% 90.50% - 87.50% 88.00% 89.50% 90.00% - MTBF - 521,000 Hours - Lifetime - 100,000 Hours - -40°C - +90°C -40°C - +80°C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5% RH to 95% RH; Efficiency at 220 Vac input: EUM-075S105DT Io= 700 mA Io=1050 mA EUM-075S150DT Io=1050 mA Io=1500 mA EUM-075S210DT Io=1400 mA Io=2100 mA Efficiency at 277 Vac input: EUM-075S105DT Io= 700 mA Io=1050 mA EUM-075S150DT Io=1050 mA Io=1500 mA EUM-075S210DT Io=1400 mA Io=2100 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 5.59 × 2.36 × 1.34 142 × 60 × 34 4.92 × 2.36 × 1.34 125 × 60 × 34 - Notes 575 g - Note: All specifications are typical at 25°C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin EUM-075S105DT EUM-075S150DT Dimming EUM-075S210DT Output EUM-075S105DT Range EUM-075S150DT EUM-075S210DT Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA 10%Ioset - Ioset 70 mA 105 mA 140 mA - Ioset Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1400 mA ≤ Ioset ≤ 2100 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 140 mA ≤ Ioset < 1400 mA 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A Dimming Specifications (Continued) Parameter Min. Typ. Max. Notes 0.25 V - 4.75 V Dimming mode set to 1-5V in PC interface. 1V - 9V Default 1-10V dimming mode with positive logic. PWM_in High Level - 10V - PWM_in Low Level - 0V - 200 Hz - 2 KHz 0% - 100% Recommended Dimming Range for 1-5V Recommended Dimming Range for 1-10V PWM_in Frequency Range PWM_in Duty Cycle Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A Derating Lifetime vs. Case Temperature Inrush Current Waveform 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A Efficiency vs. Load EUM-075S105DT(Io=700mA) EUM-075S105DT(Io=1050mA) EUM-075S150DT(Io=1050mA) EUM-075S150DT(Io=1500mA) EUM-075S210DT(Io=1400mA) EUM-075S210DT(Io=2100mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  1-5V Dimming The recommended implementation of the dimming control is provided below. 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A Implementation 1: Positive logic Implementation 2: Negative logic Notes: 1. The dimmer can also be replaced by an active 1-5V voltage source signal or passive components like resistors and zener. 2. If 1-5V dimming is not used, Dim + should be open. 3. When 1-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  1-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT 75W Programmable IP67 Driver Rev. A Implementation 4: Negative logic Notes: 1. The dimmer can also be replaced by an active 1-10V voltage source signal or passive components like resistors and zener. 2. If 1-10V dimming is not used, Dim + should be open. 3. When 1-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  10V PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 5: Positive logic Implementation 6: Negative logic Notes: 1. If PWM dimming is not used, Dim + should be open. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUM-075SxxxDT   75W Programmable IP67 Driver Rev. A Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUM-075S105DT 价格&库存
很抱歉,暂时无法提供与“EUM-075S105DT”相匹配的价格&库存,您可以联系我们找货
EUM-075S105DT
    库存:637
    EUM-075S105DT
