EUP-096S105ST
EUP-096S105ST
    INVENTRONICS(英飞特)
EUP-096S105ST 数据手册
EUP-096SxxxST 96W AOC IP67 Driver Rev. D Features          High Efficiency (Up to 93.0%)  5 Years Warranty Full Power at Wide Output Current Range (Constant Power) Adjustable Output Current (AOC) with Dip-switch Non-dimming Control Input Surge Protection: 6kV line-line, 10kV line-earth All-Around Protection: OVP, SCP, OTP Waterproof (IP67) and UL Dry / Damp / Wet Location Class 2 & SELV Output TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location Description The EUP-096SxxxST series is a 96W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including street, tunnel and bay. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) 350-700mA 450-700mA 700-1050mA 700-1050mA 850-1500mA 1050-1500mA 1000-2100mA 1400-2100mA 1250-2150mA 1750-2150mA 2100-3500mA 2625-3500mA Default Output Current Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 700 mA 127~300 Vdc 90~305 Vac/ 1050 mA 127~300 Vdc 90~305 Vac/ 2100 mA 127~300 Vdc 90~305 Vac/ 1750 mA 127~300 Vdc 90~305 Vac/ 2800 mA 127~300 Vdc 550 mA Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number 74~213Vdc 96 W 93.0% 0.99 0.96 EUP-096S070ST 48~137Vdc 96 W 93.0% 0.99 0.96 EUP-096S105ST 32~91Vdc 96 W 92.5% 0.99 0.96 EUP-096S150ST (4) 24 ~ 69Vdc 96 W 92.0% 0.99 0.96 EUP-096S210ST (4) 24 ~ 55Vdc 96 W 92.0% 0.99 0.96 EUP-096S215ST (5) 14 ~ 36Vdc 96 W 91.5% 0.99 0.96 (5) EUP-096S350ST Notes: (1) Output current range with constant power at 96W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) Class 2 & SELV Output. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Notes 127~300 Vdc 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D Input Specifications (Continued) Parameter Min. Typ. Max. - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, - - 1.10 A Measured at 100% load and 120 Vac input. - - 0.65 A Measured at 100% load and 220 Vac input. - - 1.30 A s 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (72-96W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 350 mA 700 mA 850 mA 1000 mA 1250 mA 2100 mA - 700 mA 1050 mA 1500 mA 2100 mA 2150 mA 3500 mA 450 mA 700 mA 1050 mA 1400 mA 1750 mA 2625 mA - 700 mA 1050 mA 1500 mA 2100 mA 2150 mA 3500 mA - 5%Iomax 10%Iomax 100% load. 20 MHz BW Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUP-096S070ST EUP-096S105ST EUP-096S150ST EUP-096S210ST EUP-096S215ST EUP-096S350ST - - 250 V 160 V 110 V 85 V 60 V 42 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s Leakage Current Input AC Current 2 Inrush Current(I t) PF Notes 2 At 220Vac input, 25C cold start, duration=640μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (67-96W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUP-096S070ST EUP-096S105ST EUP-096S150ST EUP-096S210ST EUP-096S215ST EUP-096S350ST Output Current Setting Range with Constant Power EUP-096S070ST EUP-096S105ST EUP-096S150ST EUP-096S210ST EUP-096S215ST EUP-096S350ST Total Output Current Ripple (pk-pk) Turn-on Delay Time 100% load 100% load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D Output Specifications (Continued) Parameter Temperature Coefficient of Ioset Min. Typ. Max. - 0.03%/C - Notes Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUP-096S070ST Io= 450 mA Io= 700 mA EUP-096S105ST Io= 700 mA Io=1050 mA EUP-096S150ST Io=1050 mA Io=1500 mA EUP-096S210ST Io=1400 mA Io=2100 mA EUP-096S215ST Io=1750 mA Io=2150 mA EUP-096S350ST Io=2625 mA Io=3500 mA Efficiency at 220 Vac input: EUP-096S070ST Io= 450 mA Io= 700 mA EUP-096S105ST Io= 700 mA Io=1050 mA EUP-096S150ST Io=1050 mA Io=1500 mA EUP-096S210ST Io=1400 mA Io=2100 mA EUP-096S215ST Io=1750 mA Io=2150 mA EUP-096S350ST Io=2625 mA Io=3500 mA Min. Typ. Max. 88.5% 87.5% 90.5% 89.5% - 88.5% 87.0% 90.5% 89.0% - 88.0% 86.5% 90.0% 88.5% - 87.5% 86.5% 89.5% 88.5% - 88.0% 86.5% 90.0% 88.5% - 87.5% 86.0% 89.5% 88.0% - 91.0% 89.5% 93.0% 91.5% - 91.0% 89.5% 93.0% 91.5% - 90.5% 89.0% 92.5% 91.0% - 90.0% 89.0% 92.0% 91.0% - 90.0% 89.0% 92.0% 91.0% - 89.5% 88.5% 91.5% 90.5% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D General Specifications (Continued) Parameter Min. Typ. Max. 91.0% 90.0% 93.0% 92.0% - 91.5% 90.0% 93.5% 92.0% - 90.5% 89.0% 92.5% 91.0% - 90.0% 89.0% 92.0% 91.0% - 90.5% 89.0% 92.5% 91.0% - 90.0% 89.0% 92.0% 91.0% - MTBF - 355,000 Hours - Lifetime - 77,000 Hours - -40°C - +89°C -40°C - +75C -40°C - +85°C Efficiency at 277 Vac input: EUP-096S070ST Io= 450 mA Io= 700 mA EUP-096S105ST Io= 700 mA Io=1050 mA EUP-096S150ST Io=1050 mA Io=1500 mA EUP-096S210ST Io=1400 mA Io=2100 mA EUP-096S215ST Io=1750 mA Io=2150 mA EUP-096S350ST Io=2625 mA Io=3500 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Case temperature for 5 years warranty Humidity: 5%RH to 100%RH With mounting ear 7.17 × 2.37 × 1.44 182 × 60 × 36.5 6.34 × 2.37 × 1.44 161 × 60 × 36.5 Net Weight Notes 750 g - Note: All specifications are typical at 25C unless otherwise stated. Safety &EMC Compliance Safety Category UL/CUL Standard UL 8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards EN 55015 (1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D Safety &EMC Compliance EMI Standards Notes ANSI C63.4 Class B FCC Part 15 (1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUP-096S070ST(Io=450mA) EUP-096S070ST(Io=700mA) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D EUP-096S105ST(Io=700mA) EUP-096S105ST(Io=1050mA) EUP-096S150ST(Io=1050mA) EUP-096S150ST(Io=1500mA) EUP-096S210ST(Io=1400mA) EUP-096S210ST(Io=2100mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D EUP-096S215ST(Io=1750mA) EUP-096S215ST(Io=2150mA) EUP-096S350ST(Io=2625mA) EUP-096S350ST(Io=3500mA) Power Factor 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Output Current vs. Dip Switch Setting  EUP-096S070ST Output Current Setting (Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. OFF ON ON ON 700mA 74V 137V OFF ON ON OFF 650mA 74V 148V OFF ON OFF ON 600mA 80V 160V OFF ON OFF OFF 550mA 87V 174V OFF OFF ON ON 500mA 96V 192V OFF OFF ON OFF 450mA 107V 213V OFF OFF OFF ON 400mA 120V 213V OFF OFF OFF OFF 350mA 137V 213V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST  96W AOC IP67 Driver Rev. D EUP-096S105ST Output Current Setting (Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1050mA 48V 91V ON ON ON OFF 1000mA 48V 96V ON ON OFF ON 950mA 51V 101V ON ON OFF OFF 900mA 53V 106V ON OFF ON ON 850mA 57V 113V ON OFF ON OFF 800mA 60V 120V ON OFF OFF ON 750mA 64V 128V ON OFF OFF OFF 700mA 69V 137V Notes / Output Current Setting with Constant Power. EUP-096S150ST Output Current Setting (Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1500mA 32V 64V ON ON ON OFF 1450mA 33V 66V ON ON OFF ON 1400mA 35V 68.5V ON ON OFF OFF 1350mA 36V 71V ON OFF ON ON 1300mA 37V 74V ON OFF ON OFF 1250mA 39V 77V ON OFF OFF ON 1200mA 40V 80V ON OFF OFF OFF 1150mA 42V 83.5V OFF ON ON ON 1100mA 44V 87V OFF ON ON OFF 1050mA 46V 91V OFF ON OFF ON 1000mA 48V 91V OFF ON OFF OFF 950mA 51V 91V OFF OFF ON ON 900mA 54V 91V OFF OFF ON OFF 850mA 57V 91V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST  96W AOC IP67 Driver Rev. D EUP-096S210ST Output Current Setting (Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 2100mA 24V 45.5V ON ON ON OFF 2000mA 24V 48V ON ON OFF ON 1900mA 26V 50.5V ON ON OFF OFF 1800mA 27V 53V ON OFF ON ON 1700mA 29V 56.5V ON OFF ON OFF 1600mA 30V 60V ON OFF OFF ON 1500mA 32V 64V ON OFF OFF OFF 1400mA 35V 69V OFF ON ON ON 1300mA 37V 69V OFF ON ON OFF 1200mA 40V 69V OFF ON OFF ON 1100mA 44V 69V OFF ON OFF OFF 1000mA 48V 69V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. EUP-096S215ST Output Current Setting (Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 2150mA 24V 44.5V ON ON ON OFF 2050mA 24V 46.5V ON ON OFF ON 1950mA 25V 49V ON ON OFF OFF 1850mA 26V 52V ON OFF ON ON 1750mA 28V 55V ON OFF ON OFF 1650mA 29V 55V ON OFF OFF ON 1550mA 31V 55V ON OFF OFF OFF 1450mA 33V 55V OFF ON ON ON 1350mA 36V 55V OFF ON ON OFF 1250mA 39V 55V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 11 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST  96W AOC IP67 Driver Rev. D EUP-096S350ST Output Current Setting (Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 3500mA 14V 27.5V ON ON ON OFF 3325mA 15V 28.5V ON ON OFF ON 3150mA 16V 30.5V ON ON OFF OFF 2975mA 16V 32V ON OFF ON ON 2800mA 17V 34V ON OFF ON OFF 2625mA 18V 36V ON OFF OFF ON 2450mA 20V 36V ON OFF OFF OFF 2275mA 21V 36V OFF ON ON ON 2100mA 23V 36V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. Notes: 1. Dip switch must be set in the setting range as specified to insure the driver operates as expected. 2. Endcap covering dip switch must be tight to insure IP67 rating. Mechanical Outline INPUT (UL SJTW 3*18AWG 7.8) OUTPUT (UL SJTW 2*18AWG 7.3) AC/L(BLACK) AC/N(WHITE) GND(GREEN) V+(RED) V-(BLUE) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 12 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxST 96W AOC IP67 Driver Rev. D Revision History Description of Change Change Date Rev. 2016-08-09 A Item B / / Features / Updated Models EUP-096S150ST Added Input Specifications PF/THD Updated Output Current Setting(Ioset) Range EUP-096S150ST Added with EUP-096S150ST Added No Load Output Voltage EUP-096S150ST Added Temperature Coefficient of Ioset Max 0.03%/C Typ 0.03%/C Efficiency at 120 Vac input EUP-096S150ST Added Efficiency at 220 Vac input EUP-096S150ST Added Efficiency at 277 Vac input EUP-096S150ST Added General Specifications Operating Case Temperature for Updated Warranty Tc_w Safety &EMC Compliance / Updated Efficiency vs. Load EUP-096S150ST Added Output Current vs. Dip Switch Setting EUP-096S150ST Added Description / Updated Models EUP-096S215ST Added Setting Range Output Current Setting(Ioset) Range Output Current Setting Range with Constant Power Output Specifications Output Specifications 2018-03-02 2018-04-20 C D To Datasheets Release Output Current Constant Power 2017/11/29 From Updated Updated Output Specifications No Load Output Voltage Updated General Specifications Efficiency at 120 Vac input: Updated General Specifications Efficiency at 220 Vac input: Updated General Specifications Efficiency at 270 Vac input: Updated Efficiency vs. Load EUP-096S215ST (Io=1750mA) EUP-096S215ST (Io=2150mA) Added Output Current vs. Dip-Switch Setting EUP-096S215ST Added Mechanical Outline / Updated 13 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUP-096S105ST 价格&库存
很抱歉,暂时无法提供与“EUP-096S105ST”相匹配的价格&库存,您可以联系我们找货
