EUV-036S024ST
EUV-036S024ST
    INVENTRONICS(英飞特)
    EUV Series 36 W 1.5 A 24 Vdc Out Max Outdoor Constant Voltage LED Driver
EUV-036S024ST 数据手册
EUV-036SxxxST 36W Constant Voltage IP67 Driver Rev. I Features  High Efficiency (Up to 87%)  Active Power Factor Correction (Typical 0.95)  Constant Voltage Output  Waterproof (IP67) and Damp & Wet location  All-Round Protection: OVP, SCP, OCP, OTP  Class 2 & SELV Output Description The EUV-036SxxxST Series operate from a 90 ~ 305 Vac input range. They are designed to be highly efficient and highly reliable. Features include over voltage protection, short circuit protection and over current protection. Models Input Voltage Range(1) Output Voltage Output Current Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac Power Factor Model Number 24 Vdc 90 ~ 305 Vac 0 ~ 1500 mA 36 W 85% 0.96 0.95 EUV-036S024ST (3) 36 Vdc 90 ~ 305 Vac 0 ~ 1000 mA 36 W 86% 0.96 0.95 EUV-036S036ST (4) 48 Vdc 90 ~ 305 Vac 36 W 87% 0.96 0.95 EUV-036S048ST (5) 0 ~ 750 mA Notes: (1) UL, FCC certified input voltage range: 100-277Vac; other certified input voltage range except UL & FCC: 100-240Vac. (2) Measured at full load and 220 Vac input. (3) Class 2 output (USR & CNR both) for wet location. (4) Class 2 output (USR); Class 2 output (CNR only) for wet location. (5) Class 2 output (USR), Non-Class 2 output (CNR). Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 V - 305 V Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.75 mA IEC60598-1; 240Vac/ 60Hz - - 0.6 A Measured at full load and 100 Vac input. - - 0.3 A Measured at full load and 220 Vac input. - - 60 A - - 2 0.2 A s 0.90 - - Leakage Current Input AC Current Inrush Current 2 Inrush Current(I t) Power Factor At 220Vac input 25℃ Cold Start. Duration=210μs, 10%Ipk-10%Ipk. At 100Vac-277Vac, 75%load-100%load 1/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-036SxxxST 36W Constant Voltage IP67 Driver Rev. I Input Specifications (Continued) Parameter Min. Typ. Max. - - 20% Min. Typ. Max. -5%Vo - 5%Vo - - 3V 4V 4V - - 28 V 40 V 52 V - - 10%Vo At full load condition. Line Regulation - - ±2% At full load condition. Load Regulation - - ±3% - 0.6 s 1.0 s - 0.3 s 0.5 s - 0.2%/C - THD Notes At 100Vac-277Vac, 75%load-100%load Output Specifications Parameter Output Voltage Tolerance Output Voltage Ripple(pk-pk) Vo = 24 V Vo = 36 V Vo = 48 V No Load Output Voltage Vo = 24 V Vo = 36 V Vo = 48 V Output Voltage Overshoot/ Undershoot Turn-on Delay Time Temperature Coefficient of Vo Notes Load conditions, Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Measured at 120Vac input, 75%load-100% load Measured at 220Vac input, 75%load-100% load Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Efficiency at 120 Vac input: VO = 24 V VO = 36 V VO = 48 V 83% 84% 85% 84% 85% 86% Efficiency at 220 Vac input: VO = 24 V VO = 36 V VO = 48 V 84% 85% 86% Efficiency at 277 Vac input: VO = 24 V VO = 36 V VO = 48 V No Load Power Dissipation MTBF Max. Notes - Measured at full load and steady-state temperature in 25C ambient. 85% 86% 87% - Measured at full load and steady-state temperature in 25C ambient. 84% 85% 86% 85% 86% 87% - Measured at full load and steady-state temperature in 25C ambient. - - 6W 371,000 hours - - Measured at 120Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) 2/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-036SxxxST 36W Constant Voltage IP67 Driver Rev. I General Specifications (Continued) Parameter Min. Typ. Max. - 111,700 Hours - Operating Case Temperature for Safety Tc_s -40 C - +90 C Operating Case Temperature for Warranty Tc_w -40 C - +70 C Humidity: 10% RH to 100% RH. Storage Temperature -40 C - +85 C Humidity: 5% RH to 100% RH Lifetime 6.77 × 1.77 × 1.38 172 × 45.0 × 35.0 Net Weight - 520 g Measured at 120Vac input, 80%Load, Case temperature=60℃ @ Tc point. See life time vs. Tc curve for the details With mounting ear 7.60 × 1.77 × 1.38 193 × 45.0 × 35.0 Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes - Note: All specifications are typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category Standard UL8750, UL1012, UL1310 Class 2, CSA-C22.2 No. 107.1, CSA C22.2 NO. 223-M91 Class 2 UL/CUL CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B This device complies with Part 15 of the FCC Rules. Operation is subject to the (1) FCC Part 15 following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT: Level 3, Criteria A EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS 3/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-036SxxxST 36W Constant Voltage IP67 Driver Rev. I Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature Efficiency vs. Load EUV-036S024ST EUV-036S036ST 4/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-036SxxxST 36W Constant Voltage IP67 Driver Rev. I EUV-036S048ST Power Factor Protection Functions Parameter Over Current Protection Min. Typ. Max. 1.1 Io 1.4 Io 1.70 Io Notes Hiccup mode. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. Short Circuit Protection No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. 5/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-036SxxxST 36W Constant Voltage IP67 Driver Rev. I Mechanical Outline INPUT(UL SJTW 3*18AWG AC/L (BLACK) AC/N (WHITE) GND (GREEN) 7.8 ) OUTPUT(UL SJTW 2*18AWG 7.3 ) V+ (RED) V- (BLACK) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2002/95/EC, calling for the elimination of lead and other hazardous substances from electronic products. 6/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-036SxxxST 36W Constant Voltage IP67 Driver Rev. I Revision History Description of Change Change Date Rev. 2012-4-24 A Datasheets Release / / 2012-05-25 B OTP / Added Life time vs. Tc Curve 2012-06-06 C / Added Notes of life time / Updated Description of OTP / Updated Max Case Temperature / Updated Mechanical Outline— wire length 320±20mm / Corrected Min Operating Temperature -35℃ -40℃ Derating Curve / Updated Inrush Current(I t) / Added Min PF / Added Max THD / Added Temperature co-efficient / Added Life time Min 50,000hrs Typical 111,700hrs Life time Curve / Updated Mechanical Outline / Updated Efficiency at 277 Vac input / Added Warranty Tc_w / Added Environmental Specifications / Deleted KS certificate Regulation / Added Note of EMI Standard / Added Derating Curve / Deleted Power Factor Curve / Updated Dimensions (L × W × H) 172 × 42.4 × 34.0 172 × 45.0 × 35.0 Net Weight 480 g 520 g Item 2012-07-02 D 2012-7-17 E 2012-7-30 F From 2 2012-8-16 2012-11-26 2017-04-05 G H I To Protection Functions - Over Temperature Protection / Updated Mechanical Outline Updated / 7/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-036S024ST 价格&库存
很抱歉,暂时无法提供与“EUV-036S024ST”相匹配的价格&库存,您可以联系我们找货
