EDC-100S105SV
EDC-100S105SV
    INVENTRONICS(英飞特)
EDC-100S105SV 数据手册
X EDC-100S105SV-000x 100W Constant Current IP67 Driver Rev. A Features  Low THD, 10% Max up to 240 Vac  High Efficiency (Up to 91%)  Input Surge Protection: 4kV line-line, 6kV line-earth   High Reliability & Long Lifetime: 96,000 Hrs. at 70°C Case Temperature Suitable for Independent Use and Class I Luminaires  Input UVP and Input OVP  Waterproof(IP67)  5 Years Warranty Description The EDC-100S105SV-000x is a 100W, constant-current, IP67 LED driver that operates from 140-305 Vac input with excellent power factor. It is created for high bay, tunnel and street lights. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Output Current Range Input Voltage Range(1)(2) Output Voltage Range Max. Output Power Typical Efficiency (3) Power Factor (3) 700 mA 140 ~ 305 Vac 71 ~ 143 Vdc 100 W 91.0% 0.96 EDC-100S105SV-0007 860 mA 140 ~ 305 Vac 58 ~ 116 Vdc 100 W 90.5% 0.96 EDC-100S105SV-0004 1050 mA 140 ~ 305 Vac 47 ~ 95 Vdc 100 W 90.0% 0.96 EDC-100S105SV Model Number Notes: (1) Certified input voltage range: 220-240Vac. (2) Operating input voltage range: 100-305Vac, and 100-140Vac is for safety operation. (3) Measured at full load and 220Vac input. Operating Area 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com X EDC-100S105SV-000x 100W Constant Current IP67 Driver Rev. A Input Specifications Parameter Min. Typ. Max. 140 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.66 A 2 - - 0.008 A s 0.90 - - THD - - 20% THD - - 10% Min. Typ. Max. Output Current Tolerance -8%Io - 8%Io At full load condition. Startup Overshoot Current - - 10%Iomax At full load condition No Load Output Voltage EDC-100S105SV-0007 EDC-100S105SV-0004 EDC-100S105SV - - 200 V 200 V 200 V Line Regulation - - ±5.0% Load Regulation - - ±5.0% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Iomax - 0.06%/C - Input Voltage Inrush Current(I t) PF Notes 2 IEC60598-1; 240Vac/60Hz Measured at full load and 220 Vac input. At 220Vac input, 25C cold start, duration=42 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 200-277Vac, 50-60Hz, 75%-100%load (75~100W) At 220-240Vac, 50-60Hz, 75%-100%load (75~100W) Output Specifications Parameter Notes Measured at full load Measured at 220Vac input, 75%-100%load Case temperature = 0C~Tc max Note: All specifications are tested by Cree XLamp XP-G2 and typical measured at 220Vac and 25C unless otherwise stated. General Specifications Parameter Efficiency at 220 Vac input: EDC-100S105SV-0007 EDC-100S105SV-0004 EDC-100S105SV MTBF Min. Typ. Max. 89.0% 88.5% 88.0% 91.0% 90.5% 90.0% - - 501,000 Hours - Notes Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com X EDC-100S105SV-000x 100W Constant Current IP67 Driver Rev. A General Specifications (Continued) Parameter Min. Typ. Max. Notes - 96,000 Hours - Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty. Humidity: 10%RH to 100%RH Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Lifetime Dimensions Inches (L × W × H) Millimeters (L × W × H) With mounting ear 6.54 x 2.66 x 1.44 166 x 67.5 x 36.5 5.71 x 2.66 x 1.44 145 x 67.5 x 36.5 Net Weight - 730 g - Note: All specifications are tested by Cree XLamp XP-G2 and typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category Standard BIS IS 15885(PART2/SEC13) CCC GB 19510.1, GB 19510.14 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com X EDC-100S105SV-000x 100W Constant Current IP67 Driver Rev. A Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature Inrush Current Waveform 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com X EDC-100S105SV-000x 100W Constant Current IP67 Driver Rev. A Efficiency vs. Load EDC-100S105SV(Io=1050mA) EDC-100S105SV-0004(Io=860mA) EDC-100S105SV-0007(Io=700mA) 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com X EDC-100S105SV-000x 100W Constant Current IP67 Driver Rev. A Power Factor Total Harmonic Distortion Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Under Voltage Protection Auto Recovery. Shut down when the input voltage falls below 100V. And the driver will restart when the input voltage is in normal. Input Over Voltage Protection Input Protection Voltage 320 Vac 340 Vac 360 Vac Recovery Voltage 300 Vac 320 Vac 340 Vac - - 440 Vac Max. of Input Over Voltage Turn off the output when the input voltage exceeds protection voltage. Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive for 48 hours with input over-voltage of 440Vac. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com X EDC-100S105SV-000x  100W Constant Current IP67 Driver Rev. A Input Over Voltage Protection Diagram Io Recovery Protection Vin 340 Vac 320 Vac   Mechanical Outline OUTPUT(VDE H05RN-F 2*1mm 2 6.8) INPUT(VDE H05RN-F 3*1.0mm 2 7.2) V+(BROWN) V-(BLUE) AC/L(BROWN) AC/N(BLUE) GND(YELLOW/GREEN) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com X EDC-100S105SV-000x 100W Constant Current IP67 Driver Rev. A Revision History Description of Change Change Date Rev. 2017-09-30 A Item From Datasheet Released / To / 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EDC-100S105SV 价格&库存
很抱歉,暂时无法提供与“EDC-100S105SV”相匹配的价格&库存,您可以联系我们找货
EDC-100S105SV
