EUV-250S024SV
EUV-250S024SV
    INVENTRONICS(英飞特)
EUV-250S024SV 数据手册
EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M Features  High Efficiency (Up to 93.5%)  Constant Voltage Output  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OVP, OCP, SCP, OTP  IP67  SELV Output  5 Years Warranty Description The EUV-250SxxxSV series is a 250W, constant-voltage LED driver that operates from 90-305 Vac input with excellent power factor. It is created for architecture lighting, decorative lighting, high bay, high mast, arena and roadway lights, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, over current, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac 12 Vdc 90 ~ 305 Vac 0~18.33 A 220 W 91.5% 0.99 0.93 EUV-250S012SV 24 Vdc 90 ~ 305 Vac 0~10.41 A 250 W 92.0% 0.99 0.96 EUV-250S024SV 28 Vdc 90 ~ 305 Vac 0~8.93 A 250 W 92.0% 0.99 0.96 EUV-250S028SV 36 Vdc 90 ~ 305 Vac 0~6.94 A 250 W 92.5% 0.99 0.96 EUV-250S036SV 42 Vdc 90 ~ 305 Vac 0~5.95 A 250 W 92.5% 0.99 0.96 EUV-250S042SV 48 Vdc 90 ~ 305 Vac 0~5.20 A 250 W 93.0% 0.99 0.96 EUV-250S048SV 54 Vdc 90 ~ 305 Vac 0~4.62 A 250 W 93.5% 0.99 0.96 EUV-250S054SV Power Factor Model Number (3) (4) Notes: (1) Certified input voltage range: 100-240Vac; (2) Measured at 100% load and 220 Vac input. (3) All the models are certificated to Global-mark, except EUV-250S012SV. (4) SELV output Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.75 mA At 240Vac/60Hz input , grounding effectively - - 3.0 A Measured at 100% load and 100 Vac input. - - 1.4 A Measured at 100% load and 220 Vac input. Input AC Current 1/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M Input Specifications (Continued) Parameter Min. Typ. Max. - - 2.33 A s 0.90 - - - - 20% Min. Typ. Max. Output Voltage Tolerance -5% - 5% Ripple and Noise (pk-pk) - - 2% VO Output Overshoot / Undershoot - - 10% When power on or off. Line Regulation - - ±1% At 100% load condition. Load Regulation - - ±3% - 0.4 s 1.0 s Measured at 120Vac input, 75%-100% Load - 0.4 s 1.0 s Measured at 220Vac input, 75%-100% Load Output Deviation - - 5% VO Settling Time - - 10 mS - 0.03%/C - 2 Inrush Current(I t) PF THD 2 Notes At 220Vac input, 25℃ cold start, duration=3 ms, 10%Ipk-10%Ipk. At 100-240Vac, 50-60Hz, 75%-100% Load (187.5-250W) Output Specifications Parameter Notes At 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Load Dynamic Response Temperature coefficient R/S: 1 A / uS Load: 25% ~ 75% 100% load. Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Efficiency at 220 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Min. Typ. Max. Notes 89.0% 89.5% 89.5% 90.0% 90.0% 90.5% 91.0% 89.5% 90.0% 90.0% 90.5% 90.5% 91.0% 91.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) 91.0% 91.5% 91.5% 92.0% 92.0% 92.5% 93.0% 91.5% 92.0% 92.0% 92.5% 92.5% 93.0% 93.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) 2/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M General Specifications (Continued) Parameter Min. Typ. Max. Efficiency at 277 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V 91.0% 91.5% 91.5% 92.0% 92.0% 92.5% 93.0% 91.5% 92.0% 92.0% 92.5% 92.5% 93.0% 93.5% - No Load Power Dissipation - - 5W MTBF - 250,000 hours - Lifetime - 59,400 hours - -40 C - +90 C -40 C - +60 C Case temperature for 5 years warranty -40 C - +85 C Humidity: 5% RH to 100% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches(L × W × H) Millimeters (L × W × H) - 1300 g Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) Measured at 120Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) Measured at 220Vac input, 80%Load and 60C case temperature; See life time vs. Tc curve for the details With mounting ear 9.88 × 3.54 × 1.46 251 × 90 × 37 8.82 × 3.54 × 1.46 224 × 90 × 37 Net Weight Notes - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 KS KS C 7655 Global Mark AS/NZS 61347.1, AS/NZS 61347.2.13 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test & Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards EN 61000-4-2 Notes Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge 3/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV (2) EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Curve EUV-250S012SV EUV-250S042SV Protection Functions Parameter Over Current Protection Min. Typ. Max. Notes 130% IO 165% IO 200% IO Hiccup mode. The power supply shall be selfrecovery when the fault condition is removed. Over Temperature Protection Auto Recovery, returning to normal after over temperature is removed. Short Circuit Protection No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 4/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M Mechanical Outline EUV-250S012SV INPUT (VDE H05RN-F 3*1.0mm2 7.2) OUTPUT (VDE H05RN-F 2*1.0mm2 6.8) AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN ) V+ (BROWN) V- (BLUE) V+ (BROWN) V- (BLUE) V+ (BROWN) V- (BLUE) Tc PROJ: Unspecified tolerance:±1 2 Note: The 3 DC output cables are connected in parallel internally because one 1.0mm wire can only carry 10A. Please connect the 3 brown wires together and 3 blue wires together in application, or ensure each cable carries same current. EUV-250S024/036SV INPUT (VDE H05RN-F 3*1.0mm2 OUTPUT (VDE H05RN-F 2*1.0mm 2 7.2) AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN ) 6.8) V+ (BROWN) V- (BLUE) V+ (BROWN) V- (BLUE) Tc PROJ: Unspecified tolerance:±1 2 Note: The 2 DC output cables are connected in parallel internally because one 1.0mm wire can only carry 10A. Please connect the 2 brown wires together and 2 blue wires together in application, or ensure each cable carries same current. 5/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M EUV-250S028/042SV INPUT (VDE H05RN-F 3*1.0mm2 7.2) OUTPUT (VDE H07RN-F 2*1.5mm2 9.4) V+ (BROWN) V- (BLUE) AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN ) Tc PROJ: Unspecified tolerance:±1 EUV-250S048/054SV INPUT (VDE H05RN-F 3*1.0mm2 7.2) OUTPUT (VDE H05RN-F 2*1.0mm 2 6.8) V+ (BROWN) V- (BLUE) AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN ) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 6/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M Revision History Change Date Description of Change Rev. Item From To Add a new model of 28V 2010-03-11 A Add Leakage Current in Input Specifications Standardize the tolerance in Mechanical Outline Change Input AC Current @220Vac 2011-01-14 2011-07-30 2012-06-18 2012-07-17 2012-11-15 B C D E F / Max. 0.75 mA At 277Vac 50Hz input / / 1.3 A 1.4 A Min. 89.5% 92.0% 92.0% 92.0% Min. Change the efficiency (220Vac) VO = 12 V 91.5% Change the efficiency (120Vac) VO = 12 V VO = 84 V VO = 105 V VO = 150 V Typ. 90.0% 92.5% 92.5% 92.5% Typ. 92.0% Min. 89.0% 91.0% 91.0% 91.0% Min. 91.0% Typ. 89.5% 91.5% 91.5% 91.5% Typ. 91.5% Change No Load Power Dissipation ≤3 W ≤5 W Update MTBF & Life Time Data For One Model For Two Models Update Life Time Data Ta=45℃ Tc=80℃ Mechanical Outline / Updated Vo=52V, 56V, 60V, 84V,105 V & 150V Models / Deleted Life time Curve / Added EN61000-4-5 line to line 2 kV, line to earth 4 line to line 4 kV, line to earth 6 kV kV Max Case Temperature / Updated Efficiency of 24V,28V,36V,42V / 0.5%,1.5% or 2% lower Operating Temperature -35 ℃ -40 ℃ Derating Curve / Updated 2013-02-26 G Efficiency of 42V,48V,54V / 0.5% lower 2013-03-11 H Over Current Protection 110%,155%,180% 130%,165%,200% Inrush current 50A 150A Min PF and max THD / Added Temperature coefficient / Added Life time / Updated Life time curve / Updated Input AC current@100Vac Max 2.8A Typ2.8A, Max3.0A Turn-on delay time 0.1s,0.2s 0.2s,0.5s Mechanical Outline---tolerance standardized / Corrected 2013-04-02 I 7/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M Revision History (Continued) Description of Change Change Date Rev. 2013-12-13 J Item From Turn-on delay time 0.2s,0.5s 0.4s,1.0s Format / Update External Grounding Screw Solution / / Features / Update Description 2015-09-10 K Update Models Notes Update General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature Added for Warranty Tc_w General Specifications Storage Temperature Added Environmental Specifications / Delete Safety & EMC Compliance Protection Functions Dimming Control Mechanical Outline 2017-08-14 2019-09-19 To / Update / Update / Update / Update CB/CCC/PSE/KS / Added Description / Updated Input Specifications PF/THD Updated Output Specifications Turn-on Delay Time Updated Temperature Coefficient Max 0.02%/C Typ 0.03%/C Dimensions 8.82 × 3.46 × 1.32 224 × 88 × 33.5 8.82 × 3.54 × 1.46 224 × 90 × 37 Safety & EMC Compliance / Updated Mechanical Outline / Updated PSE Logo / Updated Global Mark Logo / Updated Independent Logo / Added Features 4kV line-line, 6kV line-earth DM 4kV, CM 6kV Features Waterproof(IP67) IP67 Features Suitable for Independent Use Deleted Features 5 Years Warranty L M Added 8/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxSV 250W Constant Voltage IP67 Driver  Rev. M Revision History (Continued) Change Date 2019-09-19 Description of Change Rev. Item M From To General Specifications Operating Case Temperature Added for Warranty Tc_w- Notes Safety &EMC Compliance CB Added Safety &EMC Compliance CCC Added Safety &EMC Compliance PSE Added Safety &EMC Compliance KS Added Safety &EMC Compliance Global Mark Added Safety &EMC Compliance EN 55015 EN 55015/GB 17743 Safety &EMC Compliance EN 61000-3-2 EN 61000-3-2/GB 17625.1 Safety &EMC Compliance EN 61000-4-5 Updated Derating Curve / Deleted RoHS Compliance / Updated 9/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-250S024SV 价格&库存
很抱歉,暂时无法提供与“EUV-250S024SV”相匹配的价格&库存,您可以联系我们找货
EUV-250S024SV
