ESD-480S280DV
ESD-480S280DV
    INVENTRONICS(英飞特)
ESD-480S280DV 数据手册
ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B Features  Ultra High Efficiency (Up to 95%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  Isolated 0-10V/PWM/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 1.5 W  Output Lumen Compensation  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP67  SELV Output  5 Years Warranty Description The ESD-480SxxxDV series is a 480W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, aquaculture and sports, etc, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Default Current Output Range(1) Current 0.105-1.40A 1.05A-1.40A 0.210-2.80A 2.10-2.80A 0.315-4.20A 3.15-4.20A 0.435-5.60A 4.35-5.60A 0.750-10.0A 7.50-10.0A Input Voltage Range(2) 249~528Vac 352~500Vdc 249~528Vac 2.8 A 352~500Vdc 249~528Vac 4.2 A 352~500Vdc 249~528Vac 5.6 A 352~500Vdc 249~528Vac 10.0 A 352~500Vdc 1.4 A Output Voltage Range Max. Typical Power Factor Output Efficiency 277Vac 480Vac Power (3) Model Number (5) 171 ~ 457Vdc 480 W 95.0% 0.96 0.95 ESD-480S140DV 86 ~ 228Vdc 480 W 94.5% 0.96 0.95 ESD-480S280DV 57 ~ 152Vdc 480 W 94.0% 0.96 0.95 ESD-480S420DV 43 ~ 110Vdc 480 W 93.5% 0.96 0.95 ESD-480S560DV 24 ~ 64Vdc 93.5% 0.96 0.95 ESD-480S10ADV 480 W (4) (4) Notes: (1) Output current range with constant power at 480W. (2) Certified input voltage range: 277-480Vac or 352-500Vdc. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV output. . (5) All the models are certificated to Global Mark, except ESD-480S560DV and ESD-480S10ADV. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B I-V Operating Area ESD-480S140DV ESD-480S280DV ESD-480S420DV ESD-480S560DV ESD-480S10ADV 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B Input Specifications Parameter Min. Typ. Max. 249 Vac - 528 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input Voltage - - 2.09 A - - 1.21 A - - 13.8 A s 0.90 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 105 mA 210 mA 315 mA 435 mA 750 mA - 1400 mA 2800 mA 4200 mA 5600 mA 10000 mA 1050 mA 2100 mA 3150 mA 4350 mA 7500 mA - 1400 mA 2800 mA 4200 mA 5600 mA 10000 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESD-480S140DV ESD-480S280DV ESD-480S420DV ESD-480S560DV ESD-480S10ADV - - 500 V 280 V 190 V 120 V 80 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Input AC Current 2 Inrush Current(I t) PF THD 2 Notes 352-500Vdc IEC60598-1; 480Vac/60Hz Measured at 100% load and 277 Vac input. Measured at 100% load and 480 Vac input. At 480Vac input, 25℃ cold start, duration=840 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 277-480Vac, 50-60Hz, 60%-100% load (288-480W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESD-480S140DV ESD-480S280DV ESD-480S420DV ESD-480S560DV ESD-480S10ADV Output Current Setting Range with Constant Power ESD-480S140DV ESD-480S280DV ESD-480S420DV ESD-480S560DV ESD-480S10ADV Total Output Current Ripple (pk-pk) Notes At 100% load condition At 100% load condition, 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B Output Specifications (Continued) Parameter Min. Typ. Max. Notes Turn-on Delay Time - - 0.5 s Measured at 277-480Vac input, 60%-100% load Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Return terminal is “Dim−“ - - 400 mA 400mA peak for a maximum duration of 300ms in a 2s period during which time the average should not exceed 200mA. 12V Auxiliary Output Transient Peak Current Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 277 Vac input: ESD-480S140DV Io= 1050 mA Io= 1400 mA ESD-480S280DV Io= 2100 mA Io= 2800 mA ESD-480S420DV Io= 3150 mA Io= 4200 mA ESD-480S560DV Io= 4350 mA Io= 5600 mA ESD-480S10ADV Io= 7500 mA Io= 10000 mA Efficiency at 347 Vac input: ESD-480S140DV Io= 1050 mA Io= 1400 mA ESD-480S280DV Io= 2100 mA Io= 2800 mA ESD-480S420DV Io= 3150 mA Io= 4200 mA ESD-480S560DV Io= 4350 mA Io= 5600 mA ESD-480S10ADV Io= 7500 mA Io= 10000 mA Min. Typ. Max. 92.0% 91.5% 94.0% 93.5% - 91.5% 90.5% 93.5% 92.5% - 91.0% 90.5% 93.0% 92.5% - 90.5% 90.0% 92.5% 92.0% - 90.5% 89.0% 92.5% 91.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.0% 94.0% 93.0% - 91.5% 91.0% 93.5% 93.0% - 91.0% 90.5% 93.0% 92.5% - 91.0% 89.5% 93.0% 91.5% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B General Specifications (Continued) Parameter Min. Typ. Max. 93.0% 92.0% 95.0% 94.0% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.0% 94.0% 93.0% - 91.5% 91.0% 93.5% 93.0% - 91.5% 89.5% 93.5% 91.5% - Standby Power - - 1.5 W MTBF - 210,000 Hours - Lifetime - 102,000 Hours - -40°C - +85C -40°C - +75C -40°C - +85°C Efficiency at 480 Vac input: ESD-480S140DV Io= 1050 mA Io= 1400 mA ESD-480S280DV Io= 2100 mA Io= 2800 mA ESD-480S420DV Io= 3150 mA Io= 4200 mA ESD-480S560DV Io= 4350 mA Io= 5600 mA ESD-480S10ADV Io= 7500 mA Io= 10000 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Net Weight Humidity: 5%RH to 100%RH With mounting ear 10.3 x 4.92 x 1.71 262 x 125 x 43.5 9.25 x 4.92 x 1.71 235 x 125 x 43.5 - Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes 2650 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 μA 300 μA 450 μA Dimming Output Range ESD-480S140DV ESD-480S280DV ESD-480S420DV ESD-480S560DV ESD-480S10ADV 10%Ioset - Ioset ESD-480S140DV ESD-480S280DV ESD-480S420DV ESD-480S560DV ESD-480S10ADV 105 mA 210 mA 315 mA 435 mA 750 mA - Ioset Notes Vdim(+) = 0 V 1050mA ≤ Ioset ≤ 1400mA 2100mA ≤ Ioset ≤ 2800mA 3150mA ≤ Ioset ≤ 4200mA 4350mA ≤ Ioset ≤ 5600mA 7500mA ≤ Ioset ≤ 10000mA 105mA ≤ Ioset < 1050mA 210mA ≤ Ioset < 2100mA 315mA ≤ Ioset < 3150mA 435mA ≤ Ioset < 4350mA 750mA ≤ Ioset < 7500mA 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B Dimming Specifications (Continued) Parameter Min. Typ. Max. Recommended Dimming Input Range 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category CE & ENEC CB Standard EN 61347-1, EN61347-2-13 IEC 61347-1, IEC 61347-2-13 Global Mark AS/NZS 61347.1, AS/NZS 61347.2.13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS (2) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B Efficiency vs. Load ESD-480S140DV(Io=1050mA) ESD-480S140DV(Io=1400mA) ESD-480S280DV(Io=2100mA) ESD-480S280DV(Io=2800mA) ESD-480S420DV(Io=3150mA) ESD-480S420DV(Io=4200mA) 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B ESD-480S560DV(Io=4350mA) ESD-480S560DV(Io=5600mA) ESD-480S10ADV(Io=7500mA) ESD-480S10ADV(Io=10000mA) Power Factor 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDV 480W Programmable IP67 Driver Rev. B Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming Implementation 2: Positive logic Implementation 3: Negative logic   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESD-480S280DV 价格&库存
很抱歉,暂时无法提供与“ESD-480S280DV”相匹配的价格&库存,您可以联系我们找货
