EUC-035S105STM0003
EUC-035S105STM0003
    INVENTRONICS(英飞特)
EUC-035S105STM0003 数据手册
EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D Features  Low THD, 10% Max up to 240Vac  Compact Metal Case with Excellent Thermal Performance  Input Surge Protection: DM 4kV, CM 6kV  High Reliability & Long Lifetime: 80,000 hrs. at 70C Case Temperature  Suitable for Built-in Use and Class I Luminaires  Input UVP and Input OVP  IP66 and UL Dry / Damp Location  Class 2 & SELV Output  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location  5 Years Warranty Description The EUC-035SxxxSTM000x series is a 35W, constant-current IP66 LED driver that operates from 90-305 Vac input with excellent power factor and THD feature. It is created for many lighting applications including low bay, tunnel and street lights, etc. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Output Current 500 mA 700 mA 860 mA 1050 mA Input Voltage Range(1) 90 ~ 305 Vac 127 ~ 300 Vdc 90 ~ 305 Vac 127 ~ 300 Vdc 90 ~ 305 Vac 127 ~ 300 Vdc 90 ~ 305 Vac 127 ~ 300 Vdc Output Voltage Range Max. Typical Output Efficiency Power (2) Typical Power Factor 120 Vac 220 Vac Model Number (3) 32 ~ 64 Vdc 32 W 87.0% 0.99 0.96 EUC-035S070STM0004 25 ~ 47 Vdc 33 W 86.0% 0.99 0.96 EUC-035S105STM0007(4) 20 ~ 41 Vdc 35 W 86.0% 0.99 0.96 EUC-035S105STM0004(4) 18 ~ 33 Vdc 35 W 86.0% 0.99 0.96 EUC-035S105STM(4) Notes: (1) UL, FCC certified input voltage range: 120-277Vac or 127-300Vdc; other certified input voltage range except UL & FCC: 120-240Vac or 127-250Vdc. (2) Measured at 100% load and 220 Vac input. (3) SELV output. (4) Class 2 output. Input Specifications Parameter Input AC Voltage Min. Typ. Max. 90 Vac - 305 Vac Notes 1/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D Input Specifications (Continued) Parameter Min. Typ. Max. Notes Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 0.42 A Measured at 100% load and 120 Vac input. - - 0.2 A Measured at 100% load and 220 Vac input. - - 0.002 A2s 0.90 - - - - 15% - - 10% Min. Typ. Max. -8%Io - 8%Io At 100% load condition Total Output Current Ripple (pk-avg) - 50%Io 75%Io At 100% load condition Startup Overshoot Current - - 10%Io At 100% load condition No Load Output Voltage EUC-035S070STM0004 EUC-035S105STM0007 EUC-035S105STM0004 EUC-035S105STM - - 82 V 60 V 60 V 60 V Line Regulation - - ±5.0% Load Regulation - - ±5.0% - 1.5 s 2.0 s - 1.0 s 1.5 s - 0.06%/C - Leakage Current Input AC Current Inrush Current(I2t) PF THD At 220Vac input, 25℃ cold start, duration=40 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 120-277Vac, 50-60Hz, 75%-100%Load (26~35W) 120-240Vac, 50-60Hz, 75%-100%Load (26~35W) Output Specifications Parameter Output Current Tolerance Turn-on Delay Time Temperature Coefficient of Iomax Notes Measured at 100% load Measured at 120Vac input, 75%-100%Load. Measured at 220Vac input, 75%-100%Load. Case temperature = 0C ~Tc max Note: All specifications are tested by Cree XLamp XP-G and typical measured at 220Vac and 25°C unless otherwise stated. 2/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D General Specifications Parameter Min. Typ. Max. Notes 85.0% 84.0% 84.0% 83.5% 86.0% 85.0% 85.0% 84.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) 86.0% 85.0% 85.0% 85.0% 87.0% 86.0% 86.0% 86.0% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) 86.0% 85.0% 85.0% 85.0% 87.0% 86.0% 86.0% 86.0% - MTBF - 1172,000 Hours Lifetime - 80,000 Hours - -40 C - +90 C -40 C - +75 C Case temperature for 5 years warranty. Humidity: 10% RH to 95% RH; -40 C - +85C Humidity: 5%RH to 95%RH; Efficiency at 120 Vac input: EUC-035S070STM0004 EUC-035S105STM0007 EUC-035S105STM0004 EUC-035S105STM Efficiency at 220 Vac input: EUC-035S070STM0004 EUC-035S105STM0007 EUC-035S105STM0004 EUC-035S105STM Efficiency at 277 Vac input: EUC-035S070STM0004 EUC-035S105STM0007 EUC-035S105STM0004 EUC-035S105STM Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) - With mounting ear 3.82 × 2.52 × 1.26 97 × 64 × 32 3.15 × 2.52 × 1.26 80 × 64 × 32 Net Weight - 330 g Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details - Note: All specifications are tested by Cree XLamp XP-G and typical at 25°C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE & TUV EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC KS NOM GB 19510.1, GB 19510.14 KS C 7655 NOM-058-SCFI EMI Standards EN 55015/GB 17743(1) EN 61000-3-2/GB 17625.1 Notes Conducted emission Test &Radiated emission Test Harmonic current emissions 3/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D Safety & EMC Compliance (Continued) EMI Standards EN 61000-3-3 Notes Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 4/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUC-035S070STM0004(Io=500mA) EUC-035S105STM(Io=1050mA) 5/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D EUC-035S105STM0004(Io=860mA) EUC-035S105STM0007(Io=700mA) Power Factor Total Harmonic Distortion 6/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D Protection Functions Parameter Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Input Under Voltage Protection Input Protection Voltage Input Over Voltage Protection Recovery Voltage Max. of Input Over Voltage  Min. Auto Recovery. Turn off the output when the input voltage falls below 80±10V. And the driver will restart when the input voltage exceeds 85±10V. Turn off the output when the input voltage 305 Vac 315 Vac 325 Vac exceeds protection voltage. Auto Recovery. The driver will restart when 290 Vac 310 Vac 330 Vac the input voltage falls below recovery voltage. - - 380 Vac Input Over Voltage Protection Diagram Io Recovery Protection 315 Vac 310 Vac Vin 7/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D G W A 8 1 5 1 0 1 L U T U P N I Mechanical Outline ( OUTPUT (UL1015 18AWG) ) Tc N E E R G AC/L (BLACK) AC/N (WHITE) GND ( ) V+ (RED) V- (BLUE) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 8/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-035SxxxSTM000x 35W Constant Current IP66 Driver Rev. D Revision History Description of Change Change Date Rev. 2016-04-29 A Item From Datasheet Release / / Input Voltage Range(Vac) 108 ~ 305 Vac 90 ~ 305 Vac Input Voltage Range(Vdc) 127 ~ 300 Vdc Deleted EUC035S070STM0000 EUC035S105STM0000 Total Output Current Ripple (pk-pk) Max.= 150%lo Total Output Current Ripple (pk-avg) Max.= 75%Io FCC Certificate Regulation / Added Derating Curve / Added Features / Updated Description / Updated Models - EUC-035S070STM0000 / Deleted Models - EUC-035S105STM0007 / Added MTBF Min.=600,000Hours Typ.=1172,000 Hours Protection Functions - Recovery Voltage / Added Protection Functions - Max. of Input Over Voltage / Added Input Over Voltage Protection Diagram / Added BIS / Deleted NOM / Added Features / Updated Model Number - EUC-036S070STM(Io=700mA) 2016-12-26 B Model Number - EUC-035S105STM(Io=1050mA) Total Output Current Ripple 2017-03-21 To EUC-035S105STM C Description 2021-08-26 EUC-035S070STM Updated Models Input Voltage Range(1) Updated Models Notes: (1) Updated Input Specifications Input DC Voltage Added Safety & EMC Compliance TUV/ CB/ CCC/ NOM Added Safety & EMC Compliance EN 61000-4-5 Updated RoHS Compliance / Updated D 9/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com
EUC-035S105STM0003 价格&库存
很抱歉,暂时无法提供与“EUC-035S105STM0003”相匹配的价格&库存,您可以联系我们找货
EUC-035S105STM0003
