EUC-052S140ST
EUC-052S140ST
    INVENTRONICS(英飞特)
    EUC Series 52 W 1.4 A Dimmable Outdoor Constant Current LED Driver Module
EUC-052S140ST 数据手册
EUD-200SxxxDD 200W Class II Programmable IP67 Driver Rev. D Features  Ultra High Efficiency (Up to 93.0%)  Full Power at Wide Output Current Range (Constant Power)  0-10V/PWM/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤1 W  Output Lumen Compensation  Input Surge Protection: DM 6kV  All-Around Protection: OVP, SCP, OTP  IP67  Class II, Double Insulation  Suitable for Built-in Use  5 Years Warranty Description The EUD-200SxxxDD series is a 200W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast and roadway, etc, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) 90~305 Vac 120~285Vdc 200 W 127~250 Vdc 90~305 Vac 105-1500mA 1050-1500mA 1400 mA 80~190Vdc 200 W 127~250 Vdc 70-1050mA 700-1050mA 700 mA Model Number (4) 93.0% 0.99 0.96 EUD-200S105DD 93.0% 0.99 0.96 EUD-200S150DD Notes: (1) Output current range with constant power at 200W (2) Certified input voltage range: 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to KS, except EUD-200S105DD 1 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxDD 200W Class II Programmable IP67 Driver Rev. D I-V Operating Area EUD-200S105DD EUD-200S150DD 240 (105,190) (630,190) (1050,190) (10%Ioset,200/Ioset) (Ioset,200/Ioset) 160 10 0% ad Lo % 60 Output Voltage (V) 200 120 Lo ad (1500,133) (1500,80) 80 (Ioset,80) (150,80) 40 0 0 Good Performance Area Allowed Operating Area Programmed Operating Area 300 1200 600 900 1500 1800 Output Current (mA) Note: 1050mA Ioset 1500mA Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 2.0A Measured at 100% load and 120 Vac input. - - 1.0 A Measured at 100% load and 220 Vac input. - - 5.97 A s 0.90 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA - 1050 mA 1500 mA 700 mA 1050 mA - 1050 mA 1500 mA - 5%Iomax 10%Iomax - 2%Iomax - Input AC Current 2 Inrush Current(I t) PF THD Notes 2 127~250 Vdc IEC60598-1; 240Vac/ 60Hz At 220Vac input, 25C cold start, duration=1.36 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (120-200W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-200S105DD EUD-200S150DD Output Current Setting Range with Constant Power EUD-200S105DD EUD-200S150DD Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes 100% load 100% load, 20 MHz BW 100% load 2 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxDD 200W Class II Programmable IP67 Driver Rev. D Output Specifications (Continued) Parameter Min. Typ. Max. Notes Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-200S105DD EUD-200S150DD - - 330 V 220 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - 1.0 s 2.0 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA 100% load 100% load Measured at 120Vac and 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 88.0% 88.0% 90.0% 90.0% - 89.0% 88.0% 91.0% 90.0% - 91.0% 91.0% 93.0% 93.0% - 91.0% 90.5% 93.0% 92.5% - 91.5% 91.0% 93.5% 93.0% - 91.5% 91.0% 93.5% 93.0% - Standby power - 1W - MTBF - 288,000 Hours - Lifetime - 100,000 Hours - -40°C - +90°C -40°C - +70°C Case temperature for 5 years warranty -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 120 Vac input: EUD-200S105DD Io=700 mA Io=1050 mA EUD-200S150DD Io=1050 mA Io=1500 mA Efficiency at 220 Vac input: EUD-200S105DD Io=700 mA Io=1050 mA EUD-200S150DD Io=1050 mA Io=1500 mA Efficiency at 277 Vac input: EUD-200S105DD Io=700 mA Io=1050 mA EUD-200S150DD Io=1050 mA Io=1500 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 60C case temperature; See lifetime vs. Tc curve for the details 3 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxDD 200W Class II Programmable IP67 Driver Rev. D General Specifications (Continued) Parameter Min. Typ. Max. Notes Dimensions Inches (L × W × H) Millimeters (L × W × H) With mounting ear 9.88 × 2.66 × 1.56 251 × 67.5 × 39.5 8.82 × 2.66 × 1.56 224 × 67.5 × 39.5 Net Weight - 1200 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 μA 300 μA 450 μA 10%Ioset - Ioset 70mA 105mA - Ioset 0V - 10 V Dim off Voltage 0.4 V 0.55V 0.7 V Dim on Voltage 0.6 V 0.75 V 0.9 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range EUD-200S105DD EUD-200S150DD EUD-200S105DD EUD-200S150DD Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 700mA ≤ Ioset ≤ 1050mA 1050mA ≤ Ioset ≤ 1500mA 70mA ≤ Ioset < 700mA 105mA ≤ Ioset < 1050mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category Standard (1) ENEC & TUV & CE EN 61347-1 , EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 KS KS C 7655 4 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxDD 200W Class II Programmable IP67 Driver Rev. D Safety &EMC Compliance (Continued) EMI Standards (2) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This product meets all requirements for EN 61347-1, Annex O (Double insulation). However, the allowed leakage current could cause a mild shock if the case is touched while energized. (2) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature 5 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxDD 200W Class II Programmable IP67 Driver Rev. D Inrush Current Waveform Efficiency vs. Load EUD-200S105DD(Io=700mA) EUD-200S105DD(Io=1050mA) EUD-200S150DD(Io=1050mA) EUD-200S150DD(Io=1500mA) 6 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxDD 200W Class II Programmable IP67 Driver Rev. D Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. 7 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxDD 200W Class II Programmable IP67 Driver Rev. D Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic Implementation 3: Negative logic 8 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxDD   200W Class II Programmable IP67 Driver Rev. D Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUC-052S140ST 价格&库存
很抱歉,暂时无法提供与“EUC-052S140ST”相匹配的价格&库存,您可以联系我们找货
