EUG-150S210DT
EUG-150S210DT
    INVENTRONICS(英飞特)
    EUG Series 150 W 1.4 A 107 Vdc Out Max Programmable Outdoor Driver
EUG-150S210DT 数据手册
EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Features • Ultra High Efficiency (Up to 93.5%) • Full Power at Wide Output Current Range (Constant Power) • 0-5V/0-10V/PWM/Timer Dimmable • Input Surge Protection: 6kV line-line, 10kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) and UL Dry / Damp / Wet Location • SELV Output • TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location • UL Type TL (Temperature Limited) • 7 Years Warranty Description The EUG-150SxxxDT series is a 150W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, tunnel and roadway lights. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current 45-700mA 450-700mA 530 mA 70-1050mA 700-1050mA 700 mA 140-2100mA 1400-2100mA 1400 mA 245-3500mA 2450-3500mA 3150 mA 385-5600mA 3850-5600mA 4200 mA Input Voltage Range(2) 90~305 Vac 100~300 Vdc 90~305 Vac 100~300 Vdc 90~305 Vac 100~300 Vdc 90~305 Vac 100~300 Vdc 90~305 Vac 100~300 Vdc Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Output Voltage Range Model Number (4) 117~333Vdc 150 W 93.5% 0.99 0.96 EUG-150S070DT 75~214Vdc 150 W 93.5% 0.99 0.96 EUG-150S105DT 38~107Vdc 150 W 92.5% 0.99 0.96 EUG-150S210DT (5) 22 ~ 61Vdc 150 W 92.0% 0.99 0.96 EUG-150S350DT (5) 14 ~ 39Vdc 150 W 92.0% 0.99 0.96 EUG-150S560DT (5) Notes: (1) Output current range with constant power at 150W (2) Certified input voltage range: UL, FCC 100-277Vac or 100-300Vdc; otherwise 100-240Vac or 100-250Vdc (except KS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to KS, except EUG-150S070DT (5) SELV Output. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F I-V Operation Area EUG-150S070DT EUG-150S105DT EUG-150S210DT EUG-150S350DT ad Lo % 70 Output Voltage(V) EUG-150S560DT 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60 Hz - - 0.70 mA IEC60598-1; 240Vac/ 60 Hz - - 1.87 A Measured at full load and 100 Vac input. - - 0.81 A Measured at full load and 220 Vac input. - - 1.98 A s 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (112.5-150 W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 45 mA 70 mA 140 mA 245 mA 385 mA - 700 mA 1050 mA 2100 mA 3500 mA 5600 mA 450 mA 700 mA 1400 mA 2450 mA 3850 mA - 700 mA 1050 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUG-150S070DT EUG-150S105DT EUG-150S210DT EUG-150S350DT EUG-150S560DT - - 370 V 235 V 120 V 75 V 48 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Leakage Current Input AC Current Notes 100-300Vdc At 220Vac input, 25℃ cold start, 2 Inrush Current(I t) PF 2 duration=712 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (105-150 W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUG-150S070DT EUG-150S105DT EUG-150S210DT EUG-150S350DT EUG-150S560DT Output Current Setting Range with Constant Power EUG-150S070DT EUG-150S105DT EUG-150S210DT EUG-150S350DT EUG-150S560DT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition, 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. At full load condition Measured at full load 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUG-150S070DT Io= 450 mA Io= 700 mA EUG-150S105DT Io= 700 mA Io=1050 mA EUG-150S210DT Io=1400 mA Io=2100 mA EUG-150S350DT Io=2450 mA Io=3500 mA EUG-150S560DT Io=3850 mA Io=5600 mA Efficiency at 220 Vac input: EUG-150S070DT Io= 450 mA Io= 700 mA EUG-150S105DT Io= 700 mA Io=1050 mA EUG-150S210DT Io=1400 mA Io=2100 mA EUG-150S350DT Io=2450 mA Io=3500 mA EUG-150S560DT Io=3850 mA Io=5600 mA Min. Typ. Max. 87.5% 87.0% 90.5% 90.0% - 88.0% 87.0% 91.0% 90.0% - 87.0% 87.0% 90.0% 90.0% - 87.0% 86.5% 90.0% 89.5% - 86.5% 85.0% 89.5% 88.0% - 91.5% 90.5% 93.5% 92.5% - 91.5% 90.5% 93.5% 92.5% - 90.5% 90.0% 92.5% 92.0% - 90.0% 90.0% 92.0% 92.0% - 90.0% 88.5% 92.0% 90.5% - Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 91.0% 94.0% 93.0% - 91.5% 91.0% 93.5% 93.0% - 91.0% 90.0% 93.0% 92.0% - 90.5% 90.5% 92.5% 92.5% - 90.0% 88.5% 92.0% 90.5% - MTBF - 271,000 Hours - Lifetime - 99,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Operating Case Temperature for Type TL Tc_TL -40°C - +78°C Storage Temperature -40°C - +85°C Efficiency at 277 Vac input: EUG-150S070DT Io= 450 mA Io= 700 mA EUG-150S105DT Io= 700 mA Io=1050 mA EUG-150S210DT Io=1400 mA Io=2100 mA EUG-150S350DT Io=2450 mA Io=3500 mA EUG-150S560DT Io=3850 mA Io=5600 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220 Vac input, 80%Load and 25 °C ambient temperature (MIL-HDBK217F) Measured at 220 Vac input, 80%Load and 70 °C case temperature; See lifetime vs. Tc curve for the details 1100 g Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Humidity: 5%RH to 100%RH With mounting ear 8.23 × 2.66 × 1.56 209 × 67.5 × 39.7 7.40 × 2.66 × 1.56 188 × 67.5 × 39.7 - Notes - Note: All specifications are typical at 25°C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA Notes Vdim(+) = 0 V 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Dimming Specifications (Continued) Parameter Min. Typ. Max. Notes 450 mA ≤ Ioset ≤ 700 mA 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2450 mA ≤ Ioset ≤ 3500 mA 3850 mA ≤ Ioset ≤ 5600 mA 45 mA ≤ Ioset < 450 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 245 mA ≤ Ioset < 2450 mA 385 mA ≤ Ioset < 3850 mA EUG-150S070DT EUG-150S105DT EUG-150S210DT EUG-150S350DT EUG-150S560DT 10%Ioset - Ioset EUG-150S070DT EUG-150S105DT EUG-150S210DT EUG-150S350DT EUG-150S560DT 45 mA 70 mA 140 mA 245 mA 385 mA - Ioset 0V - 5V Dimming mode set to 0-5V in PC interface. 0V - 10 V Default 0-10V dimming mode with positive logic. PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Dimming Output Range Recommended Dimming Range for 0-5 V Recommended Dimming Range for 0-10 V PWM_in Duty Cycle Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25°C unless otherwise stated. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Efficiency vs. Load EUG-150S070DT(Io=450mA) EUG-150S070DT(Io=700mA) EUG-150S105DT(Io=700mA) EUG-150S105DT(Io=1050mA) EUG-150S210DT(Io=1400mA) EUG-150S210DT(Io=2100mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F EUG-150S350DT(Io=2450mA) EUG-150S350DT(Io=3500mA) EUG-150S560DT(Io=3850mA) EUG-150S560DT(Io=5600mA) Power Factor 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-5V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Implementation 2: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-5V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-5V dimming is not used, Dim + should be open. 4. When 0-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 4. When 0-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 5: Positive logic Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. 12 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F  Time Dimming Set the timing curve by pulling the sliders. Programming Connection Diagram Note: The driver does not need to be powered on during the programming process. 13 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT  150W Programmable IP67 Driver Rev. F Please refer to PRG-MUL2 (Programmer) datasheet for details. Mechanical Outline EUG-150S070DT INPUT(UL SJTW 3*18AWG 7.8) DIMMING WIRE(UL 21996 3*22AWG AC/L (BLACK) AC/N (WHITE) GND (GREEN) 5.0) V+ (RED) V- (BLUE) Tc OUTPUT(UL STW 2*18AWG BLACK/WHITE PURPLE GRAY 8.9) PROJ: Unspecified tolerance:±1 Others INPUT(UL SJTW 3*18AWG 7.8) DIMMING WIRE(UL 21996 3*22AWG AC/L (BLACK) AC/N (WHITE) GND (GREEN) 5.0) V+ (RED) V- (BLUE) Tc OUTPUT(UL SJTW 2*18AWG BLACK/WHITE PURPLE GRAY 7.3) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 14 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDT 150W Programmable IP67 Driver Rev. F Revision History Description of Change Change Date Rev. 2015-08-07 A 2016-01-12 2016-04-07 2017-07-04 2017-10-26 2018-01-31 Item B C D E F From To Datasheets Release / / KS / Added EUG-150S070DT / Added Mechanical Outline / Updated Features / Updated Input Specifications Input AC Current Updated General Specifications Operating Case Temperature for Added Type TL Tc_TL General Specifications With mounting ear Added General Specifications Net Weight Added Safety &EMC Compliance / Updated Mechanical Outline / Updated Features / Updated Models / Updated Temperature Coefficient of Ioset / Updated Dimensions / Updated Safety &EMC Compliance / Updated Mechanical Outline / Updated Features 7 Years Warranty Added Input Specifications PF/THD Updated Operating Case Temperature for Warranty Tc_w / Updated Description / Updated General Specifications Lifetime Updated General Specifications Operating Case Temperature for Updated Warranty Tc_w Lifetime vs. Case Temperature / Updated 15 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUG-150S210DT
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装。
EUG-150S210DT 价格&库存
很抱歉,暂时无法提供与“EUG-150S210DT”相匹配的价格&库存,您可以联系我们找货
