EUK-240S420DV
EUK-240S420DV
    INVENTRONICS(英飞特)
EUK-240S420DV 数据手册
EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C Features  Ultra High Efficiency (Up to 93.5%)  Full Power at Wide Output Current Range (Constant Power)  0-10V/10V PWM Dimmable (DV models) 3 Timer Modes Dimmable (TV models)  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use  5 Years Warranty Description The EUK-240SxxxDV(TV) series is a 240W, constant-current, programmable IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, sports and roadway. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Output Voltage Range 90~305 Vac/ 114~343Vdc 127~250 Vdc 90~305 Vac/ 1050 mA 80~229Vdc 127~250 Vdc 90~305 Vac/ 1400 mA 57~171Vdc 127~250 Vdc 90~305 Vac/ 4200 mA 29 ~ 86Vdc 127~250 Vdc 90~305 Vac/ 6700 mA 18 ~ 52Vdc 127~250 Vdc Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Model Number 70-1050mA 700-1050mA 700 mA 240W 93.5% 0.99 0.96 EUK-240S105DV(TV) 105-1500mA 1050-1500mA 240W 93.5% 0.99 0.96 EUK-240S150DV(TV) 240W 93.5% 0.99 0.96 EUK-240S210DV(TV) 240W 92.5% 0.99 0.96 EUK-240S420DV(TV) 240W 92.0% 0.99 0.96 EUK-240S670DV(TV) 140-2100mA 1400-2100mA 280-4200mA 2800-4200mA 460-6700mA 4600-6700mA (4) (4) Notes: (1) Output current range with constant power at 240W (2) Certified voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE, KS and BIS) (3) Measured at 100%load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C I-V Operating Area EUK-240S105DV(TV) EUK-240S150DV(TV) EUK-240S210DV(TV) EUK-240S420DV(TV) EUK-240S670DV(TV) 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 2.5 A Measured at 100%load and 120 Vac input. - - 1.3A Measured at 100%load and 220 Vac input. - - 0.90 A s 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (180-240W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 70 mA 105 mA 140 mA 280 mA 460 mA - 1050 mA 1500 mA 2100 mA 4200 mA 6700 mA 700 mA 1050 mA 1400 mA 2800 mA 4600 mA - 1050 mA 1500 mA 2100 mA 4200 mA 6700 mA - 5%Iomax 10%Iomax - 2%Iomax - 100%load Startup Overshoot Current - - 10%Iomax 100%load No Load Output Voltage EUK-240S105DV(TV) EUK-240S150DV(TV) EUK-240S210DV(TV) EUK-240S420DV(TV) EUK-240S670DV(TV) - - 390 V 270 V 200 V 110 V 70 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Input AC Current 2 Inrush Current(I t) PF 2 Notes 127~250 Vdc IEC60598-1; 240Vac/ 60Hz At 220Vac input, 25C cold start, duration=592μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (144-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUK-240S105DV(TV) EUK-240S150DV(TV) EUK-240S210DV(TV) EUK-240S420DV(TV) EUK-240S670DV(TV) Output Current Setting Range with Constant Power EUK-240S105DV(TV) EUK-240S150DV(TV) EUK-240S210DV(TV) EUK-240S420DV(TV) EUK-240S670DV(TV) Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 100%load 100%load. 20 MHz BW 100%load 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C - Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUK-240S105DV(TV) Io= 700 mA Io=1050 mA EUK-240S150DV(TV) Io=1050 mA Io=1500 mA EUK-240S210DV(TV) Io=1400 mA Io=2100 mA EUK-240S420DV(TV) Io=2800 mA Io=4200 mA EUK-240S670DV(TV) Io=4600 mA Io=6700 mA Efficiency at 220 Vac input: EUK-240S105DV(TV) Io= 700 mA Io=1050 mA EUK-240S150DV(TV) Io=1050 mA Io=1500 mA EUK-240S210DV(TV) Io=1400 mA Io=2100 mA EUK-240S420DV(TV) Io=2800 mA Io=4200 mA EUK-240S670DV(TV) Io=4600 mA Io=6700 mA Min. Typ. Max. 88.5% 87.5% 90.5% 89.5% - 88.5% 87.5% 90.5% 89.5% - 88.5% 87.0% 90.5% 89.0% - 87.5% 85.5% 89.5% 87.5% - 87.0% 85.0% 89.0% 87.0% - 91.5% 90.0% 93.5% 92.0% - 91.5% 90.0% 93.5% 92.0% - 91.5% 90.0% 93.5% 92.0% - 90.5% 88.5% 92.5% 90.5% - 90.0% 88.0% 92.0% 90.0% - Notes Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 90.5% 94.0% 92.5% - 92.0% 90.5% 94.0% 92.5% - 92.0% 90.5% 94.0% 92.5% - 91.0% 89.0% 93.0% 91.0% - 90.5% 88.5% 92.5% 90.5% - MTBF - 241,000 Hours - Lifetime - 84,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUK-240S105DV(TV) Io= 700 mA Io=1050 mA EUK-240S150DV(TV) Io=1050 mA Io=1500 mA EUK-240S210DV(TV) Io=1400 mA Io=2100 mA EUK-240S420DV(TV) Io=2800 mA Io=4200 mA EUK-240S670DV(TV) Io=4600 mA Io=6700 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.17 × 2.66 × 1.56 233 × 67.5 × 39.7 8.35 × 2.66 × 1.56 212 × 67.5 × 39.7 - Notes 1200 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter DV Models Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Recommended Dimming Range for 0-10V -20 V - 20 V 200 uA 300 uA 450 uA 0V - 10 V PWM_in High Level - 10V - PWM_in Low Level - 0V - PWM_in Frequency Range 200 Hz - 2 KHz PWM_in Duty Cycle 0% - 100% Notes Vdim(+) = 0 V 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C Dimming Specifications TV Models Parameter Min. Typ. Max. Dimming Level 10% - 100% Hold Time 0 Hours - 18 Hours Fade Time 0 Minutes - 60 Minutes 1 - 6 Dimming Step Dimming Output Range EUK-240S105DV(TV) EUK-240S150DV(TV) EUK-240S210DV(TV) EUK-240S420DV(TV) EUK-240S670DV(TV) 10%Ioset - Ioset EUK-240S105DV(TV) EUK-240S150DV(TV) EUK-240S210DV(TV) EUK-240S420DV(TV) EUK-240S670DV(TV) 70 mA 105 mA 140 mA 280 mA 460 mA - Ioset Notes Default is Traditional Timer. Dimming mode set to Self-AdaptingMidnight or Self Adapting-Percentage in PC interface. 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1400 mA ≤ Ioset ≤ 2100 mA 2800 mA ≤ Ioset ≤ 4200 mA 4600 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 140 mA ≤ Ioset < 1400 mA 280 mA ≤ Ioset < 2800 mA 460 mA ≤ Ioset < 4600 mA Safety &EMC Compliance Safety Category CE Standard EN 61347-1, EN61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore lineto-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C Inrush Current Waveform Efficiency vs. Load EUK-240S105DV(TV)(lo=700mA) EUK-240S105DV(TV)(lo=1050mA) EUK-240S150DV(TV)(lo=1050mA) EUK-240S150DV(TV)(lo=1500mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C EUK-240S210DV(TV)(lo=1400mA) EUK-240S210DV(TV)(lo=2100mA) EUK-240S420DV(TV)(lo=2800mA) EUK-240S420DV(TV)(lo=4200mA) EUK-240S670DV(TV)(lo=4600mA) EUK-240S670DV(TV)(lo=6700mA) 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming (Only DV models) The recommended implementation of the dimming control is provided below. 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUK-240SxxxDV(TV) 240W Programmable IP67 Driver Rev. C Implementation 1 Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. If 0-10V dimming is not used, Dim + should be open.  10V PWM Dimming (Only DV models) Implementation 2 Notes: If PWM dimming is not used, Dim + should be open.  Time Dimming (Only TV models) Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUK-240S420DV 价格&库存
很抱歉,暂时无法提供与“EUK-240S420DV”相匹配的价格&库存,您可以联系我们找货
