EUR-200S350DT
EUR-200S350DT
    INVENTRONICS(英飞特)
EUR-200S350DT 数据手册
EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Features • Inventronics patented metal case (Patent NO.: 201530552642.8) • High Efficiency (Up to 93.0%) • Full Power at Wide Output Current Range (Constant Power) • • Adjustable Output Current (AOC) with Potentiometer (ST models) Adjustable Output Current (AOC) with Programmability (DT models) 0-10V/PWM Dimmable (Only DT models) • Input surge protection: 4kV line-line, 4kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP65) and UL Dry / Damp / Wet Location • SELV Output • TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location Description The EUR-200SxxxDT(ST) series is a 200W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. It is designed in round shape and specially created for bay light. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 245-3500mA 2450-3500mA 3330 mA Input Voltage Range (2) Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) 90~305 Vac/ 29 ~ 82Vdc 200W 127~300 Vdc 90~305 Vac/ 29 ~ 82Vdc 200W 127~300 Vdc 90~305 Vac/ 385-5600mA 3850-5600mA 4160 mA 18 ~ 52Vdc 200W 127~300 Vdc 90~305 Vac/ 3850-5600mA 3850-5600mA 4160 mA 18 ~ 52Vdc 200W 127~300 Vdc 2450-3500mA 2450-3500mA 3330 mA Model Number (4) 93.0% 0.99 0.96 EUR-200S350DT 93.0% 0.99 0.96 EUR-200S350ST 92.5% 0.99 0.96 EUR-200S560DT 92.5% 0.99 0.96 EUR-200S560ST Notes: (1) Output current range with constant power at 200W (2) UL, FCC certified input voltage range: 100-277Vac or 127-300Vdc; other certified input voltage range except UL & FCC: 100-240Vac or 127-250Vdc (except KS). (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B I-V Operation Area EUR-200S350DT EUR-200S350ST EUR-200S560DT EUR-200S560ST Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 2.10 A Measured at full load and 120 Vac input. - - 1.10 A Measured at full load and 220 Vac input. - - 2.10 A s 0.9 - - THD - - 20% THD - - 10% Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 Notes 127~300 Vdc At 220Vac input, 25°C cold start, duration=2.96 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (140-200W) At 220-240Vac, 50-60Hz, 75%-100% Load (150-200W) 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Output Specifications Parameter Min. Typ. Max. -5%Ioset - 5%Ioset 245 mA 2450 mA 385 mA 3850 mA - 3500mA 3500mA 5600mA 5600mA 2450 mA 2450 mA 3850 mA 3850 mA - 3500mA 3500mA 5600mA 5600mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUR-200S350DT/ST EUR-200S560DT/ST - - 100 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Output Current Tolerance Output Current Setting(Ioset) Range EUR-200S350DT EUR-200S350ST EUR-200S560DT EUR-200S560ST Output Current Setting Range with Constant Power EUR-200S350DT EUR-200S350ST EUR-200S560DT EUR-200S560ST Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition. 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset Notes At full load condition Measured at full load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUR-200S350DT/ST Io=2450 mA Io=3500 mA EUR-200S560DT/ST Io=3850 mA Io=5600 mA Efficiency at 220 Vac input: EUR-200S350DT/ST Io=2450 mA Io=3500 mA EUR-200S560DT/ST Io=3850 mA Io=5600 mA Min. Typ. Max. 88.0% 86.5% 90.0% 88.5% - 88.0% 86.0% 90.0% 88.0% - 91.0% 89.0% 93.0% 91.0% - 90.5% 89.0% 92.5% 91.0% - Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B General Specifications (Continued) Parameter Min. Typ. Max. 91.5% 89.5% 93.5% 91.5% - 91.0% 89.5% 93.0% 91.5% - MTBF - 238,000 Hours - Lifetime - 82,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +85°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Storage Temperature -40°C - +85°C Efficiency at 277 Vac input: EUR-200S350DT/ST Io=2450 mA Io=3500 mA EUR-200S560DT/ST Io=3850 mA Io=5600 mA Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details Humidity: 5%RH to 100%RH Dimensions ∅5.90 x 2.83 ∅150 x 72 Inches (∅ × H) Millimeters (∅ × H) Net Weight - 1650 g - Note: All specifications are typical at 25°C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA 10%Ioset - Ioset 245 mA 385 mA - Ioset 0V - 10 V PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin EUR-200S350DT Dimming EUR-200S560DT Output EUR-200S350DT Range EUR-200S560DT Recommended Dimming Input Range PWM_in Duty Cycle Notes Vdim(+) = 0 V 2450 mA ≤ Ioset ≤ 3500 mA 3850 mA ≤ Ioset ≤ 5600 mA 245 mA ≤ Ioset < 2450 mA 385 mA ≤ Ioset < 3850 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Safety & EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 4kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUR-200S350DT/ST(Io=2450mA) EUR-200S350DT /ST(Io=3500mA) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B EUR-200S560DT/ST(Io=3850mA) EUR-200S560DT /ST(Io=5600mA) Power Factor Total Harmonic Distortion 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming Implementation 2: Positive logic 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. Programming Connection Diagram (Only DT models) Note: The driver does not need to be powered on during the programming process.  Please refer to PRG-MUL2 Multi-Programmer datasheet for details. 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Installations Part Number Suffix -0000 -0001 Product Type Center Wire Feed Outside Wire Feed Product Appearance Installation Type Caution: 1. Complete visual inspection prior to assembly to insure driver is received in proper condition. 2. Thread length for mounting accessory (hook, ring, etc.) should be 16-22mm. After mounting accessory (hook, ring, etc.) is installed an M4 set screw should be secured in the open location on the driver collar. 3. Maximum weight of combined luminaire/driver assembly should not exceed 11Kg. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Mechanical Outline EUR-200SxxxDT-0000 10 M4 ±2 Dimming Wire(UL 21996 3*22AWG OUTPUT(UL SJTW 2*18AWG 5.0) 440±30 48.5 7.3) 400±30 ° 60°±10 Hositing thread:DN15 45±5 35±5 150 5±1 25±3 12 AC/L (BLACK) AC/N (WHITE) GND (GREEN) 5 30 18 47 GRAY PURPLE BLACK/WHITE V+ (RED) V- (BLUE) 10±2 50±5 50±5 Tc 18 132 31 15±2 400±30 23 30 INPUT(UL SJTW 3*18AWG 26 7.8) PROJ: 72 Unspecified tolerance:±1.5 EUR-200SxxxST-0000 M4 INPUT(UL SJTW 3*18AWG 7.8) 10 OUTPUT(UL SJTW 2*18AWG 7.3) ±2 400±30 60°±10 48.5 400±30 ° Hositing thread:DN15 50±5 50±5 AC/L (BLACK) AC/N (WHITE) GND (GREEN) 15±2 12 V+ (RED) V- (BLUE) 5 30 18 4- 7 POTENTIOMETER 18 10±2 150 132 31 Tc 23 30 26 PROJ: 72 Unspecified tolerance:±1.5 11 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B EUR-200SxxxDT-0001 ±2 10 M4 Dimming Wire(UL 21996 3*22AWG ° 60°±10 OUTPUT(UL SJTW 2*18AWG 5.0) 440±30 48.5 7.3) 400±30 45±5 35±5 M1 0 Tc 25±3 GRAY PURPLE BLACK/WHITE 12 AC/L (BLACK) AC/N (WHITE) GND (GREEN) 5 30 18 47 5±1 ×1 .5 10±2 V+ (RED) V- (BLUE) 50±5 50±5 18 150 132 31 15±2 400±30 23 INPUT(UL SJTW 3*18AWG 30 7.8) 26 72 PROJ: Unspecified tolerance:±1.5 EUR-200SxxxST-0001 M4 ±2 10 INPUT(UL SJTW 3*18AWG OUTPUT(UL SJTW 2*18AWG 7.8) 400±30 ° 60°±10 48.5 7.3) 400±30 150 10±2 50±5 50±5 AC/L (BLACK) AC/N (WHITE) GND (GREEN) 5 30 18 47 15±2 12 V+ (RED) V- (BLUE) POTENTIOMETER 31 M1 0× 1.5 Tc 18 132 23 30 26 72 PROJ: Unspecified tolerance:±1.5 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 12 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-200SxxxDT(ST) 200W AOC Driver for High Bay Rev. B Revision History Description of Change Change Date Rev. 2017-03-02 A 2017-08-12 Item B From To Datasheets Release / / Input Specifications PF/THD (Note) Updated Output Specifications Temperature Coefficient of Updated Ioset Mechanical Outline / Updated 13 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUR-200S350DT 价格&库存
很抱歉,暂时无法提供与“EUR-200S350DT”相匹配的价格&库存,您可以联系我们找货
