EUV-042S036PS
EUV-042S036PS
    INVENTRONICS(英飞特)
EUV-042S036PS 数据手册
EUV-042SxxxPS 42W Constant Voltage IP66 Driver  Rev. J Features  High Efficiency (Up to 89%)  Active Power Factor Correction (Typical 0.95)  Constant Output Voltage  Lightning Protection  Waterproof (IP66) and Damp Location  All-Around Protection: OVP, SCP,OCP,OTP  Class 2 and SELV Description The EUV-042SxxxPS Series operates from a 90 ~ 305 Vac input range. They are designed to be highly efficient and highly reliable. Features include over voltage protection, short circuit protection, over current protection, and over temperature protection. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Power Factor Efficiency 120Vac 220Vac (2) 12 Vdc 90 ~ 305 Vac 0~3500mA 42 W 84% 0.96 0.95 EUV-042S012PS (3) 24 Vdc 90 ~ 305 Vac 0~1750mA 42 W 86% 0.96 0.95 EUV-042S024PS (3) 36 Vdc 90 ~ 305 Vac 0~1160mA 42 W 87% 0.96 0.95 EUV-042S036PS (3) 48 Vdc 90 ~ 305 Vac 0~875 mA 42 W 89% 0.96 0.95 EUV-042S048PS (4) Model Number Notes: (1) UL, FCC certified input voltage range: 100~277Vac, other certified input voltage range except UL & FCC: 100~240Vac. (2) Measured at full load and 220 Vac input. (3) Class 2 output (USR & CNR). (4) Class 2 output (USR), Non-Class 2 output (CNR). Input Specifications Parameter Min. Typ. Max. Input Voltage 90 V - 305 V Input Frequency 47 Hz - 63 Hz - - 0.75 mA At 277Vac 60Hz input - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 0.6 A Measured at full load and 100 Vac input. - - 0.3 A Measured at full load and 220 Vac input. - - 70 A - - 0.16 A s Leakage Current Input AC Current Inrush Current 2 Inrush Current(I t) 2 Notes At 220Vac input 25℃ Cold Start. Duration=100 μs, 10%Ipk-10%Ipk. 1/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-042SxxxPS 42W Constant Voltage IP66 Driver  Rev. J Input Specifications (Continued) Parameter Power Factor THD Min. Typ. Max. 0.90 - - - - 20% Min. Typ. Max. Notes At 100Vac-277Vac, 75%load-100%load (31.5~42W) Output Specifications Parameter Output Voltage Tolerance Output Voltage Ripple Vo = 12 V Vo = 24 V Vo = 36 V Vo = 48 V No Load Output Voltage Vo = 12 V Vo = 24 V Vo = 36 V Vo = 48 V Output Voltage Overshoot / Undershoot -5%Vo Notes 5%Vo Load conditions, Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. - - 3V 4V 4V 4V - - 16 V 28 V 40 V 52 V - - 10%Vo At full load condition. Line Regulation - - ±2% Measured at full load Load Regulation - - ±3% - 0.40 s 0.75 s Measured at 120Vac input. - 0.30 s 0.50 s Measured at 220Vac input. - - 0.2%/C Turn-on Delay Time Temperature coefficient Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: Vo = 12 V Vo = 24 V Vo = 36 V Vo = 48 V Efficiency at 220 Vac input: Vo = 12 V Vo = 24 V Vo = 36 V Vo = 48 V No Load Power Dissipation MTBF Lifetime Min. Typ. Max. 81% 83% 84% 86% 82% 84% 85% 87% - 83% 85% 86% 88% 84% 86% 87% 89% - - - 6W 327,000 hours - - - 116,000 Hours - Notes Measured at full load and steady-state temperature in 25℃ ambient. Measured at full load and steady-state temperature in 25℃ ambient. Measured at 120Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load, Case temperature=60℃ @ Tc point. See life time vs. Tc curve for the details 2/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-042SxxxPS 42W Constant Voltage IP66 Driver  Rev. J General Specifications (Continued) Parameter Min. Typ. Max. Operating Case Temperature for Safety Tc_s -40 C - +90 C Operating Case Temperature for Warranty Tc_w -40 C - +70 C Humidity: 10% RH to 100% RH. Storage Temperature -40 C - +85 C Humidity: 5% RH to 100% RH Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes 3.74 × 2.76 × 1.26 95 × 70 × 32 Net Weight - 390 g - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750, UL1012, UL1310 Class 2,CSA C22.2 NO. 223-M91 Class 2 CE EN 61347-1, EN61347-2-13 KS KS C 7655: 2011 EMI Standards (1) EN 55015 Standard Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4: 2009 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT: Level 3, Criteria A EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 2 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment 3/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-042SxxxPS 42W Constant Voltage IP66 Driver  Rev. J Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature Curve Efficiency vs. Load EUV-042S012PS EUV-042S024PS 4/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-042SxxxPS 42W Constant Voltage IP66 Driver  Rev. J EUV-042S036PS EUV-042S048PS Power Factor Protection Functions Parameter Over Current Protection Over Temperature Protection-Tc Short Circuit Protection Min. Typ. Max. Notes Hiccup mode. The power supply shall be self-recovery when the fault condition is removed. Hiccup mode. When the case temperature is higher than 110℃, the power supply will turn off automatically; when the case temperature is lower than 75℃, the power supply will be auto recovery. Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. 1.1 Io 1.4 Io 1.7 Io 5/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-042SxxxPS 42W Constant Voltage IP66 Driver  Rev. J Mechanical Outline DC OUTPUT (2*AWG #18) AC INPUT (2*AWG #18) WHITE (ACN) BLACK (ACL) BLACK (V-) RED (V+) RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 6/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-042SxxxPS 42W Constant Voltage IP66 Driver  Rev. J Revision History Description of Change Change Date Rev. 2012-04-24 A 2012-05-25 B 2012-06-06 C 2012-7-2 Item From To Datasheets Release / / OTP / Added EN 61000-4-5--- line to line 2 kV, line to earth 4 kV / Corrected Life time vs. Tc Curve / Added Notes of life time / Updated D Description of OTP / Updated 2012-7-17 E Max Case Temperature / Updated 2012-7-30 F Min Operating Temperature -20℃ -40℃ Derating Curve / Updated Inrush Current(I2t) / Added Inrush Current 60A 70A Temperature co-efficient / Added Life time Min 50,000hrs Typical 116,000hrs Life time Curve / Updated Energy star / Deleted Turn-on Delay Time at 120Vac Max.=1.0 s Max.=0.75 s Operating Case Temperature for Warranty Tc_w / Added Net Weight 350 g 390 g Environmental Specifications / Deleted KS Certificate Regulation / Added Note of EMI Standard / Added Derating Curve / Deleted 2012-8-16 G 2012-11-26 H 2013-07-01 I 2016-08-02 J 7/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-042S036PS 价格&库存
很抱歉,暂时无法提供与“EUV-042S036PS”相匹配的价格&库存,您可以联系我们找货
