EBS-080SxxxDT2
80W Class I/II Programmable IP20 Driver
Rev.A
Features
Full Power at Wide Output Current Range (Constant Power)
Adjustable Output Current (AOC) with NFC
Isolated 1-10V/3-Timer-Modes Dimmable
Output Lumen Compensation
End-of-Life Indicator
Long Lifetime Over 100K Hours at 75°C Case Temperature
Input Surge Protection: DM 6 kV, CM 10 kV
All-Around Protection: OVP, SCP, OTP
IP20 Design and Suitable for Outdoor Applications in
Luminaires with IP>54
SELV Output
Suitable for Luminaires with Protection Class I and II
Complies with Zhaga Interface Specification Book 13
8 Years Warranty
Description
The EBS-080SxxxDT2 series is a 80W, constant-current, NFC programmable and IP20 rated LED driver that
operates from 176-305 Vac input with excellent power factor. It was created for many lighting applications
including street, tunnel and low bay, etc. The high efficiency of these drivers and better thermal design enable
them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation,
protection is provided against input surge, output over voltage, short circuit, and over temperature.
Models
Adjustable
Output
Current
Range
Full-Power
Current
Range (1)
Default
Output
Current
45-700mA
450-700mA
530 mA
176~305 Vac
57~178Vdc
171~275 Vdc
80 W
92.5%
0.98
EBS-080S070DT2
70-1050mA 700-1050mA 700 mA
176~305 Vac
38~114Vdc
171~275 Vdc
80 W
92.5%
0.98
EBS-080S105DT2(4)
105-1500mA 1050-1500mA 1050 mA
176~305 Vac
27 ~ 76Vdc
171~275 Vdc
80 W
91.5%
0.98
EBS-080S150DT2(4)
Input
Voltage
Range(2)
Output
Voltage
Range
Max.
Typical
Output Efficiency
Power
(3)
Typical
Power
Factor
(3)
Model Number
Notes: (1) Output current range with constant power at 80W
(2) CCC certified input voltage range: 220-240Vac; otherwise: 200-240Vac
(3) Measured at 100% load and 220Vac input (see below “General Specifications” for details).
(4) SELV Output.
1 / 12
Specifications are subject to changes without notice.
www.inventronics-co.com
Tel: 86-571-56565800
All specifications are typical at 25C unless otherwise stated..
Fax: 86-571-86601139
sales@inventronics-co.com
EBS-080SxxxDT2
Rev.A
I-V Operating Area
EBS-080S070DT2
EBS-080S105DT2
EBS-080S150DT2
Input Specifications
Parameter
Min.
Typ.
Max.
Input AC Voltage
176 Vac
305 Vac
Input DC Voltage
171 Vdc
275 Vdc
Input Frequency
47 Hz
63 Hz
Leakage Current
0.70 mA
Input AC Current
0.44 A
Inrush Current(I2t)
2.41 A2s
0.90
THD
20%
THD
10%
PF
2 / 12
Notes
IEC60598-1; 240Vac/ 60Hz
Measured at 100% load and 220 Vac input.
At 220Vac input, 25C Cold Start, Duration
=368 μs, 10%Ipk-10%Ipk. See Inrush Current
Waveform for the details.
At 200-240Vac, 50-60Hz, 60%-100% Load
(48-80W)
At 220-240Vac, 50-60Hz, 70%-100% Load
(56-80W)
EBS-080SxxxDT2
Rev.A
Output Specifications
Parameter
Min.
Typ.
Max.
-5%Ioset
5%Ioset
45 mA
70 mA
105 mA
700 mA
1050 mA
1500 mA
450 mA
700 mA
1050 mA
700 mA
1050 mA
1500 mA
5%Iomax
10%Iomax
Output Current Ripple at
< 200 Hz (pk-pk)
2%Iomax
Startup Overshoot Current
10%Iomax
No Load Output Voltage
EBS-080S070DT2
EBS-080S105DT2
EBS-080S150DT2
210 V
120 V
90 V
Line Regulation
±0.5%
Load Regulation
±1.5%
Turn-on Delay Time
0.5 s
Temperature Coefficient of Ioset
0.03%/C
Min.
Typ.
Max.
89.5%
90.5%
91.5%
92.5%
90.0%
90.5%
92.0%
92.5%
89.0%
89.5%
91.0%
91.5%
MTBF
265,000
Hours
Measured at 220Vac input, 80% Load and
25C ambient temperature (MIL-HDBK-217F)
Lifetime
120,000
Hours
Measured at 220Vac input, 80%Load and
75C case temperature; See lifetime vs. Tc
curve for the details
Output Current Tolerance
Output Current Setting(Ioset)
Range
EBS-080S070DT2
EBS-080S105DT2
EBS-080S150DT2
Output Current Setting Range
with Constant Power
EBS-080S070DT2
EBS-080S105DT2
EBS-080S150DT2
Total Output Current Ripple
(pk-pk)
Notes
At 100% load condition
At 100% load condition, 20 MHz BW
At 100% load condition. Only this component
of ripple is associated with visible flicker.
Measured at 200-240Vac input,
60%-100% Load
Case temperature = 0C ~Tc max
Parameter
Efficiency at 220 Vac input:
EBS-080S070DT2
Io= 450 mA
Io= 700 mA
EBS-080S105DT2
Io= 700 mA
Io= 1050 mA
EBS-080S150DT2
Io= 1050 mA
Io= 1500 mA
3 / 12
Notes
Measured at 100% load and steady-state
temperature in 25C ambient;
(Efficiency will be about 2.0% lower if
measured immediately after startup.)
EBS-080SxxxDT2
Rev.A
General Specifications (Continued)
Parameter
Operating Case Temperature
for Safety Tc_s
Min.
Typ.
Max.
-40°C
+90C
Notes
for Warranty Tc_w
-40°C
+75C
Case temperature for 8 years warranty.
Please see Inventronics Warranty Statement
for complete details.
Humidity: 10%RH to 90%RH
No condensation.
Storage Temperature
-40°C
+85°C
Humidity: 5%RH to 95%RH; No condensation.
Dimensions
Inches (L × W × H)
Millimeters (L × W ×H)
5.24 x 3.03 x 1.42
133 x 77 x 36
Net Weight
300 g
Parameter
Min.
Typ.
Max.
Absolute Maximum Voltage on
the Vdim (+) Pin
-20 V
20 V
Source Current on Vdim (+)Pin
200 uA
300 uA
450 uA
10%Ioset
Ioset
45 mA
70 mA
105 mA
Ioset
1V
9V
Dimming Specifications
EBS-080S070DT2
EBS-080S105DT2
Dimming EBS-080S150DT2
Output
EBS-080S070DT2
Range
EBS-080S105DT2
EBS-080S150DT2
Recommended Dimming
Range for 1-10V
Notes
Vdim(+) = 0 V
450 mA ≤ Ioset ≤ 700 mA
700 mA ≤ Ioset ≤ 1050 mA
1050 mA ≤ Ioset ≤ 1500 mA
45 mA ≤ Ioset < 450 mA
70 mA ≤ Ioset < 700 mA
105 mA ≤ Ioset < 1050 mA
Default 1-10V dimming mode with positive
logic.
Safety &EMC Compliance
Safety Category
Standard
ENEC & CE
EN 61347-1, EN 61347-2-13
CB
IEC 61347-1, IEC 61347-2-13
CCC
KS
GB 19510.1, GB 19510.14
KS C 7655
EMI Standards
EN 55015/GB 17743(1)
EN 61000-3-2/GB 17625.1
EN 61000-3-3
Notes
Conducted emission Test &Radiated emission Test
Harmonic current emissions Class C
Voltage Fluctuations & Flicker
4 / 12
EBS-080SxxxDT2
Rev.A
Safety &EMC Compliance (Continued)
EMS Standards
Notes
EN 61000-4-2
Electrostatic Discharge(ESD): 8 kV air discharge, 4 kV contact discharge
EN 61000-4-3
Radio-Frequency Electromagnetic Field Susceptibility Test-RS
EN 61000-4-4
Electrical Fast Transient/Burst-EFT
EN 61000-4-5
Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 8 kV
EN 61000-4-6
Conducted Radio Frequency Disturbances Test-CS
EN 61000-4-8
Power Frequency Magnetic Field Test
EN 61000-4-11
Voltage Dips
Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV
EN 61547
Electromagnetic Immunity Requirements Applies to Lighting Equipment
Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it
depends also on the other devices connected to the driver and on the fixture itself.
Lifetime vs. Case Temperature
Inrush Current Waveform
5 / 12
EBS-080SxxxDT2
Rev.A
Efficiency vs. Load
EBS-080S070DT2(lo=450mA)
EBS-080S070DT2(lo=700mA)
EBS-080S105DT2(lo=700mA)
EBS-080S105DT2(lo=1050mA)
EBS-080S150DT2(lo=1050mA)
EBS-080S150DT2(lo=1500mA)
6 / 12
EBS-080SxxxDT2
Rev.A
Power Factor
Total Harmonic Distortion
Protection Functions
Parameter
Min.
Typ.
Max.
Notes
Over Voltage Protection
Limits output voltage at no load and in case the normal voltage limit fails.
Short Circuit Protection
Auto Recovery. No damage will occur when any output is short circuited. The output
shall return to normal when the fault condition is removed.
Over Temperature Protection
Decreases output current, returning to normal after over temperature is removed.
Input Over Voltage Withstand
320 Vac
7 / 12
The driver can survive for 48 hours with
input voltage stress of 320Vac.
EBS-080SxxxDT2
Rev.A
Dimming
1-10V Dimming
The recommended implementation of the dimming control is provided below.
Implementation 1: Positive logic
Implementation 2: Negative logic
Notes:
1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly.
2. The dimmer can also be replaced by an active 1-10V voltage source signal or passive components like
zener.
3. When 1-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.
Time Dimming
Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.
Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two
days (if difference
很抱歉,暂时无法提供与“EBS-080S105DT2”相匹配的价格&库存,您可以联系我们找货
