EBV-500S024ST
EBV-500S024ST
    INVENTRONICS(英飞特)
EBV-500S024ST 数据手册
EBV-500SxxxST 500W Constant Voltage Outdoor Driver Rev. C Features  Ultra High Efficiency (Up to 95.0%)  Constant Voltage Output  Input surge protection: 4kV line-line, 6kV line-earth  All-Around Protection: SCP, OTP, OVP, OCP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location Description The EBV-500SxxxST series is a 500W, constant-voltage outdoor LED driver that operates from 176-305 Vac input with excellent power factor. It is created for high bay, high mast, arena and roadway lights. The high efficiency of these drivers enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output short circuit, over temperature, over voltage, and over current. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Power Factor Efficiency 220Vac 277Vac (2) 24 Vdc 176 ~ 305 Vac 0~20.83 A 500 W 94.0% 0.99 0.96 EBV-500S024ST 28 Vdc 176 ~ 305 Vac 0~17.85 A 500 W 94.0% 0.99 0.96 EBV-500S028ST 36 Vdc 176 ~ 305 Vac 0~13.88 A 500 W 94.5% 0.99 0.96 EBV-500S036ST 42 Vdc 176 ~ 305 Vac 0~11.90 A 500 W 95.0% 0.99 0.96 EBV-500S042ST 48 Vdc 176 ~ 305 Vac 0~10.41 A 500 W 95.0% 0.99 0.96 EBV-500S048ST Model Number (3) Notes: (1) UL, FCC certified input voltage range: 200-277Vac; other certified input voltage range except UL & FCC:200-240Vac (2) Measured at full load and 277 Vac input. (3) SELV output Input Specifications Parameter Min. Typ. Max. 176 Vac - 305 Vac 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz, grounding effectively - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively Input AC Current - - 2.75 A 2 - - 1.6 A s Input Voltage Input Frequency Notes Leakage Current Inrush Current(I t) 2 Measured at full load and 220 Vac input. At 220Vac input 25℃ Cold start, Duration= 3.26 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-500SxxxST 500W Constant Voltage Outdoor Driver Rev. C Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - - - 20% Min. Typ. Max. -5%Vo - 5%Vo At full load condition Output Voltage Ripple(pk-pk) - - 2%Vo At full load condition, 20 MHz BW Startup Overshoot Voltage - - 5%Vo At full load condition Line Regulation - - ±0.5% Measured at full load Load Regulation - - ±1.0% Turn-on Delay Time - - 2.0 s Temperature Coefficient of Vo - - 0.03%/C PF THD Notes At 200-277Vac, 75%-100% Load (375-500W) Output Specifications Parameter Output Voltage Tolerance Notes Measured at 220Vac and 277Vac input. Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 91.5% 91.5% 92.0% 92.5% 92.5% 93.5% 93.5% 94.0% 94.5% 94.5% - Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 92.0% 92.0% 92.5% 93.0% 93.0% 94.0% 94.0% 94.5% 95.0% 95.0% - Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) MTBF - 232,000 Hours - Lifetime - 117,000 Hours - -40°C - +90C Efficiency at 220 Vac input: VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V Efficiency at 277 Vac input: VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Notes Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 60C case temperature; See lifetime vs. Tc curve for the details -40°C +70°C -40°C +85°C Humidity: 5%RH to 100%RH Dimensions 10.4 × 4.25 × 1.8 264 × 108 × 45.5 Inches (L × W × H) Millimeters (L × W ×H) Net Weight - 2500 g - Note: All specifications are typical at 25C unless otherwise stated. 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-500SxxxST 500W Constant Voltage Outdoor Driver Rev. C Safety & EMC Compliance Safety Category UL/CUL CE Standard UL 8750, CAN/CSA-C22.2 No. 250.13-12 EN 61347-1, EN61347-2-13 EMI Standards EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4:2009 Class B FCC Part15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV * EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment * Note: To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-500SxxxST 500W Constant Voltage Outdoor Driver Rev. C Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EBV-500S024ST EBV-500S028ST 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-500SxxxST 500W Constant Voltage Outdoor Driver Rev. C EBV-500S036ST EBV-500S042ST EBV-500S048ST Power Factor 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-500SxxxST 500W Constant Voltage Outdoor Driver Rev. C Total Harmonic Distortion Protection Functions Parameter Min. Over Current Protection Short Circuit Protection 1 2 3 Over Voltage Protection Max. Notes Hiccup mode. The power supply shall be selfrecovery when the fault condition is removed. Auto recovery. The power supply shall be self-recovery after the case temperature becomes normal. Hiccup mode. The power supply shall be self-recovery when the fault condition is removed. 6 4 5 7 8 Latch mode. The power supply shall return to normal operation only after the power is turn-on again 110% IO Over Temperature Protection Typ. 145% IO 180%IO A A MECHANICAL OUTLINE DRAWING Mechanical Outline DC OUTPUT(UL SJTW 2*14AWG ) AC INPUT(UL SJTW 3*18AWG ) B B BLACK(ACL) WHITE(ACN) GREEN(GND) RED(V+) BLUE(V-) C C D D PROJ: Unspecified tolerance:±1 REFERENCE DRAWING NO. E E DRAWN MATERIAL: CHECKED FINISH: UNLESS OTHERWISE SPECIFIED TOLERANCES AS FOLLOWS -SURF. ROUGHNESS TO BE ISO 2768-1 AND ISO 2768-2 MARK F 6/8 ASSEMBLE NO. ECN NO. Antony 2015.11.18 3.2 DESCRIPTION: -DIMENSIONS ARE IN MM -DENOTES CHANGE DATE DO NOT SCALE DRAWING -WORKMANSHIP SHALL BE THE EBV-500SXXXST高防雷 Specifications are subject to changes without notice. A BEST COMMERCIAL QUALITY PROJ: F WEIGHT SCALE VERSION P/N: 1 www.inventronics-co.com 2 3 Tel: 86-571-56565800 4 MFG 5 SHEET Fax: 86-571-86601139 6 7 sales@inventronics-co.com 8 AUTHORIZE: EBV-500SxxxST 500W Constant Voltage Outdoor Driver Rev. C RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-500SxxxST 500W Constant Voltage Outdoor Driver Rev. C Revision History Description of Change Change Date Rev. 2014-09-30 A 2015-5-28 2015-11-27 Item From Datasheets Release To / / Features / Update Description / Update Models / Update Input Specifications Leakage Current Update General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature for Warranty Tc_w Added General Specifications Storage Temperature Environmental Specifications / Delete Derating / Delete Safety & EMC Compliance UL/CUL Update CE / Added External Grounding Screw Solution / / Safety & EMC Compliance / Update Mechanical Outline / Update B C 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EBV-500S024ST 价格&库存
很抱歉,暂时无法提供与“EBV-500S024ST”相匹配的价格&库存,您可以联系我们找货
EBV-500S024ST
