EFD-1K2S420DT
EFD-1K2S420DT
    INVENTRONICS(英飞特)
    1,200W, 277-480Vac, 4.2A LED driver module
EFD-1K2S420DT 数据手册
EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C Features  Ultra High Efficiency (Up to 96.0%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/Timer Dimmable (3 Timer Modes, Isolated design)  Dim-to-Off with Standby Power ≤ 2.5 W  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Wet / Dry / Damp Location  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EFD-1K2SxxxDT series is a 1200W, constant-current, programmable LED driver that operates from 180528Vac input with excellent power factor. Created for many lighting applications including high mast, sports, horticulture and aquaculture, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, under voltage lock out, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Default Current Output Range(1) Current 0.336-4.2A 3.36-4.20A 4.2A 0.448-5.60A 4.48–5.60A 5.6A 0.592-7.40A 5.92–7.4A 7.0A Input Voltage Range(2) Output Voltage Range 180~528Vac/ 143~357Vdc 255~500Vdc 180~528Vac/ 108~268Vdc 255~500Vdc 180~528Vac/ 81~202Vdc 255~500Vdc Power Factor Max. Typical Output Efficiency Power (3) 277Vac 480Vac Model Number 1200W 96.0% 0.96 0.95 EFD-1K2S420DT 1200W 95.5% 0.96 0.95 EFD-1K2S560DT 1200W 95.0% 0.96 0.95 EFD-1K2S740DT Notes: (1) Output current range with constant power at 1200W (2) Certified voltage range: 200-480Vac or 255-500Vdc (3) Measured at 100%load and 480Vac input (see below “General Specifications” for details). 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C I-V Operating Area EFD-1K2S420DT EFD-1K2S560DT EFD-1K2S740DT Input Specifications Parameter Input Voltage Input Frequency Min. Typ. Max. 180 Vac - 528 Vac 47 Hz - 63 Hz - - 0.75 MIU UL8750; 480Vac/ 60Hz, grounding effectively 0.70 mA IEC60598-1; 480Vac/ 60Hz,grounding effectively Leakage Current Input AC Current 2 Inrush Current(I t) Measured at 100%load and 240Vac input. Measured at 100%load and 277Vac input. - 4.7 A - - 2.7 A 2 - 255-500Vdc 5.5 A - - Notes 37.5 A s Measured at 100%load and 480Vac input. At 480Vac input, 25℃ cold start, duration=1.18ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C Input Specifications Parameter Min. Typ. Max. 0.90 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 336 mA 448 mA 592 mA - 4200 mA 5600 mA 7400 mA 3360 mA 4480 mA 5920 mA - 4200 mA 5600 mA 7400 mA - 5%Iomax 10%Iomax - 2%Iomax - 100%load Startup Overshoot Current - - 10%Iomax 100%load No Load Output Voltage EFD-1K2S420DT EFD-1K2S560DT EFD-1K2S740DT - - 390 V 300 V 230 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - - 0.75 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA PF THD Notes At 200-480Vac, 50-60Hz, 60%-100% Load (720 – 1200W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EFD-1K2S420DT EFD-1K2S560DT EFD-1K2S740DT Output Current Setting Range with Constant Power EFD-1K2S420DT EFD-1K2S560DT EFD-1K2S740DT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes 100%load 100%load, 20 MHz BW Measured at 100%load Measured at 200-480Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C General Specifications Parameter Min. Typ. Max. 91.5% 91.5% 93.5% 93.5% - 91.5% 91.0% 93.5% 93.0% - 91.0% 91.0% 93.0% 93.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.5% 94.0% 93.5% - 92.0% 91.5% 94.0% 93.5% - 93.0% 93.0% 95.0% 95.0% - 93.0% 92.5% 95.0% 94.5% - 93.5% 92.0% 94.5% 94.0% - 94.0% 93.0% 96.0% 95.0% - 93.5% 93.0% 95.5% 95.0% - 93.0% 92.5% 95.0% 94.5% - Standby power - - 2.5W MTBF - 212,000 Hours - Lifetime - 100,000 Hours - -40°C - +85C -40°C - +75C Case temperature for 5 years warranty -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 240 Vac input: EFD-1K2S420DT Io= 3360 mA Io= 4200 mA EFD-1K2S560DT Io= 4480 mA Io= 5600 mA EFD-1K2S740DT Io= 5920 mA Io= 7400 mA Efficiency at 277 Vac input: EFD-1K2S420DT Io= 3360 mA Io= 4200 mA EFD-1K2S560DT Io= 4480 mA Io= 5600 mA EFD-1K2S740DT Io= 5920 mA Io= 7400 mA Efficiency at 347 Vac input: EFD-1K2S420DT Io= 3360 mA Io= 4200 mA EFD-1K2S560DT Io= 4480 mA Io= 5600 mA EFD-1K2S740DT Io= 5920 mA Io= 7400 mA Efficiency at 480 Vac input: EFD-1K2S420DT Io= 3360 mA Io= 4200 mA EFD-1K2S560DT Io= 4480 mA Io= 5600 mA EFD-1K2S740DT Io= 5920 mA Io= 7400 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Notes Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Typ. Max. With mounting ear 11.02 × 9.06× 2.99 280 × 230× 76 11.02 × 6.89 × 2.99 280 × 175 × 76 - Notes 6570 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA 10%Ioset - Ioset EFD-1K2S420DT EFD-1K2S560DT EFD-1K2S740DT Recommended Dimming Input Range 336 mA 448 mA 592 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 1KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Dimming Output Range EFD-1K2S420DT EFD-1K2S560DT EFD-1K2S740DT Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 3360mA ≤ Ioset ≤ 4200mA 4480mA ≤ Ioset ≤ 5600mA 5920mA ≤ Ioset ≤ 7400mA 336mA ≤ Ioset < 3360mA 448mA ≤ Ioset < 4480mA 592mA ≤ Ioset < 5920mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C Safety &EMC Compliance Safety Category CE Standard EN 61347-1, EN61347-2-13 UL/CUL UL8750,CAN/CSA-C22.2 No. 250.13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B This device complies with Part 15 of the FCC Rules. Operation is subject to the (1) FCC Part 15 following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (EFD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C Derating Lifetime vs. Case Temperature Inrush Current Waveform 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C Efficiency vs. Load EFD-1K2S420DT(lo=3360mA) EFD-1K2S420DT(lo=4200mA) EFD-1K2S560DT(lo=4480mA) EFD-1K2S560DT(lo=5600mA) EFD-1K2S740DT(lo=5920mA) EFD-1K2S740DT(lo=7400mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EFD-1K2SxxxDT 1200W Programmable IP67 Driver Rev. C Implementation 3: Negative logic   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EFD-1K2S420DT 价格&库存
很抱歉,暂时无法提供与“EFD-1K2S420DT”相匹配的价格&库存,您可以联系我们找货
