ESD-150S560DT
ESD-150S560DT
    INVENTRONICS(英飞特)
    ESD Series 150 W 4.2 A 39 Vdc Out Max Programmable Outdoor LED Driver Module
ESD-150S560DT 数据手册
ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D Features • Ultra High Efficiency (Up to 94.5%) • Full Power at Wide Output Current Range (Constant Power) • Thermal Sensing and Protection for LED Module • 0-10V/PWM/3-Timer-Modes Dimmable • Dim-to-Off with Standby Power ≤ 1.5 W • Output Lumen Compensation • Input Surge Protection: DM 6kV, CM 10kV • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) and UL Dry / Damp / Wet Location • SELV Output • TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location • 5 Years Warranty Description The ESD-150SxxxDT series is a 150W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. Created for many lighting applications including high bay, tunnel and roadway, it provides a dim-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range (2) 249~528 Vac 352~500 Vdc 249~528 Vac 140-2100mA 1400-2100mA 1400 mA 352~500 Vdc 249~528 Vac 245-3500mA 2450-3500mA 2800 mA 352~500 Vdc 249~528 Vac 385-5600mA 3850-5600mA 4200 mA 352~500 Vdc 70-1050mA 700-1050mA 700 mA Output Voltage Range Max. Typical Power Factor Output Efficiency 277Vac 480Vac Power (3) Model Number 75~214Vdc 150 W 94.5% 0.96 0.95 ESD-150S105DT 38~107Vdc 150 W 94.0% 0.96 0.95 ESD-150S210DT 22 ~ 61Vdc 150 W 93.0% 0.96 0.95 ESD-150S350DT (4) 14 ~ 39Vdc 150 W 93.0% 0.96 0.95 ESD-150S560DT (4) Notes: (1) Output current range with constant power at 150W (2) Certified input voltage range: 277-480Vac or 352-500Vdc (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV Output 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D I-V Operating Area ESD-150S105DT ESD-150S210DT 60 % a Lo d ESD-150S350DT ESD-150S560DT Input Specifications Parameter Input Voltage Input Frequency Min. Typ. Max. 249 Vac - 528 Vac 47 Hz - 63 Hz - - 0.75 MIU - - 0.70 mA - - 0.70 A - - 0.40 A - - 7.6 A s Leakage Current Input AC Current 2 Inrush Current(I t) 2 Notes 352-500 Vdc UL8750; 480Vac/ 60Hz, grounding effectively IEC60598-1; 480Vac/ 60Hz, grounding effectively Measured at 100% load and 277 Vac input. Measured at 100% load and 480 Vac input. At 480Vac input, 25°C Cold Start, Duration=680 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 140 mA 245 mA 385 mA - 1050 mA 2100 mA 3500 mA 5600 mA 700 mA 1400 mA 2450 mA 3850 mA - 1050 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESD-150S105DT ESD-150S210DT ESD-150S350DT ESD-150S560DT - - 223 V 116 V 64 V 43 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - 0.5 s 0.75 s - 0.03%/°C - 10.8 V 12 V 13.2 V 0 mA - 200 mA PF THD Notes At 277-480Vac, 50-60Hz, 60%-100% Load (90-150W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESD-150S105DT ESD-150S210DT ESD-150S350DT ESD-150S560DT Output Current Setting Range with Constant Power ESD-150S105DT ESD-150S210DT ESD-150S350DT ESD-150S560DT Total Output Current Ripple (pk-pk) Temperature Coefficient of Ioset 12V Auxiliary Output Voltage (Vaux) 12V Auxiliary Output Source Current (Iaux) Notes At 100% load condition At 100% load condition, 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 277Vac and 480Vac input, 60%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D General Specifications Parameter Efficiency at 277 Vac input: ESD-150S105DT Io= 700mA Io=1050mA ESD-150S210DT Io=1400mA Io=2100mA ESD-150S350DT Io=2450mA Io=3500mA ESD-150S560DT Io=3850mA Io=5600mA Efficiency at 347 Vac input: ESD-150S105DT Io= 700mA Io=1050mA ESD-150S210DT Io=1400mA Io=2100mA ESD-150S350DT Io=2450mA Io=3500mA ESD-150S560DT Io=3850mA Io=5600mA Efficiency at 480 Vac input: ESD-150S105DT Io= 700mA Io=1050mA ESD-150S210DT Io=1400mA Io=2100mA ESD-150S350DT Io=2450mA Io=3500mA ESD-150S560DT Io=3850mA Io=5600mA Standby power Min. Typ. Max. 91.5% 89.5% 93.5% 91.5% - 91.0% 90.0% 93.0% 92.0% - 91.0% 89.0% 93.0% 91.0% - 90.5% 88.0% 92.5% 90.0% - 92.0% 90.5% 94.0% 92.5% - 91.5% 90.5% 93.5% 92.5% - 91.5% 89.5% 93.5% 91.5% - 90.5% 88.5% 92.5% 90.5% - 92.5% 91.0% 94.5% 93.0% - 92.0% 91.0% 94.0% 93.0% - 91.0% 90.0% 93.0% 92.0% - 91.0% 89.0% 93.0% 91.0% - - - 1.5 W Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) - 203,000 Hours - Lifetime - 99,000 Hours - -40°C - +88°C -40°C - +75°C -40°C - +85°C Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 1300 g Humidity: 5%RH to 100%RH With mounting ear 9.53 × 2.66 × 1.56 242 × 67.5 × 39.7 8.70 × 2.66 × 1.56 221 × 67.5 × 39.7 - Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70°C case temperature with Iaux=100mA; See lifetime vs. Tc curve for the details MTBF Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Notes - Note: All specifications are typical at 25°C unless otherwise stated. 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA ESD-150S105DT ESD-150S210DT ESD-150S350DT ESD-150S560DT 10%Ioset - Ioset ESD-150S105DT ESD-150S210DT ESD-150S350DT ESD-150S560DT 70mA 140mA 245mA 385mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 2% 5% 8% 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - Dimming Output Range Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 700mA ≤ Ioset ≤ 1050mA 1400mA ≤ Ioset ≤ 2100mA 2450mA ≤ Ioset ≤ 3500mA 3850mA ≤ Ioset ≤ 5600mA 70mA ≤ Ioset < 700mA 140mA ≤ Ioset < 1400mA 245mA ≤ Ioset < 2450mA 385mA ≤ Ioset < 3850mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 °C unless stated otherwise. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 EMI Standards EN 55015 (1) Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D Safety & EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B (1) FCC Part15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D Inrush Current Waveform Efficiency vs. Load ESD-150S105DT(Io=700mA) ESD-150S105DT(Io=1050mA) ESD-150S210DT(Io=1400mA) ESD-150S210DT(Io=2100mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D ESD-150S350DT(Io=2450mA) ESD-150S350DT(Io=3500mA) ESD-150S560DT(Io=3850mA) ESD-150S560DT(Io=5600mA) Power Factor 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. External Thermal Protection NTC When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT 150W Programmable IP67 Driver Rev. D Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-150SxxxDT   150W Programmable IP67 Driver Rev. D Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESD-150S560DT 价格&库存
很抱歉,暂时无法提供与“ESD-150S560DT”相匹配的价格&库存,您可以联系我们找货
