ESM-075S210DT
ESM-075S210DT
    INVENTRONICS(英飞特)
ESM-075S210DT 数据手册
ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A Features  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Programmability  Isolated 1-10V/10V PWM/3-Timer-Modes Dimmable  Output Lumen Compensation  End-of-Life Indicator  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The ESM-075SxxxDx series is a 75W, constant-current, programmable and IP66/IP67 rated LED driver that operates from 249-528Vac input with excellent power factor. It is created for many lighting applications including high bay, tunnel and roadway, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Typical Max. Typical Power Factor Output Efficiency Power (3) 277Vac 480Vac Output Voltage Range 249~528 Vac/ 36~107 Vdc 352~500 Vdc 249~528 Vac/ 25~72 Vdc 105-1500mA 1050-1500mA 1050 mA 352~500 Vdc 249~528 Vac/ 140-2100mA 1400-2100mA 2100 mA 18~54 Vdc 352~500 Vdc 70-1050mA 700-1050mA 700 mA Model Number (6) 75W 91.0% 0.99 0.95 ESM-075S105Dx(4) 75W 89.5% 0.99 0.95 ESM-075S150Dx(4) 75W 89.0% 0.99 0.95 ESM-075S210Dx(5) Notes: (1) Output current range with constant power at 75W. (2) Certified input voltage range: 277-480Vac. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV Output. (5) Class 2 & SELV output. (6) x = G are UL Recognized and ENEC, etc. models; x = T are UL Class P models. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A I-V Operation Area ESM-075S105Dx ESM-075S150Dx 132 90 Output Voltage(V) (420 , 107 ) (700 , 107 ) (Ioset,75/Ioset) (10%Ioset,75/Ioset) 88 (1050 , 71 ) 66 (1050 , 43 ) 44 (1050, 36) (Ioset, 36) (105, 36) 22 Good Performance Area Allowed Operating Area (630 , 72 ) (105, 72) 75 Output Voltage(V) (70, 107) 110 (1050 , 72 ) (Ioset,75/Ioset) (10%Ioset,75/Ioset) 60 (1500 , 50 ) 45 (1500 , 30 ) 30 (Ioset, 25) (150, 25) (1500, 25) 15 Programmed Operating Area Good Performance Area Allowed Operating Area 0 Programmed Operating Area 0 0 210 420 630 840 1050 Output Current (mA) 1260 0 300 Note: 700mA≤Ioset≤1050mA 600 900 1200 Output Current (mA) 1500 1800 Note: 1050mA≤Ioset≤1500mA ESM-075S210Dx 66 (140, 54) Output Voltage(V) 55 (1400 , 54 ) (840 , 54 ) (Ioset,75/Ioset) (10%Ioset,75/Ioset) 44 (2100 , 36 ) 33 (2100 , 21 ) 22 (Ioset, 18) (210, 18) (2100, 18) 11 Good Performance Area Allowed Operating Area Programmed Operating Area 0 0 420 840 1260 1680 Output Current (mA) 2100 2520 Note: 1400mA≤Ioset≤2100mA Input Specifications Parameter Min. Typ. Max. Input AC Voltage 249 Vac - 528 Vac Input DC Voltage 352 Vdc - 500 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 480Vac/ 60Hz - - 0.70 mA IEC60598-1; 480Vac/ 60Hz, - - 0.34 A Measured at 100% load and 277 Vac input. - - 0.20 A Measured at 100% load and 480 Vac input. - - 0.89 A2s Leakage Current Input AC Current Inrush Current(I2t) 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes At 480Vac input, 25C cold start, duration=252 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A Input Specifications (Continued) Parameter Min. Typ. Max. 0.9 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 140 mA - 1050 mA 1500 mA 2100 mA 700 mA 1050 mA 1400 mA - 1050 mA 1500 mA 2100 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESM-075S105Dx ESM-075S150Dx ESM-075S210Dx - - 120 V 90 V 60 V Line Regulation - - ±1% Load Regulation - - ±5% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.06%/C - Min. Typ. Max. 88.0% 88.5% 90.0% 90.5% - 87.0% 87.0% 89.0% 89.0% - 86.5% 86.5% 88.5% 88.5% - PF THD Notes At 277-480Vac, 50-60Hz, 60%-100% Load (45-75W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESM-075S105Dx ESM-075S150Dx ESM-075S210Dx Output Current Setting Range with Constant Power ESM-075S105Dx ESM-075S150Dx ESM-075S210Dx Total Output Current Ripple (pk-pk) Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 277-480Vac input, 60%-100% Load Case temperature = 0C ~Tc max General Specifications Parameter Efficiency at 277 Vac input: ESM-075S105Dx Io= 700 mA Io=1050 mA ESM-075S150Dx Io=1050 mA Io=1500 mA ESM-075S210Dx Io=1400 mA Io=2100 mA 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A General Specifications (Continued) Parameter Min. Typ. Max. 88.5% 89.0% 90.5% 91.0% - 87.0% 87.5% 89.0% 89.5% - 87.0% 87.0% 89.0% 89.0% - 88.5% 89.0% 90.5% 91.0% - 87.0% 87.5% 89.0% 89.5% - 87.0% 87.0% 88.5% 89.0% - MTBF - 302,000 Hours - Lifetime - 102,000 Hours - -40°C - +90°C -40°C - +80C Case temperature for 5 years warranty Humidity: 10%RH to 95%RH -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 400 Vac input: ESM-075S105Dx Io= 700 mA Io=1050 mA ESM-075S150Dx Io=1050 mA Io=1500 mA ESM-075S210Dx Io=1400 mA Io=2100 mA Efficiency at 480 Vac input: ESM-075S105Dx Io= 700 mA Io=1050 mA ESM-075S150Dx Io=1050 mA Io=1500 mA ESM-075S210Dx Io=1400 mA Io=2100 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions: Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 5.59 × 2.66 × 1.52 142 × 67.5 × 38.5 4.92 × 2.66 × 1.52 125 × 67.5 × 38.5 - 710 g - Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 uA 300 uA 450 uA 10%Ioset - Ioset 70 mA 105 mA 140 mA - Ioset 1V - 9V Dimming Specifications Parameter Dimming Output Range ESM-075S105DG ESM-075S150DG ESM-075S210DG ESM-075S105DG ESM-075S150DG ESM-075S210DG Recommended Dimming Range for 1-10V 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1400 mA ≤ Ioset ≤ 2100 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 140 mA ≤ Ioset < 1400 mA Default 1-10V dimming mode with positive logic. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A Dimming Specifications (Continued) Parameter Min. Typ. Max. PWM_in High Level - 10V - PWM_in Low Level - 0V - 200 Hz - 2 KHz 0% - 100% PWM_in Frequency Range PWM_in Duty Cycle Notes Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 EMI Standards EN 55015(1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load ESM-075S105Dx(lo=700mA) ESM-075S105Dx(lo=1050mA) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A ESM-075S150Dx(lo=1050mA) ESM-075S150Dx(lo=1500mA) ESM-075S210Dx(lo=1400mA) ESM-075S210Dx(lo=2100mA) Power Factor 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  1-10V Dimming The recommended implementation of the dimming control is provided below. V+ L2/L L1/N Vac Inventronics LED Driver VVprg Dim+ G Dim- Dimmer Implementation 1: Positive logic 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A V+ L2/L Vac L1/N Inventronics LED Driver VVprg Dim+ G Dim- Dimmer Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 1-10V voltage source signal or passive components like zener. 3. When 1-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  10V PWM Dimming The recommended implementation of the dimming control is provided below. V+ L2/L Vac L1/N V- Inventronics LED Driver Vprg Dim+ G Dim- PWM Signal Implementation 3: Positive logic V+ L2/L Vac L1/N V- Inventronics LED Driver Vprg Dim+ G Dim- PWM Signal Implementation 4: Negative logic 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-075SxxxDx 75W Programmable IP66/IP67 Driver Rev.A Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESM-075S210DT 价格&库存
很抱歉,暂时无法提供与“ESM-075S210DT”相匹配的价格&库存,您可以联系我们找货
ESM-075S210DT
    库存:143
