ESM-1K2S350MG
ESM-1K2S350MG
    INVENTRONICS(英飞特)
ESM-1K2S350MG 数据手册
ESM-1K2SxxxMx 1200W Programmable Driver with INV Digital Dimming Rev.A Features  Ultra High Efficiency (Up to 96.0%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Programmability  Isolated 0-10V/PWM/3-Timer-Modes Dimmable  INV Digital Dimming, UART Based Communication Protocol  Dim-to-Off with Low Standby Power  Minimum Dimming Level with 5% or 10% Selectable  Maximum Dimming Level with 9V or 10V Selectable  Fade Time Adjustable  Always-on Auxiliary Power: 12Vdc, 250mA  Low inrush current  Output Lumen Compensation  End-of-Life Indicator  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: IUVP, IOVP, OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The ESM-1K2SxxxMx series is a 1200W, constant-current, programmable and IP66/IP67 rated LED driver that operates from 249-528Vac input with excellent power factor. Created for many lighting applications including high mast, sports, UV-LED, aquaculture and horticulture etc. It provides an auxiliary voltage and dim-to-off functionality for powering low voltage, wireless controls. The dimming control supports 0-10V dimming as well as two-way communication via Digital Dimming, a UART based communication protocol. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range(1) Current Range Input Voltage Range(2) Output Voltage Range Typical Max. Typical Power Factor Output Efficiency Power (3) 277Vac 480Vac Model Number (4) 3.5 A 249~528Vac 171 ~ 462Vdc 1200 W 352~500Vdc 96.5% 0.99 0.96 ESM-1K2S350Mx 0.395-5.25A 3.95-5.25A 5.25 A 249~528Vac 114 ~ 304Vdc 1200 W 352~500Vdc 96.0% 0.99 0.96 ESM-1K2S525Mx 0.555-7.4A 249~528Vac 352~500Vdc 96.5% 0.99 0.96 ESM-1K2S740Mx 0.26-3.5A 2.6-3.5A 5.55-7.4A 7.4 A 81 ~ 217Vdc 1200 W Notes: (1) Output current range with constant power at 1200W. (2) Certified voltage range: 277-480Vac (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) x = G are UL Recognized and ENEC, etc. models; x = T are UL Class P models. 1 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx 1200W Programmable Driver with INV Digital Dimming Rev.A I-V Operating Area ESM-1K2S350Mx ESM-1K2S525Mx 558 (260,462) (1560,462) (2600,462) 10 0% Lo (3500,206) 186 (350,171) 93 (3500,171) (Ioset,171) Good Performance Area Allowed Operating Area Programmed Operating Area 700 2800 (3950,304) (Ioset,1200/Ioset) (10%Ioset,1200/Ioset) 244 10 0% Lo ad Lo ad Lo 279 (3500,343) ad (2370,304) % 60 372 Output Voltage(V) (10%Ioset,1200/Ioset) (395,304) 305 (Ioset,1200/Ioset) % 60 Output Voltage(V) 465 366 183 ad (5250,229) (5250,137) 122 (525,114) 61 0 (Ioset,114) (5250,114) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 1400 2100 3500 4200 0 1050 2100 3150 4200 Output Current (mA) Output Current (mA) Note: 2600mA≤Ioset≤3500mA Note: 3950mA≤Ioset≤5250mA 5250 6300 ESM-1K2S740Mx 264 (555,217) (3300,217) (5550,217) (Ioset,1200/Ioset) (10%Ioset,1200/Ioset) 176 10 0% % 60 Lo ad Lo Output Voltage(V) 220 132 ad (7400,162) (7400,97) 88 (74,81) 44 (7400,81) (Ioset,81) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 1480 2960 4440 5920 7400 8800 Output Current (mA) Note: 5550mA≤Ioset≤7400mA Input Specifications Parameter Min. Typ. Max. Notes Input AC Voltage 249 Vac - 528 Vac Input DC Voltage 352 Vdc - 500 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 480Vac/ 60Hz - - 0.70 mA IEC60598-1; 480Vac/ 60Hz,  - - 5.0 A Measured at 100% load and 277 Vac input. - - 2.95 A Measured at 100% load and 480 Vac input. Leakage Current Input AC Current 2 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx 1200W Programmable Driver with INV Digital Dimming Rev.A Input Specifications (Continued) Parameter Min. Typ. Max. Notes - - 4.20 A2s At 480Vac input, 25 ℃ cold start, duration=12.7 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 0.90 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 260 mA 395 mA 555 mA - 3500 mA 5250 mA 7400 mA 2600 mA 3950 mA 5550 mA - 3500 mA 5250 mA 7400 mA - 5%Iomax 10%Iomax 100% load, 20 MHz BW - - 2%Iomax 100% load Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage ESM-1K2S350Mx ESM-1K2S525Mx ESM-1K2S740Mx - - 500 V 340 V 240 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 250 mA 12V Auxiliary Output Transient Peak Current@6W - - 500 mA 12V Auxiliary Output Transient Peak Current@10W - - 850 mA Inrush Current(I2t) PF THD At 277-480Vac, 50-60Hz, 60%-100% Load (720 - 1200W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESM-1K2S350Mx ESM-1K2S525Mx ESM-1K2S740Mx Output Current Setting Range with Constant Power ESM-1K2S350Mx ESM-1K2S525Mx ESM-1K2S740Mx Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 3 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes 100% load 100% load Measured at 277-480Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ 500mA peak for a maximum duration of 2.2 ms in a 6.0ms period during which time the average should not exceed 250mA. 850mA peak for a maximum duration of 1.3 ms in a 5.2ms period during which time the average should not exceed 250mA. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx 1200W Programmable Driver with INV Digital Dimming Rev.A General Specifications Parameter Min. Typ. Max. 93.0% 93.0% 95.0% 95.0% - 93.0% 92.5% 95.0% 94.5% - 93.5% 93.0% 95.5% 95.0% -- 94.0% 94.0% 96.0% 96.0% - 94.0% 93.5% 96.0% 95.5% - 94.0% 94.0% 96.0% 96.0% -- 94.5% 94.0% 96.5% 96.0% - 94.0% 94.0% 96.0% 96.0% - 94.5% 94.0% 96.5% 96.0% -- Standby Power - 1.5 W - MTBF - 207,000 Hours - - 101,000 Hours - - 54,000 Hours - -40°C - +90°C -40°C - +80°C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 277 Vac input: ESM-1K2S350Mx Io= 2600 mA Io= 3500 mA ESM-1K2S525Mx Io= 3950 mA Io= 5250 mA ESM-1K2S740Mx Io= 5550 mA Io= 7400 mA Efficiency at 400 Vac input: ESM-1K2S350Mx Io= 2600 mA Io= 3500 mA ESM-1K2S525Mx Io= 3950 mA Io= 5250 mA ESM-1K2S740Mx Io= 5550 mA Io= 7400 mA Efficiency at 480 Vac input: ESM-1K2S350Mx Io= 2600 mA Io= 3500 mA ESM-1K2S525Mx Io= 3950 mA Io= 5250 mA ESM-1K2S740Mx Io= 5550 mA Io= 7400 mA Lifetime Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Net Weight - 3850 g www.inventronics-co.com Tel: 86-571-56565800 Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Measured at 277Vac input, 100%Load and 40C ambient temperature - 4 / 16 Specifications are subject to changes without notice. Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) With mounting ear 12.20 × 5.55 × 1.90 310 × 141 × 48.5 11.22 × 5.55 × 1.90 285 × 141 × 48.5 Inches (L × W × H) Millimeters (L × W × H) Notes All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx 1200W Programmable Driver with INV Digital Dimming Rev.A Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 uA 300 uA 450 uA Dimming Output Range with 10%-100% (Default) ESM-1K2S350Mx ESM-1K2S525Mx ESM-1K2S740Mx 10%Ioset - Ioset ESM-1K2S350Mx ESM-1K2S525Mx ESM-1K2S740Mx 260 mA 395 mA 555 mA - Ioset Dimming Output Range with 5%-100% (Settable) ESM-1K2S350Mx ESM-1K2S525Mx ESM-1K2S740Mx 10%Ioset - Ioset ESM-1K2S350Mx ESM-1K2S525Mx ESM-1K2S740Mx Recommended Dimming Input Range 130 mA 198 mA 278 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 2600 mA ≤ Ioset ≤ 3500 mA 3950 mA ≤ Ioset ≤ 5250 mA 5550 mA ≤ Ioset ≤ 7400 mA 260 mA ≤ Ioset < 2600 mA 395 mA ≤ Ioset < 3950 mA 555 mA ≤ Ioset < 5550 mA 2600 mA ≤ Ioset ≤ 3500 mA 3950 mA ≤ Ioset ≤ 5250 mA 5550 mA ≤ Ioset ≤ 7400 mA 260 mA ≤ Ioset < 2600 mA 395 mA ≤ Ioset < 3950 mA 555 mA ≤ Ioset < 5550 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 EMI Standards EN 55015(1) EN 61000-3-2 Notes Conducted emission Test &Radiated emission Test Harmonic current emissions 5 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx Rev.A 1200W Programmable Driver with INV Digital Dimming Safety &EMC Compliance (Continued) EMI Standards EN 61000-3-3 Notes Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature 6 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx Rev.A 1200W Programmable Driver with INV Digital Dimming Inrush Current Waveform Efficiency vs. Load ESM-1K2S350Mx(lo=2600mA) ESM-1K2S350Mx(lo=3500mA) ESM-1K2S525Mx(lo=3950mA) ESM-1K2S525Mx(lo=5250mA) 7 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx Rev.A 1200W Programmable Driver with INV Digital Dimming ESM-1K2S740Mx(lo=5550mA) ESM-1K2S740Mx(lo=7400mA) Power Factor Total Harmonic Distortion 8 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx 1200W Programmable Driver with INV Digital Dimming Rev.A Protection Functions Parameter Min. Typ. Max. Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Input Under Voltage Protection (IUVP) Input Over Voltage Protection (IOVP) Input Protection Voltage Input Recovery Voltage Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 220 Vac 230 Vac 240 Vac 230 Vac 240 Vac 250 Vac 550 Vac 570 Vac 590 Vac 530 Vac 550 Vac 570 Vac 590 Vac  Input Under Voltage Protection Diagram  Input Over Voltage Protection Diagram 9 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Turn off the output when the input voltage falls below protection voltage. Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. Turn off the output when the input voltage exceeds protection voltage. Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive for 8 hours with a stable input voltage stress of 590Vac. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx Rev.A 1200W Programmable Driver with INV Digital Dimming Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic 10 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx 1200W Programmable Driver with INV Digital Dimming Rev.A Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  PWM Dimming The recommended implementation of the dimming control is provided below. V+ L V- Vac N Inventronics LED Driver G Vaux Dim+ PWM Signal Dim- Implementation 3: Positive logic 11 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-1K2SxxxMx 1200W Programmable Driver with INV Digital Dimming Rev.A V+ L V- Vac N Inventronics LED Driver Vaux Dim+ G PWM Signal Dim- Implementation 4: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self Adapting Percentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESM-1K2S350MG 价格&库存
很抱歉,暂时无法提供与“ESM-1K2S350MG”相匹配的价格&库存,您可以联系我们找货
ESM-1K2S350MG
    ESM-1K2S350MG
