EUC-030S035DVM
EUC-030S035DVM
    INVENTRONICS(英飞特)
EUC-030S035DVM 数据手册
EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A Features  Low THD, 10% Max up to 240 Vac  Compact Metal Case with Excellent Thermal Performance  Isolated 0-10V Dimmable  Input Surge Protection: 4kV line-line, 6kV line-earth  High Reliability & Long Lifetime: 88,000 hrs. at 75C Case Temperature  Suitable for Independent Use and Class I Luminaires  Input UVP and Input OVP  Waterproof(IP67)  SELV Output  5 Years Warranty Description The EUC-030SxxxDVM series is a 30W, constant-current IP67 LED driver that operates from 90-305 Vac input with excellent power factor and THD feature. It is created for low bay, tunnel and street lights. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Input Voltage Range(1) 90 ~ 305 Vac 127~250 Vdc 90 ~ 305 Vac 127~250 Vdc 90 ~ 305 Vac 127~250 Vdc Output Current 350 mA 500 mA 700 mA Output Voltage Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac 37 ~ 75 Vdc 26 W 85.0% 0.99 0.96 EUC-030S035DVM 29 ~ 60 Vdc 30 W 87.0% 0.99 0.96 EUC-030S050DVM 20 ~ 43 Vdc 30 W 85.5% 0.99 0.96 EUC-030S070DVM Power Factor Model Number(3) Notes: (1) Certified input voltage range: 120-240Vac or 127-250Vdc (except CCC and KS). (2) Measured at full load and 220Vac input. (3) SELV output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.35 A 127 ~ 250 Vdc IEC60598-1; 240Vac/ 60Hz Measured at full load and 120 Vac input. 1/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A Input Specifications (Continued) Parameter Min. Typ. Max. Input AC Current - - 0.2 A 2 - - 0.002 A s 0.90 - - THD - - 15% THD - - 10% Min. Typ. Max. -8%lo - 8%lo At full load condition Total Output Current Ripple (pk-avg) - 50%lo 75%lo At full load condition Startup Overshoot Current - 5%Io 10%Io At full load condition - - 100 V 100 V 60 V Line Regulation - - ±5.0% Measured at full load Load Regulation - - ±5.0% At 220Vac input - 1.5 s 2.0 s Measured at 120Vac input, 65%-100% load. - 1.0 s 1.5 s Measured at 220Vac input, 65%-100% load. - 0.06%/C - Inrush Current(I t) Power Factor Notes Measured at full load and 220 Vac input. 2 At 220Vac input, 25C cold start, duration= 32.8 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 100-240Vac, 50-60Hz, 65%-100% load(19.5-30W) 200-240Vac, 50-60Hz, 65%-100% load(19.5-30W) Output Specifications Parameter Output Current Tolerance No Load Output Voltage EUC-030S035DVM EUC-030S050DVM EUC-030S070DVM Turn-on Delay Time Temperature Coefficient of Iomax Notes Case temperature = 0C ~ Tc max Note: All specifications are tested by Cree XLamp XP-G2 and typical measured at 220Vac and 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUC-030S035DVM EUC-030S050DVM EUC-030S070DVM Min. Typ. Max. 83.0% 84.0% 83.0% 85.0% 86.0% 85.0% - Notes Measured at full load and steady-state temperature in 25C ambient. 2/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A General Specifications (Continued) Parameter Min. Typ. Max. Efficiency at 220 Vac input: EUC-030S035DVM EUC-030S050DVM EUC-030S070DVM 83.0% 85.0% 83.5% 85.0% 87.0% 85.5% - Measured at full load and steady-state temperature in 25C ambient. Efficiency at 277 Vac input: EUC-030S035DVM EUC-030S050DVM EUC-030S070DVM 82.0% 84.0% 83.0% 84.0% 86.0% 85.0% - Measured at full load and steady-state temperature in 25C ambient. MTBF - 799,000 Hours - Lifetime - 88,000 Hours - -40 C - +90 C -40 C - +75 C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. -40 C - +85 C Humidity: 5% RH to 100% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 75C case temperature; See lifetime vs. Tc curve for the details With mounting ear 4.13 x 2.52 x 1.26 105 x 64 x 32 3.46 x 2.52 x 1.26 88 x 64 x 32 Net Weight - 375 g - Note: All specifications are tested by Cree XLamp XP-G2 and typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the 0~10V Input Pin -20 V - 20 V Source Current on 0~10V Input Pin 0 μA 200 μA 250 μA 10%Iomax - 100%Iomax 0V - 10 V Dimming Output Range Recommended Dimming Input Range Notes Safety &EMC Compliance Safety Category CE CCC KS Standard EN 61347-1, EN61347-2-13 GB 19510.1, GB 19510.14 KS C 7655 3/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A Safety &EMC Compliance (Continued) EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature 4/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A Inrush Current Waveform Efficiency vs. Load EUC-030S035DVM EUC-030S050DVM EUC-030S070DVM 5/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A Power Factor Total Harmonic Distortion Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The driver shall be self-recovery when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Input Under Voltage Protection Auto Recovery. Shut down when the input voltage falls below 90V. And the driver will restart when the input voltage is in normal. Input Over Voltage Protection Input Protection Voltage 330 Vac 340 Vac 350 Vac Turn off the output when the input voltage exceeds protection voltage. Recovery Voltage 300 Vac 320 Vac 340 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. 6/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A Protection Functions (Continued) Parameter Input Over Voltage Protection  Max. of Input Over Voltage Min. Typ. Max. Notes - - 380 Vac Input Over Voltage Protection Diagram Io Recovery Protection 340 Vac 320 Vac Vin Dimming  0-10V Dimming The recommended implementation is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do not connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim+ should be open. 7/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A Mechanical Outline INPUT (VDE H05RN-F 3*1.0mm 2 7.2) DIMMING WIRE (VDE H05RN-F 2*0.5mm 2 6.3) N W E OU RL BB +VV PURPLE GRAY Tc ︵ ︵ ︶ ︶ AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) OUTPUT (VDE H05RN-F 2*1.0mm 2 6.8) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 8/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-030SxxxDVM 30W Constant Current IP67 Driver Rev. A Revision History Description of Change Change Date Rev. 2017-11-30 A Item From Datasheet Release / To / 9/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-030S035DVM 价格&库存
很抱歉,暂时无法提供与“EUC-030S035DVM”相匹配的价格&库存,您可以联系我们找货
EUC-030S035DVM
