ESM-320S760DT
ESM-320S760DT
    INVENTRONICS(英飞特)
ESM-320S760DT 数据手册
ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A Features  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Programmability  Isolated 1-10V/10V PWM/3-Timer-Modes Dimmable  Output Lumen Compensation  End-of-Life Indicator  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location 5 Year Warranty  Description The ESM-320SxxxDx series is a 320W, constant-current, programmable and IP66/IP67 rated LED driver that operates from 249-528Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, aquaculture and sport, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current 70-1050mA 700-1050mA 700 mA 105-1500mA 1050-1500mA 1400 mA 175-2500mA 1750-2500mA 2100 mA 285-5000mA 2850-5000mA 4900 mA 535-7600mA 5350-7600mA 6700 mA Input Voltage Range(2) 249~528 Vac/ 352~500 Vdc 249~528 Vac/ 352~500 Vdc 249~528 Vac/ 352~500 Vdc 249~528 Vac/ 352~500 Vdc 249~528 Vac/ 352~500 Vdc Output Voltage Range Typical Max. Typical Power Factor Output Efficiency Power (3) 277Vac 480Vac Model Number (5) 153~457Vdc 320 W 95.0% 0.99 0.96 ESM-320S105Dx 107~305Vdc 320 W 95.0% 0.99 0.96 ESM-320S150Dx 64~183 Vdc 320 W 95.0% 0.99 0.96 ESM-320S250Dx 32~112 Vdc 320 W 94.5% 0.99 0.96 ESM-320S500Dx (4) 21 ~ 60 Vdc 320 W 93.5% 0.99 0.96 ESM-320S760Dx (4) Notes: (1) Output current range with constant power at 320W (2) Certified input voltage range: 277-480Vac. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV output. (5) x = G are UL Recognized and ENEC, etc. models; x = T are UL Class P models. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A I-V Operation Area ESM-320S105Dx ESM-320S150Dx ESM-320S250Dx ESM-320S500Dx ESM-320S760Dx 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A Input Specifications Parameter Min. Typ. Max. Input AC Voltage 249 Vac - 528 Vac Input DC Voltage 352 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 480Vac/60Hz - - 0.70 mA IEC60598-1; 480Vac/60Hz,  - - 1.38 A Measured at 100% load and 277 Vac input. - - 0.81 A Measured at 100% load and 480 Vac input. - - 1.409 A s 0.9 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 175 mA 285 mA 535 mA - 1050 mA 1500 mA 2500 mA 5000 mA 7600 mA 700 mA 1050 mA 1750 mA 2850 mA 5350 mA - 1050 mA 1500 mA 2500 mA 5000 mA 7600 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESM-320S105Dx ESM-320S150Dx ESM-320S250Dx ESM-320S500Dx ESM-320S760Dx - - 500 V 340 V 210 V 120 V 70 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Leakage Current Input AC Current 2 Inrush Current(I t) PF THD Notes 500 Vdc 2 At 480Vac input, 25C cold start, duration=4.56 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 277-480Vac, 50-60Hz, 60%-100% Load (192-320W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESM-320S105Dx ESM-320S150Dx ESM-320S250Dx ESM-320S500Dx ESM-320S760Dx Output Current Setting Range with Constant Power ESM-320S105Dx ESM-320S150Dx ESM-320S250Dx ESM-320S500Dx ESM-320S760Dx Total Output Current Ripple (pk-pk) 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A Output Specifications (Continued) Parameter Min. Typ. Max. Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/C - Min. Typ. Max. 92.0% 91.0% 94.0% 93.0% - 92.0% 92.0% 94.0% 94.0% - 92.0% 91.0% 94.0% 93.0% - 91.5% 90.0% 93.5% 92.0% - 90.5% 90.0% 92.5% 92.0% - 93.0% 92.0% 95.0% 94.0% - 92.5% 92.5% 94.5% 94.5% - 93.0% 92.0% 95.0% 94.0% - 92.5% 90.5% 94.5% 92.5% - 91.5% 90.5% 93.5% 92.5% - 93.0% 92.0% 95.0% 94.0% - 93.0% 92.5% 95.0% 94.5% - 93.0% 92.0% 95.0% 94.0% - 92.5% 90.5% 94.5% 92.5% - 91.5% 91.5% 93.5% 93.5% - Notes Measured at 277-480Vac input, 60%-100%load Case temperature = 0C~Tc max General Specifications Parameter Efficiency at 277 Vac input: ESM-320S105Dx Io= 700 mA Io=1050 mA ESM-320S150Dx Io=1050 mA Io=1500 mA ESM-320S250Dx Io=1750 mA Io=2500 mA ESM-320S500Dx Io=2850 mA Io=5000 mA ESM-320S760Dx Io=5350 mA Io=7600 mA Efficiency at 400 Vac input: ESM-320S105Dx Io= 700 mA Io=1050 mA ESM-320S150Dx Io=1050 mA Io=1500 mA ESM-320S250Dx Io=1750 mA Io=2500 mA ESM-320S500Dx Io=2850 mA Io=5000 mA ESM-320S760Dx Io=5350 mA Io=7600 mA Efficiency at 480 Vac input: ESM-320S105Dx Io= 700 mA Io=1050 mA ESM-320S150Dx Io=1050 mA Io=1500 mA ESM-320S250Dx Io=1750 mA Io=2500 mA ESM-320S500Dx Io=2850 mA Io=5000 mA ESM-320S760Dx Io=5350 mA Io=7600 mA 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A General Specifications (Continued) Parameter Min. Typ. Max. MTBF - 296,000 Hours - Lifetime - 104,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +80C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; Storage Temperature -40°C - +85°C Humidity: 5%RH to 95%RH; Dimensions: Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes Measured at 480Vac input, 80%load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.57 × 3.15 × 1.75 243 × 80 × 44.5 8.82 × 3.15 × 1.75 224 × 80 × 44.5 - 1530 g - Min. Typ. Max. -20 V - 20 V 200 μA 300 μA 450 μA Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin ESM-320S105Dx ESM-320S150Dx ESM-320S250Dx ESM-320S500Dx ESM-320S760Dx 10%Ioset - Ioset ESM-320S105Dx ESM-320S150Dx ESM-320S250Dx ESM-320S500Dx ESM-320S760Dx 70 mA 105 mA 175 mA 285 mA 535 mA - Ioset 1V - 9V PWM_in High Level - 10 V - PWM_in Low Level - 0V - 200 Hz - 2 KHz 0% - 100% Dimming Output Range Recommended Dimming Range for 1-10V PWM_in Frequency Range PWM_in Duty Cycle 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1750 mA ≤ Ioset ≤ 2500 mA 2850 mA ≤ Ioset ≤ 5000 mA 5350 mA ≤ Ioset ≤ 7600 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 175 mA ≤ Ioset < 1750 mA 285 mA ≤ Ioset < 2850 mA 535 mA ≤ Ioset < 5350 mA Default 1-10V dimming mode with positive logic. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE CB EN 61347-1, EN61347-2-13 IEC 61347-1, IEC 61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load ESM-320S105Dx(Io=700mA) ESM-320S105Dx(Io=1050mA) 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A ESM-320S150Dx(Io=1050mA) ESM-320S150Dx(Io=1500mA) ESM-320S250Dx(Io=1750mA) ESM-320S250Dx(Io=2500mA) ESM-320S500Dx(Io=2850mA) ESM-320S500Dx(Io=5000mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A ESM-320S760Dx(Io=5350mA) ESM-320S760Dx(Io=7600mA) Power Factor Total Harmonic Distortion 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx 320W Programmable IP66/IP67 Driver Rev. A Protection Functions Parameter Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Dimming  1-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 1-10V voltage source signal or passive components like zener. 3. When 1-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-320SxxxDx  320W Programmable IP66/IP67 Driver Rev. A 10V PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESM-320S760DT 价格&库存
很抱歉,暂时无法提供与“ESM-320S760DT”相匹配的价格&库存,您可以联系我们找货
ESM-320S760DT
    库存:8
    ESM-320S760DT
