EUD-150S560DTA
EUD-150S560DTA
    INVENTRONICS(英飞特)
EUD-150S560DTA 数据手册
EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B Features  Ultra High Efficiency (Up to 94%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/Timer Dimmable (3 Timer Modes) (DTA models) DALI Dimming Control (BTA models)  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA (Transient Peak Current up to 400mA)  Output Lumen Compensation ( DTA models)  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  7 Years Warranty Description The EUD-150SxxxDTA(BTA) series is a 150W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, tunnel and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range (1) Current Range Input Voltage Range(2) Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Model Number 70-1050mA 700-1050mA 700 mA 90 ~ 305 Vac 75~214Vdc 150 W 100 ~ 300 Vdc 94.0% 0.99 0.96 EUD-150S105DTA(BTA) 140-2100mA 1400-2100mA 1400 mA 90 ~ 305 Vac 38~107Vdc 150 W 100 ~ 300 Vdc 94.0% 0.99 0.96 EUD-150S210DTA(BTA)(4) 245-3500mA 2450-3500mA 3150 mA 90 ~ 305 Vac 22 ~ 61Vdc 150 W 100 ~ 300 Vdc 93.5% 0.99 0.96 EUD-150S350DTA(BTA)(4) 385-5600mA 3850-5600mA 4200 mA 90 ~ 305 Vac 14 ~ 39Vdc 150 W 100 ~ 300 Vdc 92.5% 0.99 0.96 EUD-150S560DTA(BTA)(4) Notes: (1) Output current range with constant power at 150W (2) Certified voltage range: UL, FCC 100-277Vac or 100-300Vdc; otherwise 100-240Vac or 100-250Vdc(except KS) (3) Measured at 100%load and 220Vac input (see below “General Specifications” for details). (4) SELV Output 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B I-V Operating Area EUD-150S105DTA(BTA) EUD-150S210DTA(BTA) EUD-150S350DTA(BTA) EUD-150S560DTA(BTA) 72 (245,61) (1715,61) (2450,61) (10%Ioset,150/Ioset) (Ioset,150/Ioset) 48 10 % 70 ad Lo Output Voltage(V) 60 36 0% Lo ad (3500,43) (3500,30) 24 12 (3500,22) (Ioset,22) (350,22) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 1400 700 2100 2800 3500 4200 Output Current (mA) Note: 2450mA Ioset 3500mA Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz, grounding effectively - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively - - 1.87 A - - 0.85 A - - 1.90 A s Leakage Current Input AC Current 2 Inrush Current(I t) 2 Notes 100-300Vdc Measured at 100%load and 100 Vac input. Measured at 100%load and 220 Vac input. At 220Vac input, 25℃ cold start, duration=872μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 140 mA 245 mA 385 mA - 1050 mA 2100 mA 3500 mA 5600 mA 700 mA 1400 mA 2450 mA 3850 mA - 1050 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax - 2%Iomax - 100%load. Startup Overshoot Current - - 10%Iomax 100%load No Load Output Voltage EUD-150S105DTA(BTA) EUD-150S210DTA(BTA) EUD-150S350DTA(BTA) EUD-150S560DTA(BTA) - - 240 V 120 V 80 V 50 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA - - 400 mA PF Notes At 100-277Vac, 50-60Hz, 70%-100% Load (105-150W) At 220-240Vac, 50-60Hz, 75%-100% Load (112.5-150W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-150S105DTA(BTA) EUD-150S210DTA(BTA) EUD-150S350DTA(BTA) EUD-150S560DTA(BTA) Output Current Setting Range with Constant Power EUD-150S105DTA(BTA) EUD-150S210DTA(BTA) EUD-150S350DTA(BTA) EUD-150S560DTA(BTA) Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Turn-on Delay Time Temperature Coefficient of Ioset 12V Auxiliary Output Transient Peak Current Notes 100%load 100%load, 20 MHz BW Measured at 100%load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“(DTA models) Return terminal is “OTP−“(BTA models) 400mA peak for a maximum duration of 300ms in a 2s period during which time t he average should not exceed 200mA. Note: All specifications are typical at 25C unless otherwise stated. 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B General Specifications Parameter Min. Typ. Max. 89.5% 88.0% 91.5% 90.0% - 89.5% 87.5% 91.5% 89.5% - 88.5% 87.5% 90.5% 89.5% - 88.0% 86.0% 90.0% 88.0% - 92.0% 90.5% 94.0% 92.5% - 92.0% 89.5% 94.0% 91.5% - 91.5% 89.0% 93.5% 91.0% - 90.5% 88.5% 92.5% 90.5% - 92.0% 90.5% 94.0% 92.5% - 92.5% 90.0% 94.5% 92.0% - 91.5% 89.0% 93.5% 91.0% - 90.5% 89.0% 92.5% 91.0% - Standby power - - 0.5 W MTBF - 228,000 Hours - Lifetime - 100,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 120 Vac input: EUD-150S105DTA(BTA) Io= 700mA Io=1050mA EUD-150S210DTA(BTA) Io=1400mA Io=2100mA EUD-150S350DTA(BTA) Io=2450mA Io=3500mA EUD-150S560DTA(BTA) Io=3850mA Io=5600mA Efficiency at 220 Vac input: EUD-150S105DTA(BTA) Io= 700mA Io=1050mA EUD-150S210DTA(BTA) Io=1400mA Io=2100mA EUD-150S350DTA(BTA) Io=2450mA Io=3500mA EUD-150S560DTA(BTA) Io=3850mA Io=5600mA Efficiency at 277 Vac input: EUD-150S105DTA(BTA) Io= 700mA Io=1050mA EUD-150S210DTA(BTA) Io=1400mA Io=2100mA EUD-150S350DTA(BTA) Io=2450mA Io=3500mA EUD-150S560DTA(BTA) Io=3850mA Io=5600mA Dimensions Inches (L × W × H) Millimeters (L × W × H) 8.03 × 2.66 × 1.56 204 × 67.5 × 39.7 Notes Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MILHDBK-217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 8.86× 2.66 × 1.56 225 × 67.5 × 39.7 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B General Specifications (Continued) Parameter Net Weight Min. Typ. Max. - 1150 g - Notes Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim Source Current on Vdim (+)Pin Recommended Dimming Input Range -20 V - 20 V 200 uA 300 uA 450 uA 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz PWM_in Duty Cycle 1% - 99% 2% 5% 8% 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - DA, DA High Level 9.5V 16V 22.5V DA, DA Low Level -6.5V 0V 6.5V DA, DA Current 0mA - 2mA Notes Vdim(+) = 0 V Default 0-10V dimming mode. Hysteresis Recommended Dimming Input Range DTA Models Hysteresis PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis BTA Models Dimming mode set to PWM in PC interface. 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B Dimming Specifications (Continued) Parameter Dimming Output Range Min. EUD-150S105DTA(BTA) EUD-150S210DTA(BTA) EUD-150S350DTA(BTA) EUD-150S560DTA(BTA) Typ. Max. 10%Ioset - Ioset 70mA 140mA 245mA 385mA - Ioset Notes 700mA ≤ Ioset ≤ 1050mA 1400mA ≤ Ioset ≤ 2100mA 2450mA ≤ Ioset ≤ 3500mA 3850mA ≤ Ioset ≤ 5600mA 70mA ≤ Ioset < 700mA 140mA ≤ Ioset < 1400mA 245mA ≤ Ioset < 2450mA 385mA ≤ Ioset < 3850mA Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment DALI Standards DALI Notes (3) IEC62386-101,102 & part of 207 Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. (3) Optional Commands Implemented: 242 (query short circuit), 243 (query open circuit) Lifetime vs. Case Temperature Inrush Current Waveform 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B Efficiency vs. Load EUD-150S105DTA(BTA)(Io=700mA) EUD-150S105DTA(BTA)(Io=1050mA) EUD-150S210DTA(BTA)(Io=1400mA) EUD-150S210DTA(BTA)(Io=2100mA) EUD-150S350DTA(BTA)(Io=2450mA) EUD-150S350DTA(BTA)(Io=3500mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B EUD-150S560DTA(BTA)(Io=3850mA) EUD-150S560DTA(BTA)(Io=5600mA) Power Factor Total Harmonic Distortion 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA) 150W Programmable IP67 Driver Rev.B Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset ≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming (Only DTA models) The recommended implementation of the dimming control is provided below. V+ L V- Vac N Inventronics LED Driver G OTP+ OTPVaux Dim+ Dim- 0 (1)-10V Dimmer Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDTA(BTA)  150W Programmable IP67 Driver Rev.B PWM Dimming (Only DTA models) The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic Implementation 3: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.   Time Dimming (Only DTA models) Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-150S560DTA 价格&库存
很抱歉,暂时无法提供与“EUD-150S560DTA”相匹配的价格&库存,您可以联系我们找货
EUD-150S560DTA
