EUV-250S042ST
EUV-250S042ST
    INVENTRONICS(英飞特)
    250 W LED driver
EUV-250S042ST 数据手册
EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M Features  High Efficiency (Up to 93.5%)  Constant Voltage Output  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OVP, OCP, SCP, OTP  IP67 and UL Dry / Damp / Wet Location   SELV Output TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location 5 Years Warranty  Description The EUV-250SxxxST series is a 250W, constant-voltage LED driver that operates from 90-305 Vac input with excellent power factor. It is created for architecture lighting, decorative lighting, high bay, high mast, arena and roadway lights, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, over current, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac 12 Vdc 90 ~ 305 Vac 0~18.33 A 220 W 91.5% 0.99 0.93 EUV-250S012ST 24 Vdc 90 ~ 305 Vac 0~10.41 A 250 W 92.0% 0.99 0.96 EUV-250S024ST 28 Vdc 90 ~ 305 Vac 0~8.93 A 250 W 92.0% 0.99 0.96 EUV-250S028ST 36 Vdc 90 ~ 305 Vac 0~6.94 A 250 W 92.5% 0.99 0.96 EUV-250S036ST 42 Vdc 90 ~ 305 Vac 0~5.95 A 250 W 92.5% 0.99 0.96 EUV-250S042ST 48 Vdc 90 ~ 305 Vac 0~5.20 A 250 W 93.0% 0.99 0.96 EUV-250S048ST 54 Vdc 90 ~ 305 Vac 0~4.62 A 250 W 93.5% 0.99 0.96 EUV-250S054ST Power Factor Model Number (3) Notes: (1) Certified input voltage range: UL 100-277Vac; otherwise: 100-240Vac (2) Measured at 100% load and 220 Vac input. (3) SELV output Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.75 mA At 277Vac 60Hz input , grounding effectively - - 3.0 A Measured at 100% load and 100 Vac input. - - 1.4 A Measured at 100% load and 220 Vac input. Input AC Current 1/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M Input Specifications (Continued) Parameter Min. Typ. Max. - - 2.33 A s 0.90 - - - - 20% Min. Typ. Max. Output Voltage Tolerance -5% - 5% Ripple and Noise (pk-pk) - - 2% VO Output Overshoot / Undershoot - - 10% When power on or off. Line Regulation - - ±1% At 100% load condition. Load Regulation - - ±3% - 0.4 s 1.0 s Measured at 120Vac input, 75%-100% load. - 0.4 s 1.0 s Measured at 220Vac input, 75%-100% load. Output Deviation - - 5% VO Settling Time - - 10 mS - 0.03%/C - 2 Inrush Current(I t) Power Factor 2 Notes At 220Vac input, 25℃ cold start, duration=3 ms, 10%Ipk-10%Ipk. At 100-277Vac, 50-60Hz, 75%-100% load THD Output Specifications Parameter Notes At 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Load Dynamic Response Temperature Coefficient R/S: 1 A / uS Load: 25% ~ 75% 100% load. Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Efficiency at 220 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Min. Typ. Max. Notes 89.0% 89.5% 89.5% 90.0% 90.0% 90.5% 91.0% 89.5% 90.0% 90.0% 90.5% 90.5% 91.0% 91.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) 91.0% 91.5% 91.5% 92.0% 92.0% 92.5% 93.0% 91.5% 92.0% 92.0% 92.5% 92.5% 93.0% 93.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) 2/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M General Specifications (Continued) Parameter Min. Typ. Max. Notes Efficiency at 277 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V 91.0% 91.5% 91.5% 92.0% 92.0% 92.5% 93.0% 91.5% 92.0% 92.0% 92.5% 92.5% 93.0% 93.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) No Load Power Dissipation - - 5W MTBF - 250,000 hours - Lifetime - 59,400 hours - -40 C - +90 C -40 C - +60 C Case temperature for 5 years warranty; -40 C - +85 C Humidity: 5% RH to 100% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches(L × W × H) Millimeters (L × W × H) With mounting ear 9.88 × 3.54 × 1.46 251 × 90 × 37 8.82 × 3.54 × 1.46 224 × 90 × 37 Net Weight - Measured at 120Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) Measured at 220Vac input, 80%Load and 60C case temperature; See life time vs. Tc curve for the details 1300 g - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS ( 2) 3/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Curve EUV-250S012ST EUV-250S042ST Protection Functions Parameter Over Current Protection Min. Typ. Max. Notes 130% IO 165% IO 200% IO Hiccup mode. The power supply shall be selfrecovery when the fault condition is removed. Over Temperature Protection Auto Recovery, returning to normal after over temperature is removed. Short Circuit Protection No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 4/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M Mechanical Outline EUV-250S012ST INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*18AWG 7.8) AC/L(BLACK) AC/N(WHITE) GND (GREEN) 7.3) V+ (RED) V- (BLACK) V+ (RED) V- (BLACK) V+ (RED) V- (BLACK) Tc PROJ: Unspecified tolerance:±1 Note: The 3 DC output cables are connected in parallel internally because one AWG #18 wire can only carry 10A. Please connect the 3 red wires together and 3 black wires together in application, or ensure each cable carries same current. EUV-250S024/036ST INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*18AWG 7.8) AC/L(BLACK) AC/N(WHITE) GND (GREEN) 7.3) V+ (RED) V- (BLACK) V+ (RED) V- (BLACK) Tc PROJ: Unspecified tolerance:±1 Note: The 2 DC output cables are connected in parallel internally because one AWG #18 wire can only carry 10A. Please connect the 2 red wires together and 2 black wires together in application, or ensure each cable carries same current. 5/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M EUV-250S028ST INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*14AWG 7.8) AC/L(BLACK) 8.8) V+ (RED) V- (BLACK) Tc AC/N(WHITE) GND (GREEN) PROJ: Unspecified tolerance:±1 EUV-250S042ST OUTPUT (UL SJTW 2*16AWG INPUT (UL SJTW 3*18AWG 7.8) AC/L(BLACK) V+ (RED) V- (BLACK) Tc AC/N(WHITE) GND (GREEN) 7.9) PROJ: Unspecified tolerance:±1 6/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M EUV-250S048/054ST INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*18AWG 7.8) AC/L(BLACK) V+ (RED) V- (BLACK) Tc AC/N(WHITE) GND (GREEN) 7.3) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M Revision History Change Date Description of Change Rev. Item From To Add a new model of 28V 2010-03-11 A Add Leakage Current in Input Specifications Standardize the tolerance in Mechanical Outline Change Input AC Current @220Vac 2011-01-14 2011-07-30 2012-06-18 2012-07-17 2012-11-15 B C D E F / Max. 0.75 Ma At 277Vac 50Hz input / / 1.3 A 1.4 A Min. 89.5% 92.0% 92.0% 92.0% Min. Change the efficiency (220Vac) VO = 12 V 91.5% Change the efficiency (120Vac) VO = 12 V VO = 84 V VO = 105 V VO = 150 V Typ. 90.0% 92.5% 92.5% 92.5% Typ. 92.0% Min. 89.0% 91.0% 91.0% 91.0% Min. 91.0% Typ. 89.5% 91.5% 91.5% 91.5% Typ. 91.5% Change No Load Power Dissipation ≤3 W ≤5 W Update MTBF & Life Time Data For One Model For Two Models Update Life Time Data Ta=45℃ Tc=80℃ Mechanical Outline / Updated Vo=52V, 56V, 60V, 84V,105 V & 150V Models / Deleted Life time Curve / Added EN61000-4-5 line to line 2 kV, line to earth 4 line to line 4 kV, line to earth 6 kV kV Max Case Temperature / Updated Efficiency of 24V,28V,36V,42V / 0.5%,1.5% or 2% lower Operating Temperature -35 ℃ -40 ℃ Derating Curve / Updated 2013-02-26 G Efficiency of 42V,48V,54V / 0.5% lower 2013-03-11 H Over Current Protection 110%,155%,180% 130%,165%,200% Inrush current 50A 150A Min PF and max THD / Added Temperature coefficient / Added Life time / Updated Life time curve / Updated Input AC current@100Vac Max 2.8A Typ2.8A, Max3.0A Turn-on delay time 0.1s,0.2s 0.2s,0.5s / Corrected 18AWG 16AWG 2013-04-02 2013-12-13 I J Mechanical Outline---tolerance standardized Mechanical Outline—42V Model output wire 8/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-250SxxxST 250W Constant Voltage IP67 Driver  Rev. M Revision History (Continued) Description of Change Change Date Rev. 2013-12-13 J Item From Turn-on delay time 0.2s,0.5s 0.4s,1.0s Format / Updated External Grounding Screw Solution / / Features / Updated Description 2015-09-10 2017-06-30 2019-09-19 K L M To Updated Models Notes Updated General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature Added for Warranty Tc_w General Specifications Storage Temperature Added Environmental Specifications / Deleted Safety & EMC Compliance / Updated Protection Functions / Updated Dimming Control / Updated Mechanical Outline / Updated Description / Updated Output Specifications Temperature Coefficient Updated General Specifications Dimensions Updated Safety & EMC Compliance / Updated Mechanical Outline / Updated KS Logo / Added Features 4kV line-line, 6kV line-earth DM 4kV, CM 6kV Features Waterproof(IP67) IP67 Features 5 Years Warranty Added Input Specifications(Power Factor / 50-60Hz Added THD) Operating Case Temperature General Specifications Added for Warranty Tc_w- Notes Safety &EMC Compliance KS Added Safety &EMC Compliance EN 61000-4-5 Updated Derating Curve / Deleted RoHS Compliance / Updated 9/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-250S042ST 价格&库存
很抱歉,暂时无法提供与“EUV-250S042ST”相匹配的价格&库存,您可以联系我们找货
EUV-250S042ST
