EUP-075S280SV
EUP-075S280SV
    INVENTRONICS(英飞特)
EUP-075S280SV 数据手册
EUP-075SxxxSV 75W AOC IP67 Driver Rev.E Features  High Efficiency (Up to 91.0%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Dip-switch  Non-dimming Control  Input Surge Protection: 6 kV line-line, 10 kV line-earth   All-Around Protection: OVP, SCP, OTP Waterproof (IP67)  SELV Output  Suitable for Independent Use  5 Years Warranty Description The EUP-075SxxxSV series is a 75W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including street, tunnel and bay. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range (2) Output Voltage Range 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 700-1050mA 700-1050mA 700 mA 127~250 Vdc 90~305 Vac/ 1050-1750mA 1190-1750mA 1400 mA 127~250 Vdc 90~305 Vac/ 1700-2800mA 1900-2800mA 2100 mA 127~250 Vdc 350-700mA 450-700mA 550 mA Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number (4) 54~167Vdc 75 W 91.0% 0.98 0.96 EUP-075S070SV 36~107Vdc 75 W 91.0% 0.98 0.96 EUP-075S105SV 22 ~ 63Vdc 75 W 90.5% 0.98 0.96 EUP-075S175SV 14 ~ 39Vdc 75 W 89.5% 0.98 0.96 EUP-075S280SV (5) (5) (5) Notes: (1) Output current range with constant power at 75W (2) Certified voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE, KS and BIS) (3) Measured at 100%load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to Global-mark,except EUP-075S070SV (5) SELV Output. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.05 A Measured at 100%load and 100 Vac input. - - 0.45 A Measured at 100%load and 220 Vac input. Input AC Current Notes 127~250 Vdc IEC60598-1; 240Vac/ 60Hz 1 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-075SxxxSV 75W AOC IP67 Driver Rev.E Input Specifications (Continued) Parameter Min. Typ. Max. - - 0.54 A s 0.9 - - THD - - 20% THD - 8% - At 220-240Vac, 50-60Hz, 80%-100% Load. Please evaluate with LEDs to insure THD
EUP-075S280SV 价格&库存
很抱歉,暂时无法提供与“EUP-075S280SV”相匹配的价格&库存,您可以联系我们找货
