CNV-DMXR
CNV-DMXR
    INVENTRONICS(英飞特)
CNV-DMXR 数据手册
CNV-DMXR DMX RDM to 0-10V Converter Rev. D Features  Converts DMX Signal to 0-10V Dimming Signal  Complies with both DMX RDM and Traditional DMX Networks  Use Driver Dim-to-Off Capability to Eliminate AC Switch or Relay  Powered by 12Vdc with Simple 3-Wire Connection to Driver  Low Standby Power < 0.5W  At Power on the 0-10V Output Remains at 0V until DMX Signal is Received  In the Event of DMX Signal Loss, the 0-10V Output Will Not Change  Waterproof (IP67) and UL Dry / Damp / Wet Location  Suitable for Built-in Use Description The CNV-DMXR is a DMX RDM to 0-10V converter that enables one or more Inventronics Controls-Ready drivers to be controlled by a DMX system. The CNV-DMXR is compatible with LED drivers with dim-to-off capability, 12V/200mA auxiliary power supply and 0-10V dimming input. The CNV-DMXR is DMX RDM compatible. DMX RDM (Remote Device Management) permits intelligent bidirectional communication between devices from multiple manufacturers utilizing a modified DMX512 data link. This allows the DMX RDM compatible device to be addressed and configured remotely, using a compatible DMX RDM master. DMX RDM devices are inherently compatible with standard DMX networks. Vo(+) Vo(‐) Inventronics LED Driver DMX+ DMX‐ Shield Dim+ Return 0‐10V ← DMX RDM DMX+ DMX‐ Shield Vaux 1/6 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com CNV-DMXR DMX RDM to 0-10V Converter Rev. D Models P/N Connection to LED Driver Connection to DMX System CNV-DMXR UL Wire(black/white, purple, gray) UL Wire(black/white, purple, gray) Input Specifications Parameter Min. Typ. Max. Notes 10.8 V 12 V 13.2 V Support the maximum output current of LED driver to 100%Io - 30 mA 200 mA 200mA when transmitting, 30mA at standby -6 V - 6V DMX+ to Chassis 22M ohm - - DMX- to Chassis 22M ohm - - Logic 0 Input - - -0.2 V DMX+ to DMX- Logic 1 Input 0.2 V - - DMX+ to DMX- Min. Typ. Max. 0V - 10 V Vaux>12.5V 0V - (Vaux-2.5)V Vaux≤12.5V 0 mA - 5 mA Vaux Voltage Iaux (Vaux Current) DMX+ to DMX- Dimming Specifications Parameter Dim+ Voltage Dim+ Sink Current Notes - Note: All specifications are typical at 25C unless otherwise stated. Output Dimming Curve This controller integrates a linear curve and logarithmic curve. 2/6 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com CNV-DMXR DMX RDM to 0-10V Converter Rev. D General Specifications Parameter Min. Dimensions Inches (L × W × H) Millimeters (L × W × H) Typ. Max. With mounting ear 3.54 × 1.50 × 1.06 90 × 38 × 27 2.72 × 1.50 × 1.06 69 × 38 × 27 Net Weight - 155 g Notes - Note: All specifications are typical at 25C unless otherwise stated. Environmental Specifications Parameter Min. Typ. Max. Operating Temperature -40 C - +70 C Storage Temperature -40 C - +85 C Notes Humidity: 5% RH to 100% RH Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, CAN/CSA-C22.2 No. 250.13 CB IEC 61347-1 IEC 61347-2-11 EMI(1) Standards (2) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B This device complies with Part 15 of the FCC Rules. Operation is subject to the (2) FCC Part 15 following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS(1) Standards EN 61547 Notes Electromagnetic Immunity Requirements Applies To Lighting Equipment Notes: (1) The EMI and EMS test results are tested with Inventronics LED drivers. (2) The CNV-DMXR is considered as a component that will be operated in combination with final equipment. Since EMI performance will be affected by the complete installation, the final equipment manufacturers must re-qualify EMI Directive on the complete installation again. 3/6 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com CNV-DMXR DMX RDM to 0-10V Converter Rev. D Function Definition of Interface(Connection to LED Driver) Wire Color Function Notes BLACK/WHITE Vaux To LED driver’s auxiliary power PURPLE Dim+ Output to driver’s 0-10V dimming line GRAY Return Return for auxiliary power and dimming signal PURPLE DMX+ To DMX Console GRAY DMX- To DMX Console BLACK/WHITE Shield Connect with DMX shield Operation Notes   Wiring DMX-RDM daisy chain connection see the diagram below: DMX Console 120 Ohm Terminal LED Engine LED Driver RDM to 0‐10V Converter LED Engine LED Driver RDM to 0‐10V Converter LED Engine RDM to 0‐10V Converter LED Driver 120 Ohm Terminal    Up to 32 converters may be daisy-chained, terminated by a 120 ohm resistor (connected between DMX+ & DMX- at the last converter). 100m maximum distance between converters. For best performance, a characteristic impedance of 120 ohms should be maintained for the entire length of the control line. 4/6 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com CNV-DMXR     DMX RDM to 0-10V Converter Rev. D Loss of DMX Signal and Power on Events In the event the DMX signal is lost, the 0-10V output of the CNV-DMXR will remain the same until another DMX command is received. At power on, the CNV-DMXR will output 0V until the dimming state is changed via DMX Addressability The CNV-DMXR can be addressed in two different ways.  If the converter is being used in a DMX RDM environment, the easiest way to address the CNV-DMXR is addressing and configuring via the RDM protocol.  If you are using the CNV-DMXR in a traditional DMX environment, the address may be set using the Inventronics CNV-DMXR Tool Software. Please contact Inventronics for any questions regarding this process.    Software Interface and User Manual Download To download the CNV-DMXR software interface, please click here: CNV-DMXR Tool. More operation details please click here see the: CNV-DMXR Tool User Manual. Compatible Driver List  Compatible driver list please refer to the: CNV-DMXR Compatible List. Mechanical Outline (UL 21996 3*22AWG (UL 21996 3*22AWG 5.0) 5.0) BLACK/WHITE PURPLE GRAY BLACK/WHITE PURPLE GRAY BLACK/WHITE PURPLE GRAY PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 5/6 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com CNV-DMXR DMX RDM to 0-10V Converter Rev. D Revision History Description of Change Change Date Rev. 2017-05-26 A Datasheet Release / / 2017-07-28 B Function Definition of Interface / Corrected 2017-09-26 2018-02-11 Item C D From To Operation Notes - Tool Software Interface and User / Manual Download Added Compatible Driver List / Added Iaux (Vaux Current) - Typ. / Added Link in the Operation Notes and Compatible Driver / List Updated 6/6 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
CNV-DMXR 价格&库存
很抱歉,暂时无法提供与“CNV-DMXR”相匹配的价格&库存,您可以联系我们找货
