EBV-036S024SVF
EBV-036S024SVF
    INVENTRONICS(英飞特)
EBV-036S024SVF 数据手册
EBV-036SxxxSVF 36W Constant Voltage IP67 Driver Rev. A Features  High Efficiency (up to 87%)  Constant Voltage Output  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OCP, OVP, SCP, OTP  Waterproof (IP67)  SELV Output  5 Years Warranty Description The EBV-036SxxxSVF series is a 36W, constant-voltage IP67 LED driver that operates from 176-305 Vac input with excellent power factor. It is created for many lighting applications including architectural, decorative and signage. The high efficiency of the driver and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, short circuit, and over temperature. Models Power Factor Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power(2) Typical Efficiency (3) 220Vac 24 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 1.5 A 36 W 86.0% 0.96 EBV-036S024SVF 36 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 1.0 A 36 W 86.5% 0.96 EBV-036S036SVF 48 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 0.75 A 36 W 87.0% 0.96 EBV-036S048SVF Model Number Notes: (1) Certified input Voltage range: 200-240Vac. (2) Operating input voltage range: 90-305Vac and 90-176Vac is for safety operation (see below “Derating” curve for details). (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). Input Specifications Parameter Min. Typ. Max. 176 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.21 A - - 0.029 A s 0.9 - - - - 12% Input Voltage 2 Inrush Current(I t) Input Voltage PF THD Notes 2 190 ~ 250 Vdc IEC60598-1; 240Vac/ 60Hz Measured at 100% load and 220Vac input. At 220Vac input, 25C cold start, duration=1.72 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 220-240Vac, 50-60Hz, 70%-100%load (25.2~36W) 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-036SxxxSVF 36W Constant Voltage IP67 Driver Rev. A Output Specifications Parameter Output Voltage Tolerance Total Output Voltage Ripple (pk-avg) EBV-036S024SVF EBV-036S036SVF EBV-036S048SVF Startup Overshoot / Undershoot Min. Typ. Max. -5%Vo - 5%Vo Notes At 100% load condition At 0% - 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 μF ceramic capacitor and a 47 μF electrolytic capacitor. - - 2.0 V 2.5 V 2.5 V - - 5%Vo At 100% load condition Line Regulation - - ±1% Measured at 100% load Load Regulation - - ±3% Turn-on Delay Time - - 0.5 s Load Dynamic Response Output Deviation 8%Vo Settling Time 10 ms Temperature Coefficient of Vo - - 0.03%/C Measured at 220Vac input, 100%load R/S: 1 A/μs Load: 25% ~ 100% load. Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 84.0% 84.5% 85.0% 86.0% 86.5% 87.0% - MTBF - 871,000 Hours - Lifetime - 104,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 220Vac input: EBV-036S024SVF EBV-036S036SVF EBV-036S048SVF Dimensions Inches (L × W × H) Millimeters ((L × W × H) Net Weight Measured at 100% load and steady-state temperature in 25C ambient; Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 6.1 x 1.57 x 0.98 155 x 40.0 x 25.0 5.28 x 1.57 x 0.98 134 x 40.0 x 25.0 - 340 g Notes - Note: All specifications are typical at 25C unless otherwise stated. 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-036SxxxSVF 36W Constant Voltage IP67 Driver Rev. A Safety & EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-036SxxxSVF 36W Constant Voltage IP67 Driver Rev. A Derating Lifetime vs. Case Temperature Inrush Current Waveform 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-036SxxxSVF 36W Constant Voltage IP67 Driver Rev. A Efficiency vs. Load EBV-036S024SVF EBV-036S036SVF EBV-036S048SVF Power Factor 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-036SxxxSVF 36W Constant Voltage IP67 Driver Rev. A Total Harmonic Distortion Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. Mechanical Outline INPUT (H05RN-F 3*1mm2 OUTPUT (H05RN-F 2*1mm2 7.2) AC/L (BROWN ) AC/N (BLUE) GND (YELLOW/GREEN) 6.8) V+ (BROWN) V- (BLUE) Tc PROJ: Unspecified tolerance:±1 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-036SxxxSVF 36W Constant Voltage IP67 Driver Rev. A RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-036SxxxSVF 36W Constant Voltage IP67 Driver Rev. A Revision History Description of Change Change Date Rev. 2019-07-30 A Item From Datasheet Release / To / 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EBV-036S024SVF 价格&库存
很抱歉,暂时无法提供与“EBV-036S024SVF”相匹配的价格&库存,您可以联系我们找货
EBV-036S024SVF
