EBS-160S105BTE
EBS-160S105BTE
    INVENTRONICS(英飞特)
EBS-160S105BTE 数据手册
EBS-160SxxxBTE 160W Class I/II Programmable IP20 Driver with DALI Rev. E Features  Ultra High Efficiency (Up to 94.0%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  DALI/AC Dim/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA (Transient Peak Current up to 400mA)  Output Lumen Compensation  Long Lifetime Over 100k Hours at 75°C Case Temperature  Input Surge Protection: DM 6 kV, CM 10 kV  All-Around Protection: OVP, SCP, OTP  IP20 Design and Suitable for Outdoor Applications in Luminaires with IP>54  Suitable for Luminaires with Protection Class I and II  Complies with Zhaga Interface Specification Book 13  7 Years Warranty Description The EBS-160SxxxBTE series is a 160W, constant-current, programmable LED driver that operates from 176305Vac input with excellent power factor. Created for many lighting applications including street, tunnel and high bay, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and better thermal design enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature of both the driver and the external LED array. Models Adjustable Output Current Range Full-Power Current Range(1) 45-700mA 450-700mA 70-1050mA 700-1050mA Default Output Current Input Voltage Range(2) Output Voltage Range Max. Typical Output Efficiency Power (3) 176~305Vac 115~356Vdc 160 W 190~250Vdc 176~305Vac 700 mA 76~229Vdc 160 W 190~250Vdc 530 mA Power Factor (3) Model Number (4) 94.0% 0.98 EBS-160S070BTE 94.0% 0.98 EBS-160S105BTE Notes: (1) Output current range with constant power at 160W (2) Certified voltage range: 200-240Vac or 190-250Vdc (except CCC and KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) EBS-160S105BTE is certificated to KS. 1 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBS-160SxxxBTE 160W Class I/II Programmable IP20 Driver with DALI Rev. E I-V Operating Area EBS-160S070BTE EBS-160S105BTE Input Specifications Parameter Min. Typ. Max. 176 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.88 A Inrush Current(I2t) - - 2.30 A2s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 70%-100% Load (112-160W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 45 mA 70 mA - 700 mA 1050 mA 450 mA 700 mA - 700 mA 1050 mA - 5%Iomax 10%Iomax - 2%Iomax - Input Voltage PF Notes 190~250 Vdc IEC60598-1; 240Vac/ 60Hz Measured at 100% load and 220 Vac input. At 220Vac input, 25°C cold start, duration=1.98 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 220-240Vac, 50-60Hz, 60%-100% Load (96-160W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EBS-160S070BTE EBS-160S105BTE Output Current Setting Range with Constant Power EBS-160S070BTE EBS-160S105BTE Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At 100% load condition At 100% load condition, 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. 2 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBS-160SxxxBTE 160W Class I/II Programmable IP20 Driver with DALI Rev. E Output Specifications (Continued) Parameter Min. Typ. Max. Startup Overshoot Current - - 10%Iomax No Load Output Voltage EBS-160S070BTE EBS-160S105BTE - - 400 V 270 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Return terminal is “Return“ - - 400 mA 400mA peak for a maximum duration of 300ms in a 2s period during which time the average should not exceed 200mA. 12V Auxiliary Output Transient Peak Current Notes At 100% load condition Measured at 100% load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 92.0% 90.5% 94.0% 92.5% - 92.0% 90.0% 94.0% 92.0% - Standby power - - 0.5 W MTBF - 222,000 Hours - Lifetime - 102,000 Hours - -40°C - +90°C Efficiency at 220 Vac input: EBS-160S070BTE Io= 450 mA Io= 700 mA EBS-160S105BTE Io= 700 mA Io=1050 mA Operating Case Temperature for Safety Tc_s Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) -40°C - +75°C Storage Temperature -40°C - +85°C Net Weight Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 75C case temperature; See lifetime vs. Tc curve for the details Operating Case Temperature for Warranty Tc_w Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. No condensation. Humidity: 5%RH to 85%RH; No condensation. 6.70 × 3.94 × 1.58 170 × 100 × 40 - 750 g - Note: All specifications are typical at 25C unless otherwise stated. 3 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBS-160SxxxBTE 160W Class I/II Programmable IP20 Driver with DALI Rev. E Dimming Specifications DALI Parameter Min. Typ. Max. DA, DA High Level 9.5 V 16 V 22.5 V DA, DA Low Level -6.5 V 0V 6.5 V DA, DA Current 0 mA - 2 mA Start Input Voltage 180 Vac - 250 Vac Start Output Level 30% - 100% Stop Input Voltage 160 Vac - 230 Vac Stop Output Level 30% - 85% 20 Vac - - - 1 Vac - - 1% - 10%Ioset - Ioset 45 mA 70 mA - Ioset AC Dim Gap between Start and Stop Input Voltage Increment of Start and Stop Input Voltage Increment of Start and Stop Output Level EBS-160S070BTE Dimming EBS-160S105BTE Output EBS-160S070BTE Range EBS-160S105BTE Notes Default is 220 Vac Default is 100% Default is 170 Vac Default is 30% 450 mA ≤ Ioset ≤ 700 mA 700 mA ≤ Ioset ≤ 1050 mA 45 mA ≤ Ioset < 450 mA 70 mA ≤ Ioset < 700 mA Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category Standard ENEC & TUV & CE CCC EN 61347-1, EN61347-2-13 GB 19510.1, GB 19510.14 KS KS C 7655 Performance Standard ENEC EN 62384 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT 4 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBS-160SxxxBTE Rev. E 160W Class I/II Programmable IP20 Driver with DALI Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 8 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV Electromagnetic Immunity Requirements Applies to Lighting Equipment DALI Standards DALI Notes (2) IEC62386-101,102 & part of 207 Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) Optional Commands Implemented: 242 (query short circuit), 243 (query open circuit). Lifetime vs. Case Temperature Inrush Current Waveform 5 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBS-160SxxxBTE Rev. E 160W Class I/II Programmable IP20 Driver with DALI Efficiency vs. Load EBS-160S070BTE(Io=450mA) EBS-160S070BTE(Io=700mA) EBS-160S105BTE(Io=700mA) EBS-160S105BTE(Io=1050mA) Power Factor 6 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBS-160SxxxBTE 160W Class I/II Programmable IP20 Driver with DALI Rev. E Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. Notes R1 - 7.81 kOhm - R2 - 4.16 kOhm - Protection Current Floor 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  DALI Dimming The recommended implementation of the dimming control is provided below. 7 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBS-160SxxxBTE 160W Class I/II Programmable IP20 Driver with DALI Rev. E Implementation: DALI Dimming   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EBS-160S105BTE 价格&库存
很抱歉,暂时无法提供与“EBS-160S105BTE”相匹配的价格&库存,您可以联系我们找货
