EBV-075S048SV
EBV-075S048SV
    INVENTRONICS(英飞特)
EBV-075S048SV 数据手册
EBV-075SxxxSV 75W Constant Voltage IP67 Driver Rev. A Features  High Efficiency (up to 90%)  Constant Voltage Output  No-Load Power < 0.5 W  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OCP, OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use  5 Years Warranty Description The EBV-075SxxxSV series is a 75W, constant-voltage IP67 LED driver that operates from 176-305 Vac input with excellent power factor. It is created for many lighting applications including architectural, decorative and signage. The high efficiency of the driver and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power(2) Typical Efficiency (3) Power Factor 24 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 3.2 A 75 W 88.0% 0.96 EBV-075S024SV 36 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 2.1 A 75 W 89.0% 0.96 EBV-075S036SV 48 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 1.6 A 75 W 90.0% 0.96 EBV-075S048SV Model Number(4)(5) 220Vac Notes: (1) CCC certified input voltage range: 220/230/240 Vac; other certified input voltage range except CCC: 200-240 Vac or 190-250Vdc (except KS and BIS). (2) Operating input voltage range: 90-305Vac, and 90-176Vac is for safety operation (see below “Derating” curve for details) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) For BIS models add suffix -3000. Input Specifications Parameter Min. Typ. Max. 176 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.44 A Input Voltage Notes 190 ~ 250 Vdc IEC60598-1; 240Vac/60Hz Measured at 100% load and 220Vac input. 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-075SxxxSV 75W Constant Voltage IP67 Driver Rev. A Input Specifications (Continued) Parameter Min. Typ. Max. - - 0.0033 A s 0.9 - - THD - - 20% THD - - 12% At 220-240Vac, 50-60Hz, 75%-100% load Min. Typ. Max. Notes -5%Vo - 5%Vo 2 Inrush Current(I t) PF Notes 2 At 220Vac input, 25C cold start, duration=36 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 220-240Vac, 50-60Hz, 60%-100% load Output Specifications Parameter Output Voltage Tolerance At 100% load condition Total Output Voltage Ripple (pk-avg) EBV-075S024SV EBV-075S036SV EBV-075S048SV - - 2.0 V 2.5 V 2.5 V Startup Overshoot/Undershoot - - 5%Vo At 100% load condition Line Regulation - - ±1% Measured at 100% load Load Regulation - - ±3% Turn-on Delay Time - - 0.75 s Load Dynamic Response Output Deviation - - 8%VO Settling Time - - 10 ms - 0.03%/C - Temperature Coefficient of Vo At 0% - 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1μF ceramic capacitor and a 47μF electrolytic capacitor. Measured at 220Vac input, 100% load R/S: 1 A/μs Load: 25% ~ 100% load. Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 86.0% 87.0% 88.0% 88.0% 89.0% 90.0% - MTBF - 888,000 Hours - Lifetime - 97,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Efficiency at 220Vac input: EBV-075S024SV EBV-075S036SV EBV-075S048SV Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-075SxxxSV 75W Constant Voltage IP67 Driver Rev. A General Specifications (Continued) Parameter Min. Typ. Max. Storage Temperature -40°C - +85°C Notes Humidity: 5%RH to 100%RH Dimensions Inches (L × W × H) Millimeters ((L × W × H) 3.74 x 2.66 x 1.44 95 x 67.5 x 36.5 Net Weight - 4.57 x 2.66 x 1.44 116 x 67.5 x 36.5 520 g - Note: All specifications are typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category Standard CE & ENEC EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 BIS IS 15885(PART2/SEC13) KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-075SxxxSV 75W Constant Voltage IP67 Driver Rev. A Derating Lifetime vs. Case Temperature 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-075SxxxSV 75W Constant Voltage IP67 Driver Rev. A Inrush Current Waveform Efficiency vs. Load EBV-075S024SV EBV-075S036SV EBV-075S048SV 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-075SxxxSV 75W Constant Voltage IP67 Driver Rev. A Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-075SxxxSV 75W Constant Voltage IP67 Driver Rev. A Mechanical Outline INPUT (VDE H05RN-F 3*1.0mm 2 OUTPUT (VDE H05RN-F 2*1.0mm 2 7.2) 6.8) V+ (BROWN) V- (BLUE) AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-075SxxxSV 75W Constant Voltage IP67 Driver Rev. A Revision History Change Date Rev. 2018-09-29 A Description of Change Item From Datasheet Release / To / 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EBV-075S048SV 价格&库存
很抱歉,暂时无法提供与“EBV-075S048SV”相匹配的价格&库存,您可以联系我们找货
EBV-075S048SV
