ESD-240SxxxDT
240W Programmable IP67 Driver
Rev. E
Features
Ultra High Efficiency (Up to 94%)
Full Power at Wide Output Current Range (Constant Power)
0-10V/PWM/Timer Dimmable
Dim-to-Off with Standby Power ≤ 1.5 W
Input Surge Protection: 4kV line-line, 6kV line-earth
All-Around Protection: OVP, SCP, OTP
Waterproof (IP67) and UL Dry / Damp / Wet Location
SELV Output
TYPE HL, for use in a Class I, Division 2 hazardous
(Classified) location
5 Years Warranty
Description
The ESD-240SxxxDT series is a 240W, constant-current, programmable LED driver that operates from 249-528
Vac input with excellent power factor. Created for many lighting applications including high bay, high mast,
sports and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers
and compact metal case enables them to run cooler, significantly improving reliability and extending product life.
To ensure trouble-free operation, protection is provided against over voltage, short circuit, and over temperature.
Models
Adjustable
Output
Current
Range
Full-Power
Current
Range (1)
Default
Output
Current
Input
Voltage
Range(2)
Max.
Typical Power Factor
Output Efficiency
277Vac 480Vac
Power
(3)
Output
Voltage
Range
Model Number
249~528 Vac
120~343Vdc 240 W
352~500 Vdc
94.0%
0.96
0.95
ESD-240S100DT
105-1500mA 1050-1500mA 1400 mA
249~528 Vac
80~229Vdc
352~500 Vdc
240 W
93.5%
0.96
0.95
ESD-240S150DT
154-2200mA 1540-2200mA 2100 mA
249~528 Vac
55~156Vdc
352~500 Vdc
240 W
93.0%
0.96
0.95
ESD-240S220DT
224-3200mA 2240-3200mA 2800 mA
249~528 Vac
38~107Vdc
352~500 Vdc
240 W
93.0%
0.96
0.95
ESD-240S320DT
(4)
322-4600mA 3220-4600mA 4200 mA
249~528 Vac
352~500 Vdc
27~75Vdc
240 W
93.0%
0.96
0.95
ESD-240S460DT
(4)
462-6600mA 4620-6600mA 4900 mA
249~528 Vac
352~500 Vdc
19~52Vdc
240 W
92.5%
0.96
0.95
ESD-240S660DT
(4)
70-1000mA 700-1000mA 700 mA
Notes: (1) Output current range with constant power at 240W
(2) Certified voltage range: 277-480Vac or 352-500Vdc
(3) Measured at 100% load and 480Vac input (see below “General Specifications” for details).
(4) SELV Output
1 / 16
Specifications are subject to changes without notice.
www.inventronics-co.com
Tel: 86-571-56565800
Fax: 86-571-86601139
sales@inventronics-co.com
ESD-240SxxxDT
Rev. E
I-V Operating Area
ESD-240S150DT
ESD-240S220DT
ESD-240S320DT
ESD-240S460DT
ESD-240S660DT
60
Lo
ad
Output Voltage(V)
ESD-240S100DT
2 / 16
ESD-240SxxxDT
Rev. E
Input Specifications
Parameter
Input Voltage
Input Frequency
Leakage Current
Input AC Current
2
Inrush Current(I t)
Min.
Typ.
Max.
249 Vac
528 Vac
47 Hz
63 Hz
0.75 MIU
UL8750; 480Vac/ 60Hz
0.70 mA
IEC60598-1; 480Vac/ 60Hz
1.1 A
0.6 A
2
Notes
352-500Vdc
Measured at 100% load and 277 Vac input.
Measured at 100% load and 480 Vac input.
At 480Vac input, 25°C Cold Start,
Duration=1.43 ms, 10%Ipk-10%Ipk. See
Inrush Current Waveform for the details.
2.9 A s
0.90
20%
At 277-480Vac, 50-60Hz, 60%-100% Load
(144-240W)
Min.
Typ.
Max.
Notes
-5%Ioset
5%Ioset
70 mA
105 mA
154 mA
224 mA
322 mA
462 mA
1000 mA
1500 mA
2200 mA
3200 mA
4600 mA
6600 mA
700 mA
1050 mA
1540 mA
2240 mA
3220 mA
4620 mA
1000 mA
1500 mA
2200 mA
3200 mA
4600 mA
6600 mA
Output Current Ripple(pk-pk)
5%Iomax
10%Iomax
100% load
Startup Overshoot Current
10%Iomax
100% load
No Load Output Voltage
ESD-240S100DT
ESD-240S150DT
ESD-240S220DT
ESD-240S320DT
ESD-240S460DT
ESD-240S660DT
355 V
248 V
170 V
120 V
90 V
60 V
Line Regulation
±0.5%
Load Regulation
±1.5%
Turn-on Delay Time
0.5 s
0.75 s
Temperature Coefficient of
Ioset
0.03%/°C
PF
THD
Output Specifications
Parameter
Output Current Tolerance
Output Current Setting(Ioset)
Range
ESD-240S100DT
ESD-240S150DT
ESD-240S220DT
ESD-240S320DT
ESD-240S460DT
ESD-240S660DT
Output Current Setting Range
with Constant Power
ESD-240S100DT
ESD-240S150DT
ESD-240S220DT
ESD-240S320DT
ESD-240S460DT
ESD-240S660DT
100% load
Measured at 277Vac and 480Vac input,
60%-100% Load
Case temperature = 0°C ~Tc max
3 / 16
ESD-240SxxxDT
Rev. E
Output Specifications (Continued)
Parameter
Min.
Typ.
Max.
12V Auxiliary Output Voltage
10.8 V
12 V
13.2 V
12V Auxiliary Output Source
Current
0 mA
200 mA
Notes
Return terminal is “Dim−“
Note: All specifications are typical at 25°C unless otherwise stated.
Parameter
Efficiency at 277 Vac input:
ESD-240S100DT
Io=700 mA
Io=1000mA
ESD-240S150DT
Io=1050mA
Io=1500mA
ESD-240S220DT
Io=1540mA
Io=2200mA
ESD-240S320DT
Io=2240mA
Io=3200mA
ESD-240S460DT
Io=3220mA
Io=4600mA
ESD-240S660DT
Io=4620mA
Io=6600mA
Efficiency at 347 Vac input:
ESD-240S100DT
Io=700 mA
Io=1000mA
ESD-240S150DT
Io=1050mA
Io=1500mA
ESD-240S220DT
Io=1540mA
Io=2200mA
ESD-240S320DT
Io=2240mA
Io=3200mA
ESD-240S460DT
Io=3220mA
Io=4600mA
ESD-240S660DT
Io=4620mA
Io=6600mA
Min.
Typ.
Max.
90.0%
89.5%
92.0%
91.5%
90.0%
89.0%
92.0%
91.0%
89.5%
89.5%
91.5%
91.5%
89.5%
88.5%
91.5%
90.5%
89.5%
88.0%
91.5%
90.0%
89.0%
88.0%
91.0%
90.0%
91.0%
90.5%
93.0%
92.5%
91.0%
90.0%
93.0%
92.0%
90.0%
90.0%
92.0%
92.0%
90.0%
89.5%
92.0%
91.5%
90.0%
89.0%
92.0%
91.0%
90.0%
89.0%
92.0%
91.0%
Notes
Measured at 100% load and steady-state
temperature in 25°C ambient;
(Efficiency will be about 2.0% lower if
measured immediately after startup.)
4 / 16
ESD-240SxxxDT
Rev. E
General Specifications (Continued)
Parameter
Efficiency at 480 Vac input:
ESD-240S100DT
Io=700 mA
Io=1000mA
ESD-240S150DT
Io=1050mA
Io=1500mA
ESD-240S220DT
Io=1540mA
Io=2200mA
ESD-240S320DT
Io=2240mA
Io=3200mA
ESD-240S460DT
Io=3220mA
Io=4600mA
ESD-240S660DT
Io=4620mA
Io=6600mA
Standby power
Min.
Typ.
Max.
92.0%
91.0%
94.0%
93.0%
91.5%
91.5%
93.5%
93.5%
91.0%
91.0%
93.0%
93.0%
91.0%
90.0%
93.0%
92.0%
91.0%
89.5%
93.0%
91.5%
90.5%
89.5%
92.5%
91.5%
1.5 W
209,000
Hours
Lifetime
114,000
Hours
-40°C
+89°C
-40°C
+75°C
-40°C
+85°C
Storage Temperature
Dimensions
Inches (L × W × H)
Millimeters (L × W × H)
Net Weight
Case temperature for 5 years warranty
With mounting ear
10.32 × 2.66 × 1.56
262 × 67.5 × 39.7
9.49 × 2.66 × 1.56
241 × 67.5 × 39.7
Measured at 480Vac/50Hz; Dimming off
Measured at 480Vac input, 80%Load and
25°C ambient temperature (MIL-HDBK217F)
70°C case temperature; See lifetime vs. Tc
curve for the details
MTBF
Operating Case Temperature
for Safety Tc_s
for Warranty Tc_w
Notes
1400 g
Dimming Specifications
Parameter
Absolute Maximum Voltage
on the Vdim (+) Pin
Source Current on Vdim (+)Pin
Min.
Typ.
Max.
-20 V
20 V
200 uA
300 uA
450 uA
Notes
Vdim(+) = 0 V
5 / 16
ESD-240SxxxDT
Rev. E
Dimming Specifications (Continued)
Parameter
Min.
Typ.
Max.
ESD-240S100DT
ESD-240S150DT
ESD-240S220DT
ESD-240S320DT
ESD-240S460DT
ESD-240S660DT
10%Ioset
Ioset
ESD-240S100DT
ESD-240S150DT
ESD-240S220DT
ESD-240S320DT
ESD-240S460DT
ESD-240S660DT
70 mA
105 mA
154 mA
224 mA
322 mA
462 mA
Ioset
0V
10 V
Dim off Voltage
0.2 V
0.4 V
0.6 V
Dim on Voltage
0.4 V
0.6 V
0.8 V
0.2 V
PWM_in High Level
3V
10 V
PWM_in Low Level
-0.3 V
0.6 V
PWM_in Frequency Range
200 Hz
3 KHz
1%
99%
2%
4%
7%
4%
6%
9%
93%
96%
98%
91%
94%
96%
2%
Dimming
Output
Range
Recommended Dimming
Input Range
Hysteresis
PWM_in Duty Cycle
PWM Dimming off (Positive
Logic)
PWM Dimming on (Positive
Logic)
PWM Dimming off ( Negative
Logic)
PWM Dimming on ( Negative
Logic)
Hysteresis
Notes
700mA ≤ Ioset ≤ 1000mA
1050mA ≤ Ioset ≤ 1500mA
1540mA ≤ Ioset ≤ 2200mA
2240mA ≤ Ioset ≤ 3200mA
3220mA ≤ Ioset ≤ 4600mA
4620mA ≤ Ioset ≤ 6600mA
70mA ≤ Ioset < 700mA
105mA ≤ Ioset < 1050mA
154mA ≤ Ioset < 1540mA
224mA ≤ Ioset < 2240mA
322mA ≤ Ioset < 3220mA
462mA ≤ Ioset < 4620mA
Default 0-10V dimming mode.
Dimming mode set to PWM in PC
interface.
Note: All specifications are typical at 25 °C unless stated otherwise.
Safety & EMC Compliance
Safety Category
UL/CUL
Standard
UL8750,CAN/CSA-C22.2 No. 250.13
CE
EN 61347-1, EN61347-2-13
EMI Standards
(1)
EN 55015
Notes
Conducted emission Test & Radiated emission Test
EN 61000-3-2
Harmonic current emissions
EN 61000-3-3
Voltage fluctuations & flicker
6 / 16
ESD-240SxxxDT
Rev. E
Safety & EMC Compliance (Continued)
EMI Standards
Notes
ANSI C63.4 Class B
(1)
FCC Part 15
This device complies with Part 15 of the FCC Rules. Operation is subject to the
following two conditions: [1] this device may not cause harmful interference, and (2) this
device must accept any interference received, including interference that may cause
undesired Operation.
EMS Standards
Notes
EN 61000-4-2
Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge
EN 61000-4-3
Radio-Frequency Electromagnetic Field Susceptibility Test-RS
EN 61000-4-4
Electrical Fast Transient / Burst-EFT
EN 61000-4-5
Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV
EN 61000-4-6
Conducted Radio Frequency Disturbances Test-CS
EN 61000-4-8
Power Frequency Magnetic Field Test
EN 61000-4-11
Voltage Dips
EN 61547
(2)
Electromagnetic Immunity Requirements Applies To Lighting Equipment
Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it
depends also on the other devices connected to the driver and on the fixture itself.
(2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the
driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as
allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore
line-to-earth surge protection and secure the end cap.
Lifetime vs. Case Temperature
7 / 16
ESD-240SxxxDT
Rev. E
Efficiency vs. Load
ESD-240S100DT(Io=700mA)
ESD-240S100DT(Io=1000mA)
ESD-240S150DT(Io=1050mA)
ESD-240S150DT(Io=1500mA)
8 / 16
ESD-240SxxxDT
Rev. E
ESD-240S220DT(Io=1540mA)
ESD-240S220DT(Io=2200mA)
ESD-240S320DT(Io=2240mA)
ESD-240S320DT(Io=3200mA)
ESD-240S460DT(Io=3220mA)
ESD-240S460DT(Io=4600mA)
9 / 16
ESD-240SxxxDT
Rev. E
ESD-240S660DT(Io=4620mA)
ESD-240S660DT(Io=6600mA)
Power Factor
Total Harmonic Distortion
10 / 16
ESD-240SxxxDT
Rev. E
Protection Functions
Parameter
Notes
Over Temperature Protection
Decreases output current, returning to normal after over temperature is removed.
Short Circuit Protection
Auto Recovery. No damage will occur when any output is short circuited. The output
shall return to normal when the fault condition is removed.
Over Voltage Protection
Limits output voltage at no load and in case the normal voltage limit fails.
Dimming
0-10V Dimming
The recommended implementation of the dimming control is provided below.
Implementation 1: DC Input
Notes:
1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like
resistors and zener.
2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly.
3. If 0-10V dimming is not used, Dim + should be open.
PWM Dimming
Implementation 2: Positive logic
11 / 16
ESD-240SxxxDT
Rev. E
Implementation 3: Negative logic
Notes:
1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly.
2. If PWM dimming is not used, Dim + should be open.
3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.
Time Dimming
Set the timing curve by pulling the sliders.
12 / 16
ESD-240SxxxDT
Rev. E
Programming Connection Diagram
Note: The driver does not need to be powered on during the programming process.
Please refer to PRG-MUL2 (Programmer) datasheet for details.
Mechanical Outline
ESD-240S100DT
INPUT(UL STW 3*18AWG
DIMMING WIRE (UL 21996 3*22AWG
9.5)
5.0)
BLACK/WHITE
PURPLE
GRAY
AC/L (BLACK)
AC/N (WHITE)
GND (GREEN)
V+ (RED)
V- (BLUE)
Tc
OUTPUT(UL STW 2*18AWG
8.9)
PROJ:
Unspecified toleranc:±1
13 / 16
ESD-240SxxxDT
Rev. E
Other Models
DIMMING WIRE (UL 21996 3*22AWG 5.0)
9.5)
BLACK/WHITE
PURPLE
GRAY
AC/L (BLACK)
AC/N (WHITE)
GND (GREEN)
V+ (RED)
V- (BLUE)
Tc
OUTPUT(UL SJTW 2*18AWG
7.3)
PROJ:
RoHS Compliance
Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other
hazardous substances from electronic products.
14 / 16
ESD-240SxxxDT
Rev. E
Revision History
Description of Change
Change
Date
Rev.
2014-09-10
A
2016-5-30
2017-11-21
Item
B
C
2018-04-26
D
2018-11-28
E
From
To
Datasheets Release
Case Temperature
Operating Case
Temperature for Safety
Operating Case
Temperature for Warranty Added
Tc_w
Storage Temperature
Added
With mounting ear
Added
Net Weight
Added
Environmental Specifications
Deleted
Safety &EMC Compliance
Notes
Added
Updated
Mechanical Outline
Updated
Features
5 Years Warranty
Updated
Input AC Current
Updated
Leakage Current
Updated
Inrush Current(I2t)
Updated
PF/THD(Note)
Updated
Turn-on Delay Time
Updated
of Ioset
Updated
Lifetime
Updated
Operating Case
Temperature for Warranty Updated
Tc_w
Updated
Updated
Mechanical Outline
Updated
UL
Updated
Description
Updated
CE
Added
Features
Updated
15 / 16
ESD-240SxxxDT
Rev. E
Revision History
Change
Date
Rev.
Item
From
Models
Updated
I-V Operating Area
Updated
Leakage Current
Updated
Output Current
Setting(Ioset) Range
Range with Constant
Power
2018-11-28
E
To
Updated
Updated
Turn-on Delay Time
Updated
Dimensions
Updated
Dimming Output Range
Updated
Updated
Derating
Deleted
Mechanical Outline
Updated
16 / 16
