ESD-320S150DV
ESD-320S150DV
    INVENTRONICS(英飞特)
ESD-320S150DV 数据手册
ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B Features • Ultra High Efficiency (Up to 94.5%) • Full Power at Wide Output Current Range (Constant Power) • 0-10V/PWM/3-Timer-Modes Dimmable • Dim-to-Off with Standby Power ≤1.5W • Output Lumen Compensation • Input Surge Protection: DM 4kV, CM 6kV • All-Around Protection: OVP, SCP, OTP • IP67 • SELV Output • 5 Years Warranty Description The ESD-320SxxxDV series is a 320W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, sports and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 105-1500mA 1050-1500mA 1400 mA 154-2200mA 1540-2200mA 2100 mA 217-3100mA 2170-3100mA 2800 mA 308-4400mA 3080-4400mA 4200 mA 434-6200mA 4340-6200mA 4900 mA Input Voltage Range(2) 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc Max. Typical Power Factor Output Efficiency 277Vac 480Vac Power (3) Output Voltage Range Model Number 107~305Vdc 320 W 94.0% 0.96 0.95 ESD-320S150DV 73~208Vdc 320 W 94.5% 0.96 0.95 ESD-320S220DV 52~148Vdc 320 W 94.0% 0.96 0.95 ESD-320S310DV 37~104Vdc 320 W 94.0% 0.96 0.95 ESD-320S440DV 26 ~74Vdc 320 W 93.5% 0.96 0.95 ESD-320S620DV (4) Notes: (1) Output current range with constant power at 320W (2) Certified voltage range: 277-480Vac (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV Output 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B I-V Operating Area ESD-320S150DV ESD-320S220DV ESD-320S310DV ESD-320S440DV 10 % 60 0% L oa Lo d ad ESD-320S620DV 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B Input Specifications Parameter Min. Typ. Max. Input AC Voltage 249 Vac - 528 Vac Input DC Voltage 352Vdc - 500Vdc Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.5 A Measured at 100% load and 277 Vac input. - - 0.8 A Measured at 100% load and 480 Vac input. - - 3.87 A s 0.90 - - - - 20% At 277-480Vac, 50-60Hz, 60%-100% Load (192-320W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 105 mA 154 mA 217 mA 308 mA 434 mA - 1500 mA 2200 mA 3100 mA 4400 mA 6200 mA 1050 mA 1540 mA 2170 mA 3080 mA 4340 mA - 1500 mA 2200 mA 3100 mA 4400 mA 6200 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESD-320S150DV ESD-320S220DV ESD-320S310DV ESD-320S440DV ESD-320S620DV - - 329V 223V 158V 121V 84V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - 0.5 s 0.75 s Input AC Current 2 Inrush Current(I t) PF THD 2 Notes IIEC60598-1; 480Vac/ 60Hz; Grounding effectively. At 480Vac input, 25°C Cold Start, Duration=1.77 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESD-320S150DV ESD-320S220DV ESD-320S310DV ESD-320S440DV ESD-320S620DV Output Current Setting Range with Constant Power ESD-320S150DV ESD-320S220DV ESD-320S310DV ESD-320S440DV ESD-320S620DV Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 100% load 100% load, 20 MHz BW 100% load. Only this component of ripple is associated with visible flicker. 100% load Measured at 100% load Measured at 277Vac and 480Vac input, 60%-100% Load 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B Output Specifications (Continued) Parameter Min. Typ. Max. - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Min. Typ. Max. 90.5% 89.5% 92.5% 91.5% - 91.0% 90.0% 93.0% 92.0% - 90.5% 90.0% 92.5% 92.0% - 91.0% 90.0% 93.0% 92.0% - 90.5% 89.5% 92.5% 91.5% - 91.5% 90.5% 93.5% 92.5% - 92.0% 91.0% 94.0% 93.0% - 91.5% 90.5% 93.5% 92.5% - 91.5% 90.5% 93.5% 92.5% - 91.0% 90.0% 93.0% 92.0% - 92.0% 91.0% 94.0% 93.0% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.0% 94.0% 93.0% - 92.0% 91.0% 94.0% 93.0% - 91.5% 90.5% 93.5% 92.5% - Temperature Coefficient of Ioset Notes Case temperature = 0°C ~Tc max Return terminal is “Dim−“ General Specifications Parameter Efficiency at 277 Vac input: ESD-320S150DV Io=1050mA Io=1500mA ESD-320S220DV Io=1540mA Io=2200mA ESD-320S310DV Io=2170mA Io=3100mA ESD-320S440DV Io=3080mA Io=4400mA ESD-320S620DV Io=4340mA Io=6200mA Efficiency at 347 Vac input: ESD-320S150DV Io=1050mA Io=1500mA ESD-320S220DV Io=1540mA Io=2200mA ESD-320S310DV Io=2170mA Io=3100mA ESD-320S440DV Io=3080mA Io=4400mA ESD-320S620DV Io=4340mA Io=6200mA Efficiency at 480 Vac input: ESD-320S150DV Io=1050mA Io=1500mA ESD-320S220DV Io=1540mA Io=2200mA ESD-320S310DV Io=2170mA Io=3100mA ESD-320S440DV Io=3080mA Io=4400mA ESD-320S620DV Io=4340mA Io=6200mA Notes Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B General Specifications (Continued) Parameter Min. Typ. Max. Standby power - - 1.5 W MTBF - 200,000 Hours - Lifetime - 120,000 Hours - -40°C - +90°C -40°C - +75°C Case temperature for 5 years warranty. Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5% RH to 95% RH; Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 10.28× 3.86 × 1.76 261 × 98 × 44.8 9.21 × 3.86 × 1.76 234 × 98 × 44.8 - 1935g - Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin ESD-320S150DV ESD-320S220DV ESD-320S310DV ESD-320S440DV ESD-320S620DV 10%Ioset - Ioset ESD-320S150DV ESD-320S220DV ESD-320S310DV ESD-320S440DV ESD-320S620DV 105 mA 154 mA 217 mA 308 mA 434 mA - Ioset 0V - 10 V Dim off Voltage 0.4 V 0.55V 0.7 V Dim on Voltage 0.6 V 0.75 V 0.9 V - 0.2 V - Dimming Output Range Recommended Dimming Input Range Hysteresis Notes Vdim(+) = 0 V 1050mA ≤ Ioset ≤ 1500mA 1540mA ≤ Ioset ≤ 2200mA 2170mA ≤ Ioset ≤ 3100mA 3080mA ≤ Ioset ≤ 4400mA 4340mA ≤ Ioset ≤ 6200mA 105mA ≤ Ioset < 1050mA 154mA ≤ Ioset < 1540mA 217mA ≤ Ioset < 2170mA 308mA ≤ Ioset < 3080mA 434mA ≤ Ioset < 4340mA Default 0-10V dimming mode. 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B Dimming Specifications (Continued) Parameter Min. Typ. Max. PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Dimming mode set to PWM in PC interface. Safety & EMC Compliance Safety Category ENEC & CE Standard EN 61347-1, EN61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load ESD-320S150DV(Io=1050mA) ESD-320S150DV(Io=1500mA) 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B ESD-320S220DV(Io=1540mA) ESD-320S220DV(Io=2200mA) ESD-320S310DV(Io=2170mA) ESD-320S310DV(Io=3100mA) ESD-320S440DV(Io=3080mA) ESD-320S440DV(Io=4400mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B ESD-320S620DV(Io=4340mA) ESD-320S620DV(Io=6200mA) Power Factor Total Harmonic Distortion 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDV 320W Programmable IP67 Driver Rev. B Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESD-320S150DV 价格&库存
很抱歉,暂时无法提供与“ESD-320S150DV”相匹配的价格&库存,您可以联系我们找货
