ESD-480S280DT
ESD-480S280DT
    INVENTRONICS(英飞特)
ESD-480S280DT 数据手册
ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D Features • Ultra High Efficiency (Up to 95%) • Full Power at Wide Output Current Range (Constant Power) • Thermal Sensing and Protection for LED Module • Isolated 0-10V/PWM/3 Timer-Modes Dimmable • Dim-to-Off with Standby Power ≤ 1.5 W • Output Lumen Compensation • Input Surge Protection: DM 6kV, CM 10kV • All-Around Protection: OVP, SCP, OTP • IP67 and UL Dry / Damp / Wet Location • SELV Output • TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location • 5 Years Warranty Description The ESD-480SxxxDT series is a 480W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, aquaculture and sports, etc, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range(1) Current Range Input Voltage Range(2) Output Voltage Range Max. Typical Power Factor Output Efficiency 277Vac 480Vac Power (3) Model Number 0.105-1.40A 1.05A-1.40A 1.4 A 249~528Vac 171 ~ 457Vdc 480 W 352~500Vdc 95.0% 0.96 0.95 ESD-480S140DT 0.210-2.80A 2.10-2.80A 2.8 A 249~528Vac 86 ~ 228Vdc 352~500Vdc 480 W 94.5% 0.96 0.95 ESD-480S280DT 0.315-4.20A 3.15-4.20A 4.2 A 249~528Vac 57 ~ 152Vdc 352~500Vdc 480 W 94.0% 0.96 0.95 ESD-480S420DT 0.435-5.60A 4.35-5.60A 5.6 A 249~528Vac 43 ~ 110Vdc 352~500Vdc 480 W 93.5% 0.96 0.95 ESD-480S560DT(4) 0.750-10.0A 7.50-10.0A 10.0 A 249~528Vac 352~500Vdc 480 W 93.5% 0.96 0.95 ESD-480S10ADT 24 ~ 64Vdc (4) Notes: (1) Output current range with constant power at 480W. (2) Certified input voltage range: 277-480Vac or 352-500Vdc. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D I-V Operating Area ESD-480S140DT ESD-480S280DT 300 (10%Ioset,480/Ioset) 200 (2800,171) (Ioset,480/Ioset) 60 % Lo 150 ad Output Voltage(V) (2100,228) 10 0% Lo ad (1260,228) 250 (210,228) (2800,102) 100 (280,86) 50 (Ioset,86) (2800,86) Good Performance Area Allowed Operating Area Programmed Operating Area 550 2200 0 0 1100 1650 2750 3300 Output Current (mA) Note: 2100mA ESD-480S420DT Ioset 2800mA ESD-480S560DT 150 (10%Ioset,480/Ioset) 100 (5600,86) (Ioset,480/Ioset) 60 % Lo 75 ad Output Voltage(V) (4350,110) 10 0% Lo ad (2610,110) 125 (435,110) (5600,52) 50 (560,43) 25 (Ioset,43) (5600,43) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 1100 2200 3300 4400 5500 6600 Output Current (mA) Note: 4350mA Ioset 5600mA ESD-480S10ADT 90 (10%Ioset,480/Ioset) 60 60 (10000,48) (Ioset,480/Ioset) % a Lo 45 d Output Voltage(V) (7500,64) 10 0% Lo ad (4500,64) (750,64) 75 (10000,29) 30 (1000,24) 15 (Ioset,24) (10000,24) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 2000 4000 6000 8000 10000 12000 Output Current (mA) Note: 7500mA Ioset 10000mA 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D Input Specifications Parameter Min. Typ. Max. Input AC Voltage 249 Vac - 528 Vac Input DC Voltage 352 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU - - 0.70 mA 500 Vdc Leakage Current - - 2.09 A - - 1.21 A - - 13.8 A s 0.90 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 105 mA 210 mA 315 mA 435 mA 750 mA - 1400 mA 2800 mA 4200 mA 5600 mA 10000 mA 1050 mA 2100 mA 3150 mA 4350 mA 7500 mA - 1400 mA 2800 mA 4200 mA 5600 mA 10000 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESD-480S140DT ESD-480S280DT ESD-480S420DT ESD-480S560DT ESD-480S10ADT - - 500 V 280 V 190 V 120 V 80 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Input AC Current 2 Inrush Current(I t) PF THD Notes 2 UL8750; 480Vac/60Hz, Grounding effectively IEC60598-1; 480Vac/60Hz Measured at 100% load and 277 Vac input. Measured at 100% load and 480 Vac input. At 480Vac input, 25℃ cold start, duration=840 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 277-480Vac, 50-60Hz, 60%-100% load (288-480W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESD-480S140DT ESD-480S280DT ESD-480S420DT ESD-480S560DT ESD-480S10ADT Output Current Setting Range with Constant Power ESD-480S140DT ESD-480S280DT ESD-480S420DT ESD-480S560DT ESD-480S10ADT Total Output Current Ripple (pk-pk) Notes At 100% load condition At 100% load condition, 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D Output Specifications (Continued) Parameter Min. Typ. Max. Notes Turn-on Delay Time - - 0.5 s Measured at 277-480Vac input, 60%-100% load Temperature Coefficient of Ioset - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Return terminal is “Dim−“ - - 400 mA 400mA peak for a maximum duration of 300ms in a 2s period during which time the average should not exceed 200mA. Min. Typ. Max. Notes 92.0% 91.5% 94.0% 93.5% - 91.5% 90.5% 93.5% 92.5% - 91.0% 90.5% 93.0% 92.5% - 90.5% 90.0% 92.5% 92.0% - 90.5% 89.0% 92.5% 91.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.0% 94.0% 93.0% - 91.5% 91.0% 93.5% 93.0% - 91.0% 90.5% 93.0% 92.5% - 91.0% 89.5% 93.0% 91.5% - 12V Auxiliary Output Transient Peak Current Case temperature = 0°C~Tc max General Specifications Parameter Efficiency at 277 Vac input: ESD-480S140DT Io= 1050 mA Io= 1400 mA ESD-480S280DT Io= 2100 mA Io= 2800 mA ESD-480S420DT Io= 3150 mA Io= 4200 mA ESD-480S560DT Io= 4350 mA Io= 5600 mA ESD-480S10ADT Io= 7500 mA Io= 10000 mA Efficiency at 347 Vac input: ESD-480S140DT Io= 1050 mA Io= 1400 mA ESD-480S280DT Io= 2100 mA Io= 2800 mA ESD-480S420DT Io= 3150 mA Io= 4200 mA ESD-480S560DT Io= 4350 mA Io= 5600 mA ESD-480S10ADT Io= 7500 mA Io= 10000 mA Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D General Specifications (Continued) Parameter Min. Typ. Max. 93.0% 92.0% 95.0% 94.0% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.0% 94.0% 93.0% - 91.5% 91.0% 93.5% 93.0% - 91.5% 89.5% 93.5% 91.5% - Standby power - - 1.5 W MTBF - 210,000 Hours - Lifetime - 102,000 Hours - -40°C - +85°C -40°C - +75°C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 480 Vac input: ESD-480S140DT Io= 1050 mA Io= 1400 mA ESD-480S280DT Io= 2100 mA Io= 2800 mA ESD-480S420DT Io= 3150 mA Io= 4200 mA ESD-480S560DT Io= 4350 mA Io= 5600 mA ESD-480S10ADT Io= 7500 mA Io= 10000 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 10.3 x 4.92 x 1.71 262 x 125 x 43.5 9.25 x 4.92 x 1.71 235 x 125 x 43.5 - 2650 g - Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 μA 300 μA 450 μA Dimming Specifications Dimming Output Range ESD-480S140DT ESD-480S280DT ESD-480S420DT ESD-480S560DT ESD-480S10ADT 10%Ioset - Ioset ESD-480S140DT ESD-480S280DT ESD-480S420DT ESD-480S560DT ESD-480S10ADT 105 mA 210 mA 315 mA 435 mA 750 mA - Ioset Notes Vdim(+) = 0 V 1050mA ≤ Ioset ≤ 1400mA 2100mA ≤ Ioset ≤ 2800mA 3150mA ≤ Ioset ≤ 4200mA 4350mA ≤ Ioset ≤ 5600mA 7500mA ≤ Ioset ≤ 10000mA 105mA ≤ Ioset < 1050mA 210mA ≤ Ioset < 2100mA 315mA ≤ Ioset < 3150mA 435mA ≤ Ioset < 4350mA 750mA ≤ Ioset < 7500mA 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D Dimming Specifications (Continued) Parameter Min. Typ. Max. Recommended Dimming Input Range 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV (2) 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore lineto-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D Efficiency vs. Load ESD-480S140DT(Io=1050mA) ESD-480S140DT(Io=1400mA) ESD-480S280DT(Io=2100mA) ESD-480S280DT(Io=2800mA) ESD-480S420DT(Io=3150mA) ESD-480S420DT(Io=4200mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D ESD-480S560DT(Io=4350mA) ESD-480S560DT(Io=5600mA) ESD-480S10ADT(Io=7500mA) ESD-480S10ADT(Io=10000mA) Power Factor 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-480SxxxDT 480W Programmable IP67 Driver Rev. D Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming Implementation 2: Positive logic Implementation 3: Negative logic   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESD-480S280DT 价格&库存
很抱歉,暂时无法提供与“ESD-480S280DT”相匹配的价格&库存,您可以联系我们找货
ESD-480S280DT
