ESV-600S048ST
ESV-600S048ST
    INVENTRONICS(英飞特)
    ESV-600S048ST
ESV-600S048ST 数据手册
ESV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. A Features  Ultra High Efficiency (Up to 93.5%)  Ultra High Input Voltage (249~528Vac)  Constant Voltage Output  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OCP, OVP, SCP, OTP  Input UVP and Input OVP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (classified ) location 5 years warranty  Description The ESV-600SxxxST series is a 600W, constant-voltage IP67 LED driver that operates from 249~528 Vac input with excellent power factor. It is created for many lighting applications including horticulture and sports. The high efficiency of these drivers enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, over current, output over voltage, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc 48 Vdc 54 Vdc Output Current Range Max. Output Power Typical Efficiency (2) 277Vac 480Vac 0 ~ 12.5 A 600 W 93.0% 0.95 0.90 ESV-600S048ST 0 ~ 11.2 A 600 W 93.5% 0.95 0.90 ESV-600S054ST Power Factor Model Number (3) Notes: (1) Certified voltage range: 277-480Vac or 352-500Vdc. (2) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (3) SELV output. Input Specifications Parameter Min. Typ. Max. 249 Vac - 528 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.7 mA At 480Vac/60Hz input - - 2.50 A Measured at 100% load and 277 Vac input. - - 1.45 A Measured at 100% load and 480 Vac input. Input Voltage Notes Input AC Current 1/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. A Input Specifications (Continued) Parameter 2 Inrush Current(I t) PF THD Min. Typ. Max. - - 24.3 A s 0.90 - - - - 20% Min. Typ. Max. -2.5%VO - 2.5%VO 2 Notes At 480Vac input, 25C cold start, duration = 896 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 277-480Vac, 50-60Hz, 60%-100%load (360-600W) Output Specifications Parameter Output Voltage Tolerance Notes At 100% load condition At 0% - 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Output Voltage Ripple (pk-pk) - - 2%VO Output Voltage Overshoot / Undershoot - - 5%Vo Line Regulation - - ±0.5% Load Regulation - - ±1.0% - - 0.5 s Measured at 277Vac input, 100% load - - 0.5 s Measured at 480Vac input, 100% load Output Deviation - - 5%VO Settling Time - - 10 ms - 0.03%/C - Measured at 100% load Turn-on Delay Time Load Dynamic Response Temperature Coefficient R/S: 1 A/μs Load: 10% ~ 100% load. Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. Efficiency at 277Vac input: ESV-600S048SV ESV-600S054SV 89.5% 90.0% 91.5% 92.0% Efficiency at 347Vac input: ESV-600S048SV ESV-600S054SV 90.5% 91.0% 92.5% 93.0% - Efficiency at 480Vac input: ESV-600S048SV ESV-600S054SV 91.0% 91.5% 93.0% 93.5% - - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 2/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. A General Specifications (Continued) Parameter Min. Typ. Max. MTBF - 203,000 Hours - Lifetime - 117,000 Hours -40 °C - +88 C -40 °C - +70 C Case temperature for 5 years warranty. Humidity: 10%RH to 100%RH -40 °C - +85 °C Humidity: 5%RH to 100%RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Measured at 480Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details Dimensions Inches (L × W × H) Millimeters (L × W × H) With mounting ear 10.87 × 5.67 × 1.91 276 × 144 × 48.5 9.84 × 5.67 × 1.19 250 × 144 × 48.5 Net Weight - 3330 g Notes - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, CAN/CSA-C22.2 No. 250.13 CE EN61347-1,EN61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part15 (1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS (2) 3/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. A Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 4/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. A Efficiency vs. Load ESV-600S048ST ESV-600S054ST Power Factor Total Harmonic Distortion 5/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. A Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. Mechanical Outline INPUT(UL STW 3*18AWG 9.5) OUTPUT(UL SJTW 2*14AWG 8.8) Tc V+(RED) V-(BLUE) AC/L(BLACK) AC/N(WHITE) GND(GREEN) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 6/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. A Revision History Description of Change Change Date Rev. 2018-07-05 A Item From Datasheet Release / To / 7/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
ESV-600S048ST 价格&库存
很抱歉,暂时无法提供与“ESV-600S048ST”相匹配的价格&库存,您可以联系我们找货
