EUC-026S105DS
EUC-026S105DS
    INVENTRONICS(英飞特)
    EUC Series 26 W 1.05A 25Vdc Out Max Dimmable Outdoor Constant Current LED Driver
EUC-026S105DS 数据手册
EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Features  High Efficiency (Up to 86%)  Second Generation with Improved Performance  Active Power Factor Correction (Typical 0.95)  Constant Output Current  Waterproof (IP66) and UL Damp Location  Dimming Control  All-Around Protection: OVP, SCP, OLP  Class 2 and SELV  UL Type TL (Temperature Limited) Description The EUC-026SxxxDS(PS) series operates from a 90 ~ 305 Vac input range. They are designed to be highly efficient and highly reliable. Features include over voltage protection, short circuit protection and over load protection. Models Output Current Input Voltage Range(1) Output Voltage Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac 350 mA 90 ~ 305 Vac 38~75 Vdc 26 W 86% 0.96 0.95 EUC-026S035DS(PS) 450 mA 90 ~ 305 Vac 28~56 Vdc 25 W 85% 0.96 0.95 EUC-026S045DS(PS) 530 mA 90 ~ 305 Vac 25~49 Vdc 26 W 85% 0.96 0.95 EUC-026S053DS(PS) 700 mA 90 ~ 305 Vac 19~37 Vdc 26 W 85% 0.96 0.95 EUC-026S070DS(PS) 1050 mA 90 ~ 305 Vac 13~25 Vdc 26 W 84% 0.96 0.95 EUC-026S105DS(PS) 1400 mA 90 ~ 305 Vac 10~19 Vdc 26 W 82% 0.96 0.95 EUC-026S140DS(PS) 1750 mA 90 ~ 305 Vac 8 ~15 Vdc 26 W 81% 0.96 0.95 EUC-026S175DS(PS) Power Factor Model Number (3) (6) (4) (6) (4) (6) (5) (6) (7) (5) (6) (5) (6) (7) (5) (6) (7) Notes: (1) UL, FCC certified input voltage range: 100-277Vac; other certified input voltage range except UL, FCC: 100240Vac. (2) Measured at 100% load and 220 Vac input. (3) Non-Class 2 output (USR & CNR). (4) Class 2 output (USR), Non-Class 2 output (CNR). (5) Class 2 output (USR & CNR). (6) SELV. (7) Meet with KC and KCC Certification. Input Specifications Parameter Min. Typ. Max. Input Voltage Range 90 V - 305 V Input Frequency 47 Hz - 63 Hz Notes 1 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Input Specifications (Continued) Parameter Min. Typ. Max. Notes - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 0.4 A Measured at 100% load and 100 Vac input. - - 0.2 A Measured at 100% load and 220 Vac input. - - 0.043 A2s 0.90 - - - - 20% Min. Typ. Max. -5%Io - 5%Io - - 50%Io - - 85 V 59 V 56 V 42 V 32 V 26 V 22 V - - 10%Io Line Regulation - - ±1% Load Regulation - - ±3% - 0.40 s 0.75 s Measured at 120Vac input, 75%~100%load - 0.30 s 0.50 s Measured at 220Vac input, 75%~100%load - - 0.2%/C 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Leakage Current Input AC Current Inrush Current(I2t) Power Factor THD At 220Vac input 25℃ Cold Start. Duration=100 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At100-277Vac,50-60Hz,75%-100%load (19.5~26W) Output Specifications Parameter Output Current Tolerance Total Output Current Ripple (pk-pk) No Load Output Voltage IO = 350 mA IO = 450 mA IO = 530 mA IO = 700 mA IO = 1050 mA IO = 1400 mA IO = 1750 mA Output Current Overshoot / Undershoot Notes Related to V-I Curve of the LED At 100% load condition Measured at 100% load condition Turn-on Delay Time Temperature Coefficient of Iomax Case temperature = 0C~Tc max. Return terminal is “Dim-”. Note: All specifications are typical at 25°C unless otherwise stated. 2 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M General Specifications Parameter Efficiency at 120 Vac input: IO = 350 mA IO = 450 mA IO = 530 mA IO = 700 mA IO = 1050 mA IO = 1400 mA IO = 1750 mA Efficiency at 220 Vac input: IO = 350 mA IO = 450 mA IO = 530 mA IO = 700 mA IO = 1050 mA IO = 1400 mA IO = 1750 mA Efficiency at 277 Vac input: IO = 350 mA IO = 450 mA IO = 530 mA IO = 700 mA IO = 1050 mA IO = 1400 mA IO = 1750 mA No Load Power Dissipation MTBF Lifetime Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Operating Case Temperature for Type TL Tc_TL Storage Temperature Min. Typ. Max. 84% 82% 82% 82% 81% 80% 80% 85% 84% 84% 84% 83% 81% 81% - 85% 83% 83% 83% 82% 80% 80% 86% 85% 85% 85% 84% 82% 81% - 84% 82% 82% 82% 81% 80% 80% 85% 84% 84% 84% 83% 81% 81% - - - 5W 200,000 Hours - - Measured at 120Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) - 91,100 Hours - Measured at 120Vac input, 80%Load and 60C Case temperature. See life time vs. Tc curve for the details -40 ℃ - +90 ℃ -40 ℃ - +70 ℃ -40 ℃ -40 ℃ Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes Measured at 100% load and steady-state temperature in 25℃ ambient. Measured at 100% load and steady-state temperature in 25℃ ambient. Measured at 100% load and steady-state temperature in 25℃ ambient. Humidity: 10% RH to 100% RH. +72 ℃ - +85 ℃ Humidity: 5% RH to 100% RH 3.07 × 3.15 × 1.06 78 × 80 × 27 - 230 g - Note: All specifications are typical at 25°C unless otherwise stated. 3 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the 0~10V Input Pin 0V - 15 V Source Current on 0~10V Input Pin 0 uA 200 uA 250 uA Dimming Output Range 10%Iomax Recommended Dimming Input Range 0V Notes 100%Iomax - 10 V Safety & EMC Compliance Safety Category UL/CUL Standard UL8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 ENEC & TUV & CE CB EN 61347-1, EN61347-2-13 IEC 61347-1, IEC 61347-2-13 PSE J 61347-1, J 61347-2-13 KC K 61347-1, K 61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015/KN 15 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage Fluctuations & Flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 2 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test 4 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Safety & EMC Compliance (Continued) EMS Standards EN 61000-4-11 EN 61547 Notes Voltage Dips Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature Inrush Current Waveform 5 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Efficiency vs. Load EUC-026S035DS(PS) EUC-026S045DS(PS) EUC-026S053DS(PS) EUC-026S070DS(PS) EUC-026S105DS(PS) EUC-026S140DS(PS) 6 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M EUC-026S175DS(PS) Power Factor Total Harmonic Distortion EUC-026S053DS(PS) OTHER 7 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Protection Functions Parameter Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Dimming  0-10V Dimming The dimmer control may be operated from either a dimmer or from an input signal of 0 - 10 Vdc. The recommended implementation is provided below. Implementation 1: DC Input Implementation 2: External Resistor Implementation 3: External Resistor 8 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Notes: 1. Do not connect the Dim- to the V-, otherwise, the LED driver cannot work normally. 2. If 0-10V dimming is not used, Dim + can be either open or connected to Vaux. Mechanical Outline EUC-026SxxxDS AC INPUT (UL1015 18AWG) WHITE(ACN) BLACK (ACL) Tc DC OUTPUT (UL1007 18AWG) GRAY PURPLE YELLOW RED (V+) BLACK (V-) DIMMING WIRE (UL1015 22AWG) PROJ: Unspecified tolerance:±1 9 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M EUC-026SxxxPS AC INPUT (UL1015 18AWG) WHITE(ACN) BLACK(ACL) Tc RED(V+) BLACK(V-) DCOUTPUT (UL1007 18AWG) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 10 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Revision History Description of Change Change Date Rev. 2012-2-17 A 2012-05-25 2012-06-06 Item B C From To Datasheets Release / / EN 61000-4-5--- line to line 2 kV, line to earth 4 kV / Corrected Life time / 50,000 Hours EUC-026S045DS(PS)-0001 / Added Life time vs. Tc Curve / Added EUC-026S045DS(PS)-0001 / Deleted Notes of life time / Updated 2012-7-17 D Max Case Temperature / Updated 2012-7-30 E Min Operating Temperature -20℃ -40℃ Derating Curve / Updated Life time Curve / Updated Inrush Current 60 A 40 A Inrush Current(I t) / Added Temperature co-efficient / Added Life time Min 50,000hrs Typical 91,100hrs Life time Curve / Updated THD Curve / Added Io/Ir Vs Rx Curve / Added Efficiency Curve and PF Curve of other models except 350 mA / Added 2012-08-20 F 2 2012-11-09 G 2013-11-26 H Model 530mA / Added 2014-05-27 I ENEC certificate / Added Warranty Tc / Added Environmental Specifications / Deleted Inrush Current Waveform / Added CCC certificate ./ Added CQC certificate ./ Deleted Source Current on 0~10V Input Pin Max. 200uA 250uA 2015-08-04 J 11 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxDS(PS) 26W Constant Current IP66 Driver Rev. M Revision History (Continued) Change Date 2016-04-18 2016-08-02 2019-08-14 Description of Change Rev. Item K L M From To UL Type TL / Added KC certificate - EUC-026S070/140/175DS(PS) / Added Net Weight 200 g 230 g KS Certificate Regulation / Added Note of EMI Standard / Added Turn-on Delay Time at 120Vac Max.=1.0 s Max.=0.75 s TUV Logo / Updated ENEC Logo / Updated CCC Logo / Deleted PSE Logo / Updated Input Specifications(PF/THD) 50-60Hz Added Safety &EMC Compliance UL/CUL Updated Safety &EMC Compliance ENEC Added Safety &EMC Compliance TUV Added Safety &EMC Compliance CB Added Safety &EMC Compliance CCC Deleted Safety &EMC Compliance PSE Added Safety &EMC Compliance KS Updated Safety &EMC Compliance KC Added Safety &EMC Compliance KCC Added Safety &EMC Compliance FCC Updated Safety &EMC Compliance EN 61000-4-5 Updated RoHS Compliance / Updated 12 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-026S105DS
物料型号:EUC-026SxxxDS(PS)
器件简介: - 该系列电源设计用于高效率和高可靠性,具有防水等级IP66,并适用于潮湿环境。 - 包含多种保护功能:过压保护(OVP)、短路保护(SCP)、过载保护(OLP)。
引脚分配: - AC输入:白色为ACN,黑色为ACL。 - DC输出:红色为V+,黑色为V-。 - 调光控制:紫色和黄色为DIMMING WIRE。
参数特性: - 输入电压范围:90~305V AC。 - 频率范围:47Hz至63Hz。 - 漏电流:在UL8750标准下,277Vac/60Hz时不超过0.75mA;在IEC60598-1标准下,240Vac/60Hz时不超过0.70mA。 - 功率因数:在100-277Vac,50-60Hz,75%-100%负载下,典型值为0.90至0.96。 - 总谐波失真(THD):不超过20%。
功能详解: - 该驱动电源支持0-10V调光控制,具有自动恢复的短路保护功能。 - 提供多种输出电流型号,从350mA至1750mA不等,以满足不同应用需求。
应用信息: - 适用于需要高效率和防水性能的照明应用。
封装信息: - 尺寸:3.073.151.06英寸(78x80x27毫米)。 - 净重:230克。
安全与EMC合规性: - 符合UL、FCC、EN、IEC等多个安全和电磁兼容标准。
RoHS合规性: - 产品符合RoHS指令,限制使用铅和其他有害物质。
修订历史: - 文档记录了从2012年至2019年的多次修订,包括新增型号、标准更新、性能改进等。
EUC-026S105DS 价格&库存
很抱歉,暂时无法提供与“EUC-026S105DS”相匹配的价格&库存,您可以联系我们找货
