EUC-060S105DTM0004
EUC-060S105DTM0004
    INVENTRONICS(英飞特)
    60W driver
EUC-060S105DTM0004 数据手册
EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A Features  Low THD, 10% Max up to 240 Vac  Compact Metal Case with Excellent Thermal Performance  Isolated 0-10V Dimmable  Input Surge Protection: 4kV line-line, 6kV line-earth  High Reliability & Long Lifetime: 95,900 hrs. at 70C Case Temperature  Suitable for Built-in Use and Class I Luminaires  Input UVP and Input OVP  Waterproof(IP66) and UL Dry / Damp Location  Class 2 & SELV Output  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location  5 Years Warranty Description The EUC-060SxxxDTM000x series is a 60W, constant-current IP66 LED driver that operates from 90-305Vac input with excellent power factor and THD feature. It is created for low bay, tunnel and street lights. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Output Current Input Voltage Range(1) Output Voltage Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac Power Factor Model Number 500 mA 90 ~ 305 Vac 60 ~ 120 Vdc 127 ~ 300 Vdc 60W 90% 0.99 0.96 EUC-060S070DTM0004 700 mA 90 ~ 305 Vac 48 ~ 86 Vdc 127 ~ 300 Vdc 60W 89% 0.99 0.96 EUC-060S070DTM 860 mA 90 ~ 305 Vac 35 ~ 70 Vdc 127 ~ 300 Vdc 60W 89% 0.99 0.96 EUC-060S105DTM0004(3) 1050 mA 90 ~ 305 Vac 34 ~ 57 Vdc 127 ~ 300 Vdc 60W 89% 0.99 0.96 EUC-060S105DTM 1200 mA 90 ~ 305 Vac 25 ~ 50 Vdc 127 ~ 300 Vdc 60W 89% 0.99 0.96 EUC-060S180DTM0006 1400 mA 90 ~ 305 Vac 21 ~ 43 Vdc 127 ~ 300 Vdc 60W 88% 0.99 0.96 EUC-060S180DTM0004 1800 mA 90 ~ 305 Vac 20 ~ 33 Vdc 127 ~ 300 Vdc 60W 87% 0.99 0.96 EUC-060S180DTM (3) (3)(4) (3)(4) (3)(4) Notes: (1) UL, FCC certified input voltage range: 120-277Vac/127-300Vdc; other certified input voltage range except UL & FCC: 120-240Vac/127-250Vdc. (2) Measured at full load and 220 Vac input. (3) SELV output. (4) Class 2 output. 1 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 0.66 A Measured at full load and 120 Vac input. - - 0.35 A Measured at full load and 220 Vac input. - - 0.26 A s 0.90 - - THD - - 15% THD - - 10% Min. Typ. Max. -8%lo - 8%lo At full load condition Total Output Current Ripple (pkavg) - 50%lo 75%lo At full load condition Startup Overshoot Current - 5%Io 10%Io At full load condition No Load Output Voltage EUC-060S070DTM0004 EUC-060S070DTM EUC-060S105DTM0004 EUC-060S105DTM EUC-060S180DTM0006 EUC-060S180DTM0004 EUC-060S180DTM - - 160V 160V 100V 100V 60V 60V 60V Line Regulation - - ±5.0% Load Regulation - - ±5.0% - 1.5 s 2.0 s Measured at 120Vac input, 75%-100% Load - 1.0 s 1.5 s Measured at 220Vac input. 75%-100% Load - 0.06%/C - 127 ~ 300 Vdc Leakage Current Input AC Current 2 Inrush Current(I t) Power Factor 2 At 220Vac input, 25℃ cold start, duration= 236 μS, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 120-277Vac, 75%-100%Load(45~60W) 120-240Vac, 75%-100%Load(45~60W) Output Specifications Parameter Output Current Tolerance Turn-on Delay Time Temperature Coefficient of Iomax Notes Measured at full load Case temperature = 0C ~Tc max Note: All specifications are tested by Cree XLamp XP-G2 and typical measured at 220Vac and 25C unless otherwise stated. 2 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A General Specifications Parameter Min. Typ. Max. Efficiency at 120 Vac input: EUC-060S070DTM0004 EUC-060S070DTM EUC-060S105DTM0004 EUC-060S105DTM EUC-060S180DTM0006 EUC-060S180DTM0004 EUC-060S180DTM 86.0% 85.0% 85.0% 85.0% 85.0% 84.0% 84.0% 88.0% 87.0% 87.0% 87.0% 87.0% 86.0% 85.0% - Efficiency at 220 Vac input: EUC-060S070DTM0004 EUC-060S070DTM EUC-060S105DTM0004 EUC-060S105DTM EUC-060S180DTM0006 EUC-060S180DTM0004 EUC-060S180DTM 88.0% 87.0% 87.0% 87.0% 87.0% 86.0% 85.0% 90.0% 89.0% 89.0% 89.0% 89.0% 88.0% 87.0% - Efficiency at 277 Vac input: EUC-060S070DTM0004 EUC-060S070DTM EUC-060S105DTM0004 EUC-060S105DTM EUC-060S180DTM0006 EUC-060S180DTM0004 EUC-060S180DTM 88.0% 87.0% 87.0% 87.0% 87.0% 86.0% 85.0% 90.0% 89.0% 89.0% 89.0% 89.0% 88.0% 87.0% - MTBF - 475,000 Hours - Lifetime - 95,900 Hours - -40 C - +88 C -40 C - +75 C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. -40 C - +85 C Humidity: 5% RH to 100% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 410 g Measured at full load and steady-state temperature in 25C ambient. Measured at full load and steady-state temperature in 25C ambient. Measured at full load and steady-state temperature in 25C ambient. Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 4.41 x 2.52 x 1.26 112 x 64 x 32 3.74 x 2.52 x 1.26 95 x 64 x 32 - Notes - Note: All specifications are tested by Cree XLamp XP-G2 and typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the 0~10V Input Pin 0V - 20 V Source Current on 0~10V Input Pin 0 μA 200 μA 250 μA Notes 3 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A Dimming Specifications (Continued) Parameter Dimming Output Range Min. Typ. Max. 10%Iomax - 100%Iomax 0V - 10 V Recommended Dimming Input Range Notes Safety &EMC Compliance Safety Category UL/CUL Standard UL 8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 4 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A Derating Lifetime vs. Case Temperature Inrush Current Waveform 5 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A Efficiency vs. Load EUC-060S070DTM(Io=700mA) EUC-060S070DTM0004(Io=500mA) EUC-060S105DTM(Io=1050mA) EUC-060S105DTM0004(Io=860mA) EUC-060S180DTM(Io=1800mA) EUC-060S180DTM0004(Io=1400mA) 6 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A EUC-060S180DTM0006(Io=1200mA) Power Factor Total Harmonic Distortion 7 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Input Under Voltage Protection Input Protection Voltage Input Over Voltage Protection Input Recovery Voltage Auto Recovery. Turn off the output when the input voltage falls below 80±10V. And the driver will restart when the input voltage exceeds 85±10V. Turn off the output when the input voltage 330 Vac 340 Vac 350 Vac exceeds protection voltage. Auto Recovery. The driver will restart 300 Vac 320 Vac 340 Vac when the input voltage falls below recovery voltage. Max. of Input Over Voltage  - - 380 Vac Input Over Voltage Protection Diagram Io Recovery Protection 340 Vac 320 Vac Vin Dimming  0-10V Dimming The recommended implementation is provided below. 8 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do not connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. Mechanical Outline INPUT (UL1015 18AWG) OUTPUT (UL1015 18AWG) Tc V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) PURPLE GRAY DIMMING WIRE (UL1430 22AWG) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 9 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-060SxxxDTM000x 60W Constant Current IP66 Driver Rev. A Revision History Description of Change Change Date Rev. 2017-03-06 A Item From Datasheet Release / To / 10 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-060S105DTM0004 价格&库存
很抱歉,暂时无法提供与“EUC-060S105DTM0004”相匹配的价格&库存,您可以联系我们找货
EUC-060S105DTM0004
