EUD-096S210DTL
EUD-096S210DTL
    INVENTRONICS(英飞特)
EUD-096S210DTL 数据手册
` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C Features  Innovative Design with No Electrolytic Capacitors  Ultra Long Lifetime: Greater than 100,000 hrs at 85C Case Temperature  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/Timer Dimmable (3 Timer Modes )  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  Class 2 & SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  10 Years Warranty Description The EUD-096SxxxDTL series is a novel 96W design that has removed the use of Electrolytic capacitors to extend lifetime at elevated temperatures. It is a constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, tunnel and street, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature of both the driver and the external LED array. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current 45-700mA 450-700mA 530 mA 70-1050mA 700-1050mA 700 mA 140-2100mA 1400-2100mA 2100 mA 175-2150mA 1750-2150mA 2100 mA 245-3500mA 2450-3500mA 2800 mA Input Voltage Range(2) 90~305Vac 127~300Vdc 90~305Vac 127~300Vdc 90~305Vac 127~300Vdc 90~305Vac 127~300Vdc 90~305Vac 127~300Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number 74~213Vdc 96 W 92.5% 0.98 0.96 EUD-096S070DTL 48~137Vdc 96 W 92.0% 0.98 0.96 EUD-096S105DTL 24 ~ 69Vdc 96 W 91.5% 0.98 0.96 EUD-096S210DTL (4) 24 ~ 55Vdc 96 W 91.0% 0.98 0.96 EUD-096S215DTL (5) 14 ~ 39Vdc 96 W 91.5% 0.98 0.96 EUD-096S350DTL (5) Notes: (1) Output current range with constant power at 96W (2) UL, FCC certified input voltage range: 100-277Vac or 127-300Vdc; otherwise: 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) Class 2 & SELV Output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C I-V Operating Area EUD-096S070DTL EUD-096S105DTL EUD-096S210DTL EUD-096S215DTL EUD-096S350DTL 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 1.20 A Measured at 100% load and 100 Vac input. - - 0.50 A Measured at 100% load and 220 Vac input. - - 0.76 A2s 0.90 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 45 mA 70 mA 140 mA 175 mA 245 mA - 700 mA 1050 mA 2100 mA 2150 mA 3500 mA 450 mA 700 mA 1400 mA 1750 mA 2450 mA - 700 mA 1050 mA 2100 mA 2150 mA 3500 mA - 8%Iomax 15%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-096S070DTL EUD-096S105DTL EUD-096S210DTL EUD-096S215DTL EUD-096S350DTL - - 230 V 160 V 77 V 59 V 45 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Leakage Current Input AC Current Inrush Current(I2t) PF Notes 127~300 Vdc At 220Vac input, 25C Cold Start, Duration=116 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (67-96W) At 220-240Vac, 50-60Hz, 75%-100% Load (72-96W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-096S070DTL EUD-096S105DTL EUD-096S210DTL EUD-096S215DTL EUD-096S350DTL Output Current Setting Range with Constant Power EUD-096S070DTL EUD-096S105DTL EUD-096S210DTL EUD-096S215DTL EUD-096S350DTL Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes 100% load 100% load, 20 MHz BW 100% load. Only this component of ripple is associated with visible flicker. 100% load 100% load 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C Output Specifications (Continued) Parameter Min. Typ. Max. Notes - - 1.0 s Measured at 120Vac input, 70%-100% Load - - 0.5 s Measured at 220Vac input, 70%-100% Load - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Turn-on Delay Time Temperature Coefficient of Ioset Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUD-096S070DTL Io= 450 mA Io= 700 mA EUD-096S105DTL Io= 700 mA Io= 1050 mA EUD-096S210DTL Io= 1400 mA Io= 2100 mA EUD-096S215DTL Io= 1750 mA Io= 2150 mA EUD-096S350DTL Io= 2450 mA Io= 3500 mA Efficiency at 220 Vac input: EUD-096S070DTL Io= 450 mA Io= 700 mA EUD-096S105DTL Io= 700 mA Io= 1050 mA EUD-096S210DTL Io= 1400 mA Io= 2100 mA EUD-096S215DTL Io= 1750 mA Io= 2150 mA EUD-096S350DTL Io= 2450 mA Io= 3500 mA Min. Typ. Max. 88.5% 87.5% 90.5% 89.5% - 88.0% 87.0% 90.0% 89.0% - 87.5% 86.0% 89.5% 88.0% - 87.0% 86.0% 89.0% 88.0% - 87.5% 86.5% 89.5% 88.5% - 90.5% 89.5% 92.5% 91.5% - 90.0% 89.0% 92.0% 91.0% - 89.5% 88.5% 91.5% 90.5% - 89.0% 88.0% 91.0% 90.0% - 89.5% 88.0% 91.5% 90.0% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C General Specifications (Continued) Parameter Min. Typ. Max. 91.0% 90.0% 93.0% 92.0% - 90.5% 89.5% 92.5% 91.5% - 90.0% 88.5% 92.0% 90.5% - 89.0% 88.0% 91.0% 90.0% - 90.0% 88.5% 92.0% 90.5% - Standby power - - 0.5 W MTBF - 219,000 Hours - Lifetime - 100,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 10 years warranty. Please see Inventronics EUD-DTL Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUD-096S070DTL Io= 450 mA Io= 700 mA EUD-096S105DTL Io= 700 mA Io= 1050 mA EUD-096S210DTL Io= 1400 mA Io= 2100 mA EUD-096S215DTL Io= 1750 mA Io= 2150 mA EUD-096S350DTL Io= 2450 mA Io= 3500 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 85C case temperature; See lifetime vs. Tc curve for the details With mounting ear 7.92 × 2.66 × 1.44 201 × 67.5 × 36.5 7.09 × 2.66 × 1.44 180 × 67.5 × 36.5 - 960 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+) Pin Dimming Output Range Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA EUD-096S070DTL EUD-096S105DTL EUD-096S210DTL EUD-096S215DTL EUD-096S350DTL 10%Ioset - Ioset EUD-096S070DTL EUD-096S105DTL EUD-096S210DTL EUD-096S215DTL EUD-096S350DTL 45 mA 70 mA 140 mA 175 mA 245 mA - Ioset Notes Vdim(+) = 0 V 450 mA ≤ Ioset ≤ 700 mA 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 1750 mA ≤ Ioset ≤ 2150 mA 2450 mA ≤ Ioset ≤ 3500 mA 45 mA ≤ Ioset < 450 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 175 mA ≤ Ioset < 1750 mA 245 mA ≤ Ioset < 2450 mA 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C Dimming Specifications (Continued) Parameter Min. Typ. Max. 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 2% 5% 8% 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15 (1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge(ESD): 8kV air discharge, 4kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-4 Electrical Fast Transient/Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6kV, line to earth 10kV EN 61000-4-6 Conducted Radio Frequency Disturbances test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2)To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C Efficiency vs. Load EUD-096S070DTL(Io=450mA) EUD-096S070DTL(Io=700mA) EUD-096S105DTL(Io=700mA) EUD-096S105DTL(Io=1050mA) EUD-096S210DTL(Io=1400mA) EUD-096S210DTL(Io=2100mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL Rev.C 96W Programmable Driver with Ultra Long Lifetime EUD-096S215DTL(Io=1750mA) EUD-096S215DTL(Io=2150mA) EUD-096S350DTL(Io=2450mA) EUD-096S350DTL(Io=3500mA) Power Factor 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. Notes R1 - 7.81 kOhm - R2 - 4.16 kOhm - Protection Current Floor 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDTL 96W Programmable Driver with Ultra Long Lifetime Rev.C Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic V+(RED) L V-(BLU) Vac N Inventronics LED Driver OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) PWM Signal Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-096S210DTL 价格&库存
很抱歉,暂时无法提供与“EUD-096S210DTL”相匹配的价格&库存,您可以联系我们找货
