EUD-150S070DTL
EUD-150S070DTL
    INVENTRONICS(英飞特)
    EUD-150S070DTL
EUD-150S070DTL 数据手册
` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B Features  Innovative Design with No Electrolytic Capacitors  Ultra Long Lifetime: Greater than 100,000 hrs at 85C Case Temperature  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/Timer Dimmable (3 Timer Modes )  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  10 Years Warranty Description The EUD-150SxxxDTL series is a novel 150W design that has removed the use of Electrolytic capacitors to extend lifetime at elevated temperatures. It is a constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, tunnel and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range 45-700mA Full-Power Current Range (1) 450-700mA Default Output Current 530 mA 70-1050mA 700-1050mA 700 mA 140-2100mA 1400-2100mA 1400 mA 245-3500mA 2450-3500mA 3150 mA 385-5600mA 3850-5600mA 4200 mA Input Voltage Range(2) 90~305Vac 127~300Vdc 90~305Vac 127~300Vdc 90~305Vac 127~300Vdc 90~305Vac 127~300Vdc 90~305Vac 127~300Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number (5) 117~333Vdc 150 W 93.0% 0.98 0.96 EUD-150S070DTL 75~214Vdc 150 W 93.0% 0.98 0.96 EUD-150S105DTL 38~107Vdc 150 W 92.5% 0.98 0.96 EUD-150S210DTL (4) 22 ~ 61Vdc 150 W 92.0% 0.98 0.96 EUD-150S350DTL (4) 14 ~ 39Vdc 150 W 91.0% 0.98 0.96 EUD-150S560DTL (4) Notes: (1) Output current range with constant power at 150W (2) UL, FCC certified input voltage range: 100-277Vac or 127-300Vdc; otherwise: 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) All the models are certificated to KS,except EUD-150S070DTL 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B I-V Operating Area EUD-150S070DTL EUD-150S105DTL EUD-150S210DTL EUD-150S350DTL EUD-150S560DTL 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 1.80 A Measured at 100%load and 100 Vac input. - - 0.80 A Measured at 100%load and 220 Vac input. - - 0.70 A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (112.5-150W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 45 mA 70 mA 140 mA 245 mA 385 mA - 700 mA 1050 mA 2100 mA 3500 mA 5600 mA 450 mA 700 mA 1400 mA 2450 mA 3850 mA - 700 mA 1050 mA 2100 mA 3500 mA 5600 mA - 8%Iomax 15%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-150S070DTL EUD-150S105DTL EUD-150S210DTL EUD-150S350DTL EUD-150S560DTL - - 350 V 230 V 117 V 68 V 46 V Line Regulation - - ±0.5% 127~300 Vdc Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25C Cold Start, Duration=432 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (105-150W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-150S070DTL EUD-150S105DTL EUD-150S210DTL EUD-150S350DTL EUD-150S560DTL Output Current Setting Range with Constant Power EUD-150S070DTL EUD-150S105DTL EUD-150S210DTL EUD-150S350DTL EUD-150S560DTL Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At 100%load At 100%load, 20 MHz BW At 100%load. Only this component of ripple is associated with visible flicker. At 100%load Measured at 100%load 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B Output Specifications (Continued) Parameter Min. Typ. Max. - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Load Regulation Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUD-150S070DTL Io=450 mA Io=700 mA EUD-150S105DTL Io=700 mA Io=1050 mA EUD-150S210DTL Io=1400 mA Io=2100 mA EUD-150S350DTL Io=2450 mA Io=3500 mA EUD-150S560DTL Io=3850 mA Io=5600 mA Efficiency at 220 Vac input: EUD-150S070DTL Io=450 mA Io=700 mA EUD-150S105DTL Io=700 mA Io=1050 mA EUD-150S210DTL Io=1400 mA Io=2100 mA EUD-150S350DTL Io=2450 mA Io=3500 mA EUD-150S560DTL Io=3850 mA Io=5600 mA Min. Typ. Max. 89.0% 87.5% 91.0% 89.5% - 88.5% 87.5% 90.5% 89.5% - 88.0% 86.5% 90.0% 88.5% - 87.5% 86.0% 89.5% 88.0% - 87.0% 85.0% 89.0% 87.0% - 91.0% 90.0% 93.0% 92.0% - 91.0% 90.0% 93.0% 92.0% - 90.5% 89.0% 92.5% 91.0% - 90.0% 88.5% 92.0% 90.5% - 89.0% 87.0% 91.0% 89.0% - Notes Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B General Specifications (Continued) Parameter Min. Typ. Max. 91.5% 90.0% 93.5% 92.0% - 91.5% 90.0% 93.5% 92.0% - 91.0% 89.0% 93.0% 91.0% - 90.5% 88.5% 92.5% 90.5% - 89.5% 87.5% 91.5% 89.5% - Standby power - - 0.5 W MTBF - 240,000 Hours - Lifetime - 100,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +87°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 10 years warranty. Please see Inventronics EUD-DTL Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUD-150S070DTL Io=450 mA Io=700 mA EUD-150S105DTL Io=700 mA Io=1050 mA EUD-150S210DTL Io=1400 mA Io=2100 mA EUD-150S350DTL Io=2450 mA Io=3500 mA EUD-150S560DTL Io=3850 mA Io=5600 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 85C case temperature; See lifetime vs. Tc curve for the details With mounting ear 8.23 × 2.66 × 1.56 209 × 67.5 × 39.7 7.41 × 2.66 × 1.56 188 × 67.5 × 39.7 - Notes 1000 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+) Pin Dimming Output Range Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA EUD-150S070DTL EUD-150S105DTL EUD-150S210DTL EUD-150S350DTL EUD-150S560DTL 10%Ioset - Ioset EUD-150S070DTL EUD-150S105DTL EUD-150S210DTL EUD-150S350DTL EUD-150S560DTL 45 mA 70 mA 140 mA 245 mA 385 mA - Ioset Notes Vdim(+) = 0 V 450 mA ≤ Ioset ≤ 700 mA 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2450 mA ≤ Ioset ≤ 3500 mA 3850 mA ≤ Ioset ≤ 5600 mA 45 mA ≤ Ioset < 450 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 245 mA ≤ Ioset < 2450 mA 385 mA ≤ Ioset < 3850 mA 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B Dimming Specifications (Continued) Parameter Min. Typ. Max. 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 2% 5% 8% 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards EN 61000-4-2 Notes Electrostatic Discharge(ESD): 8kV air discharge, 4kV contact discharge 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient/Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6kV, line to earth 10kV EN 61000-4-6 Conducted Radio Frequency Disturbances test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2)To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B Efficiency vs. Load EUD-150S070DTL(Io=450mA) EUD-150S070DTL(Io=700mA) EUD-150S105DTL(Io=700mA) EUD-150S105DTL(Io=1050mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B EUD-150S210DTL(Io=1400mA) EUD-150S210DTL(Io=2100mA) EUD-150S350DTL(Io=2450mA) EUD-150S350DTL(Io=3500mA) EUD-150S560DTL(Io=3850mA) EUD-150S560DTL(Io=5600mA) 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. V+(RED) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) 0 (1)-10V Dimmer Dim-(GRY) Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming V+(RED) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) PWM Signal Implementation 2: Positive logic 11 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-150SxxxDTL 150W Programmable Driver with Ultra Long Lifetime Rev. B V+(RED) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) PWM Signal Implementation 3: Negative logic   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-150S070DTL 价格&库存
很抱歉,暂时无法提供与“EUD-150S070DTL”相匹配的价格&库存,您可以联系我们找货
