EUD-240S105DVA
EUD-240S105DVA
    INVENTRONICS(英飞特)
EUD-240S105DVA 数据手册
EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C Features  Ultra High Efficiency (Up to 94%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/Timer Dimmable (3 Timer Modes)  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA (Transient Peak Current up to 400mA)  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use  7 Years Warranty Description The EUD-240SxxxDVA series is a 240W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, sports and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current Input Voltage Range(2) Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Output Voltage Range 90~305 Vac/ 114~343Vdc 127~250 Vdc 90~305 Vac/ 140-2100mA 1400-2100mA 1400 mA 57~171Vdc 127~250 Vdc 90~305 Vac/ 280-4200mA 2800-4200mA 4200 mA 29 ~ 86Vdc 127~250 Vdc 90~305 Vac/ 445-6700mA 4450-6700mA 6700 mA 18 ~ 54Vdc 127~250 Vdc 70-1050mA 700-1050mA 1050 mA Model Number (5) 240W 94.0% 0.99 0.96 EUD-240S105DVA 240W 93.5% 0.99 0.96 EUD-240S210DVA 240W 93.0% 0.99 0.96 EUD-240S420DVA 240W 93.0% 0.99 0.96 EUD-240S670DVA (4) (4) Notes: (1) Output current range with constant power at 240W (2) Certified voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE and KS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) All the models are certificated to KS, except EUD-240S105DVA 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C I-V Operating Area 96 (280,86) EUD-240S105DVA EUD-240S210DVA EUD-240S420DVA EUD-240S670DVA (1680,86) (2800,86) 80 (Ioset,240/Ioset) (10%Ioset,240/Ioset) 10 0% L 64 ad Lo % 60 48 oa d (4200,57) (4200,34) 32 (4200,29) (Ioset,29) (420,29) 16 Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 800 1600 2400 3200 4000 4800 Output Current (mA) Note: 2800mA Ioset 4200mA Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 3.00 A Measured at full load and 100 Vac input. - - 1.30 A Measured at full load and 220 Vac input. - - 2.60 A s 127-250Vdc IEC60598-1; 240Vac/ 60Hz, grounding effectively Input AC Current 2 Inrush Current(I t) 2 At 220Vac input, 25°C cold start, duration=840 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (180-240W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 70 mA 140 mA 280 mA 445 mA - 1050 mA 2100 mA 4200 mA 6700 mA 700 mA 1400 mA 2800 mA 4450 mA - 1050 mA 2100 mA 4200 mA 6700 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-240S105DVA EUD-240S210DVA EUD-240S420DVA EUD-240S670DVA - - 360 V 190 V 96 V 66 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - - 0.03%/C 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Return terminal is “Dim−“ 400 mA 400mA peak for a maximum duration of 300ms in a 2s period during which time the average should not exceed 200mA. PF Notes At 100-240Vac, 50-60Hz, 60%-100% Load (144-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-240S105DVA EUD-240S210DVA EUD-240S420DVA EUD-240S670DVA Output Current Setting Range with Constant Power EUD-240S105DVA EUD-240S210DVA EUD-240S420DVA EUD-240S670DVA Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 12V Auxiliary Output Transient Peak Current - - At full load condition, 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset At full load condition At full load condition Measured at full load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C General Specifications Parameter Min. Typ. Max. 89.0% 88.0% 91.0% 90.0% - 89.0% 87.5% 91.0% 89.5% - 88.5% 87.0% 90.5% 89.0% - 89.0% 87.0% 91.0% 89.0% - 92.0% 90.5% 94.0% 92.5% - 91.5% 90.0% 93.5% 92.0% - 91.0% 89.5% 93.0% 91.5% - 91.0% 89.0% 93.0% 91.0% - 92.0% 91.0% 94.0% 93.0% - 92.0% 90.5% 94.0% 92.5% - 91.5% 90.0% 93.5% 92.0% - 91.5% 89.0% 93.5% 91.0% - Standby power - - 0.5 W MTBF - 228,000 Hours - Lifetime - 96,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 120 Vac input: EUD-240S105DVA Io= 700 mA Io= 1050 mA EUD-240S210DVA Io= 1400 mA Io= 2100 mA EUD-240S420DVA Io= 2800 mA Io= 4200 mA EUD-240S670DVA Io= 4450 mA Io= 6700 mA Efficiency at 220 Vac input: EUD-240S105DVA Io= 700 mA Io= 1050 mA EUD-240S210DVA Io= 1400 mA Io= 2100 mA EUD-240S420DVA Io= 2800 mA Io= 4200 mA EUD-240S670DVA Io= 4450 mA Io= 6700 mA Efficiency at 277 Vac input: EUD-240S105DVA Io= 700 mA Io= 1050 mA EUD-240S210DVA Io= 1400 mA Io= 2100 mA EUD-240S420DVA Io= 2800 mA Io= 4200 mA EUD-240S670DVA Io= 4450 mA Io= 6700 mA Notes Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C General Specifications (Continued) Parameter Min. Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Typ. Max. With mounting ear 9.45 × 2.66 × 1.57 240 × 67.5 × 39.7 8.63 × 2.66 × 1.57 219 × 67.5 × 39.7 - Notes 1300 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin EUD-240S105DVA EUD-240S210DVA EUD-240S420DVA Dimming EUD-240S670DVA Output EUD-240S105DVA Range EUD-240S210DVA EUD-240S420DVA EUD-240S670DVA Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA 10%Ioset - Ioset 70 mA 140 mA 280 mA 445 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 2% 5% 8% 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2800 mA ≤ Ioset ≤ 4200 mA 4450 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 280 mA ≤ Ioset < 2800 mA 445 mA ≤ Ioset < 4450 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C Safety &EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 KS KS C 7655 : 2011 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV(2) EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUD-240S105DVA(Io=700mA) EUD-240S105DVA(Io=1050mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C EUD-240S210DVA(Io=1400mA) EUD-240S210DVA(Io=2100mA) EUD-240S420DVA(Io=2800mA) EUD-240S420DVA(Io=4200mA) EUD-240S670DVA(Io=4450mA) EUD-240S670DVA(Io=6700mA) 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA 240W Programmable IP67 Driver Rev.C Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming Implementation 2: Positive logic Implementation 3: Negative logic 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxDVA   240W Programmable IP67 Driver Rev.C Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-240S105DVA 价格&库存
很抱歉,暂时无法提供与“EUD-240S105DVA”相匹配的价格&库存,您可以联系我们找货
