EUG-240S420DV
EUG-240S420DV
    INVENTRONICS(英飞特)
EUG-240S420DV 数据手册
EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Features • Ultra High Efficiency (Up to 94%) • Full Power at Wide Output Current Range (Constant Power) • 0-5V/0-10V/PWM/Timer Dimmable • Input Surge Protection: 6 kV line-line, 10 kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) • SELV Output • Suitable for Independent Use • 7 Years Warranty Description The EUG-240SxxxDV series is a 240W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. It is created for high bay, high mast, arena and roadway lights. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 140-2100mA 1400-2100mA 1400 mA 127~250 Vdc 90~305 Vac/ 280-4200mA 2800-4200mA 4200 mA 127~250 Vdc 90~305 Vac/ 445-6700mA 4450-6700mA 6700 mA 127~250 Vdc 70-1050mA 700-1050mA 700 mA Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Output Voltage Range Model Number (4) 114~343Vdc 240W 94.0% 0.99 0.96 EUG-240S105DV 57~171Vdc 240W 93.0% 0.99 0.96 EUG-240S210DV 29 ~ 86Vdc 240W 93.0% 0.99 0.96 EUG-240S420DV 18 ~ 54Vdc 240W 93.0% 0.99 0.96 EUG-240S670DV(5) (5) Notes: (1) Output current range with constant power at 240W (2) Certified Voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE, KS and BIS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to KS, except EUG-240S105DV (5) SELV Output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D I-V Operating Area EUG-240S105DV EUG-240S210DV EUG-240S420DV EUG-240S670DV Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 3.10 A - - 1.40 A Input AC Current 2 Inrush Current(I t) 2 - - 3.75 A s 0.9 - - THD - - 20% THD - - 10% PF Notes 127~250 Vdc IEC60598-1; 240Vac/ 60Hz, grounding effectively Measured at full load and 100 Vac input. Measured at full load and 220 Vac input. At 220Vac input, 25°C cold start, duration=1.26 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (144-240W) At 220-240Vac, 50-60Hz, 75%-100% Load (180-240W) 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Output Specifications Parameter Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 140 mA 280 mA 445 mA - 1050 mA 2100 mA 4200 mA 6700 mA 700 mA 1400 mA 2800 mA 4450 mA - 1050 mA 2100 mA 4200 mA 6700 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUG-240S105DV EUG-240S210DV EUG-240S420DV EUG-240S670DV - - 356 V 187 V 96 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Output Current Tolerance Output Current Setting(Ioset) Range EUG-240S105DV EUG-240S210DV EUG-240S420DV EUG-240S670DV Output Current Setting Range with Constant Power EUG-240S105DV EUG-240S210DV EUG-240S420DV EUG-240S670DV Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition. 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset Notes At full load condition Measured at full load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUG-240S105DV Io= 700 mA Io=1050 mA EUG-240S210DV Io=1400 mA Io=2100 mA EUG-240S420DV Io=2800 mA Io=4200 mA EUG-240S670DV Io=4450 mA Io=6700 mA Min. Typ. Max. 90.0% 88.5% 92.0% 90.5% - 88.5% 88.0% 90.5% 90.0% - 89.0% 87.0% 91.0% 89.0% - 88.5% 87.0% 90.5% 89.0% - Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D General Specifications Parameter Min. Typ. Max. 92.0% 90.5% 94.0% 92.5% - 91.0% 89.5% 93.0% 91.5% - 91.0% 89.5% 93.0% 91.5% - 91.0% 89.5% 93.0% 91.5% - 92.5% 91.0% 94.5% 93.0% - 92.0% 89.5% 94.0% 91.5% - 91.5% 90.0% 93.5% 92.0% - 91.5% 89.5% 93.5% 91.5% - MTBF - 218,000 Hours - Lifetime - 86,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +88°C Operating Case Temperature for Warranty Tc_w -40°C - +70°C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 220 Vac input: EUG-240S105DV Io= 700 mA Io=1050 mA EUG-240S210DV Io=1400 mA Io=2100 mA EUG-240S420DV Io=2800 mA Io=4200 mA EUG-240S670DV Io=4450 mA Io=6700 mA Efficiency at 277 Vac input: EUG-240S105DV Io= 700 mA Io=1050 mA EUG-240S210DV Io=1400 mA Io=2100 mA EUG-240S420DV Io=2800 mA Io=4200 mA EUG-240S670DV Io=4450 mA Io=6700 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.17 × 2.66 × 1.56 233 × 67.5 × 39.7 8.35 × 2.66 × 1.56 212 × 67.5 × 39.7 - 1200 g Notes - Note: All specifications are typical at 25°C unless otherwise stated. 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. Notes -20 V - 20 V 200 uA 300 uA 450 uA Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2800 mA ≤ Ioset ≤ 4200 mA 4450 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset <1400 mA 280 mA ≤ Ioset <2800 mA 445 mA ≤ Ioset <4450 mA EUG-240S105DV EUG-240S210DV EUG-240S420DV EUG-240S670DV 10%Ioset - Ioset EUG-240S105DV EUG-240S210DV EUG-240S420DV EUG-240S670DV 70 mA 140 mA 280 mA 445 mA - Ioset 0V - 5V Dimming mode set to 0-5V in PC interface. 0V - 10 V Default 0-10V dimming mode with positive logic. PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Dimming Output Range Recommended Dimming Range for 0-5V Recommended Dimming Range for 0-10V PWM_in Duty Cycle Dimming mode set to PWM in PC interface. Safety &EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips (2) 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Safety &EMC Compliance (Continued) EMS Standards EN 61547 Notes Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Inrush Current Waveform Efficiency vs. Load EUG-240S105DV(Io=700mA) EUG-240S105DV(Io=1050mA) EUG-240S210DV(Io=1400mA) EUG-240S210DV(Io=2100mA) 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D EUG-240S420DV(Io=2800mA) EUG-240S420DV(Io=4200mA) EUG-240S670DV(Io=4450mA) EUG-240S670DV(Io=6700mA) Power Factor 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-5V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Implementation 2: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-5V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-5V dimming is not used, Dim + should be open. 4. When 0-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 4. When 0-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  PWM Dimming Implementation 5: Positive logic Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. 11 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D  Time Dimming Set the timing curve by pulling the sliders. Programming Connection Diagram Note: The driver does not need to be powered on during the programming process. 12 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV  240W Programmable IP67 Driver Rev. D Please refer to PRG-MUL2 (Programmer) datasheet for details Mechanical Outline EUG-240S105DV INPUT (VDE H05RN-F 3*1.0mm 2 7.2) DIMMING WIRE (VDE 3*0.5mm 2 6.3) V+(BROWN) V-(BLUE) AC/L(BROWN) AC/N(BLUE) GND (YELLOW/GREEN) BLACK/WHITE PURPLE GRAY Tc OUTPUT(VDE H05RN-F 2*1.0mm 2 6.8) PROJ: Unspecified tolerance:±1 Others INPUT (VDE H05RN-F3*1.0mm 2 7.2) DIMMING WIRE (VDE 3*0.5mm 2 6.3) AC/L(BROWN) AC/N(BLUE) GND (YELLOW/GREEN) V+(BROWN) V-(BLUE) BLACK/WHITE PURPLE GRAY Tc OUTPUT(VDE H05RN-F 2*1.0mm 2 6.8) PROJ: Unspecified tolerance:±1 Note: Waterproof connectors certified to CCC & CE are also available for these drivers; please contact Inventronics Sales. RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 13 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDV 240W Programmable IP67 Driver Rev. D Revision History Description of Change Change Date Rev. 2016-02-29 A 2016-04-08 2017-08-02 2017-10-26 Item B C D From To Datasheets Release General Specifications With mounting ear Added Safety &EMC Compliance / Updated Mechanical Outline / Updated Input Specifications PF/THD Updated Output Specifications Temperature Coefficient of Ioset Updated General Specifications Dimensions Updated Safety &EMC Compliance / Updated Mechanical Outline / Updated Features 7 Years Warranty Added Operating Case Temperature / for Warranty Tc_w Updated 14 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUG-240S420DV
物料型号: EUG-240SxxxDV
器件简介: - 240W恒流可编程LED驱动器 - 适用于高杆灯、高杆灯、体育馆和道路照明 - 高效率和紧凑的金属外壳设计,提高可靠性和延长产品寿命
引脚分配: 未在文档中明确列出,但提到了输入和输出接线规格。
参数特性: - 超高效率(高达94%) - 宽输出电流范围内的全功率(恒功率) - 可调输出电流范围 - 输入浪涌保护:6kV线对线,10kV线对地 - 全方位保护:过压保护、短路保护、过温保护
功能详解: - 防水(IP67) - 安全低压(SELV)输出 - 适合独立使用 - 7年保修期
应用信息: - 适用于高杆、高杆、体育馆和道路照明
封装信息: - 尺寸:8.35x2.66x1.56英寸(212x67.5x39.7毫米) - 净重:1200克
其他特性: - CE和CB认证 - 多种调光选项:0-5V/0-10V/PWM/定时器调光 - 7年保修
EUG-240S420DV 价格&库存
很抱歉,暂时无法提供与“EUG-240S420DV”相匹配的价格&库存,您可以联系我们找货
