CNV-SNAP-AN0
Rev. A
Wireless 0-10V Dimming Controller for Synapse Networks
Features
For Use with Synapse SNAP Mesh Networks, to Control
One or More Inventronics Controls Ready Drivers
Powered by Inventronics Always On 12V Auxiliary
Supply
Uses Driver Dim-to-Off Capability to Eliminate AC Switch
or Relay
Commissioned Using Synapse SimplySNAP
Radio: SNAP 2.4GHz; 802.15.4
Range: approx. 400 Feet/100 Meters
Convenient Mounting: Outside a Junction Box or
Luminaire Secured by a Single Nut
Suitable for Direct Sunlight Applications
IP66, and UL Dry/Damp/Wet Location rated
Flame Class: 5VA
Description
The CNV-SNAP-AN0 is a self-contained, wireless network interface module that enables one or more
Inventronics LED drivers to be controlled by Synapse Lighting Control networks. Synapse wireless control can
be used for both indoor and outdoor lighting systems. Powered by compatible LED drivers, its compact design
and flexible deployment options make it ideal for placement in a wide array of luminaires.
1/6
Specifications are subject to changes without notice.
www.inventronics-co.com
Tel: 86-571-56565800
Fax: 86-571-86601139
sales@inventronics-co.com
CNV-SNAP-AN0
Rev. A
Synapse SimplySNAP
SimplySNAP is a site-based solution for monitoring and controlling LED lights via an encrypted, self-forming,
self-healing, 802.15.4 SNAP® mesh network. The network doesn’t require internet access, and allows for
system setup and configuration through a mobile-friendly Wi-Fi or LAN-accessible interface. The system stores
power data, alarms, and critical events locally for maintenance and troubleshooting, and provides California Title
24 compliant daily schedules for multiple dimming levels. With programmable schedules and easy setup,
SimplySNAP is the perfect solution for remote sites where internet access is difficult; you just configure it and it
runs. Easy access from a laptop or tablet means your system can be reconfigured whenever needed.
No Internet Required – All control is site based
Android App for commissioning and control
Each controller's location can be stored and displayed on a map
Multiple zones, scenes, sensors, events, and weekly schedule
Data and events are stored on the local site controller
Multiple user login levels for specialized control scenarios
Models
P/N
CNV-SNAP-AN0
Connection to LED Driver
Connection to Synapse System
UL Wire(black/white, purple, gray)
SNAP Mesh Network
Input Specifications
Parameter
Vaux Voltage
Min.
Typ.
Max.
5V
12 V
24 V
60 mA
Min.
Typ.
Max.
Iaux (Vaux Current) at 12V
Notes
Support the maximum output current of
LED driver to 100%Io
0.7W Max.
General Specifications
Parameter
Notes
Dimensions
Inches (L × W × H)
Millimeters (L × W × H)
3.62 x 2.71 x 1.14
92 x 69 x 29
Net Weight
Without the bracket
235 g
With the bracket and nut
Note: All specifications are typical at 25C unless stated otherwise.
Environmental Specifications
Parameter
Min.
Typ.
Max.
Operating Temperature
-40 C
+70 C
Storage Temperature
-40 C
+85 C
Notes
Humidity: 5% RH to 100% RH
2/6
CNV-SNAP-AN0
Rev. A
Dimming Specifications
Parameter
Dim+ Voltage
Dim+ Sink Current
Min.
Typ.
Max.
0V
10 V
0 mA
10 mA
Notes
Radio Specifications
+20 dBm Transmit Power
-103 dBm Receive Sensitivity
Safety & EMC Compliance
Safety Category
UL/CUL
CE
Standard
UL8750,CAN/CSA-C22.2 No. 250.13
EN 61347-2-11, EN 61347-1, EN 62479, ETSI EN 300 220-1 V2.4.1, ETSI EN 300
220-2 V2.4.1, ETSI EN 301 489-1 V1.9.2, ETSI EN 301 489-3 V1.6.1
EMI Standards
EN 55022(1)
Notes
Conducted emission Test & Radiated emission Test
ANSI C63.4 Class B
This device complies with Part 15 of the FCC Rules. Operation is subject to the
FCC Part 15(1)
following two conditions: [1] this device may not cause harmful interference, and [2]
this device must accept any interference received, including interference that may
cause undesired operation.
EMS Standards
Notes
EN 61000-4-2
Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge
EN 61000-4-3
Radio-Frequency Electromagnetic Field Susceptibility Test-RS
Note: (1) The CNV-SNAP-AN0 is considered as a component that will be operated in combination with final equipment.
since EMI performance without the bracket will be affected by the complete installation, the final equipment
manufacturers must re-qualify EMI Directive on the complete installation again.
Function Definition of Interface (Connection to LED Driver)
Wire Color
Name
Description
BLACK/WHITE
Vaux
Input from driver’s 12V auxiliary power
PURPLE
Dim+
The dimming signal output to control the
driver
3/6
CNV-SNAP-AN0
Rev. A
Function Definition of Interface (Connection to LED Driver)(Continued)
Wire Color
GRAY
Name
Description
Return for auxiliary power and dimming
signal
Return
Wiring
1:1 Wiring Diagram
1: Many Wiring Diagram
Operation Notes
For more operation details, check https://help.synapsewireless.com/
Compatible Driver List
Compatible driver list please refer to the: CNV-SNAP-AN0 Compatible List
4/6
CNV-SNAP-AN0
Rev. A
Mechanical Outline
DIMMING WIRE (UL 21996 3*22 AWG 5.0)
BLACK/WHITE
PURPLE
GRAY
PROJ:
Unspecified tolerance:¡ À
1
RoHS Compliance
Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other
hazardous substances from electronic products.
5/6
CNV-SNAP-AN0
Rev. A
Revision History
Description of Change
Change
Date
Rev.
2018-04-12
A
Item
From
Datasheet Release
To
6/6
很抱歉,暂时无法提供与“CNV-SNAP-AN0”相匹配的价格&库存,您可以联系我们找货
